楼主 # 2024-01-15 18:37:26
happy粥
兄弟们!请教个全志A20问题:内核启动报错panic - not syncing怎么解决啊?
始终报错 Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004。
打印信息在这
U-Boot 2021.04 (Jan 15 2024 - 11:33:30 +0800) Allwinner Technology
CPU:   Allwinner A20 (SUN7I)
Model: Cubietech Cubieboard2
I2C:   ready
DRAM:  1 GiB
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Setting up a 720x576i composite-pal console (overscan 32x20)
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   No ethernet found.
No working controllers found
7534840 bytes read in 633 ms (11.4 MiB/s)
25751 bytes read in 5 ms (4.9 MiB/s)
## Flattened Device Tree blob at 48000000
   Booting using the fdt blob at 0x48000000
   Loading Device Tree to 49ff6000, end 49fff496 ... OK
Starting kernel happy ...
[    0.000000][    T0] Booting Linux on physical CPU 0x0
[    0.000000][    T0] Linux version 5.15.0-rc5-Allwinner-Happy (happy@ubuntu) (arm-linux-gnueabihf-gcc (Linaro GCC 6.3-2017.05) 6.3.1 20170404, GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #33 SMP PREEMPT Mon Jan 15 17:33:19 CST 2024
[    0.000000][    T0] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
[    0.000000][    T0] CPU: div instructions available: patching division code
[    0.000000][    T0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000][    T0] OF: fdt: Machine model: Cubietech Cubieboard2
[    0.000000][    T0] printk: bootconsole [earlycon0] enabled
[    0.000000][    T0] Memory policy: Data cache writealloc
[    0.000000][    T0] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
[    0.000000][    T0] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
[    0.000000][    T0] Zone ranges:
[    0.000000][    T0]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
[    0.000000][    T0]   HighMem  [mem 0x0000000070000000-0x000000007fffffff]
[    0.000000][    T0] Movable zone start for each node
[    0.000000][    T0] Early memory node ranges
[    0.000000][    T0]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000][    T0] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000][    T0] percpu: Embedded 12 pages/cpu s18124 r8192 d22836 u49152
[    0.000000][    T0] pcpu-alloc: s18124 r8192 d22836 u49152 alloc=12*4096
[    0.000000][    T0] pcpu-alloc: [0] 0 [0] 1
[    0.000000][    T0] Built 1 zonelists, mobility grouping on.  Total pages: 260608
[    0.000000][    T0] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p3 rootwait rw earlyprintk loglevel=8
[    0.000000][    T0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000][    T0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000][    T0] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000][    T0] Memory: 918752K/1048576K available (9216K kernel code, 2299K rwdata, 5076K rodata, 1024K init, 3435K bss, 31520K reserved, 98304K cma-reserved, 262144K highmem)
[    0.000000][    T0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000][    T0] rcu: Preemptible hierarchical RCU implementation.
[    0.000000][    T0] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000][    T0]  Trampoline variant of Tasks RCU enabled.
[    0.000000][    T0] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.000000][    T0] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000][    T0] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000][    T0] random: get_random_bytes called from start_kernel+0x4a4/0x67c with crng_init=0
[    0.000000][    T0] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000][    T0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000002][    T0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008697][    T0] Switching to timer-based delay loop, resolution 41ns
[    0.015885][    T0] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.026141][    T0] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
[    0.036611][    T0] Console: colour dummy device 80x30
[    0.041912][    T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[    0.052885][    T0] pid_max: default: 32768 minimum: 301
[    0.058881][    T0] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.066922][    T0] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.078791][    T0] CPU: Testing write buffer coherency: ok
[    0.085009][    T1] /cpus/cpu@0 missing clock-frequency property
[    0.091100][    T1] /cpus/cpu@1 missing clock-frequency property
[    0.097125][    T1] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.105057][    T1] Setting up static identity map for 0x40100000 - 0x40100060
[    0.112613][    T1] rcu: Hierarchical SRCU implementation.
[    0.121487][    T1] smp: Bringing up secondary CPUs ...
[    0.128186][    T1] smp: Brought up 1 node, 1 CPU
[    0.133013][    T1] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.139937][    T1] CPU: All CPU(s) started in SVC mode.
