楼主 # 2024-05-29 09:20:27
memory
已发帖子: 656
T113 tplayerdemo 播放视频,放着放着就挂了
Clicked item content: "/mnt/exUDISK/x.mp4"
xplayer:process message XPLAYER_COMMAND_STOP.
ERROR  : audioDecItf <handleStop:1109>: invalid stop operation, already in stopped status.
join in
xplayer:process message XPLAYER_COMMAND_RESET.
ERROR  : awplayer <PlayerStop:994>: invalid stop operation, player already in stopped status.
player reset
player destroy
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> tina_multimedia <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : tina3.5
branch: tina-dev
date  : Mon Jul 15 19:04:59 2019 +0800
Change-Id: I5f6c8a88d7b387a312b7744797a0d5f8ab07ee7a
xplayer:process message XPLAYER_COMMAND_SET_AUDIOSINK.
xplayer:process message XPLAYER_COMMAND_SET_SURFACE.
xplayer:process message XPLAYER_COMMAND_SET_SUBCTRL.
xplayer:process message XPLAYER_COMMAND_SET_DI.
xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
xplayer:process message XPLAYER_COMMAND_PREPARE.
ERROR  : CdxFlvParser.c <__CdxFlvParserProbe:4030>: FlvProbe failed.
ERROR  : CdxAviParser <__CdxAviParserProbe:1251>: AviProbe failed.
warning: unknown callback from Tinaplayer.
[1970-01-01 03:47:30] ERROR  : cedarc <DebugCheckConfig:302>: now cedarc log level:5
setDataSource end
*****tplayer:video width = 3840,height = 1608
TPLAYER_NOTIFY_PREPARED,has prepared.
prepare
prepared ok
xplayer:process message XPLAYER_COMMAND_START.
(Allwinner Audio Middle Layer),line(971) : Create Decoder!!=====
(Allwinner Audio Middle Layer),line(603) : AudioDec_Installaudiolib ok
(Allwinner Audio Middle Layer),line(606) : audio decoder init start ...
(AllwinnerAlibs),line(50) :
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : audiocodec-v1.2
branch: new
commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
date  : Tue Jan 8 16:25:27 2019 +0800
(AllwinnerAlibs),line(695) : ----Loading so fail
(Allwinner Audio Middle Layer),line(274) : audio decode InitializeAudioDecoder fail!
ERROR  : audioDecItf <handleStart:1073>: initialize audio decoder fail.
(Allwinner Audio Middle Layer),line(920) : destroy_ResampleInfo!!
(Allwinner Audio Resample),line(68) : Destroy_ResampleInfo...
==> duration = 6431463
ERROR  : awplayer <__LayerQueueBuffer:934>: *** picNode is full when queue buffer
*****tplayer:video decoded width = 1920,height = 804
****player(0x1fc61e0): first video pts = 0*****
[1970-01-01 03:47:30] WARNING: cedarc <HevcSetNewRef:905>:  hevc decoder drop one frame. poc: 3
[1970-01-01 03:47:31] ERROR  : fbm.c <FbmReturnPicture:1043>: invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=1, bAlreadyDisplayed=0.
[1970-01-01 03:47:31] ERROR  : fbm.c <FbmReturnPicture:1044>: **picture[0xb160c8e8],id[8]
[1970-01-01 03:47:31] WARNING: cedarc <ReturnPicture:1700>: FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
xplayer:process message XPLAYER_COMMAND_SEEK.
ERROR  : audioDecItf <handlePause:1147>: invalid pause operation, component not in started status.
newValue=1469235
branch: new
TPLAYER_NOTIFY_SEEK_COMPLETE>>>>info: seek ok.
[1970-01-01 03:49:54] WARNING: cedarc <HevcAddCandidateRef:179>: ******* drop the RASL nalu as miss ref_frame
[1970-01-01 03:49:54] WARNING: cedarc <HevcFrameStart:2036>:  construct reference picture set failed , ret = 35
****player(0x1fc61e0): first video pts = 1469417000*****
Clicked item content: "/mnt/exUDISK/Music/0799.ywsy.mp3"
join in
player reset
player destroy
tag   : tina3.5
branch: tina-dev
ERROR  : CdxOggParser <OggParserProbe:2441>: It is not ogg version 0.
ERROR  : _apepsr <CdxApeParserProbe:780>: pApe Probe Failed
ERROR  : awplayer <__FlacParserProbe:1390>: Flac probe failed.
ERROR  : awplayer <WavProbe:977>: audio probe fail!!!
ERROR  : awplayer <__WavParserProbe:992>: wav probe failed.
setDataSource end
prepare
prepared ok
branch: new
(AllwinnerAlibs),line(700) : ----Loading so success!
(AllwinnerAlibs),line(902) : *************pAudioStreamInfo start******************
(AllwinnerAlibs),line(903) : eCodecFormat         :id(3), name(mpeg layer-III)
(AllwinnerAlibs),line(904) : eSubCodecFormat      :0
(AllwinnerAlibs),line(905) : nChannelNum          :2
(AllwinnerAlibs),line(906) : nBitsPerSample       :16
(AllwinnerAlibs),line(907) : nSampleRate          :44100
(AllwinnerAlibs),line(908) : nAvgBitrate          :128000
(AllwinnerAlibs),line(909) : nMaxBitRate          :128000
(AllwinnerAlibs),line(910) : nFileSize            :0
(AllwinnerAlibs),line(911) : eAudioBitstreamSource:0
(AllwinnerAlibs),line(912) : eDataEncodeType      :0
(AllwinnerAlibs),line(913) : nCodecSpecificDataLen:0
(AllwinnerAlibs),line(914) : pCodecSpecificData   :(nil)
(AllwinnerAlibs),line(915) : nFlags               :0
(AllwinnerAlibs),line(916) : nBlockAlign          :0
(AllwinnerAlibs),line(917) : *************pAudioStreamInfo end  ******************
(AllwinnerAlibs),line(27) : init successs...
(Allwinner Audio Middle Layer),line(614) : AUDIO DECODE INIT OK...0
==> duration = 265012
****player(0x1fc7660): first audio pts = 0*****
Clicked item content: "/mnt/exUDISK/Music/haoaini.wav"
(AllwinnerAlibs),line(34) : exit successs...
