楼主 # 2024-01-03 10:50:23
m68000
已发帖子: 22
为什么我的编译后有bin, elf, map文件,但是没有img文件
如标题,按照说明操作,不论是scons还是Eclipse,都只能生成bin, elf, map等, 没有img
#1 2024-01-03 11:46:01
海石生风
已发帖子: 762
Re: 为什么我的编译后有bin, elf, map文件,但是没有img文件
为什么你提问没有把编译输出信息帖出来,是要大家帮你猜么?
楼主 #2 2024-01-03 13:41:25
m68000
已发帖子: 22
海石生风 说:
抱歉,头一次提问,没有经验, 下面是信息:
Luban-Lite command for Windows
     _         _   ___        ___ _     _
    / \   _ __| |_|_ _|_ __  / __| |__ (_)_ __
   / _ \ | '__| __|| || '_ \| |  | '_ \| | '_ \
  / ___ \| |  | |_ | || | | | |__| | | | | |_) |
/_/   \_\_|   \__|___|_| |_|\___|_| |_|_| .__/
                                         |_|
Microsoft Windows [Version 10.0.19045.3803]
(c) Microsoft Corporation。保留所有权利。
E:\luban-lite-master>scons --list-def
scons: Reading SConscript files ...
Built-in configs:
  0. d13x_demo88-nand_baremetal_bootloader_defconfig    - Build for d13x_demo88-nand_baremetal_bootloader
  1. d13x_demo88-nand_rt-thread_helloworld_defconfig    - Build for d13x_demo88-nand_rt-thread_helloworld
  2. d13x_demo88-nor-xip_baremetal_bootloader_defconfig - Build for d13x_demo88-nor-xip_baremetal_bootloader
  3. d13x_demo88-nor-xip_rt-thread_helloworld_defconfig - Build for d13x_demo88-nor-xip_rt-thread_helloworld
  4. d13x_demo88-nor_baremetal_bootloader_defconfig     - Build for d13x_demo88-nor_baremetal_bootloader
  5. d13x_demo88-nor_baremetal_helloworld_defconfig     - Build for d13x_demo88-nor_baremetal_helloworld
  6. d13x_demo88-nor_rt-thread_helloworld_defconfig     - Build for d13x_demo88-nor_rt-thread_helloworld
  7. d13x_kunlunpi88-nor_baremetal_bootloader_defconfig - Build for d13x_kunlunpi88-nor_baremetal_bootloader
  8. d13x_kunlunpi88-nor_rt-thread_helloworld_defconfig - Build for d13x_kunlunpi88-nor_rt-thread_helloworld
  9. d21x_demo100-nand_baremetal_bootloader_defconfig   - Build for d21x_demo100-nand_baremetal_bootloader
10. d21x_demo100-nand_baremetal_helloworld_defconfig   - Build for d21x_demo100-nand_baremetal_helloworld
11. d21x_demo100-nand_rt-thread_helloworld_defconfig   - Build for d21x_demo100-nand_rt-thread_helloworld
12. d21x_demo100-nor_baremetal_bootloader_defconfig    - Build for d21x_demo100-nor_baremetal_bootloader
13. d21x_demo100-nor_rt-thread_helloworld_defconfig    - Build for d21x_demo100-nor_rt-thread_helloworld
14. d21x_demo128-nand_baremetal_bootloader_defconfig   - Build for d21x_demo128-nand_baremetal_bootloader
15. d21x_demo128-nand_rt-thread_helloworld_defconfig   - Build for d21x_demo128-nand_rt-thread_helloworld
16. d21x_demo88-mmc_baremetal_bootloader_defconfig     - Build for d21x_demo88-mmc_baremetal_bootloader
17. d21x_demo88-mmc_rt-thread_helloworld_defconfig     - Build for d21x_demo88-mmc_rt-thread_helloworld
18. d21x_demo88-nand_baremetal_bootloader_defconfig    - Build for d21x_demo88-nand_baremetal_bootloader
19. d21x_demo88-nand_baremetal_helloworld_defconfig    - Build for d21x_demo88-nand_baremetal_helloworld
20. d21x_demo88-nand_rt-thread_helloworld_defconfig    - Build for d21x_demo88-nand_rt-thread_helloworld
21. d21x_demo88-nor_baremetal_bootloader_defconfig     - Build for d21x_demo88-nor_baremetal_bootloader
22. d21x_demo88-nor_rt-thread_helloworld_defconfig     - Build for d21x_demo88-nor_rt-thread_helloworld
E:\luban-lite-master>scons --apply-def=4
Load config from target\configs\d13x_demo88-nor_baremetal_bootloader_defconfig
E:\luban-lite-master\kernel\rt-thread
scons: done reading SConscript files.
scons: Building targets ...
scons: building associated VariantDir targets: output\d13x_demo88-nor_baremetal_bootloader
LINK output\d13x_demo88-nor_baremetal_bootloader\images\d13x.elf
-rw-r--r-- 1 1426884 Jan  3 13:38 output\d13x_demo88-nor_baremetal_bootloader\images\d13x.elf
riscv64-unknown-elf-objcopy -O binary output\d13x_demo88-nor_baremetal_bootloader\images\d13x.elf E:\luban-lite-master\output/d13x_demo88-nor_baremetal_bootloader/images/d13x.bin
riscv64-unknown-elf-size output\d13x_demo88-nor_baremetal_bootloader\images\d13x.elf
   text    data     bss     dec     hex filename
109784    4640   19016  133440   20940 output\d13x_demo88-nor_baremetal_bootloader\images\d13x.elf
python3 E:\luban-lite-master\tools/scripts/linked_size.py -m E:\luban-lite-master\output/d13x_demo88-nor_baremetal_bootloader/images/d13x.map
Luban-Lite is built successfully
scons: done building targets.
#3 2024-01-03 14:42:33
chaplin1999
已发帖子: 41
@m68000
你要再编对应的app 应用才打包生成img,单编译boot 没有img
楼主 #4 2024-01-03 15:03:56
m68000
已发帖子: 22
chaplin1999 说:
@m68000
OK, 我再仔细看一下文档,匠芯创的文档中写的就是编译后直接产生img,也许有的地方我没有看到
楼主 #5 2024-01-03 15:26:40
m68000
已发帖子: 22
chaplin1999 说:
@m68000
能详细的说一下吗?使用什么工具来打包生成img,也许我比较愚钝,没有看到文档中有说明.
#6 2024-01-03 15:40:26
chaplin1999
已发帖子: 41
序号4是boot 你编译序号5 就是对应app,编译好自动生成img
#7 2024-01-06 13:40:51
xfdr0805
已发帖子: 347
要去app文件夹里找 不在bootloader里
#8 2024-01-11 00:21:05
wonderfullook
选择带有rtt的配置就有img了