[    0.147079][    T1] devtmpfs: initialized
[    0.207943][    T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.218535][    T1] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.230303][    T1] pinctrl core: initialized pinctrl subsystem
[    0.241582][    T1] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.250412][    T1] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.263169][    T1] audit: initializing netlink subsys (disabled)
[    0.271934][    T1] thermal_sys: Registered thermal governor 'step_wise'
[    0.271953][    T1] thermal_sys: Registered thermal governor 'user_space'
[    0.278752][   T23] audit: type=2000 audit(0.103:1): state=initialized audit_enabled=0 res=1
[    0.295127][    T1] cpuidle: using governor ladder
[    0.300004][    T1] cpuidle: using governor menu
[    0.304874][    T1] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.313623][    T1] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.362817][    T1] platform 1e40000.display-backend: Fixing up cyclic dependency with 1c0d000.lcd-controller
[    0.373238][    T1] platform 1e40000.display-backend: Fixing up cyclic dependency with 1c0c000.lcd-controller
[    0.383633][    T1] platform 1e40000.display-backend: Fixing up cyclic dependency with 1e20000.display-frontend
[    0.394175][    T1] platform 1e40000.display-backend: Fixing up cyclic dependency with 1e00000.display-frontend
[    0.407019][    T1] platform 1e60000.display-backend: Fixing up cyclic dependency with 1c0d000.lcd-controller
[    0.417425][    T1] platform 1e60000.display-backend: Fixing up cyclic dependency with 1c0c000.lcd-controller
[    0.427801][    T1] platform 1e60000.display-backend: Fixing up cyclic dependency with 1e20000.display-frontend
[    0.438358][    T1] platform 1e60000.display-backend: Fixing up cyclic dependency with 1e00000.display-frontend
[    0.573423][    T1] SCSI subsystem initialized
[    0.578227][    T1] libata version 3.00 loaded.
[    0.583986][    T1] usbcore: registered new interface driver usbfs
[    0.590501][    T1] usbcore: registered new interface driver hub
[    0.596791][    T1] usbcore: registered new device driver usb
[    0.603264][    T1] mc: Linux media interface: v0.10
[    0.608487][    T1] videodev: Linux video capture interface: v2.00
[    0.614959][    T1] pps_core: LinuxPPS API ver. 1 registered
[    0.620671][    T1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.630612][    T1] PTP clock support registered
[    0.637076][    T1] Advanced Linux Sound Architecture Driver Initialized.
[    0.648874][    T1] clocksource: Switched to clocksource arch_sys_counter
[    0.657473][    T1] VFS: Disk quotas dquot_6.6.0
[    0.662476][    T1] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.670994][    T1] FS-Cache: Loaded
[    0.675259][    T1] CacheFiles: Loaded
[    0.716669][    T1] NET: Registered PF_INET protocol family
[    0.722756][    T1] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.733751][    T1] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.743101][    T1] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.751725][    T1] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.759744][    T1] TCP: Hash tables configured (established 8192 bind 8192)
[    0.767207][    T1] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.774666][    T1] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.783438][    T1] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.792077][    T1] RPC: Registered named UNIX socket transport module.
[    0.798839][    T1] RPC: Registered udp transport module.
[    0.804340][    T1] RPC: Registered tcp transport module.
[    0.809760][    T1] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.817729][    T1] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[    0.827788][    T1] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.842069][    T1] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[    0.897302][    T1] NFS: Registering the id_resolver key type
[    0.903245][    T1] Key type id_resolver registered
[    0.908180][    T1] Key type id_legacy registered
[    0.916995][    T1] Key type cifs.spnego registered
[    0.922052][    T1] Key type cifs.idmap registered
[    0.926902][    T1] ntfs: driver 2.1.32 [Flags: R/W].
