楼主 #1 2018-10-01 08:03:25
zhuacai
已发帖子: 234
关于esp32录音传给http的问题?
https://github.com/espressif/esp-adf/blob/master/examples/recorder/pipeline_raw_http/main/record_raw_http.c
这个源码里面如何实现录音传给http的,代码中没有看到录音的数据缓存,不知道录音的数据是在哪里传到http的?
#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_wifi.h"
#include "nvs_flash.h"
#include "esp_http_client.h"
#include "sdkconfig.h"
#include "audio_element.h"
#include "audio_pipeline.h"
#include "audio_event_iface.h"
#include "audio_common.h"
#include "audio_hal.h"
#include "http_stream.h"
#include "i2s_stream.h"
#include "wav_encoder.h"
#include "esp_peripherals.h"
#include "periph_button.h"
#include "periph_wifi.h"
#include "filter_resample.h"
static const char *TAG = "REC_RAW_HTTP";
esp_err_t _http_stream_event_handle(http_stream_event_msg_t *msg)
    esp_http_client_handle_t http = (esp_http_client_handle_t)msg->http_client;
    char len_buf[16];
    static int total_write = 0;
    if (msg->event_id == HTTP_STREAM_PRE_REQUEST) {
        // set header
        ESP_LOGI(TAG, "[ + ] HTTP client HTTP_STREAM_PRE_REQUEST, lenght=%d", msg->buffer_len);
        esp_http_client_set_header(http, "x-audio-sample-rates", "16000");
        esp_http_client_set_header(http, "x-audio-bits", "16");
        esp_http_client_set_header(http, "x-audio-channel", "2");
        total_write = 0;
        return ESP_OK;
    if (msg->event_id == HTTP_STREAM_ON_REQUEST) {
        // write data
        int wlen = sprintf(len_buf, "%x\r\n", msg->buffer_len);
        if (esp_http_client_write(http, len_buf, wlen) <= 0) {
            return ESP_FAIL;
        if (esp_http_client_write(http, msg->buffer, msg->buffer_len) <= 0) {
            return ESP_FAIL;
        if (esp_http_client_write(http, "\r\n", 2) <= 0) {
            return ESP_FAIL;
        total_write += msg->buffer_len;
        printf("\033[A\33[2K\rTotal bytes written: %d\n", total_write);
        return msg->buffer_len;
    if (msg->event_id == HTTP_STREAM_POST_REQUEST) {
        ESP_LOGI(TAG, "[ + ] HTTP client HTTP_STREAM_POST_REQUEST, write end chunked marker");
        if (esp_http_client_write(http, "0\r\n\r\n", 5) <= 0) {
            return ESP_FAIL;
        return ESP_OK;
    if (msg->event_id == HTTP_STREAM_FINISH_REQUEST) {
        ESP_LOGI(TAG, "[ + ] HTTP client HTTP_STREAM_FINISH_REQUEST");
        char *buf = calloc(1, 64);
        assert(buf);
        int read_len = esp_http_client_read(http, buf, 64);
        if (read_len <= 0) {
            free(buf);
            return ESP_FAIL;
        buf[read_len] = 0;
        ESP_LOGI(TAG, "Got HTTP Response = %s", (char *)buf);
        free(buf);
        return ESP_OK;
    return ESP_OK;
void app_main(void)
    audio_pipeline_handle_t pipeline;
    audio_element_handle_t http_stream_writer, i2s_stream_reader;
    esp_log_level_set("*", ESP_LOG_WARN);
    esp_log_level_set(TAG, ESP_LOG_INFO);
    esp_err_t err = nvs_flash_init();
    if (err == ESP_ERR_NVS_NO_FREE_PAGES) {
        // NVS partition was truncated and needs to be erased
        // Retry nvs_flash_init
        ESP_ERROR_CHECK(nvs_flash_erase());
    tcpip_adapter_init();
    ESP_LOGI(TAG, "[ 1 ] Initialize Button Peripheral & Connect to wifi network");
    // Initialize peripherals management
    esp_periph_config_t periph_cfg = { 0 };
    esp_periph_init(&periph_cfg);
    periph_wifi_cfg_t wifi_cfg = {
        .ssid = CONFIG_WIFI_SSID,
        .password = CONFIG_WIFI_PASSWORD,
    esp_periph_handle_t wifi_handle = periph_wifi_init(&wifi_cfg);
    // Initialize Button peripheral
    periph_button_cfg_t btn_cfg = {
        .gpio_mask = GPIO_SEL_36 | GPIO_SEL_39, //REC BTN & MODE BTN
    esp_periph_handle_t button_handle = periph_button_init(&btn_cfg);
    // Start wifi & button peripheral
    esp_periph_start(button_handle);
    esp_periph_start(wifi_handle);
    periph_wifi_wait_for_connected(wifi_handle, portMAX_DELAY);
    ESP_LOGI(TAG, "[ 2 ] Start codec chip");
    audio_hal_codec_config_t audio_hal_codec_cfg =  AUDIO_HAL_ES8388_DEFAULT();
    audio_hal_codec_cfg.i2s_iface.samples = AUDIO_HAL_16K_SAMPLES;
    audio_hal_handle_t hal = audio_hal_init(&audio_hal_codec_cfg, 0);
