楼主 # 2024-06-21 11:38:47
DSH
F133芯片使用v1.5版本emmc启动
有大佬帮忙看一下烧录和开机打印log有问题吗 log.txt
[16542]fes begin commit:5bc6066ed0-dirty
[16546]set pll start
[16548]1008M
[16551]periph0 has been enabled
[16554]set pll end
[16555]board init ok
[16557]beign to init dram
[16560]ZQ value = 0x30
[16562]get_pmu_exist() = -1
[16564]ddr_efuse_type: 0xa
[16567]trefi:7.8ms
[16569][AUTO DEBUG] single rank and full DQ!
[16573]ddr_efuse_type: 0xa
[16576]trefi:7.8ms
[16578][AUTO DEBUG] rank 0 row = 13
[16581][AUTO DEBUG] rank 0 bank = 4
[16585][AUTO DEBUG] rank 0 page size = 2 KB
[16589]DRAM BOOT DRIVE INFO: V0.35
[16592]DRAM CLK = 528 MHz
[16594]DRAM Type = 2 (2:DDR2,3:DDR3)
[16598]DRAMC read ODT  off.
[16600]DRAM ODT off.
[16602]ddr_efuse_type: 0xa
[16605]DRAM SIZE = 64 MB
[16609]DRAM simple test OK.
[16612]init dram ok
U-Boot 2018.07-00001-gac341e0 (Apr 20 2024 - 06:13:29 +0000) Allwinner Technology
[19.241]DRAM:  64 MiB
[19.246]Relocation Offset is: 01f3b000
[19.266]secure enable bit: 0
[19.272]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[19.278]sunxi flash map init
SPI ALL:   ready
[19.315]line:703 init_clocks
[19.328]init_clocks:finish
[19.331]flash init start
[19.333]workmode = 16,storage type = 0
try card 2
set card number 2
get card number 2
[19.341][mmc]: mmc driver ver uboot2018:2023-08-29 10:12:00
[19.350][mmc]: get sdc_type fail and use default host:tm4.
[19.382][mmc]: Is not Boot mode!
[19.385][mmc]: SUNXI SDMMC Controller Version:0x50310
[19.396][mmc]: ************Try SD card 2************
[19.402][mmc]: mmc 2 cmd timeout 100 status 100
[19.406][mmc]: smc 2 err, cmd 8,  RTO
[19.409][mmc]: mmc 2 close bus gating and reset
[19.414][mmc]: mmc 2 cmd timeout 100 status 100
[19.418][mmc]: smc 2 err, cmd 55,  RTO
[19.422][mmc]: mmc 2 close bus gating and reset
[19.426][mmc]: ************Try MMC card 2************
[19.567][mmc]: mmc 2 cmd timeout 100 status 100
[19.571][mmc]: smc 2 err, cmd 8,  RTO
[19.575][mmc]: mmc 2 close bus gating and reset
[19.580][mmc]: mmc 2 cmd timeout 100 status 100
[19.584][mmc]: smc 2 err, cmd 55,  RTO
[19.587][mmc]: mmc 2 close bus gating and reset
[19.604][mmc]: gen_tuning_blk_bus8: total blk 10
[19.609][mmc]: gen_tuning_blk_bus4: total blk 6
[19.614][mmc]: Using 4 bit tuning now
[19.618][mmc]: write_tuning_try_freq: write ok
[19.623][mmc]: Pattern compare ok
[19.626][mmc]: Write tuning pattern ok
[19.629][mmc]: ================== HSSDR52_SDR25...
[19.634][mmc]: skip freq 400000
[19.637][mmc]: skip freq 25000000
[19.640][mmc]: freq: 2-50000000-64-4
[20.509][mmc]: [0-63|64]
[20.511][mmc]: ================== HSDDR52_DDR50...
