楼主 # 2022-11-03 13:37:21
Frankie.Yao
V3S RTC problem
哪位大神帮看看V3S RTC这程序是否正确?为保时钟差这么大?(32768-32000)/32768->2.34%
 * This RTC count flow on sun8iw8 platform.
 * 32.768KHz---   --- [32768 count] ---
 *              \/                     \___[seconds reg]
 * 32KHz    ---   --- [32000 count] ---
 * We can calculate how much seconds missing, call sunxi_rtc_fixup.
void sunxi_rtc_fixup(unsigned long long*org_time, unsigned long long *time)
    unsigned long long delta;
    unsigned long long t1, t2;
    bool out;
    if (!time)
        return;
    if (!org_time)
        t1 = (unsigned long long)(V3S_RTC->GP_DATA[6]&(~0x80000000)) << 32; /*readl( base + SUNXI_GPDATA_REG(6))*/
        t1 |= (unsigned long)V3S_RTC->GP_DATA[7]; /*readl( base + SUNXI_GPDATA_REG(7))*/
        t1 = *org_time;
    t2 = *time;
    out = V3S_RTC->LOSC_CTRL & SUN6I_LOSC_CTRL_EXT_OSC; //if used external 32768Hz oscillator
    delta = (t2 > t1) ? (t2 - t1) : (t1 - t2);
    delta = (delta * (OSC_ORG - OSC_32K)) / OSC_ORG;
    if (out)
        *time -= delta;
        *time += delta;
#1 2023-12-12 13:23:50
memory
已发帖子: 331
Re: V3S RTC problem
RTC那个我改了半天驱动,也查了资料,估计是V3s的一个bug,开机后强制把晶振切到了24M分频出来的32000Hz。
现在我能想到的办法,每N秒钟把系统时间写入RTC
#2 2023-12-12 17:02:38
memory
已发帖子: 331
Re: V3S RTC problem
找了半天,原来是 linux3.4里面的 rtc-sunxi.c 驱动,居然硬件上面还有 2033年千年虫,额滴神
     * Sorry, sunxi hardware max time is 2033 year.
    if( rtc_valid_tm(tm) || (tm->tm_year + 1900) > 2033) {
        dev_err(dev, "Alarm time is invalid, tm->tm_year:%d\n", tm->tm_year);
        if ((tm->tm_year + 1900) > 2033) {
            printk(KERN_WARNING "The process is \"%s\" (pid %i)\n", current->comm, current->pid);
            tm->tm_year = 132;
#3 2023-12-13 17:43:34
伍零壹
已发帖子: 158
Re: V3S RTC problem
2033这个和你RTC时钟不准 应该没关系吧!你这RTC是主时钟分频得到的还是外置了32768的时钟?如果是外置时钟,有可能是你晶振的匹配电容有问题。
#4 2023-12-14 09:12:41
musich
已发帖子: 238
Re: V3S RTC problem
接近300uA的耗电, 这个RTC意义不大,
