楼主 # 2024-04-03 23:01:53
Haronyx
A133 Android 无法打开WiFi
如题
[  623.676410] RTW: module init start
[  623.680515] RTW: rtl8723bs-vq0 v5.2.17_26088.20180202_COEX20171212-6e51_GTS
[  623.688959] RTW: build time: Apr  3 2024 21:08:33
[  623.694636] RTW: rtl8723bs-vq0 BT-Coex version = COEX20171212-6e51
[  623.701803] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[  623.809887] RTW: == SDIO Card Info ==
[  623.814018] RTW:   clock: 50000000 Hz
[  623.818181] RTW:   timing spec :sd high-speed
[  623.823118] RTW:   sd3_bus_mode: FALSE
[  623.827328] RTW: ================
[  623.866191] RTW: 0x000: 29 81 03 7C 51 08 28 00    62 07 0D 45 10 00 00 00
[  623.874051] RTW: 0x010: 2D 2C 2C 2D 2D 2D 31 31    30 31 31 00 FF FF FF FF
[  623.881989] RTW: 0x020: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  623.889837] RTW: 0x030: FF FF FF FF FF FF FF FF    FF FF 28 28 28 28 28 28
[  623.897662] RTW: 0x040: 28 28 28 28 28 00 FF FF    FF FF FF FF FF FF FF FF
[  623.905488] RTW: 0x050: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  623.913317] RTW: 0x060: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  623.921130] RTW: 0x070: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  623.928980] RTW: 0x080: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  623.936836] RTW: 0x090: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  623.944659] RTW: 0x0a0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  623.952482] RTW: 0x0b0: FF FF FF FF FF FF FF FF    20 3F 1F 00 00 00 FF FF
[  623.960310] RTW: 0x0c0: FF 29 20 11 00 00 00 FF    00 FF 12 FF FF FF FF FF
[  623.968161] RTW: 0x0d0: 3E 10 01 02 23 00 00 FF    20 04 4C 02 23 B7 21 02
[  623.976008] RTW: 0x0e0: 0C 00 22 04 00 08 00 32    FF 21 02 0C 00 22 2A 01
[  623.983839] RTW: 0x0f0: 01 00 00 00 00 00 00 00    00 00 00 00 02 00 FF FF
[  623.991656] RTW: 0x100: 00 00 00 00 00 00 00 00    00 00 00 00 00 00 00 00
[  623.999509] RTW: 0x110: 00 EB 00 6E 01 00 00 00    00 FF 0C CF 89 32 C5 6E
[  624.007335] RTW: 0x120: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.015149] RTW: 0x130: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.022980] RTW: 0x140: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.030820] RTW: 0x150: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.038614] RTW: 0x160: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.046476] RTW: 0x170: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.054302] RTW: 0x180: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.062092] RTW: 0x190: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.069909] RTW: 0x1a0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.077743] RTW: 0x1b0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.085564] RTW: 0x1c0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.093415] RTW: 0x1d0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.101372] RTW: 0x1e0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.109216] RTW: 0x1f0: FF FF FF FF FF FF FF FF    FF FF FF FF FF FF FF FF
[  624.117039]
[  624.118848] RTW: hal_com_config_channel_plan chplan:0x20
[  624.127099] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[  624.139404] RTW: rtw_ndev_init(wlan0) if1 mac_addr=60:3e:36:59:d8:f2
[  624.156289] RTW: rtw_ndev_init(p2p0) if2 mac_addr=62:3e:36:59:d8:f2
[  624.171480] RTW: module init ret=0
[  624.185884] init: Received control message 'interface_start' for 'android.hardware.wifi.supplicant@1.0::ISupplicant/default' from pid: 1596 (/system/bin/hwservicemanager)
[  624.211916] init: starting service 'wpa_supplicant'...
[  624.223263] init: Created socket '/dev/socket/wpa_wlan0', mode 660, user 1010, group 1010
[  625.663870] RTW: wlan0- hw port(0) mac_addr =60:3e:36:59:d8:f2
[  625.670522] RTW: p2p0- hw port(1) mac_addr =62:3e:36:59:d8:f2
[  625.681133] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  625.785079] RTW: module exit start
[  625.822536] RTW: rtw_ndev_uninit(wlan0) if1
[  625.838447] init: Service 'wpa_supplicant' (pid 23393) exited with status 0
[  625.846374] init: Sending signal 9 to service 'wpa_supplicant' (pid 23393) process group...
[  625.856272] libprocessgroup: Successfully killed process cgroup uid 0 pid 23393 in 0ms
[  625.932411] RTW: rtw_ndev_uninit(p2p0) if2
[  626.006881] RTW: rtw_sdio_primary_adapter_deinit wowlan_mode:0
[  626.013589] RTW: rtw_dev_unload: driver not in IPS
[  626.028258] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[  626.148871] RTW: module exit success
前面看上去已经识别到WIFI模块,但到了[  625.681133] 就显示这个
然后就开始卸载模组了。这是为什么?
#1 2024-04-03 23:35:43
memory
已发帖子: 619
Re: A133 Android 无法打开WiFi
root@TinaLinux:/# wpa_supplicant -i wlan0 -Dnl80211 -c/etc/wifi/wpa_supplicant.conf -O /etc/wifi/sockets -B
[  796.252780] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
mkdir[ctrl_interface=/etc/wifi/sockets]: Read-only file system
Failed to initialize control interface '/etc/wifi/sockets'.
日志提示很清晰:启动wpa_supplicant服务时依赖的套接字路径和配置文件是只读的。
看是否文件系统原因
楼主 #2 2024-04-05 12:26:32
Haronyx
@memory
我这里显示已经创建了啊
除了[  625.681133] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready什么也没有打印
