楼主 # 2023-09-12 23:09:15
muxi01
已发帖子: 63
[小爱mini音响 R16 ] 配置MTD时死机
kernel配置一旦启用Raw/Parallel Nand device support ,开机就卡死在starting kernel....
否则,就waiting for root device /dev/mtdblock7...
请教一下,接下来该怎么调试?
#1 2023-09-12 23:38:55
已发帖子: 3,394
Re: [小爱mini音响 R16 ] 配置MTD时死机
看下前面有没有生成 mtdX 设备?
楼主 #2 2023-09-13 09:49:35
muxi01
已发帖子: 63
看下前面有没有生成 mtdX 设备?
没有注意,但是应该不会有,因为我的设备就只有nand,在没有启用MTD的情况下,应该不会有设备吧
楼主 #3 2023-09-13 10:25:06
muxi01
已发帖子: 63
[    0.000000] Linux version 5.4.253-g3055d27e195b-dirty (xialixin@NBKJ-5SLTP93) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11)) #20 SMP Wed Sep 13 10:14:46 CST 2023
[    0.000000] OF: fdt: Machine model: Allwinner R16 EVB (Parrot)
[    0.000000] cma: Reserved 16 MiB at 0x47000000
[    0.000000] On node 0 totalpages: 32768
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] percpu: Embedded 15 pages/cpu s30732 r8192 d22516 u61440
[    0.000000] pcpu-alloc: s30732 r8192 d22516 u61440 alloc=15*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Kernel command line: console=ttyS0,115200 earyprintk loglevel=8 root=/dev/mtdblock7 rootfstype=ext2 rootwait init=/sbin/init mtdparts=nand.0:17m(secret_a),384k(spl2_a),384k(spl3_a),384k(env_a),2m(u-boot_a),10m(kernel_a),-(rootfs_a)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] Memory: 103260K/131072K available (6144K kernel code, 437K rwdata, 1716K rodata, 1024Kinit, 245K bss, 11428K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000017] Switching to timer-based delay loop, resolution 41ns
[    0.000237] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000759] Console: colour dummy device 80x30
[    0.000803] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000813] CPU: Testing write buffer coherency: ok
[    0.000850] pid_max: default: 32768 minimum: 301
[    0.000974] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000987] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002081] /cpus/cpu@0 missing clock-frequency property
[    0.002103] /cpus/cpu@1 missing clock-frequency property
[    0.002117] /cpus/cpu@2 missing clock-frequency property
[    0.002132] /cpus/cpu@3 missing clock-frequency property
[    0.002142] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002756] do_one_initcall.923 fn=c010cf74
[    0.002771] do_one_initcall.923 fn=c0905c14
[    0.002794] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002801] do_one_initcall.923 fn=c0908a5c
[    0.002817] do_one_initcall.923 fn=c09094f8
[    0.002935] do_one_initcall.923 fn=c090a804
[    0.002943] do_one_initcall.923 fn=c090bdc4
[    0.002948] rcu: Hierarchical SRCU implementation.
[    0.002955] do_one_initcall.923 fn=c090beac
[    0.002961] do_one_initcall.923 fn=c090c0c4
[    0.002967] do_one_initcall.923 fn=c090bec8
[    0.003057] do_one_initcall.923 fn=c090dd3c
[    0.003170] do_one_initcall.923 fn=c09101e4
[    0.003178] do_one_initcall.923 fn=c03a71fc
[    0.003310] do_one_initcall.923 fn=c0922e94
[    0.003326] do_one_initcall.923 fn=c092c708
[    0.003606] smp: Bringing up secondary CPUs ...
[    0.004605] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005684] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.006700] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.006785] smp: Brought up 1 node, 4 CPUs
[    0.006802] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.006808] CPU: All CPU(s) started in HYP mode.
[    0.006812] CPU: Virtualization extensions available.
[    0.007297] devtmpfs: initialized
[    0.012667] do_one_initcall.923 fn=c0915564
[    0.012685] do_one_initcall.923 fn=c0925b68
[    0.013161] do_one_initcall.923 fn=c0902930
[    0.013181] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.013200] do_one_initcall.923 fn=c0902c40
[    0.013207] do_one_initcall.923 fn=c0904204
[    0.013215] do_one_initcall.923 fn=c090754c
[    0.013221] do_one_initcall.923 fn=c0909288
[    0.013228] do_one_initcall.923 fn=c0909280
[    0.013234] do_one_initcall.923 fn=c0909ad4
[    0.013320] do_one_initcall.923 fn=c090a458
[    0.013345] do_one_initcall.923 fn=c090b20c
[    0.013431] do_one_initcall.923 fn=c090bd00
[    0.013438] do_one_initcall.923 fn=c090c9ac
[    0.013445] do_one_initcall.923 fn=c090cfb4
[    0.013456] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.013465] do_one_initcall.923 fn=c090d558
[    0.013481] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.013600] do_one_initcall.923 fn=c090d920
[    0.013620] do_one_initcall.923 fn=c090dc7c
[    0.013637] do_one_initcall.923 fn=c01a75a0
[    0.013655] do_one_initcall.923 fn=c0912790
[    0.014127] do_one_initcall.923 fn=c09136f0
[    0.014168] do_one_initcall.923 fn=c0913a74
[    0.014189] do_one_initcall.923 fn=c0913b38
[    0.014197] do_one_initcall.923 fn=c0913b54
[    0.014204] do_one_initcall.923 fn=c0915374
[    0.014224] do_one_initcall.923 fn=c0915e54
[    0.014232] do_one_initcall.923 fn=c0916fe4
[    0.014280] do_one_initcall.923 fn=c09170d4
[    0.014285] pinctrl core: initialized pinctrl subsystem
[    0.014408] do_one_initcall.923 fn=c0917288
