楼主 #1 2018-09-22 10:10:05
john78
已发帖子: 223
V3S SPI FLASH 启动起来了,但还有坑
Starting logging: OK
Jan  1 00:13:39 buildroot syslog.info syslogd started: BusyBox v1.26.2
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] Booting Linux on physical CPU 0x0
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000] Linux version 4.13.16-licheepi-zero-with-800x480-lcd+ (root@ubuntu) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1)) #5 SMP Sat Sep 22 09:47:53 +08 2018
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] CPU: div instructions available: patching division code
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] Memory policy: Data cache writealloc
Jan  1 00:13:39 buildroot user.debug kernel: [    0.000000] On node 0 totalpages: 16009
Jan  1 00:13:39 buildroot user.debug kernel: [    0.000000] free_area_init_node: node 0, pgdat c0a35c80, node_mem_map c3e03000
Jan  1 00:13:39 buildroot user.debug kernel: [    0.000000]   Normal zone: 126 pages used for memmap
Jan  1 00:13:39 buildroot user.debug kernel: [    0.000000]   Normal zone: 0 pages reserved
Jan  1 00:13:39 buildroot user.debug kernel: [    0.000000]   Normal zone: 16009 pages, LIFO batch:3
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33920 r8192 d23424 u65536
Jan  1 00:13:39 buildroot user.debug kernel: [    0.000000] pcpu-alloc: s33920 r8192 d23424 u65536 alloc=16*4096
Jan  1 00:13:39 buildroot user.debug kernel: [    0.000000] pcpu-alloc: [0] 0
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 15883
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] Memory: 53580K/64036K available (6144K kernel code, 218K rwdata, 1456K rodata, 1024K init, 264K bss, 10456K reserved, 0K cma-reserved, 0K highmem)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000] Virtual kernel memory layout:
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]     vmalloc : 0xc4000000 - 0xff800000   ( 952 MB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xc3e89000   (  62 MB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]       .data : 0xc0a00000 - 0xc0a368c0   ( 219 kB)
Jan  1 00:13:39 buildroot user.notice kernel: [    0.000000]        .bss : 0xc0a3dafc - 0xc0a7fdfc   ( 265 kB)
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000] Hierarchical RCU implementation.
Jan  1 00:13:39 buildroot user.info kernel: [    0.000000]     RCU eveJan  1 00:13:39 buildroot user.info kernel: [    0.000453] CalibInitializing random number generator... done.
Starting network: ifup: can't open '/var/run/ifstate.new': No such file or directory
FAIL
Jan  1 00:13:39 buildroot daemon.info : starting pid 91, tty '/dev/console': '/sbin/getty -L  console 0 vt100 '
Welcome to Buildroot
buildroot login:
buildroot login: root
Jan  1 00:13:45 buildroot auth.info login[91]: root login on 'console'
# ls
#2 2018-09-22 10:20:15
已发帖子: 9,433
Re: V3S SPI FLASH 启动起来了,但还有坑
#pwd
#cd /
#ls
楼主 #3 2018-09-22 10:29:10
john78
已发帖子: 223
# pwd
/root
# cd /
# ls
[1;34mbin[0m      [1;34mlib[0m      [1;34mmedia[0m    [1;34mproc[0m     [1;34msbin[0m     [1;34musr[0m
[1;34mdev[0m      [1;36mlib32[0m    [1;34mmnt[0m      [1;34mroot[0m     [1;34msys[0m      [1;34mvar[0m
[1;34metc[0m      [1;36mlinuxrc[0m  [1;34mopt[0m      [1;34mrun[0m      [1;34mtmp[0m
#4 2018-09-22 10:47:06
已发帖子: 9,433
可以了。
但是你这个串口终端太坑了,换 putty, mobaxterm 等功能强大的吧 。
楼主 #5 2018-09-22 10:49:07
john78
已发帖子: 223
# ls
bin      lib      media    proc     sbin     usr
dev      lib32    mnt      root     sys      var
etc      linuxrc  opt      run      tmp
楼主 #6 2018-09-22 10:52:41
john78
已发帖子: 223
FAIL
# cd /var
# ls
www
# cd /dev
缺少的这个和哪个设置相关?
#7 2018-09-22 10:59:38
已发帖子: 9,433
ifconfig eth0 up
ifconfig eth0 192.168.1.99
用这个命令,你用的可能是脚本,脚本又访问了文件,刚好你的文件又没有,就出警告了。
楼主 #8 2018-09-22 14:07:47
john78
已发帖子: 223
ifconfig eth0 up
这个可以了,后续再查哪个脚本。
#9 2024-04-18 15:33:29
wcq669
这个芯片可以配置到1280X640的分辨率显示吗?
