楼主 # 2024-06-23 05:56:51
yuqingli
t113-s3 配置内核第二阶段卡死
1、使用 tina sdk,天嵌的 核心板
2、使用uart3 控制台输出
3、改了根据自己的底板改了 dts之后,时不时的卡死。有时候修改个 无关的 dts(比如加一个不存在的 i2c cpt 触摸 节点竟然好了)。修改无关的 dts 时好时坏。
4、把uart3整个 dts节点全部 屏蔽掉,竟然能正常 启动并且输出,好像一直用 earlyprink输出的。
5、有时候死机日志 也不一定固定在哪一行,老是感觉 启动时候初始化不知道怎么了,测了很多次,感觉都不是本质问题,感觉像 修改dts节点 或者 串口啥的 影响了启动顺序导致死机。
实在找不到问题了,各位大佬有遇见类似的现象的吗 救救我
日志如下
HELLO! BOOT0 is starting!
[225]BOOT0 commit : 1417090655
[228]set pll start
[230]fix vccio detect value:0xc0
[237]periph0 has been enabled
[240]set pll end
[241][pmu]: bus read error
[244]board init ok
[246]enable_jtag
[248]ZQ value = 0x2f
[250]get_pmu_exist() = -1
[252]DRAM BOOT DRIVE INFO: V0.33
[255]DRAM CLK = 792 MHz
[257]DRAM Type = 3 (2:DDR2,3:DDR3)
[261]DRAMC read ODT  off.
[263]DRAM ODT value: 0x42.
[266]ddr_efuse_type: 0xa
[269]DRAM SIZE =128 M
[271]dram_tpr4:0x0
[273]PLL_DDR_CTRL_REG:0xf8004100
[276]DRAM_CLK_REG:0xc0000000
[278][TIMING DEBUG] MR2= 0x18
[287]DRAM simple test OK.
[289]rtc standby flag is 0x0, super standby flag is 0x0
[294]dram size =128
[297]card no is 2
[298]sdcard 2 line count 4
[301][mmc]: mmc driver ver 2021-05-21 14:47
[310][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[316][mmc]: ***Try MMC card 2***
[339][mmc]: RMCA OK!
[341][mmc]: mmc 2 bias 0
[344][mmc]: MMC 5.1
[346][mmc]: HSSDR52/SDR25 4 bit
[349][mmc]: 50000000 Hz
[351][mmc]: 7396 MB
[353][mmc]: ***SD/MMC 2 init OK!!!***
[454]Loading boot-pkg Succeed(index=0).
[458]Entry_name        = u-boot
[465]Entry_name        = optee
[469]Entry_name        = dtb
[472]tunning data addr:0x430003e8
[475]Jump to second Boot.
M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
U-Boot 2018.07 (Jun 21 2024 - 22:19:37 +0800) Allwinner Technology
[00.528]CPU:   Allwinner Family
[00.530]Model: EmbedSky TQT113-Core Board-uboot
[00.535]DRAM:  128 MiB
[00.538]Relocation Offset is: 04e92000
[00.569]secure enable bit: 0
E/TC:0   tee_read_fdt:433 fine node /firmware/optee failed with FDT_ERR_NOTFOUND
[00.582]smc_tee_inform_fdt failed with: ffff0000
[00.587]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[00.594]gic: sec monitor mode
sunxi flash map init
[00.599]flash init start
[00.601]workmode = 0,storage type = 2
$$$$[drivers/sunxi_flash/mmc/sdmmc.c] sdmmc_init_for_boot 832 card_no:2
[00.611][mmc]: mmc driver ver uboot2018:2022-12-07 18:56:00
[00.617][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.642][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[00.648]sunxi flash init ok
mmc2(part 0) is current device
Partition Map for MMC device 2  --   Partition Type: EFI
Part    Start LBA       End LBA         Name
        Attributes
        Type GUID
        Partition GUID
  1     0x0001a000      0x000227ff      "boot-resource"
        attrs:  0x8000000000000000
        type:   ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
        guid:   a0085546-4166-744a-a353-fca9272b8e45
  2     0x00022800      0x00022fff      "env"
        guid:   a0085546-4166-744a-a353-fca9272b8e46
  3     0x00023000      0x000237ff      "env-redund"
        guid:   a0085546-4166-744a-a353-fca9272b8e47