[    0.014454] do_one_initcall.923 fn=c091b124
[    0.014804] do_one_initcall.923 fn=c091d068
[    0.014821] do_one_initcall.923 fn=c091dc34
[    0.014828] do_one_initcall.923 fn=c09211d0
[    0.014840] do_one_initcall.923 fn=c09211f8
[    0.014853] do_one_initcall.923 fn=c09259fc
[    0.015129] do_one_initcall.923 fn=c0925ab4
[    0.015148] do_one_initcall.923 fn=c0925b44
[    0.015156] do_one_initcall.923 fn=c0925c9c
[    0.015165] do_one_initcall.923 fn=c0926414
[    0.015719] NET: Registered protocol family 16
[    0.015916] do_one_initcall.923 fn=c09057b8
[    0.017013] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.017027] do_one_initcall.923 fn=c090ba60
[    0.017489] do_one_initcall.923 fn=c090e694
[    0.017547] do_one_initcall.923 fn=c090e7b4
[    0.017560] do_one_initcall.923 fn=c092caac
[    0.017577] do_one_initcall.923 fn=c091738c
[    0.017603] do_one_initcall.923 fn=c091b3bc
[    0.017621] do_one_initcall.923 fn=c091bb7c
[    0.017707] do_one_initcall.923 fn=c091cfac
[    0.017742] do_one_initcall.923 fn=c091d92c
[    0.017753] do_one_initcall.923 fn=c091dae8
[    0.017770] do_one_initcall.923 fn=c091db20
[    0.017799] do_one_initcall.923 fn=c091dc24
[    0.017815] do_one_initcall.923 fn=c091de48
[    0.017849] do_one_initcall.923 fn=c091e740
[    0.017892] do_one_initcall.923 fn=c091fdbc
[    0.017980] do_one_initcall.923 fn=c092c640
[    0.018129] do_one_initcall.923 fn=c0902bd0
[    0.018137] do_one_initcall.923 fn=c0902c6c
[    0.018144] do_one_initcall.923 fn=c09048c8
[    0.018266] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.018274] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.018284] do_one_initcall.923 fn=c0904e80
[    0.018313] do_one_initcall.923 fn=c090508c
[    0.018320] do_one_initcall.923 fn=c091af30
[    0.018360] do_one_initcall.923 fn=c091ae48
[    0.018398] do_one_initcall.923 fn=c0923190
[    0.023867] do_one_initcall.923 fn=c0902c9c
[    0.024222] do_one_initcall.923 fn=c09099b4
[    0.024246] do_one_initcall.923 fn=c090a210
[    0.029707] do_one_initcall.923 fn=c090a7c0
[    0.029757] do_one_initcall.923 fn=c090d908
[    0.029774] do_one_initcall.923 fn=c090dbe0
[    0.029781] do_one_initcall.923 fn=c090e218
[    0.030030] do_one_initcall.923 fn=c090e6f0
[    0.030266] do_one_initcall.923 fn=c090ea20
[    0.030275] do_one_initcall.923 fn=c09100a0
[    0.030397] do_one_initcall.923 fn=c092c75c
[    0.030406] do_one_initcall.923 fn=c01ed5e8
[    0.030412] do_one_initcall.923 fn=c01ed5b8
[    0.030418] do_one_initcall.923 fn=c0911c04
[    0.030437] do_one_initcall.923 fn=c0911c9c
[    0.030444] do_one_initcall.923 fn=c09155c8
[    0.030861] do_one_initcall.923 fn=c09155d4
[    0.031033] do_one_initcall.923 fn=c09155e0
[    0.031178] do_one_initcall.923 fn=c09155ec
[    0.031318] do_one_initcall.923 fn=c09155f8
[    0.031398] do_one_initcall.923 fn=c0915734
[    0.031406] do_one_initcall.923 fn=c091576c
[    0.031415] do_one_initcall.923 fn=c09157ac
[    0.031425] do_one_initcall.923 fn=c0915848
[    0.031431] do_one_initcall.923 fn=c0915888
[    0.031654] do_one_initcall.923 fn=c0917354
[    0.031671] do_one_initcall.923 fn=c0917430
[    0.031704] do_one_initcall.923 fn=c0917468
[    0.031731] do_one_initcall.923 fn=c091752c
[    0.031849] do_one_initcall.923 fn=c091b24c
[    0.032772] do_one_initcall.923 fn=c091b26c
[    0.032863] do_one_initcall.923 fn=c091ce00
[    0.032896] do_one_initcall.923 fn=c048d56c
[    0.032919] do_one_initcall.923 fn=c091de58
[    0.032999] do_one_initcall.923 fn=c091df10
[    0.033261] SCSI subsystem initialized
[    0.033270] do_one_initcall.923 fn=c091e308
[    0.033501] libata version 3.00 loaded.
[    0.033510] do_one_initcall.923 fn=c091e944
[    0.033603] do_one_initcall.923 fn=c091f20c
[    0.033625] do_one_initcall.923 fn=c091f234
[    0.033723] usbcore: registered new interface driver usbfs
[    0.033778] usbcore: registered new interface driver hub
[    0.033820] usbcore: registered new device driver usb
[    0.033828] do_one_initcall.923 fn=c091f420
[    0.033913] do_one_initcall.923 fn=c091f5cc
[    0.033933] do_one_initcall.923 fn=c091f624
[    0.033964] do_one_initcall.923 fn=c091f684
[    0.033995] do_one_initcall.923 fn=c091f8f4
[    0.034016] do_one_initcall.923 fn=c092053c
[    0.034039] do_one_initcall.923 fn=c09205a4
[    0.034057] pps_core: LinuxPPS API ver. 1 registered
[    0.034063] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.034069] do_one_initcall.923 fn=c0920658
[    0.034087] PTP clock support registered
[    0.034094] do_one_initcall.923 fn=c09206f8
[    0.034112] do_one_initcall.923 fn=c0920778
[    0.034137] do_one_initcall.923 fn=c0921360
[    0.034211] do_one_initcall.923 fn=c09214c4
[    0.034238] do_one_initcall.923 fn=c09252c4
[    0.034285] do_one_initcall.923 fn=c059e228
[    0.034294] do_one_initcall.923 fn=c0925360
[    0.034326] do_one_initcall.923 fn=c092537c
[    0.034344] do_one_initcall.923 fn=c09253bc
[    0.034377] Advanced Linux Sound Architecture Driver Initialized.