[20.516][mmc]: skip freq 400000
[20.519][mmc]: freq: 1-25000000-64-4
[21.223][mmc]: freq: 2-50000000-64-4
[21.816][mmc]: [0-51|52]
[21.819][mmc]: [0-44|45] [49-51|3]
[21.822][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
[21.826][mmc]: HSSDR52/SDR25: 0xff20ffff 0xffffffff
[21.831][mmc]: HSDDR52/DDR50: 0xff161aff 0xffffffff
[21.835][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
[21.840][mmc]: HS400: 0xffffffff 0xffffffff
[21.844][mmc]: HS400: 0xffffffff 0xffffffff
[21.848][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[21.860]Loading Environment from SUNXI_FLASH... OK
[21.867]try to burn key
[21.871]out of usb burn from boot: not need burn key
sunxi work mode=0x10
run usb efex
delay time 2500
weak:otg_phy_config
usb init ok
set address 0x12
set address 0x12 ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x1
origin_erase_flag = 0x0
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 7
part[0] name      :env
part[0] classname :DISK
part[0] addrlo    :0x80
part[0] lenlo     :0x100
part[0] user_type :32768
part[0] keydata   :0
part[0] ro        :1
part[1] name      :env-redund
part[1] classname :DISK
part[1] addrlo    :0x180
part[1] lenlo     :0x100
part[1] user_type :32768
part[1] keydata   :0
part[1] ro        :1
part[2] name      :bootA
part[2] classname :DISK
part[2] addrlo    :0x280
part[2] lenlo     :0x1800
part[2] user_type :32768
part[2] keydata   :0
part[2] ro        :1
part[3] name      :bootB
part[3] classname :DISK
part[3] addrlo    :0x1a80
part[3] lenlo     :0x1800
part[3] user_type :32768
part[3] keydata   :0
part[3] ro        :1
part[4] name      :ROOTFS
part[4] classname :DISK
part[4] addrlo    :0x3280
part[4] lenlo     :0x4f70
part[4] user_type :32768
part[4] keydata   :0
part[4] ro        :1
part[5] name      :USER_DATA
part[5] classname :DISK
part[5] addrlo    :0x81f0
part[5] lenlo     :0xa000
part[5] user_type :32768
part[5] keydata   :0
part[5] ro        :0
part[6] name      :UDISK
part[6] classname :DISK
part[6] addrlo    :0x121f0
part[6] lenlo     :0x0
part[6] user_type :32768
part[6] keydata   :0
part[6] ro        :0
common1(partition3) need it, here is a weak func
total part: 8
mbr 0, 80, 8000
env 1, 100, 8000
env-redund 2, 100, 8000
bootA 3, 1800, 8000
bootB 4, 1800, 8000
ROOTFS 5, 4f70, 8000
USER_DATA 6, a000, 8000
UDISK 7, 0, 8000
[25.543]erase all part start
need erase flash: 1
no part need to protect user data
[25.552]erase all part start
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
write primary GPT success
write Backup GPT success
[25.569]update partition map
******Has init
FEX_CMD_fes_verify_value, start 0x80, size high 0x0:low 0x1000
FEX_CMD_fes_verify_value 0x2b2c8554
FEX_CMD_fes_verify_value, start 0x180, size high 0x0:low 0x1000
FEX_CMD_fes_verify_value, start 0x280, size high 0x0:low 0xa4000
FEX_CMD_fes_verify_value 0xa00c8fe9
FEX_CMD_fes_verify_value, start 0x1a80, size high 0x0:low 0xa4000
FEX_CMD_fes_verify_value, start 0x3280, size high 0x0:low 0x51af00
FEX_CMD_fes_verify_value 0x506dcfbc
FEX_CMD_fes_verify_value, start 0x81f0, size high 0x0:low 0x1400000
FEX_CMD_fes_verify_value 0xc3cd1b47
flash sectors: 0xe90000
FEX_CMD_fes_verify_value, start 0x121f0, size high 0x0:low 0x47c2000
FEX_CMD_fes_verify_value 0xa0be6e23
bootfile_mode=4
SUNXI_EFEX_BOOT1_TAG
boot1 size = 0xa4000, max size = 0x200000
uboot size = 0xa4000
storage type = 2
bootfile_mode=4
SUNXI_EFEX_BOOT0_TAG
boot0 size = 0xc000
