楼主 # 2024-01-02 17:21:05
zm
搞了一个T113S3裸机代码(copy xboot和awboot),遇到定时器中断一直触发不了。。。
手上有一块t113-s3 麻雀开发板,自己焊了norflash(怕nand flash出现坏块搞不定。。。),想试试能不能自己移植freertos在t113上跑,先打算实现裸机正常运行和中断正常运行。目前可以正常的打印,定时器也正常计数,就是无法触发中断,本人小白,花了一段时间,实在找不出问题,只能把源码贴出来了,希望有大佬帮忙看看。。
log:
dram start
dram init ok
welcome to T113s3
now run in security
[D] CLK: CPU PLL=PLL_CPU FREQ=1200MHz
[D] CLK: PLL_peri (2X)=1200MHz, (1X)=600MHz, (800M)=800MHz
[D] CLK: PLL_ddr=1584MHz
gic_base address is 0x3020000
gic irqs supported is 224
0)  current val = 0
1)  current val = 22779507
2)  current val = 21555507
3)  current val = 20331507
4)  current val = 19107507
5)  current val = 17883507
6)  current val = 16659507
7)  current val = 15435507
8)  current val = 14211506
9)  current val = 12987506
10)  current val = 11763507
11)  current val = 10539507
12)  current val = 9315507
13)  current val = 8091507
14)  current val = 6867506
15)  current val = 5643506
16)  current val = 4419507
17)  current val = 3195507
18)  current val = 1971507
19)  current val = 747506
20)  current val = 23523507
#include "debug.h"
#include "arch_timer/arch_timer.h"
#include "timer/timer.h"
#include "gic400/gic400.h"
#include "gic400/t113_irq.h"
#include "t113_clk/sunxi_clk.h"
#include "arm32.h"
#include "bit_ops.h"
static void timer0_irq_handler(void * data);
static void timer1_irq_handler(void * data);
int main(void)
    u32 cur_val = 0;
    u32 scr;
    message("welcome to T113s3\r\n");
    scr = arm32_read_scr_ns();
    if(GET_BIT(scr,0))//获取SCR.NS位,如果是0则是安全模式,如果是1则是非安全模式
        message("now run in non_security\r\n");
        message("now run in security\r\n");
    sunxi_clk_dump();
    start_gic();
    register_irq(T113_IRQ_TIMER1,timer1_irq_handler,NULL,(30 << 3),3);
    start_ms_timer(TIMER1,1000);
    int i = 0;
    while(1)
        cur_val = get_current_timer_value(TIMER1);
        message("%d)  current val = %d \r\n",i,cur_val);
        mdelay(50);
        i ++;
    //清中断
    clear_timern_irq(TIMER0);
    message("timer0 irq get \r\n");
    //清中断
    clear_timern_irq(TIMER1);
    message("timer1 irq get \r\n");
GIC部分代码:
#include "io.h"
#include "smp.h"
#include "debug.h"
enum {
	DIST_CTRL 			= 0x1000,
	DIST_CTR 			= 0x1004,
	DIST_IIDR           = 0X1008,
	DIST_IGROUPRn       = 0x1080,
	DIST_ENABLE_SET 	= 0x1100,
	DIST_ENABLE_CLEAR 	= 0x1180,
	DIST_PENDING_SET 	= 0x1200,
	DIST_PENDING_CLEAR	= 0x1280,
	DIST_ACTIVE_BIT		= 0x1300,
	DIST_PRI			= 0x1400,
	DIST_TARGET			= 0x1800,
	DIST_CONFIG			= 0x1c00,