[    0.034385] do_one_initcall.923 fn=c0925aa8
[    0.034399] do_one_initcall.923 fn=c0925e30
[    0.034812] do_one_initcall.923 fn=c092606c
[    0.034826] do_one_initcall.923 fn=c0926324
[    0.034837] do_one_initcall.923 fn=c0926330
[    0.034877] do_one_initcall.923 fn=c092654c
[    0.034920] do_one_initcall.923 fn=c092767c
[    0.034937] do_one_initcall.923 fn=c0921044
[    0.035269] do_one_initcall.923 fn=c0902d08
[    0.035298] do_one_initcall.923 fn=c0907474
[    0.035311] do_one_initcall.923 fn=c090ceb4
[    0.035378] clocksource: Switched to clocksource arch_sys_counter
[    0.035387] do_one_initcall.923 fn=c0912e34
[    0.035451] do_one_initcall.923 fn=c09137d0
[    0.035473] do_one_initcall.923 fn=c0913834
[    0.035499] do_one_initcall.923 fn=c0913908
[    0.035556] do_one_initcall.923 fn=c0913a34
[    0.035569] do_one_initcall.923 fn=c0913e0c
[    0.035578] do_one_initcall.923 fn=c0913e44
[    0.035587] do_one_initcall.923 fn=c0913e80
[    0.035595] do_one_initcall.923 fn=c0913ea8
[    0.035603] do_one_initcall.923 fn=c0913ee4
[    0.035612] do_one_initcall.923 fn=c0913f20
[    0.035620] do_one_initcall.923 fn=c0913f58
[    0.035637] do_one_initcall.923 fn=c0913f90
[    0.035646] do_one_initcall.923 fn=c0913fb8
[    0.035655] do_one_initcall.923 fn=c0913ff0
[    0.035663] do_one_initcall.923 fn=c0914028
[    0.035671] do_one_initcall.923 fn=c0914120
[    0.035679] do_one_initcall.923 fn=c0914148
[    0.035689] do_one_initcall.923 fn=c0914998
[    0.035697] do_one_initcall.923 fn=c0915c40
[    0.035704] do_one_initcall.923 fn=c0917a90
[    0.035832] do_one_initcall.923 fn=c091cae0
[    0.042480] do_one_initcall.923 fn=c091db50
[    0.042500] do_one_initcall.923 fn=c09207ac
[    0.042510] thermal_sys: Registered thermal governor 'step_wise'
[    0.042921] do_one_initcall.923 fn=c092124c
[    0.042934] do_one_initcall.923 fn=c0925cf0
[    0.042990] do_one_initcall.923 fn=c09263fc
[    0.042998] do_one_initcall.923 fn=c09272b8
[    0.043090] NET: Registered protocol family 2
[    0.043303] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.043703] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.043733] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.043754] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.043776] TCP: Hash tables configured (established 1024 bind 1024)
[    0.043872] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.043909] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.044072] do_one_initcall.923 fn=c0927234
[    0.044082] do_one_initcall.923 fn=c092960c
[    0.044093] NET: Registered protocol family 1
[    0.044123] do_one_initcall.923 fn=c0929660
[    0.044134] do_one_initcall.923 fn=c0929ac4
[    0.044723] RPC: Registered named UNIX socket transport module.
[    0.044735] RPC: Registered udp transport module.
[    0.044740] RPC: Registered tcp transport module.
[    0.044745] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.044753] do_one_initcall.923 fn=c0902820
[    0.045140] do_one_initcall.923 fn=c0904b34
[    0.045528] do_one_initcall.923 fn=c090917c
[    0.045549] do_one_initcall.923 fn=c0909204
[    0.045580] do_one_initcall.923 fn=c09092a0
[    0.045649] do_one_initcall.923 fn=c09095e0
[    0.045666] do_one_initcall.923 fn=c090bcd0
[    0.045673] do_one_initcall.923 fn=c090bce8
[    0.045679] do_one_initcall.923 fn=c090cbc8
[    0.045685] do_one_initcall.923 fn=c090cf38
[    0.045830] do_one_initcall.923 fn=c090cfd4
[    0.045843] do_one_initcall.923 fn=c090d018
[    0.045898] do_one_initcall.923 fn=c090d0c0
[    0.045950] do_one_initcall.923 fn=c090d100
[    0.046241] do_one_initcall.923 fn=c090d200
[    0.046249] do_one_initcall.923 fn=c090d880
[    0.046260] do_one_initcall.923 fn=c090d8a8
[    0.046278] do_one_initcall.923 fn=c090dcfc
[    0.046300] do_one_initcall.923 fn=c090ddf0
[    0.046326] do_one_initcall.923 fn=c090de08
[    0.046458] do_one_initcall.923 fn=c090e2e4
[    0.046588] do_one_initcall.923 fn=c090e3f4
[    0.046626] do_one_initcall.923 fn=c090e7ec
[    0.046634] do_one_initcall.923 fn=c090fd9c
[    0.046647] do_one_initcall.923 fn=c0910100
[    0.046654] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.046662] do_one_initcall.923 fn=c0910358
[    0.046671] do_one_initcall.923 fn=c0911208
[    0.046703] do_one_initcall.923 fn=c0911c74
[    0.046713] do_one_initcall.923 fn=c0911fec
[    0.051746] do_one_initcall.923 fn=c0912e88
[    0.051767] do_one_initcall.923 fn=c09130f0
[    0.051782] do_one_initcall.923 fn=c09134e0
[    0.051795] do_one_initcall.923 fn=c0913610
