手上有一块t113-s3 麻雀开发板,自己焊了norflash(怕nand flash出现坏块搞不定。。。),想试试能不能自己移植freertos在t113上跑,先打算实现裸机正常运行和中断正常运行。目前可以正常的打印,定时器也正常计数,就是无法触发中断,本人小白,花了一段时间,实在找不出问题,只能把源码贴出来了,希望有大佬帮忙看看。。
log:
dram start
dram init ok
welcome to T113s3
now run in security
[D] CLK: CPU PLL=PLL_CPU FREQ=1200MHz
[D] CLK: PLL_peri (2X)=1200MHz, (1X)=600MHz, (800M)=800MHz
[D] CLK: PLL_ddr=1584MHz
gic_base address is 0x3020000
gic irqs supported is 224
0) current val = 0
1) current val = 22779507
2) current val = 21555507
3) current val = 20331507
4) current val = 19107507
5) current val = 17883507
6) current val = 16659507
7) current val = 15435507
8) current val = 14211506
9) current val = 12987506
10) current val = 11763507
11) current val = 10539507
12) current val = 9315507
13) current val = 8091507
14) current val = 6867506
15) current val = 5643506
16) current val = 4419507
17) current val = 3195507
18) current val = 1971507
19) current val = 747506
20) current val = 23523507#include "debug.h"
#include "arch_timer/arch_timer.h"
#include "timer/timer.h"
#include "gic400/gic400.h"
#include "gic400/t113_irq.h"
#include "t113_clk/sunxi_clk.h"
#include "arm32.h"
#include "bit_ops.h"
static void timer0_irq_handler(void * data);
static void timer1_irq_handler(void * data);
int main(void)
u32 cur_val = 0;
u32 scr;
message("welcome to T113s3\r\n");
scr = arm32_read_scr_ns();
if(GET_BIT(scr,0))//获取SCR.NS位,如果是0则是安全模式,如果是1则是非安全模式
message("now run in non_security\r\n");
message("now run in security\r\n");
sunxi_clk_dump();
start_gic();
register_irq(T113_IRQ_TIMER1,timer1_irq_handler,NULL,(30 << 3),3);
start_ms_timer(TIMER1,1000);
int i = 0;
while(1)
cur_val = get_current_timer_value(TIMER1);
message("%d) current val = %d \r\n",i,cur_val);
mdelay(50);
i ++;
//清中断
clear_timern_irq(TIMER0);
message("timer0 irq get \r\n");
//清中断
clear_timern_irq(TIMER1);
message("timer1 irq get \r\n");
}GIC部分代码:
#include "io.h"
#include "smp.h"
#include "debug.h"
enum {
DIST_CTRL = 0x1000,
DIST_CTR = 0x1004,
DIST_IIDR = 0X1008,
DIST_IGROUPRn = 0x1080,
DIST_ENABLE_SET = 0x1100,
DIST_ENABLE_CLEAR = 0x1180,
DIST_PENDING_SET = 0x1200,
DIST_PENDING_CLEAR = 0x1280,
DIST_ACTIVE_BIT = 0x1300,
DIST_PRI = 0x1400,
DIST_TARGET = 0x1800,
DIST_CONFIG = 0x1c00,
DIST_SOFTINT = 0x1f00,
CPU_CTRL = 0x2000,
CPU_PRIMASK = 0x2004,
CPU_BINPOINT = 0x2008,
CPU_INTACK = 0x200c,
CPU_EOI = 0x2010,
CPU_RUNNINGPRI = 0x2014,
CPU_HIGHPRI = 0x2018,
}GIC_REG_NUM;
#define FGicPs_PRIORITY_OFFSET_CALC(InterruptID) \
((u32)DIST_PRI + (((InterruptID)/4U) * 4U))
#define FGicPs_INT_CFG_OFFSET_CALC(InterruptID) \
((u32)DIST_CONFIG + (((InterruptID)/16U) * 4U))
u32 read_gicd_pri(int int_id)
return read32(T113_GIC_400_BASE + FGicPs_PRIORITY_OFFSET_CALC(int_id));
void write_gicd_pri(int int_id, u32 val)
write32(T113_GIC_400_BASE + FGicPs_PRIORITY_OFFSET_CALC(int_id),val);
u32 read_gicd_cfg(int int_id)
return read32(T113_GIC_400_BASE + FGicPs_INT_CFG_OFFSET_CALC(int_id));
void write_gicd_cfg(int int_id, u32 val)
write32(T113_GIC_400_BASE + FGicPs_INT_CFG_OFFSET_CALC(int_id),val);
#if 0
static inline uint32_t arm32_get_gic_base(void)
uint32_t value;
__asm__ __volatile__(
"mrc p15, 4, %0, c15, c0, 0"
: "=r" (value)
: "memory");
return value;
void gic400_dist_init(void)
u32_t gic_irqs;
u32_t cpumask;
u32_t gic_base = T113_GIC_400_BASE;
int i;
message("gic_base address is 0x%x \r\n",gic_base);
write32(gic_base + DIST_CTRL, 0x0);
* Find out how many interrupts are supported.