(AllwinnerAlibs),line(750) : ----dlclose so success!
join in
player reset
player destroy
tag   : tina3.5
branch: tina-dev
setDataSource end
prepare
prepared ok
branch: new
(AllwinnerAlibs),line(903) : eCodecFormat         :id(10), name(linear pcm wav audio)
(AllwinnerAlibs),line(904) : eSubCodecFormat      :1
(AllwinnerAlibs),line(908) : nAvgBitrate          :176400
(AllwinnerAlibs),line(909) : nMaxBitRate          :0
(AllwinnerAlibs),line(916) : nBlockAlign          :4
(Wav Decoder),line(28) : init success...
==> duration = 267866
Clicked item content: "/mnt/exUDISK/Music/0846.djx.mp3"
(Wav Decoder),line(35) : exit successs...
join in
player reset
player destroy
tag   : tina3.5
branch: tina-dev
setDataSource end
prepare
prepared ok
branch: new
==> duration = 273867
join in
player reset
player destroy
tag   : tina3.5
branch: tina-dev
setDataSource end
prepare
prepared ok
branch: new
newValue=38921
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:38921000
****player(0x1fc7660): first audio pts = 37999455*****
newValue=63293
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:63293000
****player(0x1fc7660): first audio pts = 62989931*****
newValue=142815
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:142815000
****player(0x1fc7660): first audio pts = 141984217*****
newValue=190359
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:190359000
****player(0x1fc7660): first audio pts = 189997278*****
newValue=234542
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:234542000
****player(0x1fc7660): first audio pts = 233987482*****
newValue=249190
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:249190000
****player(0x1fc7660): first audio pts = 248999183*****
ERROR  : awplayer <StreamManagerReset:191>: memory leak,,,, the guy not return... '0xb1417728'
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:0
^Cbegin stop
Got signal 2, exiting ...
join in
player reset
player destroy
^C# ^C
# chmod +x /usr/bin/player &&  modprobe gt9xxnew_ts && QT_QPA_EVDEV_TOUCHSCREEN_
PARAMETERS=/dev/input/event3 /usr/bin/player -platform linuxfb
WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 6
[1970-01-01 04:03:23] INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
[1970-01-01 04:03:23] INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
[1970-01-01 04:03:23] INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
[1970-01-01 04:03:23] INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
[1970-01-01 04:03:23] INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
[1970-01-01 04:03:23] INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
ERROR  : awplayer <DlOpenPlugin:105>: dlopen 'libawwmv3.so' fail: libawwmv3.so: cannot open shared object file: No such file or directory
[1970-01-01 04:03:23] INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
player not init.
Clicked item content: "/mnt/exUDISK/film/5.Ice.mp4"
player not init.
tag   : tina3.5
branch: tina-dev
[1970-01-01 04:03:27] INFO   : cedarc <log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
[1970-01-01 04:03:27] ERROR  : cedarc <DebugCheckConfig:302>: now cedarc log level:5
setDataSource end
*****tplayer:video width = 1920,height = 1080
prepare
prepared ok
branch: new
(AllwinnerAlibs),line(903) : eCodecFormat         :id(4), name(aac low-complexy)
(AllwinnerAlibs),line(905) : nChannelNum          :6
(AllwinnerAlibs),line(907) : nSampleRate          :48000
(AllwinnerAlibs),line(908) : nAvgBitrate          :0
(AllwinnerAlibs),line(912) : eDataEncodeType      :1
(AllwinnerAlibs),line(913) : nCodecSpecificDataLen:2
(AllwinnerAlibs),line(914) : pCodecSpecificData   :0xb14685b8
(AAC Decoder),line(36) : init successs...
==> duration = 5672768
****player(0x12b26b8): first audio pts = 0*****
*****tplayer:video decoded width = 1920,height = 1080
*****tplayer:video width = 3840,height = 2160
****player(0x12b26b8): first video pts = 0*****
ERROR  : awplayer <ProcessVideoSync:1317>: need to drop this frame
[1970-01-01 04:03:27] ERROR  : fbm.c <FbmReturnPicture:1043>: invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=1, bAlreadyDisplayed=0.
[1970-01-01 04:03:27] ERROR  : fbm.c <FbmReturnPicture:1044>: **picture[0x12e7fd0],id[8]
[1970-01-01 04:03:27] WARNING: cedarc <ReturnPicture:1700>: FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
[1970-01-01 04:08:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3996338 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4145339 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4069633 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4071548 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4169634 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4148802 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4103437 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4136769 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4126547 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4164039 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4155263 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4165867 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172182 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:08:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4137545 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:13:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4184295 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4141262 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4153905 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3893169 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4136925 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3972767 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4031852 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4015077 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3979862 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4143795 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4095365 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3997885 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4164078 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4084911 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4043369 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172036 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4110123 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4105002 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4177814 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4072148 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4117727 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4076312 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182423 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4123271 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4024710 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4116039 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4063401 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4030467 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4184579 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4121034 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4082141 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4070249 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4158564 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182722 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182332 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:18:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4180467 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4069291 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4168666 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4036667 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4151872 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4183623 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4180548 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4150417 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4176078 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4163902 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4180308 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:19:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4073603 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4139320 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4120620 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160342 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4150360 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4123361 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4126479 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4175936 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4151131 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4161345 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4185877 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4179553 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172125 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4174694 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4144040 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4116278 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4159306 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4178812 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4116375 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4154515 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4123733 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4168041 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4143166 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160647 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4163891 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4145820 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4173372 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4181735 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:23:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4120385 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4185324 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4135893 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4144512 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4105365 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4148214 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160956 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4147841 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160612 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4179447 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4147463 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4154625 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4133210 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4124449 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4132555 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4143987 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4169446 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4165256 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4129013 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4141142 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4061539 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4129932 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4111324 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:24:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4162659 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4149402 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4131838 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4145998 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4165962 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160636 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4165609 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4118867 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4126915 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4149098 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4142378 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4180072 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4135810 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4095582 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4108839 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4159753 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4171449 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4151860 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4165597 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4146339 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4139567 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4136319 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4170767 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4072732 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4114384 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4185649 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4176571 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4148201 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4153708 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4151624 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160155 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4133059 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4174377 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172960 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4104426 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4167242 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4134137 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4142387 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4171097 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4125015 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:25:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4184562 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4174250 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4185630 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4177011 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4184925 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4110547 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4139019 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4117343 