楼主 # 2024-02-05 10:45:43
memory
已发帖子: 694
modprobe aic8800_fdrv 出错,请问是什么原因呢?
root@TinaLinux:/# modprobe aic8800_fdrv
[   80.607302] AICWFDBG(LOGTRACE)       >>> rwnx_mod_init()
[   80.612790] AICWFDBG(LOGINFO)        rwnx v6.4.3.0 - - 241c091M (master)
[   80.619718] AICWFDBG(LOGINFO)        RELEASE_DATE:2023_1219_3cf85031
[   80.626411] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Enter
[   80.632919] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[0]:e09bf021
[   80.640910] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[1]:b491ef27
[   80.648690] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[2]:3d28fc62
[   80.656530] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[3]:1e341e02
[   80.664440] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[4]:02d22c8f
[   80.672222] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[5]:b348bcfa
[   80.679996] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[6]:99decb26
[   80.687720] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[7]:8302a139
[   80.695546] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[8]:363740c7
[   80.703340] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[9]:eaab7093
[   80.703347] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[10]:59fed743
[   80.703353] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[11]:d3e745f8
[   80.703364] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[12]:618916fe
[   80.734644] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[13]:0059b263
[   80.734655] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[14]:fe5fb1c6
[   80.750432] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[15]:114f33b3
[   80.758293] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[16]:56866e6d
[   80.766161] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[17]:77c73f90
[   80.774022] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[18]:5f030b3f
[   80.781877] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[19]:5d270d0d
[   80.789803] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Exit
[   80.795897] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[   80.803078] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[   80.811328] aicbsp: aicbsp_platform_power_on
[   80.866454] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[   80.923672] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   80.934949] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[   80.955193] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   80.979558] sunxi-mmc 4021000.sdmmc: failed to get DS26_SDR12 used default
[   81.000243] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[   81.007934] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[   81.014906] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   81.026672] sunxi-mmc 4021000.sdmmc: failed to get DS26_SDR12 used default
[   81.052679] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   81.079580] sunxi-mmc 4021000.sdmmc: failed to get DS26_SDR12 used default
[   81.089447] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[   81.097027] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[   81.104773] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[   81.112479] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[   81.119312] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   83.009527] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
[   83.016835] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[   83.024873] AICWFDBG(LOGERROR)       rwnx_mod_init, set power on fail!
1 module could not be probed
- aic8800_fdrv
#1 2024-02-06 09:27:34
0x754C
Re: modprobe aic8800_fdrv 出错,请问是什么原因呢?
没扫到卡,建议检查物理连线
楼主 #2 2024-02-06 10:57:59
memory
已发帖子: 694
0x754C 说:
没扫到卡,建议检查物理连线
有扫描到卡片:
root@TinaLinux:/# ls /sys/bus/sdio/devices/ -l
lrwxrwxrwx    1 root     root             0 Jan  1 21:37 mmc0:390b:1 -> ../../../devices/platform/soc@3000000/4021000.sdmmc/mmc_host/mmc0/mmc0:390b/mmc0:390b:1
lrwxrwxrwx    1 root     root             0 Jan  1 21:37 mmc0:390b:2 -> ../../../devices/platform/soc@3000000/4021000.sdmmc/mmc_host/mmc0/mmc0:390b/mmc0:390b:2
root@TinaLinux:/#
安装驱动的日志:
root@TinaLinux:/#
root@TinaLinux:/# insmod /lib/modules/5.4.61/aic8800_fdrv.ko
[44326.173440] AICWFDBG(LOGTRACE)       >>> rwnx_mod_init()
[44326.178911] AICWFDBG(LOGINFO)        rwnx v6.4.3.0 - - 241c091M (master)
[44326.185776] AICWFDBG(LOGINFO)        RELEASE_DATE:2023_1219_3cf85031
[44326.192493] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Enter
[44326.198756] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[0]:b2bbe77e
[44326.206481] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[1]:573aef1b
[44326.214289] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[2]:027d02d6
[44326.214296] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[3]:a8a24393
[44326.214302] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[4]:2bf9087b
[44326.214308] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[5]:387b7179
[44326.214314] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[6]:cb34a1d6
[44326.214321] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[7]:0d53ca4e
[44326.214327] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[8]:358d572f
[44326.214332] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[9]:53cf20d0
[44326.214339] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[10]:f509168e
[44326.214345] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[11]:07aaf870
[44326.214351] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[12]:092a6c66
[44326.214356] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[13]:8b6870c8
[44326.214362] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[14]:04763693
[44326.214368] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[15]:8566d843
[44326.214374] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[16]:d4388082
[44326.214380] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[17]:eda3af40
[44326.214386] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[18]:636fa75c
[44326.214392] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[19]:a637554f
[44326.214396] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Exit
[44326.214404] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[44326.214410] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[44326.214414] aicbsp: aicbsp_platform_power_on
[44326.214578] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[44326.214643] aicbsp_dummy_sdmmc: probe of mmc0:390b:1 failed with error -110
[44326.214716] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[44326.219530] aicbsp_dummy_sdmmc: probe of mmc0:390b:2 failed with error -110
[44326.478419] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[44326.535661] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 7, RTO !!