* The GIC only supports up to 1020 interrupt sources.
gic_irqs = read32(gic_base + DIST_CTR) & 0x1f;
gic_irqs = (gic_irqs + 1) * 32;
message("gic irqs supported is %d \r\n",gic_irqs);
if(gic_irqs > 1020)
gic_irqs = 1020;
* Set all global interrupts to this CPU only.
cpumask = 1 << smp_processor_id();
cpumask |= cpumask << 8;
cpumask |= cpumask << 16;
for(i = 32; i < gic_irqs; i += 4)
write32(gic_base + DIST_TARGET + (i / 4 )* 4, cpumask);
* Set all global interrupts to be level triggered, active low.
for(i = 32; i < gic_irqs; i += 16)
write32(gic_base + DIST_CONFIG + (i /16) * 4 , 0);
* Set priority on all global interrupts.
write32(gic_base + DIST_PRI + (i / 4) * 4, 0xa0a0a0a0);
* Disable all interrupts, leave the SGI and PPI alone
* as these enables are banked registers.
for(i = 32; i < gic_irqs; i += 32)
write32(gic_base + DIST_ENABLE_CLEAR + (i / 32) * 4, 0xffffffff);
//将所有中断设为group0
for(i = 32 ; i < gic_irqs; i += 32)
write32(gic_base + DIST_IGROUPRn + (i / 32) * 4, 0x0);
write32(gic_base + DIST_CTRL, 0x1);
void gic400_cpu_init(void)
int i;
* Deal with the banked SGI and PPI interrupts - enable all
* SGI interrupts, ensure all PPI interrupts are disabled.
write32(gic_base + DIST_ENABLE_CLEAR, 0xffff0000);
write32(gic_base + DIST_ENABLE_SET, 0x0000ffff);
* Set priority on SGI and PPI interrupts
for(i = 0; i < 32; i += 4)
write32(gic_base + DIST_PRI + ( i / 4 ) * 4, 0xa0a0a0a0);
write32(gic_base + CPU_PRIMASK, 0xf0);
write32(gic_base + CPU_CTRL, 0x1);
void irq_gic400_enable(int irq) //unmask对应中断
write32(T113_GIC_400_BASE + DIST_ENABLE_SET + (irq / 32) * 4, 1 << (irq % 32));
void irq_gic400_disable(int irq)//mask对应中断
write32(T113_GIC_400_BASE + DIST_ENABLE_CLEAR + (irq / 32) * 4, 1 << (irq % 32));
void irq_gic400_settype(void)
void irq_gic400_dispatch(void)//处理中断后清除中断标志
int irq = read32(T113_GIC_400_BASE + CPU_INTACK) & 0x3ff;
irq_gic400_disable(irq);
do_handler(irq);
write32(T113_GIC_400_BASE + CPU_EOI, irq);//清除中断
irq_gic400_enable(irq);
void gic_interrupt_handle_exception(void* regs)
irq_gic400_dispatch();
void start_gic(void)
gic400_dist_init();
gic400_cpu_init();
}register_irq:
bool_t register_irq(int irq,void (*func)(void *), void * data, u8 Priority, u8 trigger)
u32 val;
u8 LocalPriority;
if(!func)
return FALSE;
if(irq_hanlder_arry[irq].func != null_interrupt_function)
return FALSE;
irq_hanlder_arry[irq].func = func;
irq_hanlder_arry[irq].data = data;
// val = read_gicd_pri(irq);
// LocalPriority = LocalPriority & (u8)(0x000000F8U);
// val &= ~(0x000000FFU << ((irq%4U)*8U));
// val |= (u32)LocalPriority << ((irq%4U)*8U);
// write_gicd_pri(irq,val);
// val = read_gicd_cfg(irq);
// val &= ~(0x00000003U << ((irq%16U)*2U));