  4     0x00023800      0x0002c7ff      "boot"
        guid:   a0085546-4166-744a-a353-fca9272b8e48
  5     0x0002c800      0x0022c7ff      "rootfs"
        guid:   a0085546-4166-744a-a353-fca9272b8e49
  6     0x0022c800      0x0022cfff      "dsp0"
        guid:   a0085546-4166-744a-a353-fca9272b8e4a
  7     0x0022d000      0x00234fff      "private"
        guid:   a0085546-4166-744a-a353-fca9272b8e4b
  8     0x00235000      0x00254fff      "recovery"
        guid:   a0085546-4166-744a-a353-fca9272b8e4c
  9     0x00255000      0x00e71fde      "UDISK"
        guid:   a0085546-4166-744a-a353-fca9272b8e4d
## Info: input data size = 2501 = 0x9C5
No reserved memory region found in source FDT
[00.827]line:719 init_clocks
[00.830]drv_disp_init
[00.836]handle_num : 6
request pwm success, pwm7:pwm7:0x2000c00.
[00.848]handle_num : 2
[00.850]drv_disp_init finish
[00.857]Loading Environment from SUNXI_FLASH... OK
[00.873]boot_gui_init:start
[00.876]set disp.dev2_output_type fail. using defval=0
[00.882]set disp.fb0_rot_used fail. using defval=0
[00.887]set disp.fb0_rot_degree fail. using defval=0
[00.893]boot_gui_init:finish
partno erro : can't find partition bootloader
[00.900]bmp_name=bootlogo.bmp size 368276
[00.921]Item0 (Map) magic is bad
[00.924]the secure storage item0 copy0 magic is bad
[00.931]Item0 (Map) magic is bad
[00.934]the secure storage item0 copy1 magic is bad
[00.939]Item0 (Map) magic is bad
secure storage read widevine fail
[00.945]secure storage read widevine fail with:-1
secure storage read ec_key fail
[00.952]secure storage read ec_key fail with:-1
secure storage read ec_cert1 fail
[00.959]secure storage read ec_cert1 fail with:-1
secure storage read ec_cert2 fail
[00.967]secure storage read ec_cert2 fail with:-1
secure storage read ec_cert3 fail
[00.974]secure storage read ec_cert3 fail with:-1
secure storage read rsa_key fail
[00.982]secure storage read rsa_key fail with:-1
secure storage read rsa_cert1 fail
[01.250]secure storage read rsa_cert1 fail with:-1
secure storage read rsa_cert2 fail
[01.257]secure storage read rsa_cert2 fail with:-1
secure storage read rsa_cert3 fail
[01.265]secure storage read rsa_cert3 fail with:-1
[01.270]usb burn from boot
delay time 0
weak:otg_phy_config
[01.281]usb prepare ok
[01.483]usb sof ok
[01.485]usb probe ok
[01.487]usb setup ok
set address 0x5
set address 0x5 ok
try to update
[01.794]LCD open finish
[01.892]do_burn_from_boot usb : have no handshake
List file under ULI/factory
** Unrecognized filesystem type **
root_partition is rootfs
set root to /dev/mmcblk0p5
[01.917]update part info
[01.920]update bootcmd
[01.925]change working_fdt 0x44851e58 to 0x44831e58
[01.930][mmc]: no mmc-hs400-1_8v!
[01.933][mmc]: delete mmc-hs200-1_8v from dtb
[01.937][mmc]: get max-frequency ok 50000000 Hz
disable nand error: FDT_ERR_BADPATH
[01.956]update dts
[01.958]No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
## Error: "sunxi_sprite_test" not defined
[02.986][mmc]: mmc driver ver uboot2018:2022-12-07 18:56:00
[02.992][mmc]: get sdc_type fail and use default host:tm1.