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4107458 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4156936 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:31:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4170300 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4148377 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4129357 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4121810 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4117250 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4109547 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4151311 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4085641 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4170461 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4121456 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160904 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4128479 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4099880 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4110105 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182018 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4161277 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4164634 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4099884 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4179571 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4162477 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4107735 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4137110 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:35:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4185111 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4103067 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4111626 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4168877 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4173224 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4166678 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4142855 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4120383 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4144709 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4130706 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4160365 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4168822 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4125770 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4168580 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4120525 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4155637 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4168469 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4075179 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4048976 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4162432 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4065316 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4117353 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4141770 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4115283 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4102873 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4142222 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4154202 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4113492 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4108753 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4153813 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4116956 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:37:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4170634 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4166816 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4139923 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4164451 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4183758 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4137722 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4166293 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4098004 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4144999 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4176427 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4148718 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4131412 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4128743 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4131471 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4122527 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4180007 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4091055 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172945 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4152616 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4145403 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:38:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4170067 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4073684 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3992950 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172972 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4168574 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4156165 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4161451 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4129362 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4164592 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3971222 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4164018 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4109750 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4169704 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4073564 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4087341 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182827 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4185527 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4099720 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4166012 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4119977 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4125770 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4170425 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4123717 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4078874 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182297 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182283 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4162478 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4145612 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4161430 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3766309 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4153332 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4135346 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172772 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4185038 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4087153 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4174140 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4163271 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4180342 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172100 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4161984 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4177340 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4178150 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4123400 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4184372 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4083925 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4122961 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4090499 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4109478 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4125668 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4112401 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4143932 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4047935 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4014139 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4125596 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4183397 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4136959 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4023992 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4011670 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4011117 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4184166 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4071890 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4114676 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3997974 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4021485 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4084850 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:43:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4113033 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4172367 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4128373 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4120614 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4135939 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4137469 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4141570 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4178447 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4182402 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4154846 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4112946 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4157484 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4138989 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4134710 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4157387 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4153139 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4130436 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4126704 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4173631 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  4126636 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
[1970-01-01 04:44:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3945573 bytes valid data in SBM[0], total buffer size is 4194304 bytes.
xplayer:process message XPLAYER_COMMAND_SEEK.
newValue=3935526
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:3935526000
TPLAYER_NOTIFY_SEEK_COMPLETE>>>>info: seek ok.
****player(0x12b26b8): first audio pts = 3943531000*****
warning: unknown callback from Tinaplayer.
****player(0x12b26b8): first video pts = 3943523000*****
newValue=4529393
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:4529393000
****player(0x12b26b8): first audio pts = 4530624000*****
****player(0x12b26b8): first video pts = 4530609000*****
newValue=5211897
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:5211897000
****player(0x12b26b8): first audio pts = 5221099000*****
****player(0x12b26b8): first video pts = 5221091000*****
newValue=5310177
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:5310177000
****player(0x12b26b8): first audio pts = 5312320000*****
****player(0x12b26b8): first video pts = 5312307000*****
newValue=3475392
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:3475392000
****player(0x12b26b8): first audio pts = 3478144000*****
****player(0x12b26b8): first video pts = 3478141000*****
newValue=1746971
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:1746971000
****player(0x12b26b8): first video pts = 1754294000*****
****player(0x12b26b8): first audio pts = 1754304000*****
newValue=407103
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:407103000
****player(0x12b26b8): first video pts = 414164000*****
****player(0x12b26b8): first audio pts = 414165000*****
newValue=105738
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:105738000
****player(0x12b26b8): first audio pts = 110656000*****
****player(0x12b26b8): first video pts = 110652000*****
newValue=690742
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:690742000
****player(0x12b26b8): first video pts = 694360000*****
****player(0x12b26b8): first audio pts = 694379000*****
newValue=1598749
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:1598749000
****player(0x12b26b8): first video pts = 1600641000*****
****player(0x12b26b8): first audio pts = 1600661000*****
newValue=2742166
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:2742166000
****player(0x12b26b8): first audio pts = 2743872000*****
****player(0x12b26b8): first video pts = 2743866000*****
newValue=4098312
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:4098312000
****player(0x12b26b8): first video pts = 4099929000*****
****player(0x12b26b8): first audio pts = 4099947000*****
newValue=5144228
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:5144228000
****player(0x12b26b8): first video pts = 5145015000*****
****player(0x12b26b8): first audio pts = 5145024000*****
ERROR  : awplayer <ebml_read_num:378>:  read error at pos(10fb5fcae)
ERROR  : awplayer <ebml_peek_id:498>: Invalid id(0) at pos (0x10fb5fcae)
xplayer:process message XPLAYER_COMMAND_START.
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:0
Clicked item content: "/mnt/exUDISK/film/3.Ice.Age.Dawn.of.the.Dinosaurs.2009.BD1080P.X264.AAC.Mandarin&English.CHS-ENG.mp4"
xplayer:process message XPLAYER_COMMAND_STOP.
(AAC Decoder),line(44) : exit successs...
(AllwinnerAlibs),line(750) : ----dlclose so success!
(Allwinner Audio Middle Layer),line(920) : destroy_ResampleInfo!!
(Allwinner Audio Resample),line(68) : Destroy_ResampleInfo...
join in
xplayer:process message XPLAYER_COMMAND_RESET.
ERROR  : awplayer <PlayerStop:994>: invalid stop operation, player already in stopped status.
player reset
player destroy
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> tina_multimedia <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : tina3.5
branch: tina-dev
date  : Mon Jul 15 19:04:59 2019 +0800
Change-Id: I5f6c8a88d7b387a312b7744797a0d5f8ab07ee7a
xplayer:process message XPLAYER_COMMAND_SET_AUDIOSINK.
xplayer:process message XPLAYER_COMMAND_SET_SURFACE.
xplayer:process message XPLAYER_COMMAND_SET_SUBCTRL.
xplayer:process message XPLAYER_COMMAND_SET_DI.
xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
xplayer:process message XPLAYER_COMMAND_PREPARE.
ERROR  : CdxFlvParser.c <__CdxFlvParserProbe:4030>: FlvProbe failed.
ERROR  : CdxAviParser <__CdxAviParserProbe:1251>: AviProbe failed.
