Hello! Does anyone have experience with MJPEG encoding (or any other format) a video stream using the LicheePi Nano?, I have read that it supports hardware encoding, but I haven't been able to find any information about how to use it. In addition, i am programming in bare metal, which makes it more complex. Does anyone have any suggestion? I'm building a web camera.
Can you already capture an image? It would probably be worth starting with this. The process of hardware encoding to jpeg will need to be done later and it is quite simple.
Thank you for your answer. Currently I'm able to capture image using the tvd driver and send the captured image through USB. But is too slow without compression. To achieve this, I used some examples from the web, as I'm not very experienced with embedding programming.
Could you share some recourses or examples that may guide me in the right direction on how to do the encoding?