[44326.542504] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 7, RTO !!
[44326.549323] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 7, RTO !!
[44326.556140] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 7, RTO !!
[44326.563531] mmc0: card 390b removed
[44326.567800] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[44326.589803] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[44326.601049] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[44326.621229] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[44326.638534] sunxi-mmc 4021000.sdmmc: failed to get DS26_SDR12 used default
[44326.681881] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[44326.689602] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[44326.696517] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[44326.728476] sunxi-mmc 4021000.sdmmc: failed to get DS26_SDR12 used default
[44326.739167] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[44326.808455] sunxi-mmc 4021000.sdmmc: failed to get DS26_SDR12 used default
[44326.828490] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[44326.858514] sunxi-mmc 4021000.sdmmc: failed to get DS26_SDR12 used default
[44326.866947] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-DDR50 dt B
[44326.878386] sunxi-mmc 4021000.sdmmc: failed to get HSDDR52_DDR50 used default
[44326.878420] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing UHS-DDR50 dt B
[44326.878514] sunxi-mmc 4021000.sdmmc: failed to get HSDDR52_DDR50 used default
[44326.909447] mmc0: new ultra high speed DDR50 SDIO card at address 390b
[44326.934867] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1  did:0x0082
[44326.941605] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1  did:0x0182
[44326.948156] aicbsp: aicbsp_sdio_probe after replace:1
[44326.953879] AICWFDBG(LOGINFO)        aicwf_sdio_chipmatch USE AIC8800D80
[44326.960860] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz
[44326.968196] aicbsp: aicwf_sdio_reg_init
[44326.974830] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44326.982129] sunxi-mmc 4021000.sdmmc: retry:start
[44326.987413] sunxi-mmc 4021000.sdmmc: retry:stop
[44326.992622] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44326.998562] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.004880] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.011287] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.017420] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.024218] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.031411] sunxi-mmc 4021000.sdmmc: retry:start
[44327.036690] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.036733] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.047754] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.054084] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.060477] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.066569] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.073363] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.080598] sunxi-mmc 4021000.sdmmc: retry:start
[44327.080608] sunxi-mmc 4021000.sdmmc: retry:stop
** 13 printk messages dropped **
[44327.091244] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.091270] sunxi-mmc 4021000.sdmmc: retry:start
[44327.091277] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.091306] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.091338] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.091346] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710110
[44327.091354] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.091369] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.091397] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.091429] sunxi-mmc 4021000.sdmmc: retry:start
[44327.091436] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.091466] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.091498] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.091506] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710110
[44327.091516] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.091533] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.091560] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.091586] sunxi-mmc 4021000.sdmmc: retry:start
[44327.091595] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.091623] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.091654] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.091662] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.091670] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.091684] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.091710] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.091733] sunxi-mmc 4021000.sdmmc: retry:start
[44327.091740] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.091768] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.091800] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.091808] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.091816] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.091830] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.091857] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.091883] sunxi-mmc 4021000.sdmmc: retry:start
[44327.091891] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.091920] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.091951] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.091959] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.091967] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.091982] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.092009] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.092033] sunxi-mmc 4021000.sdmmc: retry:start
[44327.092040] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.092069] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.092101] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.092109] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.092118] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.092132] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.092159] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.092182] sunxi-mmc 4021000.sdmmc: retry:start
[44327.092190] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.092217] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.092249] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.092258] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.092265] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.092280] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.092307] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.092328] sunxi-mmc 4021000.sdmmc: retry:start