[51.015][mmc]: write mmc 2 info ok
dram para[0] = 210
dram para[1] = 2
dram para[2] = 7b7bf9
dram para[3] = 0
dram para[4] = d2
dram para[5] = 400000
dram para[6] = e73
dram para[7] = 2
dram para[8] = 0
dram para[9] = 0
dram para[10] = 471992
dram para[11] = 131a10c
dram para[12] = 57041
dram para[13] = b4787896
dram para[14] = 0
dram para[15] = 48484848
dram para[16] = 48
dram para[17] = 1621121e
dram para[18] = 0
dram para[19] = 0
dram para[20] = 0
dram para[21] = 30010
dram para[22] = 35
dram para[23] = b4006003
dram para[24] = 0
dram para[25] = 0
dram para[26] = 0
dram para[27] = 0
dram para[28] = 0
dram para[29] = 0
dram para[30] = 0
dram para[31] = 0
storage type = 2
sunxi_efex_next_action=2
exit usb
next work 2
[36]HELLO! BOOT0 is starting!OT
[38]BOOT0 commit : 5bc6066ed0-dirty
sbi2ekernel
|                  /'\_/`\       (_ )  _                      ( )( )     /' _`\    /' _`\
|                  |     |   __   | | (_)  ___  ______  _   _ | || |     | ( ) |   | ( ) |
|                  | (_) | /'__`\ | | | |/',__)(______)( ) ( )| || |_    | | | |   | | | |
|                  | | | |(  ___/ | | | |\__, \        | \_/ |(__ ,__) _ | (_) | _ | (_) |
|                  (_) (_)`\____)(___)(_)(____/        `\___/'   (_)  (_)`\___/'(_)`\___/'
|version : V4.0.0        |
|commitid: f204d55e50503ab9b9f0cdaf059e4204b35ec1da                                                           |
|sunxiver: 40000        |
|timever : Fri, 21 Jun 2024 11:29:10 +0800        |
|compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104)                                           |
|optimal : -Os -g -gdwarf-2 -gstrict-dwarf        |
|linker  : GNU ld (GNU Binutils) 2.32        |
|newlibc : 3.0.0        |
|author  : dsh        |
[DBG]: [__mount_parts:0301]:                                classname=DMS
[DBG]: [__mount_parts:0302]:                                devname=dms01
[DBG]: [__mount_parts:0330]:                                find last lun.
[DBG]: [__mount_parts:0367]:                                nPart = 1.
[DBG]: [__mount_parts:0496]:                                dmsPart: "DMS\dms010" is linked to symbel "B".
[ERR]: [esFSYS_pread:0331]:                                 part is not readable!
[ERR]: [exfat_identify:0118]:                               esFSYS_pread read failed
mount errno: -19!
[DBG]: [esFSYS_mntfs:0333]:                                 melis_devfs,mount on B.
[DBG]: [kservice_maintask:0845]:                            partition [B] plug in..
sunxi_dma_clk_init()412 enter dma clk init
dfs already init.
used_card_no = 0x5
init sdmmc driver name: sdmmc i= 0
SDC:hal_sdc_create host:0x40261240 id:0
host debug mask 3c[ERR] SDC:bus-width default: 4
SDC:name ???,port 6,port_num 0,mul_sel 2, pull 1, drv_level 1
SDC:name ???,port 6,port_num 1,mul_sel 2, pull 1, drv_level 1
SDC:name ???,port 6,port_num 2,mul_sel 2, pull 1, drv_level 1
SDC:name ???,port 6,port_num 3,mul_sel 2, pull 1, drv_level 1
SDC:name ???,port 6,port_num 4,mul_sel 2, pull 1, drv_level 1
SDC:name ???,port 6,port_num 5,mul_sel 2, pull 1, drv_level 1
SDC:Not implement __mci_restore_io,939
SDC:Not imp hal_sdc_init,2704
SDC:hal_sdc_init,2744 no imp
SDC:hal_sdc_init,2753 no imp
SDC:SDC Host Capability:0x20f Ocr avail:0x3f0000
SDC:Not implement __mci_hold_io,924
SDC:SDC cd_mode:2 present_val:0
SDC:SDC id:0 dma_use:1 present:0
 driver version SD/MMC/SDIO Host Controller Driver(v0.30 2023-10-30 12:10) init ok.
host_id =0!