[02.999][mmc]: Using default timing para
[03.003][mmc]: SUNXI SDMMC Controller Version:0x50310
[03.008][mmc]:  (eMMC)[03.010][mmc]: , [03.020][mmc]: mmc 0 cmd timeout 100 status 100
[03.024][mmc]: smc 0 err, cmd 8,  RTO
[03.028][mmc]: mmc 0 close bus gating and reset
[03.033][mmc]: mmc 0 cmd timeout 100 status 100
[03.037][mmc]: smc 0 err, cmd 55,  RTO
[03.040][mmc]: mmc 0 close bus gating and reset
[03.049][mmc]: mmc 0 cmd timeout 100 status 100
[03.053][mmc]: smc 0 err, cmd 1,  RTO
[03.056][mmc]: mmc 0 close bus gating and reset
[03.060][mmc]: Card did not respond to voltage select!
[03.065][mmc]: mmc_init: -95, time 54
[03.069][mmc]: mmc_init: mmc init fail, err -95
card0 init failed
sunxi_card0_probe - probe sunxi card0 device
Usage:
sunxi_card0_probe sunxi_card0_probe
Read EmbedSky.ini from SD
[03.094][mmc]: mmc 0 cmd timeout 100 status 100
[03.098][mmc]: smc 0 err, cmd 8,  RTO
[03.102][mmc]: mmc 0 close bus gating and reset
[03.107][mmc]: mmc 0 cmd timeout 100 status 100
[03.111][mmc]: smc 0 err, cmd 55,  RTO
[03.114][mmc]: mmc 0 close bus gating and reset
[03.123][mmc]: mmc 0 cmd timeout 100 status 100
[03.127][mmc]: smc 0 err, cmd 1,  RTO
[03.130][mmc]: mmc 0 close bus gating and reset
[03.134][mmc]: Card did not respond to voltage select!
[03.139][mmc]: mmc_init: -95, time 54
[03.143][mmc]: mmc_init: mmc init fail, err -95
** Bad device mmc 0 **
EmbedSky.ini file is not in SD.
Read EmbedSky.ini from Udisk
** Bad device usb 0 **
EmbedSky.ini file is not in Udisk.
boot  addr 0x43000000 0x43b49000 exceed dsp0 scope
dsp0  addr 0x43000000 0x43100000
[03.462]no vendor_boot partition is found
Android's image name: sun8i_arm
[03.477]Starting kernel ...
[03.479][mmc]: mmc exit start
[03.497][mmc]: mmc 2 exit ok
[    0.000000] 000: printk: bootconsole [earlycon0] enabled
[    0.000000] 000: Memory policy: Data cache writealloc
[    0.000000] 000: cma: Reserved 16 MiB at 0x47000000
[    0.000000] 000: On node 0 totalpages: 32768
[    0.000000] 000:   Normal zone: 256 pages used for memmap
[    0.000000] 000:   Normal zone: 0 pages reserved
[    0.000000] 000:   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] 000: psci: probing for conduit method from DT.
[    0.000000] 000: psci: PSCIv1.0 detected in firmware.
[    0.000000] 000: psci: Using standard PSCI v0.2 function IDs
[    0.000000] 000: psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] 000: psci: SMC Calling Convention v1.0
[    0.000000] 000: percpu: Embedded 11 pages/cpu s14720 r8192 d22144 u45056
[    0.000000] 000: pcpu-alloc: s14720 r8192 d22144 u45056 alloc=11*4096
[    0.000000] 000:
[    0.000000] 000: [0]
[    0.000000] 000: 0
[    0.000000] 000: 1
[    0.000000] 000:
[    0.000000] 000: Built 1 zonelists, mobility grouping on.  Total pages: 32512
[    0.000000] 000: Kernel command line: ubi.block=0,rootfs earlyprintk= clk_ignore_unused initcall_debug=0 console=ttySAC3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:recovery@mmcblk0p8:UDISK@mmcblk0p9 cma=16M snum=fc001444300483d180b mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.serialno=fc001444300483d180b androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.07(06/21/2024-22:19:37) disp_reserve=4096000,0x448df000 androidboot.dramsize=128
[    0.000000] 000: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] 000: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] 000: mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] 000: Memory: 86880K/131072K available (8192K kernel code, 463K rwdata, 2864K rodata, 1024K init, 219K bss, 27808K reserved, 16384K cma-reserved)
[    0.000000] 000: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] 000: rcu: Preemptible hierarchical RCU implementation.