	DIST_SOFTINT		= 0x1f00,
	CPU_CTRL 			= 0x2000,
	CPU_PRIMASK 		= 0x2004,
	CPU_BINPOINT 		= 0x2008,
	CPU_INTACK 			= 0x200c,
	CPU_EOI 			= 0x2010,
	CPU_RUNNINGPRI 		= 0x2014,
	CPU_HIGHPRI 		= 0x2018,
}GIC_REG_NUM;
#define FGicPs_PRIORITY_OFFSET_CALC(InterruptID) \
	((u32)DIST_PRI + (((InterruptID)/4U) * 4U))
#define FGicPs_INT_CFG_OFFSET_CALC(InterruptID) \
	((u32)DIST_CONFIG + (((InterruptID)/16U) * 4U))
u32 read_gicd_pri(int int_id)
	return read32(T113_GIC_400_BASE + FGicPs_PRIORITY_OFFSET_CALC(int_id));
void write_gicd_pri(int int_id, u32 val)
	write32(T113_GIC_400_BASE + FGicPs_PRIORITY_OFFSET_CALC(int_id),val);
u32 read_gicd_cfg(int int_id)
	return read32(T113_GIC_400_BASE + FGicPs_INT_CFG_OFFSET_CALC(int_id));
void write_gicd_cfg(int int_id, u32 val)
	write32(T113_GIC_400_BASE + FGicPs_INT_CFG_OFFSET_CALC(int_id),val);
#if 0
static  inline uint32_t arm32_get_gic_base(void)
	uint32_t value;
	__asm__ __volatile__(
		"mrc p15, 4, %0, c15, c0, 0"
		: "=r" (value)
		: "memory");
	return value;
void gic400_dist_init(void)
	u32_t gic_irqs;
	u32_t cpumask;
    u32_t gic_base = T113_GIC_400_BASE;
	int i;
	message("gic_base address is 0x%x \r\n",gic_base);
	write32(gic_base + DIST_CTRL, 0x0);
	 * Find out how many interrupts are supported.
	 * The GIC only supports up to 1020 interrupt sources.
	gic_irqs = read32(gic_base + DIST_CTR) & 0x1f;
	gic_irqs = (gic_irqs + 1) * 32;
	message("gic irqs supported is %d \r\n",gic_irqs);
	if(gic_irqs > 1020)
		gic_irqs = 1020;
	 * Set all global interrupts to this CPU only.
	cpumask = 1 << smp_processor_id();
	cpumask |= cpumask << 8;
	cpumask |= cpumask << 16;
	for(i = 32; i < gic_irqs; i += 4)
		write32(gic_base + DIST_TARGET + (i / 4 )* 4, cpumask);
	 * Set all global interrupts to be level triggered, active low.
	for(i = 32; i < gic_irqs; i += 16)
		write32(gic_base + DIST_CONFIG + (i /16) * 4 , 0);
	 * Set priority on all global interrupts.
		write32(gic_base + DIST_PRI + (i / 4) * 4, 0xa0a0a0a0);
	 * Disable all interrupts, leave the SGI and PPI alone
	 * as these enables are banked registers.
	for(i = 32; i < gic_irqs; i += 32)
		write32(gic_base + DIST_ENABLE_CLEAR + (i / 32) * 4, 0xffffffff);
	//将所有中断设为group0
	for(i = 32 ; i < gic_irqs; i += 32)
		write32(gic_base + DIST_IGROUPRn + (i / 32) * 4, 0x0);
	write32(gic_base + DIST_CTRL, 0x1);
void gic400_cpu_init(void)
	int i;
	 * Deal with the banked SGI and PPI interrupts - enable all
	 * SGI interrupts, ensure all PPI interrupts are disabled.
