楼主 # 2024-06-19 09:24:50
wangjun110
A33主线Mali
参考大神 https://whycan.com/t_3675.html 的帖子。驱动能正常加载
root@FunKey:~# modprobe mali
[   12.885128] mali: loading out-of-tree module taints kernel.
[   12.902206] Allwinner sunXi mali glue initialized
[   12.907508] Mali:
[   12.907514] Found Mali GPU Mali-400 MP r1p1
[   12.914451] Mali:
[   12.914455] 2+0 PP cores initialized
[   12.920788] Mali:
[   12.920791] Mali device driver loaded
在但编译测试程序时(https://github.com/linux-sunxi/sunxi-mali/tree/master/test),需要-lX11,请问libX11.so是用buildroot里面的吗?mali-blobs没这个库。
楼主 #1 2024-06-20 11:36:17
wangjun110
Re: A33主线Mali
cat /tmp/Xorg.0.0.log
[     2.531]
X.Org X Server 1.20.10
X Protocol Version 11, Revision 0
[     2.531] Build Operating System: Linux 5.15.0-107-generic x86_64
[     2.531] Current Operating System: Linux FunKey 5.5.5 #2 SMP Thu Jun 20 09:32:37 CST 2024 armv7l
[     2.531] Kernel command line: console=ttyS0,115200 panic=5 rootwait fbcon=map:10 fbcon=font:VGA8x8 vt.global_cursor_default=0 root=/dev/mmcblk0p2 rootfstype=ext4 rootflags=commit=120,data=writeback,barrier=0,journal_async_commit ro
[     2.531] Build Date: 20 June 2024  09:20:25AM
[     2.531]
[     2.531] Current version of pixman: 0.40.0
[     2.531]    Before reporting problems, check [url]http://wiki.x.org[/url]
        to make sure that you have the latest version.
[     2.531] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     2.531] (==) Log file: "/var/log/Xorg.0.0.log", Time: Thu Jan  1 00:00:00 1970
[     2.535] (==) Using config file: "/etc/X11/xorg.conf"
[     2.536] (==) No Layout section.  Using the first Screen section.
[     2.536] (==) No screen section available. Using defaults.
[     2.536] (**) |-->Screen "Default Screen Section" (0)
[     2.536] (**) |   |-->Monitor "<default monitor>"
[     2.537] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[     2.537] (**) |   |-->Device "Allwinner A10/A13 FBDEV"
[     2.537] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[     2.537] (==) Not automatically adding devices
[     2.537] (==) Not automatically enabling devices
[     2.537] (==) Not automatically adding GPU devices
[     2.537] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     2.547] (WW) The directory "/usr/share/fonts/X11//TTF/" does not exist.
[     2.547]    Entry deleted from font path.
[     2.547] (WW) The directory "/usr/share/fonts/X11//OTF/" does not exist.
[     2.547] (WW) The directory "/usr/share/fonts/X11//Type1/" does not exist.
[     2.547] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11//100dpi/".
[     2.547]    (Run 'mkfontdir' on "/usr/share/fonts/X11//100dpi/").
[     2.548] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11//75dpi/".
[     2.548]    Entry deleted from font path.
[     2.548]    (Run 'mkfontdir' on "/usr/share/fonts/X11//75dpi/").
[     2.548] (==) FontPath set to:
        /usr/share/fonts/X11//misc/
[     2.548] (==) ModulePath set to "/usr/lib/xorg/modules"
[     2.548] (==) |-->Input Device "<default pointer>"
[     2.548] (==) |-->Input Device "<default keyboard>"
[     2.548] (==) No Layout section. Using the default mouse configuration.
[     2.548] (==) No Layout section. Using the default keyboard configuration.