[    0.051827] do_one_initcall.923 fn=c09136b0
[    0.051843] do_one_initcall.923 fn=c091374c
[    0.051864] do_one_initcall.923 fn=c0913970
[    0.052078] do_one_initcall.923 fn=c09139f4
[    0.052096] do_one_initcall.923 fn=c0913b70
[    0.052200] do_one_initcall.923 fn=c0913bb4
[    0.052215] do_one_initcall.923 fn=c0914240
[    0.052248] do_one_initcall.923 fn=c09144c0
[    0.052875] do_one_initcall.923 fn=c091485c
[    0.053103] do_one_initcall.923 fn=c09149f0
[    0.053270] do_one_initcall.923 fn=c0914a50
[    0.053280] do_one_initcall.923 fn=c0914ae0
[    0.053906] do_one_initcall.923 fn=c0915228
[    0.053918] do_one_initcall.923 fn=c0915240
[    0.053924] do_one_initcall.923 fn=c0915258
[    0.053930] NFS: Registering the id_resolver key type
[    0.053982] Key type id_resolver registered
[    0.053988] Key type id_legacy registered
[    0.054008] do_one_initcall.923 fn=c0915290
[    0.054037] do_one_initcall.923 fn=c0915354
[    0.054045] do_one_initcall.923 fn=c0915364
[    0.054050] do_one_initcall.923 fn=c09154dc
[    0.054068] do_one_initcall.923 fn=c0915584
[    0.054078] do_one_initcall.923 fn=c0915908
[    0.054089] do_one_initcall.923 fn=c0915bbc
[    0.054096] do_one_initcall.923 fn=c0915d20
[    0.054133] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.054140] do_one_initcall.923 fn=c0915e3c
[    0.054148] io scheduler mq-deadline registered
[    0.054154] do_one_initcall.923 fn=c0915e48
[    0.054160] io scheduler kyber registered
[    0.054165] do_one_initcall.923 fn=c0915fb0
[    0.058151] do_one_initcall.923 fn=c0916360
[    0.058263] do_one_initcall.923 fn=c0916408
[    0.058531] do_one_initcall.923 fn=c0916ff4
[    0.058762] do_one_initcall.923 fn=c091704c
[    0.058784] do_one_initcall.923 fn=c09170a4
[    0.058967] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.059252] do_one_initcall.923 fn=c09170b4
[    0.059339] do_one_initcall.923 fn=c09170c4
[    0.059412] do_one_initcall.923 fn=c09171a8
[    0.059525] do_one_initcall.923 fn=c09171b8
[    0.059629] do_one_initcall.923 fn=c09171c8
[    0.059718] do_one_initcall.923 fn=c09171d8
[    0.059796] do_one_initcall.923 fn=c09171e8
[    0.059868] do_one_initcall.923 fn=c09171f8
[    0.059949] sun8i-a23-r-pinctrl 1f02c00.pinctrl: Reset controller missing
[    0.059997] do_one_initcall.923 fn=c0917208
[    0.062750] sun8i-a33-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.062875] do_one_initcall.923 fn=c0917218
[    0.062964] do_one_initcall.923 fn=c0917228
[    0.063038] do_one_initcall.923 fn=c0917238
[    0.063109] do_one_initcall.923 fn=c0917248
[    0.063190] do_one_initcall.923 fn=c0917258
[    0.063283] do_one_initcall.923 fn=c0917268
[    0.063353] do_one_initcall.923 fn=c0917278
[    0.063440] do_one_initcall.923 fn=c091747c
[    0.063596] do_one_initcall.923 fn=c0917e58
[    0.063658] do_one_initcall.923 fn=c0917e68
[    0.063719] do_one_initcall.923 fn=c0917e7c
[    0.063792] do_one_initcall.923 fn=c09191bc
[    0.063864] do_one_initcall.923 fn=c091a4f0
[    0.063931] do_one_initcall.923 fn=c091a8b8
[    0.064003] do_one_initcall.923 fn=c091a8c8
[    0.064087] do_one_initcall.923 fn=c091a8d8
[    0.064181] do_one_initcall.923 fn=c091a8e8
[    0.064248] do_one_initcall.923 fn=c091ac40
[    0.064320] do_one_initcall.923 fn=c091ad80
[    0.064495] do_one_initcall.923 fn=c091ae08
[    0.064567] do_one_initcall.923 fn=c091ae18
[    0.064637] do_one_initcall.923 fn=c091ae28
[    0.064708] do_one_initcall.923 fn=c091ae38
[    0.064784] do_one_initcall.923 fn=c091afdc
[    0.064856] do_one_initcall.923 fn=c091afec
[    0.067517] do_one_initcall.923 fn=c091affc
[    0.068088] do_one_initcall.923 fn=c091b25c
[    0.068139] do_one_initcall.923 fn=c091b27c
[    0.068326] do_one_initcall.923 fn=c091b538
[    0.068335] do_one_initcall.923 fn=c091b558
[    0.110858] do_one_initcall.923 fn=c091c748
[    0.110876] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.112386] do_one_initcall.923 fn=c091cac0
[    0.112582] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    0.113376] printk: console [ttyS0] disabled
[    0.133572] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[    1.942602] printk: console [ttyS0] enabled
[    1.947151] do_one_initcall.923 fn=c091cad0
[    1.951620] do_one_initcall.923 fn=c091cee0
[    1.955825] do_one_initcall.923 fn=c091cee8
[    1.960066] do_one_initcall.923 fn=c091cfb8
[    1.964616] do_one_initcall.923 fn=c091cfc8
[    1.969175] do_one_initcall.923 fn=c091cfd8
[    1.973422] do_one_initcall.923 fn=c091cfe8
[    1.977955] do_one_initcall.923 fn=c091cff8