	write32(gic_base + DIST_ENABLE_CLEAR, 0xffff0000);
	write32(gic_base + DIST_ENABLE_SET, 0x0000ffff);
	 * Set priority on SGI and PPI interrupts
	for(i = 0; i < 32; i += 4)
		write32(gic_base + DIST_PRI + ( i / 4 ) * 4, 0xa0a0a0a0);
	write32(gic_base + CPU_PRIMASK, 0xf0);
	write32(gic_base + CPU_CTRL, 0x1);
void irq_gic400_enable(int irq) //unmask对应中断
	write32(T113_GIC_400_BASE + DIST_ENABLE_SET + (irq / 32) * 4, 1 << (irq % 32));
void irq_gic400_disable(int irq)//mask对应中断
	write32(T113_GIC_400_BASE + DIST_ENABLE_CLEAR + (irq / 32) * 4, 1 << (irq % 32));
void irq_gic400_settype(void)
void irq_gic400_dispatch(void)//处理中断后清除中断标志
	int irq = read32(T113_GIC_400_BASE + CPU_INTACK) & 0x3ff;
    irq_gic400_disable(irq);
    do_handler(irq);
    write32(T113_GIC_400_BASE + CPU_EOI, irq);//清除中断
	irq_gic400_enable(irq);
void gic_interrupt_handle_exception(void* regs)
    irq_gic400_dispatch();
void start_gic(void)
    gic400_dist_init();
    gic400_cpu_init();
register_irq:
bool_t register_irq(int irq,void (*func)(void *), void * data, u8 Priority, u8 trigger)
    u32 val;
    u8 LocalPriority;
    if(!func)
		return FALSE;
    if(irq_hanlder_arry[irq].func != null_interrupt_function)
        return FALSE;
    irq_hanlder_arry[irq].func = func;
    irq_hanlder_arry[irq].data = data;
    // val = read_gicd_pri(irq);
    // LocalPriority = LocalPriority & (u8)(0x000000F8U);
    // val &= ~(0x000000FFU << ((irq%4U)*8U));
	// val |= (u32)LocalPriority << ((irq%4U)*8U);
    // write_gicd_pri(irq,val);
    // val = read_gicd_cfg(irq);
    // val &= ~(0x00000003U << ((irq%16U)*2U));
	// val |= (u32)trigger << ((irq%16U)*2U);
  //  write_gicd_cfg(irq,val);
    arm32_interrupt_enable();
    return TRUE;
定时器部分
enum {
	TMR_IRQ_EN_REG 		       =0x0000	,
	TMR_IRQ_STA_REG 		   =0x0004  ,
	TMR0_CTRL_REG 	           =0x0010  ,
	TMR0_INTV_VALUE_REG 	   =0x0014  ,
	TMR0_CUR_VALUE_REG 	       =0x0018,
	TMR1_CTRL_REG              =0x0020  ,
    TMR1_INTV_VALUE_REG        =0x0024,
    TMR1_CUR_VALUE_REG         =0x0028,
}TIMER_REG_OFFSET;
#define Timer_Periodic_mode 0
#define Timer_Single_mode   1
//a &= ~(数值<<每组位数*组编号) :将连续几位清零的方法
//数值表示一组中每个bit都是1的情况下的值,比如组位数是2,则数值就是11b所代表的值,即3
//组编号是给寄存器多少个bit为1组进行分组,组号从0开始
void timern_init(int timer_id,  int timing_mode) //时钟频率为24000000/2
    u32 addr,val;
    if(timer_id == 0)
        addr = TIMER_BASE + TMR0_CTRL_REG;
        addr = TIMER_BASE + TMR1_CTRL_REG;
    if(timing_mode == Timer_Periodic_mode)
        val = (u32)0x14;
        val = (u32)0x94;
    write32(addr,val);
void set_timern_interval_value(int timer_id, u32 value)
    u32 addr,val;