    audio_hal_ctrl_codec(hal, AUDIO_HAL_CODEC_MODE_ENCODE, AUDIO_HAL_CTRL_START);
    ESP_LOGI(TAG, "[3.0] Create audio pipeline for recording");
    audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
    pipeline = audio_pipeline_init(&pipeline_cfg);
    mem_assert(pipeline);
    ESP_LOGI(TAG, "[3.1] Create http stream to post data to server");
    http_stream_cfg_t http_cfg = HTTP_STREAM_CFG_DEFAULT();
    http_cfg.type = AUDIO_STREAM_WRITER;
    http_cfg.event_handle = _http_stream_event_handle;
    http_stream_writer = http_stream_init(&http_cfg);
    ESP_LOGI(TAG, "[3.2] Create i2s stream to read audio data from codec chip");
    i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();
    i2s_cfg.type = AUDIO_STREAM_READER;
    i2s_stream_reader = i2s_stream_init(&i2s_cfg);
    ESP_LOGI(TAG, "[3.3] Register all elements to audio pipeline");
    audio_pipeline_register(pipeline, i2s_stream_reader, "i2s");
    audio_pipeline_register(pipeline, http_stream_writer, "http");
    ESP_LOGI(TAG, "[3.4] Link it together [codec_chip]-->i2s_stream->http_stream-->[http_server]");
    audio_pipeline_link(pipeline, (const char *[]) {"i2s", "http"}, 2);
    ESP_LOGI(TAG, "[ 4 ] Setup event listener");
    audio_event_iface_cfg_t evt_cfg = AUDIO_EVENT_IFACE_DEFAULT_CFG();
    audio_event_iface_handle_t evt = audio_event_iface_init(&evt_cfg);
    ESP_LOGI(TAG, "[4.1] Listening event from the pipeline");
    audio_pipeline_set_listener(pipeline, evt);
    ESP_LOGI(TAG, "[4.2] Listening event from peripherals");
    audio_event_iface_set_listener(esp_periph_get_event_iface(), evt);
    i2s_stream_set_clk(i2s_stream_reader, 16000, 16, 2);
    ESP_LOGI(TAG, "[ 5 ] Listen for all pipeline events");
    while (1) {
        audio_event_iface_msg_t msg;
        esp_err_t ret = audio_event_iface_listen(evt, &msg, portMAX_DELAY);
        if (ret != ESP_OK) {
            ESP_LOGE(TAG, "[ * ] Event interface error : %d", ret);
            continue;
        if (msg.source_type != PERIPH_ID_BUTTON) {
            continue;
        // It's not REC button
        if ((int)msg.data == GPIO_NUM_39) {
            break;
        if ((int)msg.data != GPIO_NUM_36) {
            continue;
        if (msg.cmd == PERIPH_BUTTON_PRESSED) {
            ESP_LOGI(TAG, "[ * ] Resuming pipeline");
            audio_element_set_uri(http_stream_writer, CONFIG_SERVER_URI);
            audio_pipeline_run(pipeline);
        } else if (msg.cmd == PERIPH_BUTTON_RELEASE || msg.cmd == PERIPH_BUTTON_LONG_RELEASE) {
            ESP_LOGI(TAG, "[ * ] Stop pipeline");
            audio_pipeline_stop(pipeline);
            audio_pipeline_wait_for_stop(pipeline);
            audio_pipeline_terminate(pipeline);
    ESP_LOGI(TAG, "[ 6 ] Stop audio_pipeline");
    /* Terminal the pipeline before removing the listener */
    audio_pipeline_remove_listener(pipeline);
    /* Stop all periph before removing the listener */
    esp_periph_stop_all();
    audio_event_iface_remove_listener(esp_periph_get_event_iface(), evt);
    /* Make sure audio_pipeline_remove_listener & audio_event_iface_remove_listener are called before destroying event_iface */
    audio_event_iface_destroy(evt);
    /* Release all resources */
    audio_pipeline_deinit(pipeline);
    audio_element_deinit(http_stream_writer);
    audio_element_deinit(i2s_stream_reader);
    esp_periph_destroy();
#2 2018-10-01 09:30:28
路人甲
已发帖子: 202
Re: 关于esp32录音传给http的问题?
看代码 _http_stream_event_handle 是回调函数吧,应该是这个 HTTP_STREAM_ON_REQUEST 状态实现数据传输的。
楼主 #3 2018-10-01 10:14:42
zhuacai
已发帖子: 234
路人甲 说:
路哥,应该是录音的数据放在内存缓冲里,在用http上传到服务器,现在不知道录音的缓冲数据放在那里?
#4 2018-10-01 11:06:57
路人甲
已发帖子: 202
esp_http_client_write 这个函数会写到 ip协议栈的。
楼主 #5 2018-10-01 11:58:04
zhuacai
已发帖子: 234
路人甲 说:
路哥,我意思是说iis录音的pcm数据放在那里?
#6 2018-10-01 13:20:49
basicdev
已发帖子: 159
https://github.com/espressif/esp-adf/blob/master/examples/recorder/pipeline_wav_sdcard/main/record_wav_sdcard_example.c
楼主看下这个sdcard 录音demo,更简单一点,可以跟进源码看下
楼主 #7 2018-10-01 13:48:56
zhuacai
已发帖子: 234
basicdev 说:
这个也一样,看不出来代码是怎么获得pcm数据,我说的是pcm数据,我说的是pcm数据
,我说的是pcm数据?录音的的数据放在什么变量里???