[    1.982416] do_one_initcall.923 fn=c091d008
[    1.986804] do_one_initcall.923 fn=c091d018
[    1.991092] do_one_initcall.923 fn=c091d028
[    1.995337] do_one_initcall.923 fn=c091d038
[    1.999787] do_one_initcall.923 fn=c091d048
[    2.004057] do_one_initcall.923 fn=c091d058
[    2.008350] do_one_initcall.923 fn=c0476018
[    2.012666] do_one_initcall.923 fn=c091d8ec
[    2.016891] do_one_initcall.923 fn=c091de10
[    2.022364] do_one_initcall.923 fn=c091de20
[    2.026605] do_one_initcall.923 fn=c091de2c
[    2.030807] do_one_initcall.923 fn=c091de3c
[    2.035004] do_one_initcall.923 fn=c091e154
[    2.039284] do_one_initcall.923 fn=c091e730
[    2.043577] do_one_initcall.923 fn=c091e7c8
[    2.047864] do_one_initcall.923 fn=c091e7d8
[    2.052142] do_one_initcall.923 fn=c091e848
[    2.056347] do_one_initcall.923 fn=c091e8bc
[    2.060572] do_one_initcall.923 fn=c091eddc
[    2.064854] do_one_initcall.923 fn=c091edec
[    2.069237] do_one_initcall.923 fn=c091eefc
[    2.073415] CAN device driver interface
[    2.077274] do_one_initcall.923 fn=c091ef28
[    2.081533] do_one_initcall.923 fn=c091ef38
[    2.085836] do_one_initcall.923 fn=c091f1a0
[    2.090046] do_one_initcall.923 fn=c091f1dc
[    2.094300] do_one_initcall.923 fn=c091f1ec
[    2.098689] do_one_initcall.923 fn=c091f1fc
[    2.103072] do_one_initcall.923 fn=c091f430
[    2.107266] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.113783] do_one_initcall.923 fn=c091f4a0
[    2.117971] ehci-platform: EHCI generic platform driver
[    2.123563] do_one_initcall.923 fn=c091f4f4
[    2.127778] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.133993] do_one_initcall.923 fn=c091f558
[    2.138184] ohci-platform: OHCI generic platform driver
[    2.143676] do_one_initcall.923 fn=c091f5ac
[    2.147921] do_one_initcall.923 fn=c091f5bc
[    2.152316] do_one_initcall.923 fn=c091f654
[    2.156513] do_one_initcall.923 fn=c091f790
[    2.160691] do_one_initcall.923 fn=c091f79c
[    2.164868] do_one_initcall.923 fn=c091f7a8
[    2.169115] do_one_initcall.923 fn=c091f7c0
[    2.173459] do_one_initcall.923 fn=c091f7d0
[    2.177788] do_one_initcall.923 fn=c091f7e0
[    2.182005] do_one_initcall.923 fn=c091f984
[    2.186264] do_one_initcall.923 fn=c091f994
[    2.191143] sun6i-rtc 1f00000.rtc: registered as rtc0
[    2.196217] sun6i-rtc 1f00000.rtc: RTC enabled
[    2.200797] do_one_initcall.923 fn=c091fdac
[    2.205083] do_one_initcall.923 fn=c091fe7c
[    2.209278] i2c /dev entries driver
[    2.212792] do_one_initcall.923 fn=c091ff34
[    2.217147] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-ph not found, using dummy regulator
[    2.227619] do_one_initcall.923 fn=c091ff44
[    2.231893] do_one_initcall.923 fn=c091ff54
[    2.236116] do_one_initcall.923 fn=c091ff60
[    2.240293] do_one_initcall.923 fn=c091ff6c
[    2.244470] do_one_initcall.923 fn=c091ff78
[    2.248669] do_one_initcall.923 fn=c091ff84
[    2.252847] do_one_initcall.923 fn=c091ff90
[    2.257035] do_one_initcall.923 fn=c091ff9c
[    2.261212] do_one_initcall.923 fn=c091ffa8
[    2.265399] do_one_initcall.923 fn=c091ffb4
[    2.269576] do_one_initcall.923 fn=c091ffc0
[    2.273752] do_one_initcall.923 fn=c091ffcc
[    2.277940] do_one_initcall.923 fn=c091ffd8
[    2.282117] do_one_initcall.923 fn=c091ffe4
[    2.286303] do_one_initcall.923 fn=c091fff0
[    2.290480] do_one_initcall.923 fn=c091fffc
[    2.294657] do_one_initcall.923 fn=c0920008
[    2.298843] do_one_initcall.923 fn=c0920014
[    2.303024] do_one_initcall.923 fn=c0920020
[    2.307211] do_one_initcall.923 fn=c092002c
[    2.311388] do_one_initcall.923 fn=c0920038
[    2.315575] do_one_initcall.923 fn=c0920044
[    2.319752] do_one_initcall.923 fn=c0920050
[    2.323928] do_one_initcall.923 fn=c092005c
[    2.328115] do_one_initcall.923 fn=c0920068
[    2.332292] do_one_initcall.923 fn=c0920074
[    2.336479] do_one_initcall.923 fn=c0920080
[    2.340655] do_one_initcall.923 fn=c092008c
[    2.344831] do_one_initcall.923 fn=c0920098
[    2.349018] do_one_initcall.923 fn=c09200a4
[    2.353194] do_one_initcall.923 fn=c09200b0
[    2.357381] do_one_initcall.923 fn=c09200bc
[    2.361558] do_one_initcall.923 fn=c09200c8
[    2.365744] do_one_initcall.923 fn=c09200d4
[    2.369924] do_one_initcall.923 fn=c09200e0
[    2.374100] do_one_initcall.923 fn=c09200ec
[    2.378288] do_one_initcall.923 fn=c09200f8
[    2.382465] do_one_initcall.923 fn=c0920104
[    2.386652] do_one_initcall.923 fn=c0920110
[    2.390829] do_one_initcall.923 fn=c092011c
[    2.395005] do_one_initcall.923 fn=c0920128