    val = value;
    if(timer_id == 0)
        addr = TIMER_BASE + TMR0_INTV_VALUE_REG;
        addr = TIMER_BASE + TMR1_INTV_VALUE_REG;
    write32(addr,val);//设置间隔值
void load_timern_interval_value(int timer_id)
    u32 addr,val;
    if(timer_id == 0)
    write32(addr, read32(addr)|(1<<1)); //Set the Reload bit
void start_timer(int timer_id)
    u32 addr,val;
    if(timer_id == 0)
    val	 = read32(addr);
    val |= (0x1 << 0);
    write32(addr,val);
void start_ms_timer(int timer_id,u32 ms)
    u32 value = (24000 * ms);
    u32 addr;
    enable_timern_irq(timer_id);
    set_timern_interval_value(timer_id,value);
    timern_init(timer_id, Timer_Periodic_mode);
    load_timern_interval_value(timer_id);
    if(timer_id == 0)
    while((read32(addr)>>1)&1);
    start_timer(timer_id);
void enable_timern_irq(int timer_id)
    u32 addr,val;
    addr = TIMER_BASE + TMR_IRQ_EN_REG;
    if(timer_id == 0)
         val = read32(addr);
         val |= (1 << 0);
         val = read32(addr);
         val |= (1 << 1);
    write32(addr,val);
    addr = TIMER_BASE + TMR_IRQ_STA_REG;
    if(timer_id == 0)
        val = read32(addr);
        val |= (1 << 0);
        val = read32(addr);
        val |= (1 << 1);
    write32(addr,val);
void clear_timern_irq(int timer_id)
    u32 addr,val;
    if(timer_id == 0)
         val = read32(addr);
         if( (val & 0x01))
            val |= (1 << 0);
         val = read32(addr);
         if((val & 0x2))
            val |= (1 << 1);
    write32(addr,val);
u32 get_current_timer_value(int timer_id)
    u32 addr,val;
     if(timer_id == 0)
        addr = TIMER_BASE + TMR0_CUR_VALUE_REG;
        addr = TIMER_BASE + TMR1_CUR_VALUE_REG;
    val = read32(addr);
    return val;
完整代码工程似乎传不上了,有兴趣的可以私聊
最近编辑记录 zm (2024-01-02 17:34:49)
#1 2024-01-03 15:00:57
musich
已发帖子: 253
Re: 搞了一个T113S3裸机代码(copy xboot和awboot),遇到定时器中断一直触发不了。。。
瞎猜一个, 其它中断有正常的没? 或任意开一个其它中断试试.
若能中断就是timer部分配置问题, 反之就是系统中断问题.
大概率是系统中断没弄好.
#2 2024-01-09 21:59:43
eagletskt
我也正在T113S3上搞rtos,一堆的坑呐,想跟楼主交流
楼主 #3 2024-01-10 10:45:01
zm
总算搞定中断了,发现还是前面gic初始化出问题了,哎,心累  sad
dram start
dram init ok
welcome to T113s3
now run in security
sys tick handler get
下面开始移植freertos,开搞!!
楼主 #5 2024-01-12 14:23:21
zm
freertos 初步移植成功,用的freertos版本是10.0.0,目前只验证了多任务运行,运行正常!
[I] AWBoot r51 starting...
[D] DRAM BOOT DRIVE INFO: V0.24
[D] DRAM CLK = 792 MHz
[D] DRAM Type = 3 (2:DDR2,3:DDR3)
[D] DRAMC read ODT off
[D] ZQ value = 0x12e
[D] DDR efuse: 0xa
[D] chip id efuse: 0x6000
[D] single rank and full DQ
[D] DDR efuse: 0xa
[D] rank 0 row = 13
[D] para->dram_para1 = 0x10d2
[D] rank 0 bank = 8
[D] rank 0 page size = 2 KB
