楼主 # 2023-12-18 13:10:20
bigzhu
已发帖子: 24
T113-s3 使用awboot启动不了kernel
各种尝试,现在开始整awboot。
问题:kernel zImage是从Tina linux里面拿过来的,可以使用uboot正常启动。为啥使用awboot启动就异常了?
log如下
[I] AWBoot r6165 starting...
[D] DRAM BOOT DRIVE INFO: V0.24
[D] DRAM CLK = 792 MHz
[D] DRAM Type = 3 (2:DDR2,3:DDR3)
[D] DRAMC read ODT off
[D] ZQ value = 0x30
[D] DDR efuse: 0xa
[D] chip id efuse: 0x6000
[D] single rank and full DQ
[D] DDR efuse: 0xa
[D] rank 0 row = 13
[D] para->dram_para1 = 0x10d2
[D] rank 0 bank = 8
[D] rank 0 page size = 2 KB
[D] DRAM ODT value: 0x42
[D] DDR efuse: 0xa
[D] DRAM: size = 128MB
[D] DRAM: simple test OK
[D] CLK: CPU PLL=PLL_CPU FREQ=1200MHz
[D] CLK: PLL_peri (2X)=1200MHz, (1X)=600MHz, (800M)=800MHz
[D] CLK: PLL_ddr=1584MHz
[D] DMA: init
[D] DMA: test OK in 24ms
[D] SPI: init
[D] SPI: set clock asked=100MHz actual=100MHz mclk=200MHz
[I] SPI-NAND: W25N01GV detected
[D] SPI-NAND: dt blob: Copy from 0x00040000 to 0x44000000 size:0x0000dc73
[I] SPI-NAND: read dt blob of size 56435 at 47.00MB/S
[D] SPI-NAND: Image: Copy from 0x00080000 to 0x44800000 size:0x003e03f8
[I] SPI-NAND: read Image of size 4064248 at 49.00MB/S
[I] booting linux...
[    0.000000] Linux version 5.4.61 (root@a3715198cb35) (arm-openwrt-linux-muslgnueabi3
[    0.000000] OF: fdt: Machine model: sun8iw20
[    0.000000] printk: bootconsole [earlycon0] enabled
[    0.000000] cma: Reserved 16 MiB at 0x47000000
[    0.000000] On node 0 totalpages: 32768
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] Bad mode in prefetch abort handler detected
[    0.000000] Internal error: Oops - bad mode: 0 [#1] PREEMPT SMP ARM
[    0.000000] Modules linked in:
[    0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 5.4.61 #54
[    0.000000] Hardware name: Generic DT based system
[    0.000000] PC is at 0xfff7fdc8
[    0.000000] LR is at __invoke_psci_fn_smc+0x40/0x60
[    0.000000] pc : [<fff7fdc8>]    lr : [<c04c03f4>]    psr: 600001d6
[    0.000000] sp : c0a01e98  ip : c0a01ef0  fp : c6ffff40
[    0.000000] r10: c0a0df8c  r9 : c0b51c98  r8 : c0a00000
[    0.000000] r7 : 00000000  r6 : 00000000  r5 : 00000000  r4 : 00000000
[    0.000000] r3 : 00000000  r2 : 00000000  r1 : 00000000  r0 : 84000000
[    0.000000] Flags: nZCv  IRQs off  FIQs off  Mode MON_32  ISA ARM  Segment none
[    0.000000] Control: 10c5387d  Table: 4000406a  DAC: c0a00000
[    0.000000] Process swapper (pid: 0, stack limit = 0x(ptrval))
[    0.000000] Stack: (0xc0a01e98 to 0xc0a02000)
[    0.000000] 1e80:                                                       84000000 000
[    0.000000] 1ea0: 00000000 00000000 00000000 00000000 00000000 00000000 c0a00000 c08
[    0.000000] 1ec0: c0a0df8c c6ffff40 c0a01ef0 c0a01e98 c04c03f4 fff7fdc8 600001d6 fff
[    0.000000] 1ee0: c0a00000 00000000 c0a4b180 c0a06d80 00000000 00000000 00000000 000
[    0.000000] 1f00: c0a01f0c 00000000 c0a4b180 c04c064c c4000914 00000000 00000001 000
[    0.000000] 1f20: c0a00000 c09180e0 c0a00000 c6ece450 c0a4b180 c0a06d80 c0a00000 c08
[    0.000000] 1f40: c0a00000 c09184f4 c092e360 00000000 00000000 c09238fc c0a08218 c04
[    0.000000] 1f60: ffffffff 10c5387d 40000000 c083bdec c0a03dc0 c0a4b000 410fc075 10d
[    0.000000] 1f80: 00000000 c01552b8 c07cd9bd 00000000 00000001 c0900330 c0a00000 10d
[    0.000000] 1fa0: c0a03dc0 c0a4b000 410fc075 10c5387d 00000000 c0900974 00000000 000
[    0.000000] 1fc0: 00000000 00000000 00000000 c09270c0 00000000 00000000 c0900330 001
[    0.000000] 1fe0: 10c0387d ffffffff 44000000 410fc075 10c5387d 00000000 00000000 000
[    0.000000] [<c04c03f4>] (__invoke_psci_fn_smc) from [<c0a01e98>] (0xc0a01e98)
[    0.000000] Code: bad PC value
[    0.000000] random: get_random_bytes called from init_oops_id+0x20/0x40 with crng_i0
[    0.000000] ---[ end trace 0000000000000000 ]---
[    0.000000] Kernel panic - not syncing: Attempted to kill the idle task!
[    0.000000] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]-
#1 2023-12-20 22:23:58
zzm24
已发帖子: 126
Re: T113-s3 使用awboot启动不了kernel
awboot非常简单,他启动主线kernel可以,启动Tina够呛,uboot会编辑dts,设置smp,设置cortex A7时钟等,这些awboot都做不了。要awboot启动Tina,只能分析uboot对Tina具体干了什么,并添加进awboot。
楼主 #2 2023-12-25 11:26:30
bigzhu
已发帖子: 24
zzm24 说:
原来如此,非常感谢!
#3 2024-03-29 15:08:10
dsp2000
已发帖子: 28
大佬们现在有进展吗?也碰到相同的问题
#4 2024-03-30 22:06:28
vigour1000
已发帖子: 101
kernel 设备树中或内核配制选项 删除对smp PSI总线支持,第二个核另外写代码