[    0.933788][    T1] fuse: init (API version 7.34)
[    1.022593][    T1] bounce: pool size: 64 pages
[    1.027703][    T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.035909][    T1] io scheduler mq-deadline registered
[    1.041184][    T1] io scheduler kyber registered
[    1.064341][    T1] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    1.340788][    T1] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.360131][    T1] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[    1.371343][    T1] printk: console [ttyS0] disabled
[    1.397062][    T1] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 56, base_baud = 1500000) is a U6_16550A
[    1.406903][    T1] printk: console [ttyS0] enabled
[    1.416668][    T1] printk: bootconsole [earlycon0] disabled
[    1.443330][    T1] brd: module loaded
[    1.487644][    T1] loop: module loaded
[    1.491610][    T1] the cryptoloop driver has been deprecated and will be removed in in Linux 5.16
[    1.505763][    T1] libphy: Fixed MDIO Bus: probed
[    1.514682][    T1] CAN device driver interface
[    1.520509][    T1] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[    1.530079][    T1] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found
[    1.537180][    T1] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found
[    1.544184][    T1] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    1.550843][    T1] sun7i-dwmac 1c50000.ethernet: no regulator found
[    1.558025][    T1] sun7i-dwmac 1c50000.ethernet: Version ID not available
[    1.565043][    T1] sun7i-dwmac 1c50000.ethernet:    DWMAC1000
[    1.570756][    T1] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
[    1.578690][    T1] sun7i-dwmac 1c50000.ethernet: Normal descriptors
[    1.585090][    T1] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
[    1.594810][    T1] libphy: stmmac: probed
[    1.609371][    T1] PPP generic driver version 2.4.2
[    1.615224][    T1] PPP BSD Compression module registered
[    1.620735][    T1] PPP Deflate Compression module registered
[    1.626573][    T1] PPP MPPE Compression module registered
[    1.632083][    T1] NET: Registered PF_PPPOX protocol family
[    1.638670][    T1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.646024][    T1] ehci-platform: EHCI generic platform driver
[    1.652402][    T1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.659420][    T1] ohci-platform: OHCI generic platform driver
[    1.666546][    T1] mousedev: PS/2 mouse device common for all mice
[    1.673486][    T1] i2c_dev: i2c /dev entries driver
[    1.680296][    T1] device-mapper: uevent: version 1.0.3
[    1.687208][    T1] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    1.697525][    T1] device-mapper: multipath round-robin: version 1.2.0 loaded
[    1.704913][    T1] device-mapper: multipath queue-length: version 0.2.0 loaded
[    1.712280][    T1] device-mapper: multipath service-time: version 0.3.0 loaded
[    1.721682][    T1] usbcore: registered new interface driver ushc
[    1.728782][   T75] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[    1.738793][    T1] ledtrig-cpu: registered to indicate activity on CPUs
[    1.746474][    T7] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dummy regulator
[    1.757255][    T1] hid: raw HID events driver (C) Jiri Kosina
[    1.774762][    T1] usbcore: registered new interface driver usbhid
[    1.781266][    T1] usbhid: USB HID core driver
[    1.787143][    T1] ashmem: initialized
[    1.792964][   T75] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.800773][    T7] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB
[    1.812423][    T1] [HuXiLED]:/***************************/
[    1.818570][    T1] [HuXiLED]:----------MODULE------------
[    1.824269][    T1] [HuXiLED]:--NAME:My Huxi LED Driver---
[    1.829975][    T1] [HuXiLED]:/***************************/
[    1.836042][    T1] [HuXiLED]:Finding compatible gpio node! :gpio_huxi:0
[    1.843073][    T1] [HuXiLED]:Module HuXiLed Time_HuXiA = <300> !
[    1.843073][    T1]
[    1.843193][    T1] [HuXiLED]:Get gpio242:htled_gpio number from node!
[    1.858707][    T1] [HuXiLED]:Get gpio243:hxled_gpio number from node!
[    1.865765][    T1] Get gpio device major=241,minor=0
[    1.872701][    T1] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    1.882353][    T1] Initializing XFRM netlink socket
[    1.887582][    T1] NET: Registered PF_PACKET protocol family
[    1.893554][    T1] NET: Registered PF_KEY protocol family
[    1.899068][    T1] can: controller area network core
[    1.904430][    T1] NET: Registered PF_CAN protocol family
[    1.909994][    T1] can: raw protocol
[    1.913702][    T1] can: broadcast manager protocol
[    1.918703][    T1] can: netlink gateway - max_hops=1
[    1.925107][    T1] Key type dns_resolver registered
[    1.930408][    T1] Registering SWP/SWPB emulation handler
[    1.937415][    T1] registered taskstats version 1
[    1.942333][   T22] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.951455][    T1] kmemleak: Kernel memory leak detector initialized (mem pool available: 15894)
[    1.960436][   T95] kmemleak: Automatic memory scanning thread started
[    1.967276][   T22] mmc0: new SDHC card at address 0001
[    1.979671][   T22] mmcblk0: mmc0:0001 SD16G 29.5 GiB
[    1.987461][    T1] Key type encrypted registered
[    2.013990][   T22]  mmcblk0: p1 p2 p3 p4
[    2.088045][   T75] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
[    2.104385][    T1] printk: console [netcon0] enabled
[    2.109601][    T1] netconsole: network logging started
[    2.115448][    T1] ALSA device list:
[    2.119242][    T1]   No soundcards found.