[     2.548] (II) Loader magic: 0x1d0c78
[     2.548] (II) Module ABI versions:
[     2.548]    X.Org ANSI C Emulation: 0.4
[     2.548]    X.Org Video Driver: 24.1
[     2.548]    X.Org XInput driver : 24.1
[     2.548]    X.Org Server Extension : 10.0
[     2.548] (II) LoadModule: "fbturbo"
[     2.551] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[     2.569] (II) Module fbturbo: vendor="X.Org Foundation"
[     2.569]    compiled for 1.20.13, module version = 0.4.0
[     2.569]    Module class: X.Org Video Driver
[     2.569]    ABI class: X.Org Video Driver, version 24.1
[     2.569] (II) LoadModule: "mouse"
[     2.569] (II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
[     2.572] (II) Module mouse: vendor="X.Org Foundation"
[     2.572]    compiled for 1.20.10, module version = 1.9.3
[     2.572]    Module class: X.Org XInput Driver
[     2.572]    ABI class: X.Org XInput driver, version 24.1
[     2.572] (II) LoadModule: "kbd"
[     2.573] (II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
[     2.574] (II) Module kbd: vendor="X.Org Foundation"
[     2.574]    compiled for 1.20.10, module version = 1.9.0
[     2.574]    Module class: X.Org XInput Driver
[     2.574]    ABI class: X.Org XInput driver, version 24.1
[     2.574] (II) FBTURBO: driver for framebuffer: fbturbo
[     2.574] (++) using VT number 1
[     2.575] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[     2.575] (WW) Falling back to old probe method for fbturbo
[     2.575] (II) Loading sub module "fbdevhw"
[     2.575] (II) LoadModule: "fbdevhw"
[     2.575] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     2.577] (II) Module fbdevhw: vendor="X.Org Foundation"
[     2.577]    compiled for 1.20.10, module version = 0.0.2
[     2.577]    ABI class: X.Org Video Driver, version 24.1
[     2.577] (II) FBTURBO(0): using /dev/fb0
[     2.578] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[     2.578] (II) FBTURBO(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     2.578] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[     2.578] (==) FBTURBO(0): RGB weight 888
[     2.578] (==) FBTURBO(0): Default visual is TrueColor
[     2.578] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[     2.578] (II) FBTURBO(0): hardware: sun4i-drmdrmfb (video memory: 4800kB)
[     2.578] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[     2.578] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[     2.578] (II) FBTURBO(0): processor: ARM Cortex-A7
[     2.578] (II) FBTURBO(0): checking modes against framebuffer device...
[     2.578] (II) FBTURBO(0): checking modes against monitor...
[     2.578] (II) FBTURBO(0): Virtual size is 1024x600 (pitch 1024)
[     2.578] (**) FBTURBO(0):  Built-in mode "current"
[     2.578] (==) FBTURBO(0): DPI set to (96, 96)
[     2.578] (II) Loading sub module "fb"
[     2.578] (II) LoadModule: "fb"
[     2.579] (II) Loading /usr/lib/xorg/modules/libfb.so
[     2.584] (II) Module fb: vendor="X.Org Foundation"
[     2.584]    compiled for 1.20.10, module version = 1.0.0
[     2.584]    ABI class: X.Org ANSI C Emulation, version 0.4
[     2.636] (II) FBTURBO(0): using backing store heuristics
[     2.643] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[     2.644] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[     2.644] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[     2.644] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[     2.644] (II) FBTURBO(0): enabled VFP/NEON optimizations
[     2.644] (==) FBTURBO(0): Backing store disabled
[     2.651] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[     2.652] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[     2.653] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[     2.654] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[     2.655] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[     2.656] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[     2.656] (==) FBTURBO(0): DPMS enabled
[     2.656] (II) FBTURBO(0): failed to enable hardware cursor
[     2.728] (II) FBTURBO(0): can't load 'mali_drm' kernel module
[     2.728] (II) Loading sub module "dri2"
[     2.728] (II) LoadModule: "dri2"
[     2.728] (II) Module "dri2" already built-in
[     2.743] SunxiMaliDRI2_Init: drmOpen failed!