// val |= (u32)trigger << ((irq%16U)*2U);
// write_gicd_cfg(irq,val);
arm32_interrupt_enable();
return TRUE;
}定时器部分
enum {
TMR_IRQ_EN_REG =0x0000 ,
TMR_IRQ_STA_REG =0x0004 ,
TMR0_CTRL_REG =0x0010 ,
TMR0_INTV_VALUE_REG =0x0014 ,
TMR0_CUR_VALUE_REG =0x0018,
TMR1_CTRL_REG =0x0020 ,
TMR1_INTV_VALUE_REG =0x0024,
TMR1_CUR_VALUE_REG =0x0028,
}TIMER_REG_OFFSET;
#define Timer_Periodic_mode 0
#define Timer_Single_mode 1
//a &= ~(数值<<每组位数*组编号) :将连续几位清零的方法
//数值表示一组中每个bit都是1的情况下的值,比如组位数是2,则数值就是11b所代表的值,即3
//组编号是给寄存器多少个bit为1组进行分组,组号从0开始
void timern_init(int timer_id, int timing_mode) //时钟频率为24000000/2
u32 addr,val;
if(timer_id == 0)
addr = TIMER_BASE + TMR0_CTRL_REG;
addr = TIMER_BASE + TMR1_CTRL_REG;
if(timing_mode == Timer_Periodic_mode)
val = (u32)0x14;
val = (u32)0x94;
write32(addr,val);
void set_timern_interval_value(int timer_id, u32 value)
u32 addr,val;
val = value;
if(timer_id == 0)
addr = TIMER_BASE + TMR0_INTV_VALUE_REG;
addr = TIMER_BASE + TMR1_INTV_VALUE_REG;
write32(addr,val);//设置间隔值
void load_timern_interval_value(int timer_id)
u32 addr,val;
if(timer_id == 0)
write32(addr, read32(addr)|(1<<1)); //Set the Reload bit
void start_timer(int timer_id)
u32 addr,val;
if(timer_id == 0)
val = read32(addr);
val |= (0x1 << 0);
write32(addr,val);
void start_ms_timer(int timer_id,u32 ms)
u32 value = (24000 * ms);
u32 addr;
enable_timern_irq(timer_id);
set_timern_interval_value(timer_id,value);
timern_init(timer_id, Timer_Periodic_mode);
load_timern_interval_value(timer_id);
if(timer_id == 0)
while((read32(addr)>>1)&1);
start_timer(timer_id);
void enable_timern_irq(int timer_id)
u32 addr,val;
addr = TIMER_BASE + TMR_IRQ_EN_REG;
if(timer_id == 0)
val = read32(addr);
val |= (1 << 0);
val = read32(addr);
val |= (1 << 1);
write32(addr,val);
addr = TIMER_BASE + TMR_IRQ_STA_REG;
if(timer_id == 0)
val = read32(addr);
val |= (1 << 0);
val = read32(addr);
val |= (1 << 1);
write32(addr,val);
void clear_timern_irq(int timer_id)
u32 addr,val;
if(timer_id == 0)
val = read32(addr);
if( (val & 0x01))
val |= (1 << 0);
val = read32(addr);
if((val & 0x2))
val |= (1 << 1);
write32(addr,val);
u32 get_current_timer_value(int timer_id)
u32 addr,val;
if(timer_id == 0)
addr = TIMER_BASE + TMR0_CUR_VALUE_REG;
addr = TIMER_BASE + TMR1_CUR_VALUE_REG;
val = read32(addr);
return val;
}完整代码工程似乎传不上了,有兴趣的可以私聊
最近编辑记录 zm (2024-01-02 17:34:49)
瞎猜一个, 其它中断有正常的没? 或任意开一个其它中断试试.
若能中断就是timer部分配置问题, 反之就是系统中断问题.
大概率是系统中断没弄好.
我也正在T113S3上搞rtos,一堆的坑呐,想跟楼主交流
总算搞定中断了,发现还是前面gic初始化出问题了,哎,心累 ![]()
dram start
dram init ok
welcome to T113s3
now run in security
sys tick handler get
sys tick handler get下面开始移植freertos,开搞!!
freertos 初步移植成功,用的freertos版本是10.0.0,目前只验证了多任务运行,运行正常!
[I] AWBoot r51 starting...