[1970-01-01 05:04:08] ERROR  : cedarc <DebugCheckConfig:302>: now cedarc log level:5
setDataSource end
*****tplayer:video width = 1920,height = 1036
TPLAYER_NOTIFY_PREPARED,has prepared.
prepare
prepared ok
(Allwinner Audio Middle Layer),line(971) : Create Decoder!!=====
(Allwinner Audio Middle Layer),line(603) : AudioDec_Installaudiolib ok
(Allwinner Audio Middle Layer),line(606) : audio decoder init start ...
(AllwinnerAlibs),line(50) :
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : audiocodec-v1.2
branch: new
commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
date  : Tue Jan 8 16:25:27 2019 +0800
(AllwinnerAlibs),line(700) : ----Loading so success!
(AllwinnerAlibs),line(902) : *************pAudioStreamInfo start******************
(AllwinnerAlibs),line(903) : eCodecFormat         :id(4), name(aac low-complexy)
(AllwinnerAlibs),line(904) : eSubCodecFormat      :0
(AllwinnerAlibs),line(905) : nChannelNum          :6
(AllwinnerAlibs),line(906) : nBitsPerSample       :16
(AllwinnerAlibs),line(907) : nSampleRate          :48000
(AllwinnerAlibs),line(908) : nAvgBitrate          :0
(AllwinnerAlibs),line(909) : nMaxBitRate          :0
(AllwinnerAlibs),line(910) : nFileSize            :0
(AllwinnerAlibs),line(911) : eAudioBitstreamSource:0
(AllwinnerAlibs),line(912) : eDataEncodeType      :1
(AllwinnerAlibs),line(913) : nCodecSpecificDataLen:2
(AllwinnerAlibs),line(914) : pCodecSpecificData   :0xb16688d0
(AllwinnerAlibs),line(915) : nFlags               :0
(AllwinnerAlibs),line(916) : nBlockAlign          :0
(AllwinnerAlibs),line(917) : *************pAudioStreamInfo end  ******************
(AAC Decoder),line(36) : init successs...
(Allwinner Audio Middle Layer),line(614) : AUDIO DECODE INIT OK...0
==> duration = 5643349
****player(0x12e6088): first audio pts = 0*****
ERROR  : awplayer <__LayerQueueBuffer:934>: *** picNode is full when queue buffer
*****tplayer:video decoded width = 1920,height = 1036
*****tplayer:video width = 3840,height = 2072
****player(0x12e6088): first video pts = 0*****
[1970-01-01 05:04:08] ERROR  : fbm.c <FbmReturnPicture:1043>: invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=1, bAlreadyDisplayed=0.
[1970-01-01 05:04:08] ERROR  : fbm.c <FbmReturnPicture:1044>: **picture[0x12b45f8],id[8]
[1970-01-01 05:04:08] WARNING: cedarc <ReturnPicture:1700>: FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
newValue=593231
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:593231000
****player(0x12e6088): first audio pts = 597440000*****
****player(0x12e6088): first video pts = 597430000*****
newValue=2503197
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:2503197000
****player(0x12e6088): first audio pts = 2504341000*****
****player(0x12e6088): first video pts = 2504335000*****
[1970-01-01 05:04:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121946 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079803 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086001 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089731 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072850 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085072 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064529 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047704 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135383 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133327 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078262 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090352 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119475 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129451 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108982 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100662 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064256 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126669 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102140 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069117 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134355 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092595 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094555 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133312 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098621 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092318 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120709 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097486 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093894 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065992 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117338 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102721 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100359 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112854 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127818 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124154 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125267 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090123 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107908 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075456 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072661 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3054415 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092550 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123944 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107919 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122495 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094906 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094796 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074590 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119781 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121361 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105333 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130367 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123934 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117797 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118515 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2881025 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088530 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058868 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2949134 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108838 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090025 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099099 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095095 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129062 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119433 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3049744 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092451 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045772 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125180 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3041046 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105170 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089078 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114701 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063093 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106570 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103467 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087136 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109746 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3032964 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130953 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091074 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:04:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124936 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116064 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3011142 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102938 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120523 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115500 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3001029 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093203 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085234 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3015087 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3041510 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3050735 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109783 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108176 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114126 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122921 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091893 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119035 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100123 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071128 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091920 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2854714 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114495 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133862 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121589 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134359 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118071 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099232 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098842 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119205 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133123 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113914 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095622 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074790 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056191 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116948 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127595 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130403 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132955 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072050 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134737 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125584 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132003 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067635 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:05:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3044773 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110209 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102026 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120980 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118504 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052235 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112191 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121863 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110868 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125219 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136245 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099525 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122779 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121759 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099305 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122600 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056713 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135418 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3034199 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122753 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3004025 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136622 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129932 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134600 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3054203 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097458 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114248 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058616 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097352 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130723 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131580 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:06:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2916161 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:07:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3006982 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:07:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084357 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:07:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113132 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:07:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059770 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:07:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067548 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:07:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089817 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128601 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112145 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107091 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131075 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129445 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3011617 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128207 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088839 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3048539 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122021 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2961511 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069599 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122141 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060788 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120640 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113709 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094281 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114533 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3006647 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103833 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087092 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:09:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121563 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116012 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101796 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082414 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106623 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125290 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120397 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109236 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084456 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128906 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132807 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074520 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106104 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111665 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131491 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083032 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130668 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102027 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121942 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110641 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079909 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058903 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122948 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093008 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083005 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058461 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045241 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129931 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074329 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115575 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135855 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:10:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2840307 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:11:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110958 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:11:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2765374 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116701 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127206 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129336 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104893 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085668 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089235 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097475 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091343 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107049 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2992395 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083267 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060401 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129308 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3028711 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108536 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120085 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130012 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137072 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2971796 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125979 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118228 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2971636 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113223 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108438 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2937464 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3030706 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3030868 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3036502 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110134 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2931629 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3033478 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113072 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127445 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3038238 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087902 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2987137 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:13:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128344 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131033 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3016540 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125107 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103623 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061401 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111761 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080041 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063422 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072584 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108197 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108637 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088479 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076532 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130959 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094642 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104465 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080292 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095551 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098018 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134561 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128328 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082305 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098673 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132043 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136812 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099771 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133016 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115342 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072105 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118240 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129124 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090334 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093428 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3030324 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113052 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3017330 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047007 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125257 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3042996 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059346 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043203 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131084 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132915 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117798 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130558 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123139 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107984 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3051561 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3035825 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131720 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3041140 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106070 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115969 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113637 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067940 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106369 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134091 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096579 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080903 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052576 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098717 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137149 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060475 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063834 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053654 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132090 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115044 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107729 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073634 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111120 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099139 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061793 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083951 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058372 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079206 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097964 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096245 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125197 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136906 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086474 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129148 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097889 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107357 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134812 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081736 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070411 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130784 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056168 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099370 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134511 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061833 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062048 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120854 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111003 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106098 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122501 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104595 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3042546 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114733 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3037055 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128376 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106683 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135310 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118342 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120315 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091271 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129702 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097652 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126872 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122965 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116195 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083800 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097213 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116636 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094000 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110727 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130205 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111979 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100809 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117200 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136521 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3020790 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110864 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121891 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119691 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085858 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3021191 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093387 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118991 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109061 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106276 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101188 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082963 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085269 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134129 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125807 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:14:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133071 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092125 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124012 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111216 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131958 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074766 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095344 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3017448 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055952 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116683 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115940 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094925 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131267 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114810 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129908 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132552 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104680 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114617 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127711 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043394 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109918 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112686 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128816 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059249 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078402 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119137 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125606 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095871 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101892 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115870 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122106 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:15:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098299 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110515 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130859 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123617 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104764 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077458 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117306 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108318 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125154 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094809 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110018 