楼主 # 2024-06-08 00:01:39
sunew
HI3516EV300,接入imx335,运行uvc_app,找不到/dev/video0报错
具体的日志是这个
[RCS]: /etc/init.d/S00devs
mknod: /dev/console: File exists
mknod: /dev/ttyAMA0: File exists
mknod: /dev/null: File exists
[RCS]: /etc/init.d/S01udev
udevd[640]: starting eudev-3.2.7
[RCS]: /etc/init.d/S80network
mmz_start: 0x42000000, mmz_size: 96M
sys_config: loading out-of-tree module taints kernel.
==== online_flag=0, cmos_yuv_flag=0, sensor=imx335, chip=hi3516ev300, board=demo====
==== g_quick_start_flag=0 ====
sysconfig init success!
Module himedia: init ok
Hisilicon Media Memory Zone Manager
hi_osal 1.0 init success!
hi3516ev200_base: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
load sys.ko for Hi3516EV200...OK!
load tde.ko for HI3516EV200...OK!
load region.ko for Hi3516EV200...OK!
load vgs.ko for Hi3516EV200...OK!
load vi.ko for Hi3516EV200...OK !
ISP Mod init!
load vpss.ko for Hi3516EV200...OK!
load vo.ko for Hi3516EV200...OK!
load hifb.ko OK!
load chnl.ko for Hi3516EV200...OK!
load vedu.ko for Hi3516EV200...OK!
load rc.ko for Hi3516EV200...OK!
load venc.ko for Hi3516EV200...OK!
load h264e.ko for Hi3516EV200...OK!
load h265e.ko for Hi3516EV200...OK!
load jpege.ko for Hi3516EV200...OK!
load ive.ko for Hi3516EV200...OK!
Load sensor_spi.ko for Hi3516EV200...OK !
load hi_piris.ko OK!!
insert audio
load mipi_rx driver successful!
/etc/init.d/rcS: line 46: /bin/stupid-ftpd: not found
ifconfig: SIOCSIFADDR: No such device
route: SIOCADDRT: Network is unreachable
Auto login as root ...
Jan  1 00:06:34 login[1076]: root login on 'ttyS000'
Welcome to HiLinux.
None of nfsroot found in cmdline.
@@@@@ HiUVC App Sample @@@@@
v4l2 open failed(/dev/video0): No such file or directory (2)
uvc_app exit!
hisi-femac 10040000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