[    0.000000] 000: rcu:        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] 000:     Tasks RCU enabled.
[    0.000000] 000: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] 000: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] 000: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] 000: random: get_random_bytes called from start_kernel+0x24c/0x3cc with crng_init=0
[    0.000000] 000: arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] 000: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] 000: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008447] 000: Switching to timer-based delay loop, resolution 41ns
[    0.015055] 000: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.025250] 000: Console: colour dummy device 80x30
[    0.030185] 000: Calibrating delay loop (skipped), value calculated using timer frequency..
[    0.038633] 000: 48.00 BogoMIPS (lpj=240000)
[    0.042915] 000: pid_max: default: 32768 minimum: 301
[    0.048095] 000: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.055875] 000: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.064689] 000: CPU: Testing write buffer coherency:
[    0.069902] 000: ok
[    0.072297] 000: /cpus/cpu@0 missing clock-frequency property
[    0.078063] 000: /cpus/cpu@1 missing clock-frequency property
[    0.083839] 000: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.090534] 000: Setting up static identity map for 0x40100000 - 0x40100060
[    0.097660] 000: rcu: Hierarchical SRCU implementation.
[    0.103190] 000: BOOTEVENT:       103.189332: ON
[    0.108063] 000: smp: Bringing up secondary CPUs ...
[    0.114259] 001: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.120516] 000: smp: Brought up 1 node, 2 CPUs
[    0.125045] 000: SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.131711] 000: CPU: All CPU(s) started in SVC mode.
[    0.137295] 001: devtmpfs: initialized
[    0.153966] 001: VFP support v0.3:
[    0.157531] 001: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.164516] 001: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.174818] 001: futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.182847] 001: pinctrl core: initialized pinctrl subsystem
[    0.190000] 001: NET: Registered protocol family 16
[    0.196853] 000: DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.238589] 000: rtc_ccu: sunxi ccu init OK
[    0.245359] 000: ccu: sunxi ccu init OK
[    0.249728] 000: r_ccu: sunxi ccu init OK
[    0.301061] 001: sun6i-dma 3002000.dma-controller: sunxi dma probed
[    0.310393] 001: iommu: Default domain type: Translated
[    0.315948] 001: sunxi iommu: irq = 24
[    0.320966] 001: SCSI subsystem initialized
[    0.325713] 001: usbcore: registered new interface driver usbfs
[    0.331797] 001: usbcore: registered new interface driver hub
[    0.337714] 001: usbcore: registered new device driver usb
[    0.343964] 001: mc: Linux media interface: v0.10
[    0.348783] 001: videodev: Linux video capture interface: v2.00
[    0.356232] 001: Advanced Linux Sound Architecture Driver Initialized.
[    0.363481] 001: Bluetooth: Core ver 2.22
[    0.367643] 001: NET: Registered protocol family 31
[    0.372535] 001: Bluetooth: HCI device and connection manager initialized
[    0.379339] 001: Bluetooth: HCI socket layer initialized
[    0.384664] 001: Bluetooth: L2CAP socket layer initialized
[    0.390183] 001: Bluetooth: SCO socket layer initialized
[    0.395827] 001: pwm module init!
[    0.400759] 001: g2d 5410000.g2d: Adding to iommu group 0
[    0.406612] 001: G2D: rcq version initialized.major:250
[    0.412603] 001: input: sunxi-keyboard as /devices/virtual/input/input0
[    0.420736] 001: clocksource: Switched to clocksource arch_sys_counter
[    0.436787] 001: sun8iw20-pinctrl pio: initialized sunXi PIO driver
[    0.457581] 001: thermal_sys: Registered thermal governor 'step_wise'
[    0.464078] 001: thermal_sys: Registered thermal governor 'user_space'
[    0.470626] 001: thermal_sys: Registered thermal governor 'power_allocator'
[    0.478198] 001: NET: Registered protocol family 2
[    0.483756] 001: tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.492603] 001: TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.500717] 001: TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.508263] 001: TCP: Hash tables configured (established 1024 bind 1024)
[    0.515190] 001: UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.522198] 001: UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.529795] 001: NET: Registered protocol family 1
[    0.535237] 000: RPC: Registered named UNIX socket transport module.
