移植st官方的en.SOURCES-stm32mp1-openstlinux-5-4-dunfell-mp1-20-06-24.tar到开发板上,设备树参考野火的设备树进行修改,通过网线将网口直接连接电脑使用静态ip设置能够ping通,然后将网口接到路由器,使用dhcpc命令获取动态ip无法获取ip,请问有知道怎么解决吗?
开关eth0会报如下错误:
root@lubancat:~# ifconfig eth0 down
[ 91.649324] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 91.656553] stm32-dwmac 5800a000.ethernet eth0: Link is Down
[ 91.672475] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
root@lubancat:~# ifconfig eth0 up
[ 108.589301] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 108.597533] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet]
[ 108.620796] dwmac4: Master AXI performs any burst length
[ 108.624688] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[ 108.632229] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 108.641048] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[ 108.646857] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 108.660790] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
root@lubancat:~# [ 111.772307] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 111.779364] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
动态获取ip一直是这样:
root@lubancat:~# udhcpc -i eth0
udhcpc: started, v1.30.1
udhcpc: sending discover
使用静态IP ping电脑是没问题的
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.10.2 netmask 255.255.255.0 broadcast 192.168.10.255
ether 3e:ab:3b:fb:f4:91 txqueuelen 1000 (Ethernet)
RX packets 291 bytes 29201 (28.5 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 27 bytes 5532 (5.4 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 45
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 140 bytes 9672 (9.4 KiB)
TX packets 140 bytes 9672 (9.4 KiB)
root@lubancat:~# ping 192.168.10.10
PING 192.168.10.10 (192.168.10.10) 56(84) bytes of data.
64 bytes from 192.168.10.10: icmp_seq=1 ttl=128 time=0.777 ms
64 bytes from 192.168.10.10: icmp_seq=2 ttl=128 time=0.462 ms
64 bytes from 192.168.10.10: icmp_seq=3 ttl=128 time=0.327 ms
^C
--- 192.168.10.10 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 31ms
rtt min/avg/max/mdev = 0.327/0.522/0.777/0.188 ms
root@lubancat:~#
感觉像设备树还是驱动没移植成功
连上wifi执行udhcpc命令是能动态获取ip的,证明动态获取ip相关配置应该是没问题的
[root@star-mp157]:~$ ifconfig
lo Link encapocal Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 94:A1:A2:69:C4:50
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:254 (254.0 B) TX bytes:248 (248.0 B)
[root@star-mp157]:~$ udhcpc -i wlan0
udhcpc: started, v1.31.1
udhcpc: sending select for 192.168.137.83
udhcpc: lease of 192.168.137.83 obtained, lease time 604800
deleting routers
adding dns 192.168.137.1
但获取eth0的动态ip就是不成功,是设备还是驱动需要修改?有大佬知道吗?
[root@star-mp157]:~$ udhcpc -i eth0
[ 49.832857] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 49.840959] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet]
[ 49.860348] dwmac4: Master AXI performs any burst length
[ 49.864234] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[ 49.872056] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 49.880558] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[ 49.886381] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 49.895610] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 49.902976] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 49.912397] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 49.919453] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
^C
eth0 Link encap:Ethernet HWaddr 5E:65:81:5C:65:AB
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1026 (1.0 KiB)
Interrupt:45
https://blog.csdn.net/u014170843/article/details/120158095 我看这里的移植步骤我都做了,而且都有相应的打印了,但dhcp就是死活不行
[root@star-mp157]:~$ ifconfig eth0 up
[ 48.193921] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 48.201977] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet]
[ 48.221835] dwmac4: Master AXI performs any burst length
[ 48.225722] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[ 48.233230] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 48.241952] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[ 48.247857] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 48.257055] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 48.264728] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[root@star-mp157]:~$ [ 52.412118] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 52.419342] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
udhcpc: sending select for 192.168.22.76
udhcpc: lease of 192.168.22.76 obtained, lease time 7200
deleting routers
adding dns 192.168.25.2
adding dns 202.96.128.166
修改设备树将千兆改成百兆之后能够成功获取ip,感觉是配置千兆的时候哪里出问题了,目前就算百兆能执行udhcpc,但千兆不行,有大佬能指点下吗?
这种一般是千兆PHY没有配置好或者pcb布线的问题,需要调整tx_delay或者rx_delay
用的是野火的板子,用原来的固件是没问题的,所以首先排除PCB等硬件问题
问题解决了,也不是phy配置的问题,是uboot的网卡的设备树pin脚有一个没配好,不知道为什么会影响到kernel,kernel的设备树是没问题的,估计是uboot的引脚没释放吧,改了之后就没问题了
@why1canhbjack
可能是,uboot和内核驱动是不同的