[44327.092336] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.092363] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.092404] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.092413] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710000
[44327.092420] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.092435] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.092462] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.092485] sunxi-mmc 4021000.sdmmc: retry:start
[44327.092492] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.092520] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.092551] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.092560] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710110
[44327.092567] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.092582] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.092608] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.092631] sunxi-mmc 4021000.sdmmc: retry:start
[44327.092638] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.092667] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.092699] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.092708] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710110
[44327.092715] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.092730] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.092756] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.092779] sunxi-mmc 4021000.sdmmc: retry:start
[44327.092786] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.092812] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.092842] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.092851] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710110
[44327.092859] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.092873] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.092896] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.092919] sunxi-mmc 4021000.sdmmc: retry:start
[44327.092927] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.092953] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.092983] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.092991] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710220
[44327.092999] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.093013] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.093036] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.093056] sunxi-mmc 4021000.sdmmc: retry:start
[44327.093063] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.093089] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.093120] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.093128] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710220
[44327.093136] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.093149] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.093173] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.093194] sunxi-mmc 4021000.sdmmc: retry:start
[44327.093201] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.093226] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.093257] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00030000
[44327.093265] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710220
[44327.093273] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.093287] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.093311] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.093331] sunxi-mmc 4021000.sdmmc: retry:start
[44327.093339] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.093365] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.093403] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.093411] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710220
[44327.093419] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.093433] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.093455] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.093477] sunxi-mmc 4021000.sdmmc: retry:start
[44327.093484] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.093510] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.093540] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.093549] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710220
[44327.093556] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.093570] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.093593] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.093614] sunxi-mmc 4021000.sdmmc: retry:start
[44327.093621] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.093647] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.093677] sunxi-mmc 4021000.sdmmc: REG_DRV_DL: 0x00000000
[44327.093685] sunxi-mmc 4021000.sdmmc: REG_SD_NTSR: 0x81710220
[44327.093693] sunxi-mmc 4021000.sdmmc: REG_NTDC: 0x00000800
[44327.093707] sunxi-mmc 4021000.sdmmc: *****retry:re-send cmd*****
[44327.093731] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 53, WR DCE !!
[44327.093752] sunxi-mmc 4021000.sdmmc: retry:start
[44327.093760] sunxi-mmc 4021000.sdmmc: retry:stop
[44327.093786] sunxi-mmc 4021000.sdmmc: retry:stop recover
[44327.093812] sunxi-mmc 4021000.sdmmc: sunxi v5p3x retry give up, return to HS
[44327.093820] sunxi-mmc 4021000.sdmmc: retry:set phase failed or over retry times
[44327.093831] sunxi-mmc 4021000.sdmmc: retry:give up
[44327.093949] aicbsp: sdio_err:<aicwf_sdio_tx_msg,978>: aicwf_sdio_send_pkt fail-110
[44327.094019] aicbsp: sdio_err:<aicwf_sdio_bus_txmsg,1122>: send faild:0, 0,1e9
[44330.118368] cmd timed-out
[44330.121342] tkn[0]  flags:0012  result: -4  cmd:1024 - reqcfm(1025)
[44330.129128] aicbsp: aicbsp_sdio_remove
[44330.133358] aicbsp: aicwf_sdio_release
[44330.137686] aicbsp: aicwf_bus_deinit
[44330.137696] aicbsp: aicwf_sdio_bus_stop
[44330.146144] aicbsp: sdio_err:<aicwf_sdio_bustx_thread,1341>: sdio bustx thread stop
[44330.155081] aicbsp: sdio_err:<aicwf_sdio_busrx_thread,1360>: sdio busrx thread stop
[44330.163907] aicbsp: aicbsp_sdio_remove done
[44330.169484] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
[44330.276821] aicbsp: aicbsp_platform_power_off
[44330.281813] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[44330.289817] AICWFDBG(LOGERROR)       rwnx_mod_init, set power on fail!
failed to insert /lib/modules/5.4.61/aic8800_fdrv.ko
root@TinaLinux:/#
楼主 #3 2024-11-24 15:20:49
memory
已发帖子: 694
aic8800 驱动里面所有的 Makefile都改成:
CONFIG_PLATFORM_ALLWINNER ?= y
CONFIG_PLATFORM_UBUNTU ?= n
#4 2025-10-15 13:50:10
fenglichao
@memory
大佬是怎么解决的?