init sdmmc driver name: sdmmc2 i= 2
SDC:hal_sdc_create host:0x40261400 id:2
host debug mask 3cSDC:name ???,port 3,port_num 2,mul_sel 3, pull 1, drv_level 1
SDC:name ???,port 3,port_num 3,mul_sel 3, pull 1, drv_level 1
SDC:name ???,port 3,port_num 6,mul_sel 3, pull 1, drv_level 1
SDC:name ???,port 3,port_num 5,mul_sel 3, pull 1, drv_level 1
SDC:name ???,port 3,port_num 4,mul_sel 3, pull 1, drv_level 1
SDC:name ???,port 3,port_num 7,mul_sel 3, pull 1, drv_level 1
SDC:Not imp hal_sdc_init,2720
SDC:SDC cd_mode:3 present_val:0
SDC:SDC id:2 dma_use:1 present:1
card_detect insert sdmmc_test->card_id=2
card id is 2
SD:mmc_card_create card:0x40221280 id:2
card debug mask 3c
scheduler startup
SDC:SDC clock=400000 kHz,src:0, n:1, m:14
[ERR] SDC:__mci_irq_handler,1025 raw_int:100 err!
[ERR] SDC:SDC err, cmd 8,  RTO
[ERR] SDC:sdc 819 abnormal status: RespErr
SD:sd1.0 or mmc
SD:***** Try mmc *****
SD:card raw csd:
m:4095, e:7, dtr:25000000, cl:245, len:512, cap:2097152 str:3, clk:50
max_clk:50, mul:26, unit:10000000, clk26000000
HAL_GetDevClock,90 Warning Use fix value 600000000
SDC:SDC clock=25000000 kHz,src:1, n:0, m:11
SD:***** mmc init ok *****
Initial card success
[DBG]: [melis_part_init_bootcard:0968]:                     the actual total_size of the emmc is 15269888 sectors
[DBG]: [melis_part_init_bootcard:1010]:                     sdmmc user gpt
ekernel/drivers/drv/source/sdmmc/sdmmc_drv.c 1097 melis_part_init_bootcard name:env
ekernel/drivers/drv/source/sdmmc/sdmmc_drv.c 1097 melis_part_init_bootcard name:env-redund
ekernel/drivers/drv/source/sdmmc/sdmmc_drv.c 1097 melis_part_init_bootcard name:bootA
ekernel/drivers/drv/source/sdmmc/sdmmc_drv.c 1097 melis_part_init_bootcard name:bootB
ekernel/drivers/drv/source/sdmmc/sdmmc_drv.c 1097 melis_part_init_bootcard name:ROOTFS
[DBG]: [__mount_parts:0301]:                                classname=DISK
[DBG]: [__mount_parts:0302]:                                devname=ROOTFS
[DBG]: [__mount_parts:0496]:                                rawpart: "DISK\ROOTFS0" is linked to symbel "D".
[DBG]: [esFSYS_mntfs:0333]:                                 minfs,mount on D.
[DBG]: [kservice_maintask:0845]:                            partition [D] plug in..
ekernel/drivers/drv/source/sdmmc/sdmmc_drv.c 1097 melis_part_init_bootcard name:USER_DATA
[DBG]: [__mount_parts:0302]:                                devname=USER_DATA
[DBG]: [__mount_parts:0496]:                                rawpart: "DISK\USER_DATA0" is linked to symbel "E".
[DBG]: [esFSYS_mntfs:0333]:                                 fat,mount on E.
[DBG]: [kservice_maintask:0845]:                            partition [E] plug in..
ekernel/drivers/drv/source/sdmmc/sdmmc_drv.c 1097 melis_part_init_bootcard name:UDISK
[DBG]: [__mount_parts:0302]:                                devname=UDISK
[DBG]: [__mount_parts:0496]:                                rawpart: "DISK\UDISK0" is linked to symbel "W".
[DBG]: [esFSYS_mntfs:0333]:                                 fat,mount on W.
[DBG]: [kservice_maintask:0845]:                            partition [W] plug in..
host_id =2!
[ERR]: [hal_ths_init:0094]:                                 0x2009404, 0x2009400, 0x2009430, 0x2009408
port_info->port.port_type:2
the cir_master_init success
[ehci-usb1] insmod host driver!
phy_vbase : 0x4200800, usbc_no : 1, efuse : 0x1e9300c
[ohci-usb1] insmod host driver!
