楼主 # 2024-03-10 08:53:23
lmnb
已发帖子: 39
荔枝派nano电阻触摸使用tsc2007驱动一直触发中断问题
dtsi
i2c0: i2c@1c27000 {
			compatible = "allwinner,sun6i-a31-i2c";
			reg = <0x01c27000 0x400>;
			interrupts = <7>;
			clocks = <&ccu CLK_BUS_I2C0>;
			resets = <&ccu RST_BUS_I2C0>;
			pinctrl-names = "default";
			pinctrl-0 = <&i2c0_pins>;
			status = "disabled";
			#address-cells = <1>;
			#size-cells = <0>;
dts
&i2c0 {
	tsc2007@48 {
		compatible = "ti,tsc2007";
		reg = <0x48>;
		interrupt-parent = <&pio>;
		interrupts = <4 10 0x2>;
		gpios = <&pio 4 10 GPIO_ACTIVE_LOW>;
		pendown-gpio = <&pio 4 10 GPIO_ACTIVE_LOW>;
		ti,x-plate-ohms = <660>;
		wakeup-source;
用了这个命令ts_test发现一直在打印数据,而且那个点也一直在lcd左上角动,然后使用cat /proc/interrupts命令发现居然一直在中断
[root@lmnb:~]$ cat /proc/interrupts
           CPU0
 16:      12129  sun4i_irq  13 Edge      timer@1c20c00
 17:        298  sun4i_irq  29 Edge      1c0c000.lcd-controller
 18:          0  sun4i_irq  18 Edge      1c02000.dma-controller
 20:          0  sun4i_irq  10 Edge      sun6i-spi
 21:          0  sun4i_irq  11 Edge      sun6i-spi
 22:     298480  sun4i_irq   7 Edge      mv64xxx_i2c
 26:       3159  sun4i_irq  23 Edge      sunxi-mmc
 27:      12897  sun4i_irq   1 Edge      ttyS0
 28:          0  sun4i_irq  26 Edge      musb-hdrc.1.auto
 64:          1  sunxi_pio_edge  34 Edge      usb0-id-det
 72:      17059  sunxi_pio_edge  42 Edge      tsc2007
Err:          0
