楼主 # 2024-05-27 00:00:34
qingyue.mo
V3S 硬件H264编码
按照 论坛unturned3 大佬给的包 去做  提示
CAM_V2P_IOCTL: Inappropriate ioctl for device
我使用的也是DVP 的 OV5640
我是不是没装什么库
大佬代码 cam.c这段
// dirty hack to get physical address of buffers
// see github repo README for details
perror_ret(ioctl(fd, CAM_V2P_IOCTL, &addr), "CAM_V2P_IOCTL");
出现了这个东西
大佬说的要获取物理地址 这个无法操作啊
有人遇到过吗 是少了什么么
copy_video.sh   fswebcam.sh     h264enc_demo    kern_update.sh
# ./h264enc_demo 640 480 30 300
Info: DLOG_LEVEL changed to 1
debug  : ionAlloc <__GetIonMemOpsS:985>:*** get __GetIonMemOpsS ***
debug  : ionAlloc <ion_alloc_open:134>:begin ion_alloc_open
debug  : cedarc <VeSetSpeed:1559>: *** set ve freq to 360 Mhz ***
debug  : cedarc <VeInitialize:1198>: ve init ok
debug  : ionAlloc <ion_alloc_open:175>:** phy offset = 40000000
debug  : cedarc <VeRelease:1253>: ve release ok
debug  : cedarc <LogVersionInfo:40>:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cedar Codec <<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : createBranch_customize_sylix
branch: CedarC-v1.1.9
commit: 4a182bd42c931bea2f77b0ff9a531d233df8541e
date  : Thu May 25 15:34:03 2017 +0800
author: jenkins8080
patch :
debug  : cedarc <VideoEncInit:195>: (f:VideoEncInit, l:195)
debug  : cedarc <VideoEncInit:210>: (f:VideoEncInit, l:210)
debug  : cedarc <BitStreamCreate:102>: BitStreamCreate OK
Info: h264 encoder init OK
Debug: 2 media entities detected
CAMEAR_IC: name  sun6i-csi: subdev entity id = -1
CAMEAR_IC: name  ov5640 1-003c: subdev entity id = -1
Debug: ov5640 1-003c: subdev entity id = 5
Debug: ov5640 1-003c: subdev pad = 0
Info: ov5640 1-003c: subdev format set to: 640x480, media bus format code = 0x20                               06
Info: ov5640 1-003c: frame rate: requested for 30; image sensor accepted 30
Error: cam_init() failed
#1 2024-05-27 12:16:07
4610
已发帖子: 113
Re: V3S 硬件H264编码
找物理地址映射直接查/proc/self/pagemap
或者先写个特征值在物理地址空间里逐页找都行
#2 2024-06-07 00:08:38
unturned3
已发帖子: 272
Re: V3S 硬件H264编码
你用我配套的buildroot了吗?我那里头有相关的内核补丁,没用补丁的话估计会导致 CAM_V2P_IOCTL: Inappropriate ioctl for device
#3 2024-06-07 00:11:28
unturned3
已发帖子: 272
Re: V3S 硬件H264编码
楼主 #4 2024-06-08 21:31:04
qingyue.mo
Re: V3S 硬件H264编码
万幸 前几天抱着姐姐睡觉 在梦里成功编码了  回来后按照梦里的指示   修改了 sun6i_video.c    成功实现了编码
可能我是5.2.y 配置文件无法完全适配  最后掉坑里了  只能复制粘贴地改
虽然成功了  但出现个新问题  OV5640   1920 1080  15帧  编码是看得到画面的
但当我
# ./f264 1920 1080 30 60
Info: captured 60 frames in 2.01s; FPS = 29.8
30帧  是带有绿色的花屏画面
按照你的代码 里的提示   也是无法解决这个问题
        // This ALIGN_16B thing is wrong?
        // At 1920x1080, this will screw up the data alignment and create a green band in video
        if(width==1920)
         buffers[l].addrVirC = buffers[l].start + ALIGN_16B(g_width) * ALIGN_16B(g_height);
        }else
        buffers[l].addrVirC = buffers[l].start + g_width * g_height;
        int addr = buf.m.offset;
        buffers[l].addrPhyY = (void *) addr;
        if(width==1920)
          buffers[l].addrPhyC = (void *) ( addr + ALIGN_16B(g_width) * ALIGN_16B(g_height) );
        }else
         buffers[l].addrPhyC = (void *) (addr + g_width * g_height);
Info: captured 60 frames in 23.73s; FPS = 2.5
效果如图
.png
这是编码后的视频截图
设置15帧的时候是:
图像下方好像有点问题  虽然不是很清晰
我想知道 为什么30帧的时候  画成绿色  15帧就有一点正常  是不是 PCLK速度不够?
楼主 #5 2024-06-09 22:13:18
qingyue.mo
Re: V3S 硬件H264编码
#6 2024-06-09 22:24:08
已发帖子: 9,401