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104253 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122880 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127360 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116827 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089028 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094408 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045154 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121863 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092399 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125171 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119047 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111752 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112270 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111143 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079860 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122724 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:20:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126145 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043488 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130910 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129418 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113355 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082393 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055467 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045108 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2991854 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3034873 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136897 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123671 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081248 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120613 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2969734 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119935 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109784 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2983739 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132165 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057114 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3009517 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135036 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096043 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079711 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108642 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069490 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3002122 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109723 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082068 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126492 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3024162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091312 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091820 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087720 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124488 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088530 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115236 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122512 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3023873 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101983 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2998385 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135947 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3042703 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3030066 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083226 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093550 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2962976 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078438 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3015762 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073034 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120105 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133328 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127332 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118402 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105237 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087803 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065908 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045089 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077420 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2989034 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088966 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097626 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074544 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071787 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105403 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088006 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2963260 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127425 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3024349 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3021438 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132889 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086225 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069532 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088920 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125489 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125872 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111738 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101233 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109748 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:21:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109139 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100685 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115654 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105484 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129367 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133563 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125425 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122621 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106798 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092010 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066079 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104846 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091584 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096935 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114363 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084416 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128418 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064064 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124483 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3031518 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074461 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123619 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072901 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129447 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3025300 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126446 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060725 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107139 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059200 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3036466 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123026 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134857 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071708 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116529 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113130 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125173 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085612 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3039061 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109828 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113777 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3034575 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062086 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124389 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045765 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104652 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080315 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135956 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125282 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085595 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134529 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090399 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096527 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083946 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122871 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106355 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070490 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045934 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074288 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134361 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084428 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122047 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086411 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113121 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111324 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3054084 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122380 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105189 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114155 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134922 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081479 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062151 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133821 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107568 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088711 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115713 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118151 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134587 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089007 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102374 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094533 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079489 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113276 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3019445 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114731 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129647 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135952 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055912 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069309 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127798 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135979 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:23:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129444 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102881 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136186 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133109 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093002 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3020239 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3046945 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078418 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106510 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3027225 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077715 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122074 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2912081 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076947 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136406 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112826 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104596 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085351 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137121 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103543 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115387 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112619 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121645 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131198 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133083 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092079 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059669 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117003 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107748 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085674 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3048241 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125313 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094680 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055419 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073566 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067074 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085876 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055097 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108608 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062555 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126447 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112492 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064047 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131598 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064257 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135893 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3015269 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3036252 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3021976 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2987855 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121929 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072789 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102360 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090436 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101304 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094172 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135092 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2783684 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120505 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3024918 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126773 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:24:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084153 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3001984 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061001 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120851 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102770 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3049655 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111282 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114629 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109856 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3011731 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134016 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107556 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058208 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133328 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080311 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111451 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130130 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132307 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121974 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099246 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110104 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133315 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129462 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101101 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125676 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082997 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065480 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086468 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111263 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133778 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093855 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124270 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116602 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058574 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070241 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094475 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122958 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059362 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100690 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123560 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125503 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136044 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133364 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097174 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057946 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069201 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123483 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121009 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126385 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137028 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2972822 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133419 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114172 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128376 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080388 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2996335 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110959 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070771 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109223 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099629 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114804 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088672 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125317 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063418 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126085 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123929 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:25:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117342 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095583 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3023052 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3038529 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094686 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2991644 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077510 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088040 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045498 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114889 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089753 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083024 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120001 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135199 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084357 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:26:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128876 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126899 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067666 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126715 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089122 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133353 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136515 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064852 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107369 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120618 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106843 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070151 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061933 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065022 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3012307 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078221 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084121 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060235 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102236 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064867 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086382 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116258 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076878 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113566 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121711 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093411 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126860 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115880 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112504 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082191 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085746 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122767 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3050804 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126156 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089042 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108147 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3038235 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134972 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067866 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105284 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135549 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133125 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135033 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095847 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124686 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091785 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061917 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099202 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108515 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080091 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128880 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097851 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134905 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095642 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126082 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120810 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136692 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093224 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119973 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078648 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089646 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128892 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105616 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122543 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104849 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133811 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125225 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2955321 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136931 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131029 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125957 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135736 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096629 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096103 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108065 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116570 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:27:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088109 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095360 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105170 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122434 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132921 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099082 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078860 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124349 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063706 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079436 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111773 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092446 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056709 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084754 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055655 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116926 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129129 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043771 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118676 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104653 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064918 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073126 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131276 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111335 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114590 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102016 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112105 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070763 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080598 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087484 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129632 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107383 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3049912 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108873 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124176 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067970 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080057 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116566 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127275 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111387 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128794 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129305 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108231 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124668 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112193 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135051 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077637 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114371 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114323 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114073 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089473 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132938 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098536 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123344 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:28:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3021271 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093057 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091104 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115475 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095622 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112538 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096865 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095329 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136188 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125407 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134904 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125589 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102193 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132967 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112558 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125538 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099127 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128264 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104220 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072390 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069864 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053841 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065237 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107454 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101367 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134409 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116317 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134717 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101827 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117871 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103591 