[    0.542277] 000: RPC: Registered udp transport module.
[    0.547432] 000: RPC: Registered tcp transport module.
[    0.552587] 000: RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.562276] 000: Initialise system trusted keyrings
[    0.567323] 000: workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.585244] 000: squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.592975] 000: ntfs: driver 2.1.32 [Flags: R/W].
[    0.598132] 000: fuse: init (API version 7.31)
[    0.632420] 001: NET: Registered protocol family 38
[    0.637326] 001: Key type asymmetric registered
[    0.641933] 001: Asymmetric key parser 'x509' registered
[    0.647335] 001: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.655185] 001: io scheduler mq-deadline registered
[    0.660163] 001: io scheduler kyber registered
[    0.664713] 001: atomic64_test: passed
[    0.670529] 001: pwm-backlight soc@3000000:backlight: soc@3000000:backlight supply power not found, using dummy regulator
[    0.681803] 001: of_pwm_get(): can't parse "pwms" property
[    0.687318] 001: pwm-backlight soc@3000000:backlight: unable to request PWM, trying legacy API
[    0.696165] 001: sunxi_pwm_enable_dual: can't parse pwm device
[    0.702234] 001: [DISP]disp_module_init
[    0.706652] 001: disp 5000000.disp: Adding to iommu group 0
[    0.712921] 001: [DISP] parser_disp_init_para,line:1407:
[    0.718247] 001: of_property_read fb0_width fail
[    0.722915] 001: [DISP] disp_init,line:2331:
[    0.727188] 001: smooth display screen:0 type:1 mode:4
[    0.732931] 001: display_fb_request,fb_id:0
[    0.737115] 001: [DISP] display_fb_request,line:2050:
[    0.742218] 001: invalid paras xres(0), yres(0) bpp(32)
[    0.747844] 001: disp_al_manager_apply ouput_type:1
[    0.751431] 000: [DISP]disp_module_init finish
[    0.752913] 001: [DISP] lcd_clk_config,line:777:
[    0.758728] 000: sunxi_sid_init()783 - insmod ok
[    0.762109] 001: disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
     clk real:pll(297000000),clk(210000000),dclk(0) dsi_rate(0)
[    0.768373] 000: sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[    0.786954] 000: uart uart1: uart1 supply uart not found, using dummy regulator
[    0.794661] 000: uart1: ttySAC1 at MMIO 0x2500400 (irq = 33, base_baud = 1500000) is a SUNXI
[    0.803853] 000: sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[    0.812436] 000: uart uart2: uart2 supply uart not found, using dummy regulator
[    0.820075] 000: uart2: ttySAC2 at MMIO 0x2500800 (irq = 34, base_baud = 1500000) is a SUNXI
[    0.829402] 000: uart uart3: uart3 supply uart not found, using dummy regulator
[    0.837119] 000: uart3: ttySAC3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[    0.845643] 000: sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
?[    0.854052] 000: printk: console [ttySAC3] enabled
[    0.858901] 000: printk: bootconsole [earlycon0] disabled
[    0.875556] 001: PPP Deflate Compression module registered
** 3 printk messages dropped **
[    0.875790] 001: usbcore: registered new interface driver ax88179_178a
[    0.875854] 001: usbcore: registered new interface driver cdc_ether
** 6 printk messages dropped **
[    0.876219] 001: sunxi-ehci: EHCI SUNXI driver
** 1 printk message dropped **
[    0.876705] 001: get ehci0-controller wakeup-source is fail.