[    2.399191] do_one_initcall.923 fn=c0920134
[    2.403368] do_one_initcall.923 fn=c0920140
[    2.407554] do_one_initcall.923 fn=c092014c
[    2.411731] do_one_initcall.923 fn=c0920158
[    2.415917] do_one_initcall.923 fn=c0920164
[    2.420094] do_one_initcall.923 fn=c0920170
[    2.424271] do_one_initcall.923 fn=c092017c
[    2.428458] do_one_initcall.923 fn=c0920188
[    2.432635] do_one_initcall.923 fn=c0920194
[    2.436825] do_one_initcall.923 fn=c09201a0
[    2.441002] do_one_initcall.923 fn=c09201ac
[    2.445178] do_one_initcall.923 fn=c09201b8
[    2.449365] do_one_initcall.923 fn=c09201c4
[    2.453542] do_one_initcall.923 fn=c09201d0
[    2.457728] do_one_initcall.923 fn=c09201dc
[    2.461905] do_one_initcall.923 fn=c09201e8
[    2.466091] do_one_initcall.923 fn=c09201f4
[    2.470268] do_one_initcall.923 fn=c0920200
[    2.474444] do_one_initcall.923 fn=c092020c
[    2.478632] do_one_initcall.923 fn=c0920218
[    2.482808] do_one_initcall.923 fn=c0920224
[    2.486995] do_one_initcall.923 fn=c0920230
[    2.491172] do_one_initcall.923 fn=c092023c
[    2.495348] do_one_initcall.923 fn=c0920248
[    2.499534] do_one_initcall.923 fn=c0920254
[    2.503714] do_one_initcall.923 fn=c0920260
[    2.507909] do_one_initcall.923 fn=c092026c
[    2.512086] do_one_initcall.923 fn=c0920278
[    2.516273] do_one_initcall.923 fn=c0920284
[    2.520450] do_one_initcall.923 fn=c0920290
[    2.524626] do_one_initcall.923 fn=c092029c
[    2.528813] do_one_initcall.923 fn=c09202a8
[    2.532990] do_one_initcall.923 fn=c09202b4
[    2.537176] do_one_initcall.923 fn=c09202c0
[    2.541353] do_one_initcall.923 fn=c09202cc
[    2.545539] do_one_initcall.923 fn=c09202d8
[    2.549716] do_one_initcall.923 fn=c09202e4
[    2.553892] do_one_initcall.923 fn=c09202f0
[    2.558078] do_one_initcall.923 fn=c09202fc
[    2.562255] do_one_initcall.923 fn=c0920308
[    2.566441] do_one_initcall.923 fn=c0920314
[    2.570622] do_one_initcall.923 fn=c0920320
[    2.574798] do_one_initcall.923 fn=c092032c
[    2.578986] do_one_initcall.923 fn=c0920338
[    2.583163] do_one_initcall.923 fn=c0920344
[    2.587349] do_one_initcall.923 fn=c0920350
[    2.591526] do_one_initcall.923 fn=c092035c
[    2.595712] do_one_initcall.923 fn=c0920368
[    2.599889] do_one_initcall.923 fn=c0920374
[    2.604065] do_one_initcall.923 fn=c0920380
[    2.608251] do_one_initcall.923 fn=c092038c
[    2.612428] do_one_initcall.923 fn=c0920398
[    2.616614] do_one_initcall.923 fn=c09203a4
[    2.620791] do_one_initcall.923 fn=c09203b0
[    2.624967] do_one_initcall.923 fn=c09203bc
[    2.629154] do_one_initcall.923 fn=c09203c8
[    2.633330] do_one_initcall.923 fn=c09203d4
[    2.637520] do_one_initcall.923 fn=c09203e0
[    2.641697] do_one_initcall.923 fn=c09203ec
[    2.645884] do_one_initcall.923 fn=c09203f8
[    2.650061] do_one_initcall.923 fn=c0920404
[    2.654237] do_one_initcall.923 fn=c0920410
[    2.658424] do_one_initcall.923 fn=c092041c
[    2.662601] do_one_initcall.923 fn=c0920428
[    2.666787] do_one_initcall.923 fn=c0920434
[    2.670964] do_one_initcall.923 fn=c0920440
[    2.675140] do_one_initcall.923 fn=c092044c
[    2.679326] do_one_initcall.923 fn=c0920458
[    2.683503] do_one_initcall.923 fn=c0920464
[    2.687689] do_one_initcall.923 fn=c0920470
[    2.691866] do_one_initcall.923 fn=c092047c
[    2.696052] do_one_initcall.923 fn=c0920488
[    2.700228] do_one_initcall.923 fn=c0920494
[    2.704408] do_one_initcall.923 fn=c09204a0
[    2.708595] do_one_initcall.923 fn=c09204ac
[    2.712772] do_one_initcall.923 fn=c09204b8
[    2.716959] do_one_initcall.923 fn=c09204c4
[    2.721136] do_one_initcall.923 fn=c09204d0
[    2.725312] do_one_initcall.923 fn=c09204dc
[    2.729498] do_one_initcall.923 fn=c09204e8
[    2.733675] do_one_initcall.923 fn=c09204f4
[    2.737862] do_one_initcall.923 fn=c0920500
[    2.742038] do_one_initcall.923 fn=c092050c
[    2.746224] do_one_initcall.923 fn=c0920518
[    2.750401] do_one_initcall.923 fn=c0920524
[    2.754577] do_one_initcall.923 fn=c0920530
[    2.758763] do_one_initcall.923 fn=c0920594
[    2.763078] do_one_initcall.923 fn=c0920748
[    2.767386] do_one_initcall.923 fn=c0920758
[    2.771661] do_one_initcall.923 fn=c0920768
[    2.775948] do_one_initcall.923 fn=c09211c0
[    2.780465] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.788407] do_one_initcall.923 fn=c0921258
[    2.792633] do_one_initcall.923 fn=c0921268
[    2.798358] do_one_initcall.923 fn=c0921398
[    2.802738] do_one_initcall.923 fn=c09213a8
[    2.807044] do_one_initcall.923 fn=c09213b8