[    2.400464][    C0] random: fast init done
[    6.301092][    T1] EXT4-fs (mmcblk0p3): recovery complete
[    6.310302][    T1] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    6.321082][    T1] VFS: Mounted root (ext4 filesystem) on device 179:3.
[    6.328313][    T1] devtmpfs: mounted
[    6.333334][    T1] Freeing unused kernel image (initmem) memory: 1024K
[    6.341158][    T1] Run /sbin/init as init process
[    6.346006][    T1]   with arguments:
[    6.349712][    T1]     /sbin/init
[    6.353137][    T1]   with environment:
[    6.356984][    T1]     HOME=/
[    6.360050][    T1]     TERM=linux
[    6.364090][    T1] Run /etc/init as init process
[    6.368991][    T1]   with arguments:
[    6.372784][    T1]     /etc/init
[    6.376161][    T1]   with environment:
[    6.380037][    T1]     HOME=/
[    6.383111][    T1]     TERM=linux
[    6.387042][    T1] Run /bin/init as init process
[    6.391880][    T1]   with arguments:
[    6.395593][    T1]     /bin/init
[    6.398969][    T1]   with environment:
[    6.402848][    T1]     HOME=/
[    6.405956][    T1]     TERM=linux
[    6.409808][    T1] Run /bin/sh as init process
[    6.414454][    T1]   with arguments:
[    6.418173][    T1]     /bin/sh
[    6.421366][    T1]   with environment:
[    6.425245][    T1]     HOME=/
[    6.428336][    T1]     TERM=linux
[    6.454707][    T1] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
[    6.463086][    T1] CPU: 0 PID: 1 Comm: sh Not tainted 5.15.0-rc5-Allwinner-Happy #33 2cbe631b8feb782ec637f4454c93c0defca4b1ea
[    6.474472][    T1] Hardware name: Allwinner sun7i (A20) Family
[    6.480391][    T1] [<c010a714>] (unwind_backtrace) from [<c0105a80>] (show_stack+0x10/0x14)
[    6.488847][    T1] [<c0105a80>] (show_stack) from [<c09bfa58>] (dump_stack_lvl+0x40/0x4c)
[    6.497117][    T1] [<c09bfa58>] (dump_stack_lvl) from [<c09bd4a0>] (panic+0x100/0x2e4)
[    6.505122][    T1] [<c09bd4a0>] (panic) from [<c011eb5c>] (do_exit+0x9e4/0xb7c)
[    6.512521][    T1] [<c011eb5c>] (do_exit) from [<c011fdb0>] (do_group_exit+0x3c/0xb8)
[    6.520440][    T1] [<c011fdb0>] (do_group_exit) from [<c012b6f4>] (get_signal+0x1a0/0x854)
[    6.528794][    T1] [<c012b6f4>] (get_signal) from [<c0104ee4>] (do_work_pending+0x100/0x5cc)
[    6.537321][    T1] [<c0104ee4>] (do_work_pending) from [<c01000c0>] (slow_work_pending+0xc/0x20)
[    6.546194][    T1] Exception stack(0xc1871fb0 to 0xc1871ff8)
[    6.551939][    T1] 1fa0:                                     ???????? ???????? ???????? ????????
[    6.560800][    T1] 1fc0: ???????? ???????? ???????? ???????? ???????? ???????? ???????? ????????
[    6.569661][    T1] 1fe0: ???????? ???????? ???????? ???????? ???????? ????????
[    6.576970][    T1] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004 ]---
百度搜了一下说是什么EABI编译问题,更改之后还是不行,还有说根文件系统问题,换了之后也还是同样错误。芯片是全志A20。我实在黔驴技穷了,来个大神救救孩子吧。
#1 2024-01-17 19:17:09
ktouch
Re: 兄弟们!请教个全志A20问题:内核启动报错panic - not syncing怎么解决啊?
A20是个很古老的芯片了吧