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117607 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068945 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131694 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085566 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136160 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113254 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090345 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094832 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102567 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108190 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:29:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116550 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3036096 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110527 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130154 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045409 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137034 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127166 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127488 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135014 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131069 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101679 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119816 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136126 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127222 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079612 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105361 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096727 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119426 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2997779 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113649 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079522 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074068 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3041771 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103120 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2950060 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105228 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117843 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098908 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117996 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074984 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116906 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063842 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123116 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132108 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104243 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079736 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109433 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126553 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109825 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110746 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129615 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116949 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083225 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135444 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099510 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106157 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099142 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121446 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131251 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136920 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119428 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112665 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086017 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101881 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085053 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120688 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126682 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088288 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114794 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097623 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104358 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083961 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094771 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113218 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080650 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113282 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3039386 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134155 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137172 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111294 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104119 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102025 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120077 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119890 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070796 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062979 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057600 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123843 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096269 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064120 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084978 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137173 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082896 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098889 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131133 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103087 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072597 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130163 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065811 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073668 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057359 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085941 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114784 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091126 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074328 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081561 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109342 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063375 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099314 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077767 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093533 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106323 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121377 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:30:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134800 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129250 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129307 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123775 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130644 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128768 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108523 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127944 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118724 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106018 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132056 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093051 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079871 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095960 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094152 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128601 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085358 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118296 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134699 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108813 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111569 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124899 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107094 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067336 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052679 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110706 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122723 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118715 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129522 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089881 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124256 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133520 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119818 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133391 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102511 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129080 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092062 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137199 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121713 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119756 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103090 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127480 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108213 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125445 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101219 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108128 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111988 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123373 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116663 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092547 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111651 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117697 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069720 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098898 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113363 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116902 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108336 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127604 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137358 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109413 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109389 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101035 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121110 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3006994 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2998095 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076391 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084646 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110030 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113252 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101420 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114781 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110598 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120990 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100341 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108999 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121609 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081644 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078089 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082687 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087613 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088666 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056469 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071707 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123653 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119639 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2978339 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085438 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122487 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2986785 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059758 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119342 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095417 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128801 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3015162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060680 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116041 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104075 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129396 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134472 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110123 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2944260 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137112 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115369 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117593 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079103 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130997 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107465 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099964 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092190 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2999186 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121634 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123647 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100952 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103513 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136377 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129255 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131498 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122337 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3051865 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056068 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3019583 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077729 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065153 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094635 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088917 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3009129 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133164 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110880 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105003 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126598 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2874995 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103150 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081182 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118401 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106540 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109729 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128905 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083121 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123707 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059124 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135903 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135487 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079179 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093637 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127290 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105543 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105032 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114861 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3050539 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107791 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135692 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127123 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128147 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102623 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124526 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101763 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088828 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063519 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3040685 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089294 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123740 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:31:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131469 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086461 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086042 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113114 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099088 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067665 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120761 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104730 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052468 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3022135 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131275 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064611 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129434 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111808 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3032941 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3049432 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134804 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128526 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123021 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099962 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130286 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122453 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132519 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122965 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135619 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135364 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083132 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110638 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131334 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102225 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116082 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086075 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116553 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3031909 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114536 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111803 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103168 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094157 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085067 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096077 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128980 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111570 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133079 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101799 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115702 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063322 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102184 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129500 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087840 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117841 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066653 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121330 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115712 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116338 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113598 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091139 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114931 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104007 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106423 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121627 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091520 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126742 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123386 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122732 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104200 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124802 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115109 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107529 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114623 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111882 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106488 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124644 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122780 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101796 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091476 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100257 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127147 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055505 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132552 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083638 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075651 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085293 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094947 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115332 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052664 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099812 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097379 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3051857 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094635 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100336 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131300 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093359 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066703 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093888 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103366 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102829 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123415 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079048 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072510 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3042356 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133069 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128013 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122259 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126322 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123872 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082141 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083041 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099813 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085074 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117510 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114100 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076131 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067434 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117063 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129848 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077272 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131820 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102771 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136595 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096801 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098065 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078438 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105272 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127250 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098766 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082348 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124067 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127727 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137032 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114818 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117101 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081560 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057173 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2981576 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3039844 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3048922 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083810 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3009523 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057907 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3050336 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064964 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056433 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097337 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047155 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081042 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091930 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129220 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092358 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125097 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124692 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111093 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3044553 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134730 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121534 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119613 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066691 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068681 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136581 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095988 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098733 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096814 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102141 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095431 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:57] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109932 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130190 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128163 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118495 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3010470 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:58] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092201 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112818 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065842 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070096 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128594 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:32:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047963 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3011350 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130018 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058345 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094871 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113138 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104130 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126238 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109094 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118776 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097454 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082593 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097330 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099241 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066219 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088789 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129158 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087025 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110976 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103484 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070816 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108221 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102482 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067079 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114196 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081801 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103537 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117777 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115943 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117839 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108741 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077407 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081355 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117128 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096012 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119291 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130539 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094596 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102669 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104587 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131081 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089998 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112582 