楼主 # 2023-11-22 14:51:39
EKE
已发帖子: 28
荔枝派识别不到TFka
eke@eke-virtual-machine:~/linux/tools/u-boot$ df -h
文件系统        容量  已用  可用 已用% 挂载点
udev            1.9G   28K  1.9G    1% /dev
tmpfs           391M  1.7M  389M    1% /run
/dev/sda1        40G  9.8G   28G   27% /
tmpfs           2.0G     0  2.0G    0% /dev/shm
tmpfs           5.0M  4.0K  5.0M    1% /run/lock
tmpfs           2.0G     0  2.0G    0% /sys/fs/cgroup
/dev/loop1       41M   41M     0  100% /snap/snapd/20290
/dev/loop2       92M   92M     0  100% /snap/gtk-common-themes/1535
/dev/loop3      497M  497M     0  100% /snap/gnome-42-2204/141
/dev/loop5       56M   56M     0  100% /snap/core18/2796
/dev/loop6      219M  219M     0  100% /snap/gnome-3-34-1804/72
/dev/loop7      128K  128K     0  100% /snap/bare/5
/dev/loop4      512K  512K     0  100% /snap/gnome-characters/795
/dev/loop0      1.7M  1.7M     0  100% /snap/gnome-system-monitor/186
/dev/loop8      242M  242M     0  100% /snap/gnome-3-38-2004/70
/dev/loop9      2.5M  2.5M     0  100% /snap/gnome-calculator/884
/dev/loop10      66M   66M     0  100% /snap/gtk-common-themes/1515
/dev/loop11      62M   62M     0  100% /snap/core20/1081
/dev/loop12      74M   74M     0  100% /snap/core22/864
/dev/loop13      56M   56M     0  100% /snap/core18/2128
/dev/loop15     350M  350M     0  100% /snap/gnome-3-38-2004/143
/dev/loop14     2.3M  2.3M     0  100% /snap/gnome-calculator/955
/dev/loop16     768K  768K     0  100% /snap/gnome-characters/726
/dev/loop17     219M  219M     0  100% /snap/gnome-3-34-1804/93
/dev/loop18     896K  896K     0  100% /snap/gnome-logs/121
/dev/loop19      64M   64M     0  100% /snap/core20/2015
/dev/loop20     640K  640K     0  100% /snap/gnome-logs/106
/dev/loop21     2.5M  2.5M     0  100% /snap/gnome-system-monitor/163
tmpfs           391M   28K  391M    1% /run/user/1000
/dev/sr0        2.4G  2.4G     0  100% /media/eke/Ubuntu 18.04.6 LTS amd64
楼主 #1 2023-11-22 14:52:24
EKE
已发帖子: 28
Re: 荔枝派识别不到TFka
TF卡是插在USB口旁边的
楼主 #2 2023-11-22 14:53:06
EKE
已发帖子: 28
Re: 荔枝派识别不到TFka
有没有大神知道是咋回事,感谢!
楼主 #3 2023-11-25 18:32:28
EKE
已发帖子: 28
Re: 荔枝派识别不到TFka
更换14.04之后,按照教程重新走一遍,已能识别到TF卡
楼主 #4 2023-11-25 18:33:04
EKE
已发帖子: 28
Re: 荔枝派识别不到TFka
eke@eke-ThinkPad-T540p:~/linux/linux-zero$ ls /dev/sd*
/dev/sda   /dev/sda2  /dev/sda6  /dev/sda8  /dev/sdb
/dev/sda1  /dev/sda5  /dev/sda7  /dev/sda9  /dev/sdb1