[DBG]: [layer_request:0706]:                                layer_request MOD_DISP_LAYER_WORK_MODE_SCALER
[DBG]: [layer_request:0756]:                                requested: ch:0, id:0  disp_mgr[0].req_layer_cnt = 1
[ERR]: [open_lcd_backlight:0627]:                           get backlight err,default to 100
[DBG]: [open_lcd_backlight:0631]:                           mixture backlight = 100
msh />enter app_entry
Execute startup script begin..............
         install mod para num [2]: insmod d:\mod\orange.mod
Mod:d:\mod\orange.mod Installed!, mod id=120
         install mod para num [2]: insmod d:\apps\desktop.mod
[DBG]: [DESKTOP_MOpen:0091]:                                DESKTOP_MOpen.
Mod:d:\apps\desktop.mod Installed!, mod id=127
...............Execute startup script end
[DBG]: [msg_srv_init_key_channel:0163]:                     emit_ctr.h_keyGraber=0x4045a1a0
[DBG]: [msg_srv_init_key_channel:0174]:                     LdevID=0
[DBG]: [application_init_process:0853]:                     &           application_init_process enter!             &
dsk_reg_read_config_file 603 e:\setting.bin eLIBs_fopen fail
dsk_reg_init_para 827 config not ok, format e:
[DBG]: [esFSYS_umntfs:0395]:                                part "E:[USER_DATA0]" is unmounted from "fat" fs.
[DBG]: [kservice_maintask:0855]:                            partition [E] plug out..
[DBG]: [fat_format:0047]:                                   fat format enter...
[E/DFS] open failed
can not find device:/dev/UDISK_flush
[DBG]: [fat_format:0049]:                                   fat format return(0)
[E/DFS] `open failed
[DBG]: [application_init_process:0871]:                     application_init_process 871 before live_init
[DBG]: [live_init:0056]:                                    ~~~~~~~~~~~~~~before dsk_set_isn_charset~~~~~~~~~~~
[DBG]: [dsk_display_set_lcd_brightness:0300]:               setting lcd_bright=176
[DBG]: [application_init_process:0879]:                     application_init_process 879 before gscene_bgd_init
[DBG]: [gscene_bgd_is_file_exist:0633]:                     file is exist:d:\apps\bg_default0.bgd
[DBG]: [gscene_bgd_init:0143]:                              bgd_com->screen_size.width = 1920  bgd_com->screen_size.height = 1080  ftype = 1
[DBG]: [application_init_process:0900]:                     .start device monitor .......................................
[DBG]: [application_init_process:0908]:                     application_init_process 908 before init_mainwin_create
[DBG]: [dsk_display_set_lcd_brightness:0300]:               setting lcd_bright=192
[DBG]: [headbar_init_uipara:0084]:                          AAAAAAW=1081570040 BBBBBBBH=1081570044
[DBG]: [headbar_init_uipara:0119]:                          1920_800
[DBG]: [__hbar_layer_create:0107]:                          hbar fb 480 24 gui_dir=0
[DBG]: [__hbar_layer_create:0108]:                          hbar src 0 0 480 24
[DBG]: [__hbar_layer_create:0109]:                          hbar scn 720 0 480 24
card_detect removed sdmmc_test->card_id=0
[WRN] SD:mmc_card_open card not exit! id:0
card open fail
[usb0] insmod device driver!
adbd version:AW-V1.1.0, compiled on: Jun 21 2024 11:29:15
phy_vbase : 0x4100400, usbc_no : 0, efuse : 0x1e9300c
adbd service init successful
[DBG]: [reset_headbar_data:0287]:                           xxxxxx para->data.volume = 30
[DBG]: [reset_headbar_data:0291]:                           xxxxxx bright = 11
[DBG]: [init_mainwin_cb:2450]:                              .start device monitor .......................................
[DBG]: [application_init_process:0914]:                     application_init_process 914 before _process_init
[DBG]: [applet_info_manager_load_dir:0320]:                 find dir file d:\apps\desktop\app_root.desktop!
[DBG]: [applet_info_manager_load_file:0280]:                filename = d:\apps\desktop\app_root.desktop len=124
[DBG]: [_process_init:0419]:                                ********_process_init***********
[DBG]: [__activity_load_common:0408]:                       load application application://app_root.