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103248 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127929 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070252 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105184 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130930 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105894 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135605 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090289 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122639 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088726 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128735 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117574 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099488 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135327 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114008 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098653 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088441 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3028293 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122929 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101599 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073171 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130099 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124687 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126686 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047098 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136909 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122604 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109497 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082929 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104296 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085063 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136445 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071810 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107485 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134831 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055677 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102532 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105057 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116656 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109116 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121383 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087009 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053633 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083025 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112005 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061620 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103451 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131136 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066776 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118418 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081600 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132714 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114854 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076769 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097962 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074281 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123689 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127738 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116586 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087023 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099389 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128244 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053393 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080123 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116321 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099782 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110527 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134925 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097958 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135584 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118677 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124821 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114861 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134297 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112670 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108959 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122434 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103405 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128737 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092976 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092735 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082790 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091508 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064472 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124520 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119018 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110199 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3010266 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083407 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111457 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088841 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113370 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099258 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127935 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114007 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2998561 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084083 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085511 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078152 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106489 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099746 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113769 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125335 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062108 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119443 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083571 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125353 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113596 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071398 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087765 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094779 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059556 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060946 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061334 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075638 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088403 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090976 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103590 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106258 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122899 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045013 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093588 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101721 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068978 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100525 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092026 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123142 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094783 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105849 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136948 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067549 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098239 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133650 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124745 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123443 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092077 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125647 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:33:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089954 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103924 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109304 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088328 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128734 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107826 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133412 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120088 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126368 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108359 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085587 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115456 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075960 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058923 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117631 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096657 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065287 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098945 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3048252 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122357 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134021 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073977 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060897 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082618 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130469 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094611 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087496 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120911 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131198 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078505 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101021 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066631 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121601 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121920 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079466 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128402 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3049503 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3010353 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113637 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121932 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129791 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092954 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3013002 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103545 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3021270 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103576 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116875 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115918 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114743 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128086 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109034 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108073 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127829 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127675 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116850 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086280 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118170 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097707 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130214 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101724 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047627 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113453 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3051734 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124826 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099126 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083089 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124624 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2913876 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130131 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2883352 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108081 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114433 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098779 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056361 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3042586 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090825 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133830 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061334 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125837 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120037 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132626 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045647 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083077 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110681 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086808 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132456 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080675 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123845 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115190 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099702 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120529 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3028982 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052007 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107726 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097604 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059215 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3049450 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094776 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135014 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118635 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066518 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:48] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107104 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111911 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057798 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072887 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071840 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088887 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136193 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:34:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097990 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063803 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102585 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118596 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3040201 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102762 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104561 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058750 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117291 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130646 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109535 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114437 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129459 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113953 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132021 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2875948 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084152 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073665 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:35:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3046539 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100871 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104642 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103828 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103867 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068053 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078228 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061764 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133707 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111168 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3007094 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2985495 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2740569 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099585 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:36:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109994 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083993 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097129 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124616 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095644 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130245 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124448 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117254 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130780 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073973 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055135 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3034784 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079853 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090676 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124458 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073509 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132134 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105810 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070261 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117602 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3044706 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089682 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081697 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136482 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135075 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2942733 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093606 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136758 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117828 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110267 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112796 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088739 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077488 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134428 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:37:59] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127475 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124060 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133218 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085499 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3044792 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:00] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130491 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117988 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068304 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077384 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131091 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083575 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105378 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133010 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102783 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117060 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120588 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103341 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137251 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128843 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096116 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132311 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088061 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090385 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119786 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124316 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119504 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108062 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104801 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116299 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109553 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128436 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2891973 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123235 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103584 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120201 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129581 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134462 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125900 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118904 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083263 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122815 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135262 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:38:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2803634 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133082 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074839 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088247 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060988 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101912 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122904 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129657 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068942 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060926 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119316 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093744 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095445 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059393 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098139 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132111 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135915 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113545 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117244 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125254 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2851984 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094860 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045838 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053842 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066695 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097346 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056993 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064281 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089545 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111303 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075459 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053889 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090124 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071987 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118727 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116462 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132932 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3009037 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072871 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2963469 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132259 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3032732 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131804 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102546 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053578 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094361 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087478 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3051145 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088029 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075241 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052783 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074277 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080730 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2816662 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:32] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086190 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133716 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086986 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3044638 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2998136 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131844 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2992961 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089085 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131256 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122495 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134491 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134345 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2850632 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077812 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2984160 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2933511 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3029522 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130234 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122322 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135823 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115821 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084927 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108528 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3015818 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077232 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101535 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102899 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105498 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115612 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133287 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119875 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089198 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066518 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117915 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129492 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077232 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059647 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127834 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071389 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119335 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081980 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:49] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107677 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118530 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131409 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077179 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095256 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070305 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090856 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124804 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043293 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097067 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097681 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3050503 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134146 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130321 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123968 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099517 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3038319 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128330 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109670 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093053 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3088335 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097687 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055812 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077476 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058555 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126405 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:39:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090735 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117780 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124284 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059714 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114941 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070666 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097342 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3019319 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118574 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082095 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134692 