[     2.743] (II) FBTURBO(0): failed to enable DRI2 integration for Mali GPU
[     2.743] (II) Initializing extension Generic Event Extension
[     2.743] (II) Initializing extension SHAPE
[     2.743] (II) Initializing extension MIT-SHM
[     2.743] (II) Initializing extension XInputExtension
[     2.747] (II) Initializing extension XTEST
[     2.747] (II) Initializing extension BIG-REQUESTS
[     2.747] (II) Initializing extension SYNC
[     2.747] (II) Initializing extension XKEYBOARD
[     2.747] (II) Initializing extension XC-MISC
[     2.747] (II) Initializing extension XFIXES
[     2.747] (II) Initializing extension RENDER
[     2.747] (II) Initializing extension RANDR
[     2.747] (II) Initializing extension DAMAGE
[     2.747] (II) Initializing extension DOUBLE-BUFFER
[     2.747] (II) Initializing extension RECORD
[     2.747] (II) Initializing extension DPMS
[     2.747] (II) Initializing extension Present
[     2.747] (II) Initializing extension DRI3
[     2.748] (II) Initializing extension X-Resource
[     2.748] (II) Initializing extension XVideo
[     2.748] (II) Initializing extension XVideo-MotionCompensation
[     2.748] (II) Initializing extension XFree86-VidModeExtension
[     2.748] (II) Initializing extension XFree86-DGA
[     2.748] (II) Initializing extension DRI2
[     2.957] (II) Using input driver 'mouse' for '<default pointer>'
[     2.958] (**) Option "CorePointer" "on"
[     2.958] (**) <default pointer>: always reports core events
[     2.958] (WW) <default pointer>: No Device specified, looking for one...
[     2.958] (EE) <default pointer>: Cannot find which device to use.
[     2.958] (==) <default pointer>: Protocol: "Auto"
[     2.958] (EE) xf86OpenSerial: No Device specified.
[     2.958] (WW) <default pointer>: cannot open input device
[     2.958] (==) <default pointer>: Emulate3Buttons, Emulate3Timeout: 50
[     2.958] (**) <default pointer>: ZAxisMapping: buttons 4 and 5
[     2.958] (**) <default pointer>: Buttons: 9
[     2.958] (II) XINPUT: Adding extended input device "<default pointer>" (type: MOUSE, id 6)
[     2.959] (**) <default pointer>: (accel) keeping acceleration scheme 1
[     2.959] (**) <default pointer>: (accel) acceleration profile 0
[     2.959] (**) <default pointer>: (accel) acceleration factor: 2.000
[     2.959] (**) <default pointer>: (accel) acceleration threshold: 4
[     2.959] (EE) xf86OpenSerial: No Device specified.
[     2.959] (WW) <default pointer>: cannot open input device
[     2.959] (II) Using input driver 'kbd' for '<default keyboard>'
[     2.959] (**) Option "CoreKeyboard" "on"
[     2.959] (**) <default keyboard>: always reports core events
[     2.959] (**) Option "Protocol" "standard"
[     2.959] (**) Option "XkbRules" "base"
[     2.959] (**) Option "XkbModel" "pc105"
[     2.959] (**) Option "XkbLayout" "us"
[     2.959] (II) XINPUT: Adding extended input device "<default keyboard>" (type: KEYBOARD, id 7)
xrog启动log,求救
最近编辑记录 wangjun110 (2024-06-20 11:50:44)
楼主 #2 2024-06-21 09:16:04
wangjun110
Re: A33主线Mali
Xorg是使用xf86-video-fbdev还是xf86-video-fbturbo呢?
如果用xf86-video-fbturbo的话会提示mali_drm.ko没被加载。
最近编辑记录 wangjun110 (2024-06-21 09:17:05)
楼主 #3 2024-06-24 10:50:46
wangjun110
Re: A33主线Mali
用lima+mesa3d有效果了
楼主 #4 2024-06-24 16:38:54
wangjun110
Re: A33主线Mali
运行其它的DEMO会出现。libEGL warning: DRI2: failed to authenticate
free(): double free detected in tcache 2
Aborted