[DBG]: [app_home_create:0689]:                              ********  enter multi screen home application  **************
[DBG]: [get_fb_from_file:0423]:                             filename=d:\apps\bg_default0.bgd
[DBG]: [get_fb_from_file:0465]:                             bg pic is compress...
[DBG]: [get_fb_from_file:0468]:                             compress_buf=40e43000
[DBG]: [gscene_bgd_set_status_show:0183]:                   bkpic: d:\apps\bg_default0.bgd.
[DBG]: [disp_layer_get_para:0930]:                          ch[0]lyl[0] disable, use storage value
[ERR]: [Mod_Display_MIoctrl:1870]:                          no this CMD in display mod
[DBG]: [dsktop_scene_get_cur_app:0678]:                     g_last_desk_app_index:0
[DBG]: [desktop_scene_create:0596]:                         width = 1920, height= 1080
[DBG]: [desktop_scene_create:0601]:                         1cur_desk_app_index:0
[DBG]: [GUI_LogicLayerRequest:0647]:
  2src.w = 1920   2src.h = 1080
[DBG]: [layer_request:0723]:                                layer_request MOD_DISP_LAYER_WORK_MODE_NORMAL
[DBG]: [layer_request:0756]:                                requested: ch:1, id:0  disp_mgr[0].req_layer_cnt = 1
[DBG]: [_LyrOn:0145]:                                       herexx GUI_LogicLayerRequest xxxxxxxxxxx  p_lyr->h_hwlyr = 68
  2src.w = 480   2src.h = 24
[DBG]: [layer_request:0756]:                                requested: ch:1, id:1  disp_mgr[0].req_layer_cnt = 2
[DBG]: [_LyrOn:0145]:                                       herexx GUI_LogicLayerRequest xxxxxxxxxxx  p_lyr->h_hwlyr = 69
[DBG]: [app_root_wincreate:4517]:                           root win = 405ef8f8
[DBG]: [application_init_process:0935]:                     application_init_process 935 before GUI_GetMessageEx
thread:initprocess stack overflow
thread                           pri  status      sp     stack size max used left tick  error
initbkhdle                        24  ready   0x00000180 0x00000800    22%   0x0000000f -02
headbar_fresh                     24  suspend 0x00000200 0x00002000    12%   0x0000000f 000
adbd-clean                        20  suspend 0x000001b0 0x00002000    05%   0x00000005 000
adbd-output                       20  suspend 0x00000250 0x00002000    14%   0x00000005 000
adbd-input                        20  suspend 0x00000250 0x00002000    08%   0x00000005 000
appmsg2emitq                       9  suspend 0x000001e0 0x00001000    15%   0x00000014 000
initprocess                       24  ready   0x00000e40 0x00010000    100%   0x00000002 000
emitq2orange                      24  ready   0x000001a0 0x00001000    22%   0x0000000f -02
OrangTmr                           9  suspend 0x00000180 0x00001000    93%   0x00000014 000
tshell                            12  suspend 0x00000300 0x00004000    19%   0x00000001 000
kb_input                           3  suspend 0x00000530 0x00001000    35%   0x0000000a 000
hub_tt                             3  suspend 0x00000140 0x00002000    03%   0x0000000a 000
hub-status-thread                  3  suspend 0x000001d0 0x00002000    05%   0x0000000a 000
giveback_workqueue                 3  suspend 0x00000140 0x00000800    15%   0x0000000a 000
0x40039300                        24  ready   0x000001e0 0x00001000    19%   0x0000000d 000
usb-hardware-scan                  3  suspend 0x000001a0 0x00002000    38%   0x0000000a 000
disp2                             15  suspend 0x00000140 0x00002000    29%   0x00000008 000
hub-main-thread                    3  suspend 0x00000240 0x00002000    15%   0x0000000a 000
kmsg2appq                          6  suspend 0x00000240 0x00001000    17%   0x00000006 000
mnt_task                           7  suspend 0x000001b0 0x00004000    02%   0x0000000a 000
tidle                             31  ready   0x00000260 0x00002000    08%   0x00000002 000
timer                              8  suspend 0x00000170 0x00004000    18%   0x0000000a 000
最近编辑记录 DSH (2024-06-21 11:46:51)