[    2.811280] do_one_initcall.923 fn=c09214b4
[    2.815705] do_one_initcall.923 fn=c0921510
[    2.820031] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    2.830300] do_one_initcall.923 fn=c0921520
[    2.834487] do_one_initcall.923 fn=c0921560
[    2.838688] do_one_initcall.923 fn=c0921a68
[    2.843063] sun4i-ss 1c15000.crypto-engine: Die ID 5
[    2.849576] do_one_initcall.923 fn=c0922ecc
[    2.853811] do_one_initcall.923 fn=c0922f20
[    2.858062] do_one_initcall.923 fn=c0922f38
[    2.862279] do_one_initcall.923 fn=c0922f50
[    2.866511] do_one_initcall.923 fn=c0922f68
[    2.870715] do_one_initcall.923 fn=c0922f80
[    2.874917] do_one_initcall.923 fn=c0922f98
[    2.879133] do_one_initcall.923 fn=c0922fb0
[    2.883336] do_one_initcall.923 fn=c0922fc8
[    2.887551] do_one_initcall.923 fn=c0922fe0
[    2.891756] do_one_initcall.923 fn=c0922ff8
[    2.895982] do_one_initcall.923 fn=c0923010
[    2.900196] do_one_initcall.923 fn=c0923028
[    2.904403] do_one_initcall.923 fn=c0923040
[    2.908621] do_one_initcall.923 fn=c0923058
[    2.912827] do_one_initcall.923 fn=c0923070
[    2.917070] usbcore: registered new interface driver usbhid
[    2.922632] usbhid: USB HID core driver
[    2.926473] do_one_initcall.923 fn=c09252a4
[    2.930669] do_one_initcall.923 fn=c0925350
[    2.934992] do_one_initcall.923 fn=c092536c
[    2.939409] do_one_initcall.923 fn=c09255b8
[    2.943794] do_one_initcall.923 fn=c09257c0
[    2.947997] do_one_initcall.923 fn=c092582c
[    2.952498] do_one_initcall.923 fn=c0925978
[    2.956902] do_one_initcall.923 fn=c09262e4
[    2.961163] do_one_initcall.923 fn=c092766c
[    2.965342] do_one_initcall.923 fn=c092776c
[    2.969695] do_one_initcall.923 fn=c09295a8
[    2.973877] do_one_initcall.923 fn=c0929744
[    2.978071] NET: Registered protocol family 17
[    2.982536] do_one_initcall.923 fn=c09297bc
[    2.986727] can: controller area network core (rev 20170425 abi 9)
[    2.992972] NET: Registered protocol family 29
[    2.997427] do_one_initcall.923 fn=c0929860
[    3.001602] can: raw protocol (rev 20170425)
[    3.005884] do_one_initcall.923 fn=c09298a8
[    3.010059] can: broadcast manager protocol (rev 20170425 t)
[    3.015728] do_one_initcall.923 fn=c0929900
[    3.019904] can: netlink gateway (rev 20190810) max_hops=1
[    3.025559] do_one_initcall.923 fn=c0929b84
[    3.029785] do_one_initcall.923 fn=c0929c44
[    3.034018] Key type dns_resolver registered
[    3.038449] do_one_initcall.923 fn=c0902d2c
[    3.042631] do_one_initcall.923 fn=c090485c
[    3.046827] Registering SWP/SWPB emulation handler
[    3.051613] do_one_initcall.923 fn=c011daf8
[    3.055824] do_one_initcall.923 fn=c09091dc
[    3.060010] do_one_initcall.923 fn=c09091b4
[    3.064197] do_one_initcall.923 fn=c09094d0
[    3.068391] do_one_initcall.923 fn=c09094a8
[    3.072574] do_one_initcall.923 fn=c090b150
[    3.076933] do_one_initcall.923 fn=c090b1d4
[    3.081123] do_one_initcall.923 fn=c090b60c
[    3.085305] do_one_initcall.923 fn=c090be00
[    3.089502] do_one_initcall.923 fn=c090d520
[    3.093687] do_one_initcall.923 fn=c0910224
[    3.097882] do_one_initcall.923 fn=c0911c6c
[    3.102059] do_one_initcall.923 fn=c0912230
[    3.106245] do_one_initcall.923 fn=c09154d0
[    3.110529] do_one_initcall.923 fn=c0915f78
[    3.114709] do_one_initcall.923 fn=c0917b34
[    3.126315] do_one_initcall.923 fn=c0470d2c
[    3.130821] sun8i-a33-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    3.143641] sun8i-a23-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    3.152619] sun8i-a23-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
[    3.163015] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz
[    3.169092] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP223 found
[    3.177792] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
[    3.187851] axp20x-adc axp22x-adc: DMA mask not set
[    3.193316] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[    3.201491] vcc-3v0: supplied by regulator-dummy
[    3.206485] vdd-sys: supplied by regulator-dummy
[    3.211344] vdd-cpu: supplied by regulator-dummy
[    3.216348] dcdc4: supplied by regulator-dummy
[    3.220908] vcc-dram: supplied by regulator-dummy
[    3.225957] dc1sw: supplied by vcc-3v0
[    3.229836] vdd-cpus: supplied by vcc-dram
[    3.234164] vcc-io: supplied by regulator-dummy
[    3.238979] vdd-dll: supplied by regulator-dummy
[    3.243844] vcc-pll-avcc: supplied by regulator-dummy
[    3.249200] vcc-1v2-hsic: Bringing 700000uV into 1200000-1200000uV
