楼主 # 2024-04-17 08:29:02
tomas
luban-lite新发布的# V1.0.4 #变慢了
测试平台:官方D213开发板。
1-新发布的V1.0.4开机时间至少需要2s。V1.0.3开机时间大概不到1s。
2-提示sd卡挂载失败。其实是有sd卡,开机后ls sdcard也能正常查看sd卡文件。
3-spi nand时钟变慢了,v1.0.3是100MHZ,与配置一致
   qspi0 freq (input): 91636363Hz
   qspi0 freq ( bus ): 91636363Hz
可否给个解释,作为RTOS系统,2s开机时间有点长了。
Welcome to ArtInChip Luban-Lite 1.0 [Built on Apr 17 2024 08:05:07]
01-01 10:31:37 I/touch: rt_touch init success
01-01 10:31:38 I/gt911: touch device gt911 init success
[w] aic_find_panel()62 find panel driver : panel-lvds
[w] aicfb_probe()950 fb0 allocated at 0x46000040
[w] hal_ge_init()1620 dither line phys: 0x464B0100
[w] aic_sdmc_clk_init()547 SDMC1 sclk: 50400 KHz, parent clk 1008000 KHz
01-01 10:31:38 I/SDMC: SDMC1 BW 1, sclk 50400 KHz, clk 400 KHz(406 KHz), div 2-62
[w] aic_sdmc_probe()664 SDMC1 driver loaded
[w] spinand_info_read()472 find raw ID efaa2100
[w] spinand_flash_init()523 Enabled BUF, HWECC. Unprotected.
nftl vol: data, size 0
01-01 10:31:38 I/sensor: rt_sensor[temp_aic] init success
01-01 10:31:38 I/WDT: ArtInChip WDT loaded
01-01 10:31:39 E/DFS: mount fs[elm] on /sdcard failed.
Reboot action: Watchdog-Reset, reason: Command-Reboot
Startup time: 2.004 sec
[ND]nftl start:400,51
[ND]nftl ok!
id = GT911
range_x = 1024
range_y = 600
point_num = 5
#1 2024-04-18 00:00:13
ArtInChip
已发帖子: 236
Re: luban-lite新发布的# V1.0.4 #变慢了
晚一点我们看一下
#2 2024-04-18 15:23:02
xdlkliang
所在地: 珠海
新版本为了加速UI ,D213上开启了ramdisk,影响了启动时间,您可以关闭一下
me/Local package options /Third-party packages options/ ramdisk:A RAM memory block device
这个关闭掉就可以了
#3 2024-04-21 17:12:13
astankvai
已发帖子: 74
配置可以关掉很多东西的
