楼主 # 2024-08-05 12:48:58
metri
4寸圆屏, 2.8寸圆屏,这样的 F1C100s 上用
我想用圆屏和F1C100s. 有人做过吗?问题是要用SPI开始这个屏幕。 屏幕ST7701s花片。 ESP32可以用这个屏幕可是太慢,想用MJPEG。
I'm trying to use these round displays with the F1C100s. The problem is that they need to be configured by SPI as the control ICs have no memory. Each boot/reset they need to be configured by SPI. One of these screens uses ST7701s. I want to play MJPEG, or other simple video on these screens. No need for audio. There is ESP32 example code but ESP32 is too slow to play smooth video.
不好意思,我的中文不那么专业。
#1 2024-08-05 14:25:08
soso
已发帖子: 143
Re: 4寸圆屏, 2.8寸圆屏,这样的 F1C100s 上用
https://whycan.com/t_10818.html   可以看看我们这个,t113可以轻松完成。
楼主 #2 2024-08-05 15:43:25
metri
谢谢,我看一下这个T113 S3. 你们做的产品很好看。只比F1C100s 贵
#3 2024-08-06 08:57:20
soso
已发帖子: 143
100要转码,然后sdk支持又一般般。如果纯玩,还是尽早用s3.产品就忍痛用100~
楼主 #4 2024-08-06 10:53:32
metri
明白。便宜的F1C00s会很麻烦。 S3已经有软件可以做。我最大的问题是自己的能力有点低