[D] DRAM BOOT DRIVE INFO: V0.24
[D] DRAM CLK = 792 MHz
[D] DRAM Type = 3 (2:DDR2,3:DDR3)
[D] DRAMC read ODT off
[D] ZQ value = 0x12e
[D] DDR efuse: 0xa
[D] chip id efuse: 0x6000
[D] single rank and full DQ
[D] DDR efuse: 0xa
[D] rank 0 row = 13
[D] para->dram_para1 = 0x10d2
[D] rank 0 bank = 8
[D] rank 0 page size = 2 KB
[D] DRAM ODT value: 0x42
[D] DDR efuse: 0xa
[D] DRAM: size = 128MB
[D] DRAM: simple test OK
[D] DMA: init
[T] DMA: test 0x44000000 ====> 0x44800000, len 512KB
[T] DMA: provide channel 0
[D] DMA: test OK in 59ms
[T] SPI: parent_clk=600MHz, div=3, n=1, m=3
[T] SPI: CDR2 - n = 0
[T] SPI: clock div=0
[D] SPI: set clock asked=100MHz actual=100MHz mclk=200MHz
[T] SPI: tsfr mode=0 tx=1 rx=0
[T] SPI: ISR=0x1032
[T] SPI: tsfr mode=0 tx=1 rx=1
[T] SPI: ISR=0x1033
[T] SPI: tsfr mode=0 tx=1 rx=4
[T] SPI: ISR=0x1033
[I] SPI-NOR: MFR:0xEF DEV:0x4019
[T] SPI: tsfr mode=1 tx=5 rx=2097152
[T] SPI: ISR=0x1037
[I] SPI NOR: READ USER BIN TIME:89785uS
[I] ------BootLoader Jump Successed-----------
[D] welcome to T113s3
[D] timer0 irq is enable
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1
[D] i am task0
[D] i am task2
[D] i am task1后续打算研究一下t113s3的在线调试,想用openocd估计又是一个大坑~
@zm
大佬你好,请问GIC初始化出问题了,具体是哪个问题呀。
@zm 大佬,我现在也遇到中断触发不了的问题了,能加个联系方式,聊一聊吗,已经自己做T113的裸机几个月了,问题很多呀
已经实现t113-s,3裸奔,参考这个项目
https://github.com/evilbinary/duck/blob/main/platform/t113-s3/init.c#L97-L97
@evilbinary 这个代码里有中断吗,好像没找到
有的你搜void interrupt_regist(u32 vec, interrupt_handler_t handler)
@evilbinary 我看到有中断处理函数void irq_handler() {
// asm("msr cpsr, #0xD2 \n");
interrupt_entering_code(EX_IRQ, 0, 4);
interrupt_process(interrupt_default_handler);
interrupt_exit_ret();
}但是没看到startup.s文件,那是怎么通过向量表跳到中断函数的呢
跳转是cpu得功能啊,你只管配置好中断地址,中断地址看这个void interrutp_set(int i)
@evilbinary 我现在是参考的本版的一个iar工程弄的,可以仿真调试,但是看了你的程序,没看懂中断流程,不知道该怎么对照着改IAR工程
我没有使用IAR,但流程都差不多,工程我放在gitee仓库了,目前没实现啥功能,只是移植了freertos,可以跑任务,想要参考的话可以看看
https://gitee.com/zmzone/mangzai_freertos_kit/tree/master/
@zm 感谢,我参考了你的代码,初始化了start_gic(); 配置了串口中断,注册了串口中断函数register_irq(usart->irq_num, usart->handler,usart,15,1);
串口接收触发中断IRQ_Handler
LDR R0, =arm32_do_fiq
BLX R0 但是在s文件里运行到IRQ_Handler 后 不会跳转到arm32_do_fiq 中断处理函数,这个是什么原因呢,之后程序就跑死了
@lyy mmu关闭了吗
@lyy
额,,首先为啥是fiq,我记得根本没用fiq,然后,如果你是跑了freertos的话,进入中断应该不是这段汇编吧,而是FreeRTOS_Asm_Vector.S里的汇编吧,建议再看看代码,最后,,串口中断目前我还没做,现在只是轮询
@jxmlegend arm32_mmu_disable(); mmu关了
@zm fiq是写错了 是LDR R0, =arm32_do_irq ,然后我用的IAR的工程和startup.s文件,还没跑freertos,但是进中断向量表的流程应该是一样的吧,参考了你的gic初始化函数,以及中断注册函数,但是到startup.s汇编文件这里就出问题了