[    0.876833] 001: [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0e9b2b0, 0x:c8833000, irq_no:38
[    0.876843] 001: [sunxi-ehci0]: Not init ehci0
[    0.877152] 001: get drvvbus-en is fail, 22
[    0.877161] 001: get ehci1-controller wakeup-source is fail.
** 2 printk messages dropped **
[    0.877549] 001: sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[    0.878009] 001: sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    0.878052] 001: sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    0.878680] 001: sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
[    0.901793] 001: hub 1-0:1.0: 1 port detected
** 5 printk messages dropped **
[    0.903218] 001: [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0e9b560
[    0.903226] 001: [sunxi-ohci0]: Not init ohci0
楼主 #1 2024-06-29 15:18:12
yuqingli
Re: t113-s3 配置内核第二阶段卡死
这个日志也是死机
[    1.672634] Bluetooth: RFCOMM TTY layer initialized
[    1.673565] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.678121] Bluetooth: RFCOMM socket layer initialized
[    1.695610] Bluetooth: RFCOMM ver 1.11
[    1.700502] Registering SWP/SWPB emulation handler
[    1.706298] Loading compiled-in X.509 certificates
[    1.725572] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.732703] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[    1.748861] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.758474] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.760739] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.768331] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.775913] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.785510] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.795303] clk: Not disabling unused clocks
[    1.805009] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.809799] ALSA device list:
[    1.822956] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    1.822963] cfg80211: failed to load regulatory.db
[    1.834733]   No soundcards found.
[    1.843832] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    1.851388] alloc_fd: slot 0 not NULL!
[    1.859904] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
[    1.872250] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52 dt B
[    1.872348] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
[    1.892459] Please append a correct "root=" boot option; here are the available partitions:
[    1.901879] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    1.911155] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #1
[    1.917792] Hardware name: Generic DT based system
[    1.923186] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[    1.931883] [<c010a8bc>] (show_stack) from [<c06ed070>] (dump_stack+0x7c/0x98)
[    1.939992] [<c06ed070>] (dump_stack) from [<c0119808>] (panic+0x104/0x3dc)
[    1.947812] [<c0119808>] (panic) from [<c0b01294>] (mount_block_root+0x278/0x32c)
[    1.956212] [<c0b01294>] (mount_block_root) from [<c0b014e4>] (prepare_namespace+0x118/0x178)
[    1.965785] [<c0b014e4>] (prepare_namespace) from [<c070174c>] (kernel_init+0x8/0x118)
[    1.974671] [<c070174c>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.983160] Exception stack(0xc6827fb0 to 0xc6827ff8)
[    1.988828] 7fa0:                                     00000000 00000000 00000000 00000000
[    1.998004] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.007178] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    2.014602] CPU1: stopping
[    2.017640] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #1
[    2.024277] Hardware name: Generic DT based system
[    2.029659] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[    2.038350] [<c010a8bc>] (show_stack) from [<c06ed070>] (dump_stack+0x7c/0x98)
[    2.046460] [<c06ed070>] (dump_stack) from [<c010c6b0>] (handle_IPI+0xc0/0x168)
[    2.054664] [<c010c6b0>] (handle_IPI) from [<c0346e10>] (gic_handle_irq+0x70/0x78)
[    2.063164] [<c0346e10>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[    2.071559] Exception stack(0xc6861f80 to 0xc6861fc8)
[    2.077227] 1f80: 000004a0 c6ec3534 00000000 c0114d20 00000002 c6860000 c0c03de8 c0c03e24
[    2.086408] 1fa0: 4000406a 410fc075 00000000 00000000 00000000 c6861fd0 c0107fb8 c0107fbc
[    2.095584] 1fc0: 60000113 ffffffff
[    2.099501] [<c01021cc>] (__irq_svc) from [<c0107fbc>] (arch_cpu_idle+0x2c/0x38)
[    2.107803] [<c0107fbc>] (arch_cpu_idle) from [<c013e430>] (do_idle+0xb8/0x120)
[    2.116007] [<c013e430>] (do_idle) from [<c013e734>] (cpu_startup_entry+0x18/0x1c)
[    2.124505] [<c013e734>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[    2.132326] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