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098576 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118515 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2859520 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133569 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078349 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080643 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116366 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099402 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127475 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045233 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123259 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132490 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058137 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121164 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066494 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087816 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121094 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112491 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2934538 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134594 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093431 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107965 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056300 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101024 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064242 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136642 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109404 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104452 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084566 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121971 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074597 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062500 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120116 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134865 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126342 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131941 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110103 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136461 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095589 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3006375 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106291 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122832 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126672 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080590 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095780 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073132 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082663 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065171 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072783 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091827 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110573 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118200 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117386 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059544 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072113 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106586 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066440 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059449 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071231 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135439 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111691 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135035 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134802 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065221 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2996630 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124869 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094144 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121166 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3007925 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3002273 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097470 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080631 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3019827 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3100057 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3099503 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057815 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106724 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124399 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090599 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129442 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080777 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091906 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069979 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103404 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2989107 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2975718 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2852794 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133369 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102442 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123170 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3030664 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131819 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107636 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106834 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2998963 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095063 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122666 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076609 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097221 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096002 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108880 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106454 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3023945 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119397 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2930040 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114287 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129593 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2852598 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:33] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096922 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089602 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097765 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056136 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076863 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062132 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123052 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097014 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131768 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075594 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:35] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082026 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3087724 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3034771 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3089016 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3003731 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:36] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134162 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3007883 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2704965 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3115398 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068997 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:37] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3042543 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114679 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053666 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114580 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:38] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120011 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080603 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076390 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108681 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3010384 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:39] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110805 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126582 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102126 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095988 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084010 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:40] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096334 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3001801 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084671 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098487 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114791 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096395 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111071 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130274 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2840146 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076968 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3076097 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3104928 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080564 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055055 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059233 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094393 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3067047 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079795 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045827 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126042 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078984 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063994 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3025665 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084118 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061708 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3044688 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3080817 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122222 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3112072 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113825 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:40:47] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079211 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094524 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2979333 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3031878 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118620 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122821 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130539 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:05] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135127 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134858 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108220 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085789 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043197 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:06] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097696 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119434 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085779 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114755 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:07] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3042951 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058481 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079478 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133335 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102914 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:08] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096629 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136219 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120176 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043889 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:09] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126579 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078764 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2936415 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2680937 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056039 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:10] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132568 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131301 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3065600 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135032 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:11] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069006 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124913 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116569 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130647 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131306 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:12] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3102560 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:13] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124235 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124589 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3055575 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3061713 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137242 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:14] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072579 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119139 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132326 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064379 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3077499 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:15] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092935 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3070378 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3053378 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134266 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043697 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:16] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3084141 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073293 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3097673 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3056844 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:17] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081369 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3096685 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128426 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045900 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:18] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132550 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047000 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3057857 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108882 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093706 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:19] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3083236 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2754691 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134761 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3063762 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3066944 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135963 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098356 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069981 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3073208 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2963104 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3022704 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3030218 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3029487 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075767 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3128010 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:24] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118732 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123515 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068212 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060803 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085575 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:25] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135459 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3105579 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3126150 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122974 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:26] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110996 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134107 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137310 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3028441 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133294 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075917 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:28] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127997 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3092055 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091613 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098618 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043129 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047970 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3047940 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2945208 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2899965 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093731 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121421 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079297 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3015164 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:41:31] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134743 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:42:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2911870 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:42:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2717215 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:42:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3113859 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:42:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133019 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:42:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136465 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:44:50] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079703 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:44:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119763 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:44:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122244 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:44:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136565 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074019 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3098850 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:51] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3111556 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074258 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078141 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3060485 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119773 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:52] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129390 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3136584 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118778 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3064240 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:53] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3074869 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127937 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106779 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071900 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3058855 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:54] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3059432 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3117391 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125511 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068723 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3090748 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:55] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3132186 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122685 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118874 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3062483 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3081619 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:46:56] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3109530 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:47:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133436 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:47:29] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3122121 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:47:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3043432 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:47:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3068511 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:47:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3069365 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:47:30] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3020737 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3072721 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3075292 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3121387 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:01] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3085147 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093015 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3091628 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103424 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135163 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:02] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130644 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3137436 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3086277 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3078757 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3106625 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:03] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116669 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:04] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3093439 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:34] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3027478 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3108526 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3082103 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3114200 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124982 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  2962049 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:43] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123368 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3134278 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3123936 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131470 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127059 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:44] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3095290 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3079154 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130255 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3131126 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129326 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:45] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3110408 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130326 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3127558 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3103818 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3125665 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:48:46] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3133597 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
ERROR  : awplayer <ebml_read_num:378>:  read error at pos(120afec1d)
ERROR  : awplayer <ebml_peek_id:498>: Invalid id(0) at pos (0x120afec1d)
warning: unknown callback from Tinaplayer.
xplayer:process message XPLAYER_COMMAND_START.
(AllwinnerAlibs),line(1474) : ad_cedar seek sync ......nSeekTime:0
****player(0x12e6088): first audio pts = 0*****
*****tplayer:video decoded width = 1920,height = 1036
*****tplayer:video width = 3840,height = 2072
****player(0x12e6088): first video pts = 0*****
[1970-01-01 05:57:20] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3045868 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071158 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3035981 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129834 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130261 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:21] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3071373 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3052183 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3094339 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3130061 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3129003 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:22] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116484 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:23] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3118840 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3120913 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:27] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3017125 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3116302 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3101980 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3119712 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:41] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3107307 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3135469 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
[1970-01-01 05:57:42] WARNING: cedarc <RequestVideoStreamBuffer:1275>: request stream buffer fail,                  3124911 bytes valid data in SBM[0], total buffer size is 3145728 bytes.
ERROR  : awplayer <__FileStreamSeek:273>: invalid arguments, offset(1282084421980), size(4843367453), curPos(63060059)
ERROR  : awplayer <__FileStreamSeek:273>: invalid arguments, offset(1311566969217), size(4843367453), curPos(63074498)
ERROR  : awplayer <__FileStreamSeek:273>: invalid arguments, offset(24714604196), size(4843367453), curPos(63074504)
ERROR  : awplayer <__FileStreamSeek:273>: invalid arguments, offset(34114605295), size(4843367453), curPos(63074511)
[1970-01-01 05:57:52] WARNING: cedarc <detectWithoutStartCode:798>:  error: nNaluSize[33574968] > nCurStreamDataSize[20476], curNaluIdx = 1, max = 1024
ERROR  : awplayer <__FileStreamSeek:273>: invalid arguments, offset(2318868212006), size(4843367453), curPos(63532742)
[1970-01-01 05:57:54] ERROR  : cedarc <H264CheckNewFrame:2033>: here1: the first slice of the frame is not 0
ERROR  : awplayer <__FileStreamRead:154>: ret(-1), errno(5), cur pos:(100650246), impl->size(4843367453)
ERROR  : awplayer <ebml_read_num:378>:  read error at pos(5ffcd06)
ERROR  : awplayer <ebml_peek_id:498>: Invalid id(0) at pos (0x5ffcd06)
ERROR  : awplayer <__FileStreamRead:154>: ret(-1), errno(5), cur pos:(100650242), impl->size(4843367453)
ERROR  : awplayer <ebml_read_num:403>: Invalid EBML number size tag 0xd at pos(0xc04767e)
ERROR  : awplayer <ebml_peek_id:498>: Invalid id(0) at pos (0xc04767f)
ERROR  : awplayer <ebml_read_num:403>: Invalid EBML number size tag 0x4 at pos(0x1325b26a)
ERROR  : awplayer <ebml_peek_id:498>: Invalid id(0) at pos (0x1325b26b)
[1970-01-01 05:58:01] ERROR  : cedarc <H264CheckNewFrame:2033>: here1: the first slice of the frame is not 0
begin stop
xplayer:process message XPLAYER_COMMAND_STOP.
[1970-01-01 05:58:01] WARNING: cedarc <detectWithoutStartCode:798>:  error: nNaluSize[1963] > nCurStreamDataSize[1965], curNaluIdx = 1, max = 1024
begin stop
这种情况就是彻底死机了,按啥都没反应了:
^Cbegin stop
^Cbegin stop
^Cbegin stop
^ZGot signal 2, exiting ...
join in
^Zplayer reset
^Z^Z^Z^Z
楼主 #1 2024-05-29 10:49:09
memory
已发帖子: 656
Re: T113 tplayerdemo 播放视频,放着放着就挂了
发现是电脑里面的U盘挂了,CRC32读文件出现输入输出错误
最近编辑记录 memory (2024-05-29 10:50:13)
楼主 #2 2024-05-29 10:51:34
memory
已发帖子: 656
但是这狗屎一样的全志系统,出了重启别无他法,文件系统挂了关你播放器啥事,播放器挂了系统只能重启,垃圾
#3 2024-07-02 23:11:28
arychen
已发帖子: 275
我也发现了同样的问题。 中间报Io错误,还有各种错误,感觉播放器一点也不健壮,还不如以前F1C800这种跑melis系统的。