[    3.255607] vcc-1v2-hsic: supplied by regulator-dummy
[    3.260762] vcc-dsp: Bringing 700000uV into 3000000-3000000uV
[    3.266695] vcc-dsp: supplied by regulator-dummy
[    3.271431] eldo3: Bringing 700000uV into 3000000-3000000uV
[    3.277207] eldo3: supplied by regulator-dummy
[    3.281745] vcc-wifi0: Bringing 700000uV into 3300000-3300000uV
[    3.287743] vcc-wifi0: supplied by regulator-dummy
[    3.292779] vcc-wifi1: Bringing 700000uV into 3300000-3300000uV
[    3.298769] vcc-wifi1: supplied by regulator-dummy
[    3.303845] vcc-3v0-csi: Bringing 700000uV into 3000000-3000000uV
[    3.310126] vcc-3v0-csi: supplied by regulator-dummy
[    3.315342] dldo4: supplied by regulator-dummy
[    3.319929] rtc_ldo: supplied by regulator-dummy
[    3.324882] ldo_io0: supplied by regulator-dummy
[    3.329770] ldo_io1: supplied by regulator-dummy
[    3.334610] usb0-vbus: supplied by vcc5v0
[    3.339065] axp20x-ac-power-supply axp20x-ac-power-supply: DMA mask not set
[    3.346376] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[    3.354600] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
[    3.361237] ehci-platform 1c1a000.usb: EHCI Host Controller
[    3.366880] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    3.375201] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    3.405396] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    3.412269] hub 1-0:1.0: USB hub found
[    3.416077] hub 1-0:1.0: 1 port detected
[    3.420767] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    3.427418] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    3.435449] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    3.510036] hub 2-0:1.0: USB hub found
[    3.513825] hub 2-0:1.0: 1 port detected
[    3.518620] usb_phy_generic usb_phy_generic.1.auto: usb_phy_generic.1.auto supply vcc not found, using dummy regulator
[    3.529768] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[    3.535547] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 3
[    3.544162] hub 3-0:1.0: USB hub found
[    3.547964] hub 3-0:1.0: 1 port detected
[    3.553229] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input1
[    3.561252] do_one_initcall.923 fn=c091f7f0
[    3.565495] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:55 UTC (55)
[    3.573487] do_one_initcall.923 fn=c0923248
[    3.577817] do_one_initcall.923 fn=c0926d2c
[    3.581998] do_one_initcall.923 fn=c0928478
[    3.586208] do_one_initcall.923 fn=c03d263c
[    3.590486] do_one_initcall.923 fn=c091b0d8
[    3.594668] do_one_initcall.923 fn=c0925988
[    3.598856] ALSA device list:
[    3.601824]   No soundcards found.
[    3.605955] Waiting for root device /dev/mtdblock7...
[   33.755403] vcc3v0: disabling
[   33.758373] vcc3v3: disabling
[   33.761337] vcc5v0: disabling
[   33.764309] dc1sw: disabling
U-Boot(SPL) SPL 2023.10-rc2-g8ba06ef2-dirty (Sep 12 2023 - 14:49:02 +0800)
DRAM: 128 MiB
Trying to boot from FEL
U-Boot 2023.10-rc2-g8ba06ef2-dirty (Sep 12 2023 - 14:49:02 +0800) Allwinner Technology
CPU:   Allwinner A33 (SUN8I 1667)
Model: Allwinner R16 EVB (Parrot)
DRAM:  128 MiB
Core:  26 devices, 18 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
NAND:  128 MiB
Loading Environment from NAND... *** Warning - bad CRC, using default environment
In:    serial,usbkbd
Out:   serial
Err:   serial
Net:   using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
eth0: usb_ether
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
musb-hdrc: peripheral reset irq lost!
Starting download of 4377528 bytes
downloading of 4377528 bytes finished
Flashing image at offset 0x1420000
download kernel iamge addr:0x40008000 len:4377528
Starting download of 23769 bytes
downloading of 23769 bytes finished
download dtb iamge addr:0x41000000 len:23769
status: -108 ep 'ep1in' trans: 4
## Booting kernel from Legacy Image at 40008000 ...
   Image Name:   ARM OpenWrt Linux-5.4.61
   Data Size:    4377464 Bytes = 4.2 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Working FDT set to 41000000
   Loading Kernel Image
   Loading Device Tree to 40f2c000, end 40f34cd8 ... OK
   Working FDT set to 40f2c000
Using machid 4137 from environment
前面部分是启用MTD设备但是没有启用Raw/Parallel Nand device support的,可以执行到wait for xxx,后面部分是启用了Raw/Parallel Nand device support的,直接就死掉了。
楼主 #4 2023-09-13 10:30:26
muxi01
已发帖子: 63
可以肯定的是kernel中的串口,肯定是配置对了的。
楼主 #5 2023-09-13 10:50:06
muxi01
已发帖子: 63
muxi01 说:
nand 使用的是PC端口,串口使用的是PF2 PF4,完全不冲突。
最近编辑记录 muxi01 (2023-09-13 10:52:23)
楼主 #6 2023-09-15 14:23:38
muxi01
已发帖子: 63
结帖,已经解决,方法是修改CONFIG_SYS_MALLOC_LEN为2M