[D] DRAM ODT value: 0x42
[D] DDR efuse: 0xa
[D] DRAM: size = 128MB
[D] DRAM: simple test OK
[D] DMA: init
[T] DMA: test 0x44000000 ====> 0x44800000, len 512KB
[T] DMA: provide channel 0
[D] DMA: test OK in 59ms
[T] SPI: parent_clk=600MHz, div=3, n=1, m=3
[T] SPI: CDR2 - n = 0
[T] SPI: clock div=0
[D] SPI: set clock asked=100MHz actual=100MHz mclk=200MHz
[T] SPI: tsfr mode=0 tx=1 rx=0
[T] SPI: ISR=0x1032
[T] SPI: tsfr mode=0 tx=1 rx=1
[T] SPI: ISR=0x1033
[T] SPI: tsfr mode=0 tx=1 rx=4
[T] SPI: ISR=0x1033
[I] SPI-NOR: MFR:0xEF DEV:0x4019
[T] SPI: tsfr mode=1 tx=5 rx=2097152
[T] SPI: ISR=0x1037
[I] SPI NOR: READ USER BIN TIME:89785uS
[I] ------BootLoader Jump Successed-----------
[D] welcome to T113s3
[D] timer0 irq is enable
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
后续打算研究一下t113s3的在线调试,想用openocd估计又是一个大坑~
#6 2024-01-26 10:22:34
tea74110
@zm
大佬你好,请问GIC初始化出问题了,具体是哪个问题呀。
#8 2024-04-03 11:27:13
lyy
@zm 大佬,我现在也遇到中断触发不了的问题了,能加个联系方式,聊一聊吗,已经自己做T113的裸机几个月了,问题很多呀
#9 2024-04-04 23:29:13
evilbinary
lyy 说:
已经实现t113-s,3裸奔,参考这个项目
https://github.com/evilbinary/duck/blob/main/platform/t113-s3/init.c#L97-L97
#10 2024-04-08 15:49:35
lyy
@evilbinary  这个代码里有中断吗,好像没找到
#11 2024-04-09 08:37:53
evilbinary
lyy 说:
有的你搜void interrupt_regist(u32 vec, interrupt_handler_t handler)
#12 2024-04-09 14:17:45
lyy
@evilbinary  我看到有中断处理函数void irq_handler() {
  // asm("msr   cpsr, #0xD2 \n");
  interrupt_entering_code(EX_IRQ, 0, 4);
  interrupt_process(interrupt_default_handler);
  interrupt_exit_ret();
}但是没看到startup.s文件,那是怎么通过向量表跳到中断函数的呢
#13 2024-04-10 09:20:18
evilbinary
跳转是cpu得功能啊,你只管配置好中断地址,中断地址看这个void interrutp_set(int i)
#14 2024-04-10 14:34:36
lyy
@evilbinary  我现在是参考的本版的一个iar工程弄的,可以仿真调试,但是看了你的程序,没看懂中断流程,不知道该怎么对照着改IAR工程
楼主 #15 2024-04-11 16:40:10
zm
lyy 说:
我没有使用IAR,但流程都差不多,工程我放在gitee仓库了,目前没实现啥功能,只是移植了freertos,可以跑任务,想要参考的话可以看看
https://gitee.com/zmzone/mangzai_freertos_kit/tree/master/
#16 2024-04-12 15:43:15
lyy
@zm  感谢,我参考了你的代码,初始化了start_gic(); 配置了串口中断,注册了串口中断函数register_irq(usart->irq_num, usart->handler,usart,15,1);
串口接收触发中断IRQ_Handler
        LDR     R0, =arm32_do_fiq
        BLX     R0    但是在s文件里运行到IRQ_Handler 后  不会跳转到arm32_do_fiq 中断处理函数,这个是什么原因呢,之后程序就跑死了
#17 2024-04-12 17:29:05
jxmlegend
已发帖子: 49
@lyy mmu关闭了吗
楼主 #18 2024-04-12 17:56:27
zm
@lyy
额,,首先为啥是fiq,我记得根本没用fiq,然后,如果你是跑了freertos的话,进入中断应该不是这段汇编吧,而是FreeRTOS_Asm_Vector.S里的汇编吧,建议再看看代码,最后,,串口中断目前我还没做,现在只是轮询
#19 2024-04-15 12:32:31
lyy
@jxmlegend  arm32_mmu_disable(); mmu关了
@zm fiq是写错了 是LDR     R0, =arm32_do_irq   ,然后我用的IAR的工程和startup.s文件,还没跑freertos,但是进中断向量表的流程应该是一样的吧,参考了你的gic初始化函数,以及中断注册函数,但是到startup.s汇编文件这里就出问题了
