楼主 # 2024-08-14 08:49:44
jxmlegend
已发帖子: 49
t113-s3 要使用spi-nor flash存储整个文件系统,应该如何配置
tina 中,要使用spi-nor flash存储整个文件系统,应该如何配置,整了一个星期了,还是运行不了
#1 2024-08-14 09:53:09
hameyou
已发帖子: 251
Re: t113-s3 要使用spi-nor flash存储整个文件系统,应该如何配置
按理说用tina的spi nor-flash demo工程是没问题的,不知道你改了什么
楼主 #2 2024-08-18 09:21:37
jxmlegend
已发帖子: 49
[00.402]Loading Environment from SUNXI_FLASH... *** Warning - bad CRC, using default environment
*** Warning - no device, using default environment
Failed (-5)
[00.438]boot_gui_init:start
[00.441]set disp.dev2_output_type fail. using defval=0
[00.447]boot_gui_init:finish
partno erro : can't find partition bootloader
** Unrecognized filesystem type **
[00.457]sunxi bmp info error : unable to open logo file bootlogo.bmp
[00.464]update part info
[00.466]update bootcmd
[00.468]change working_fdt 0x43f05e70 to 0x43ee5e70
disable nand error: FDT_ERR_NOTFOUND
[00.488]update dts
Hit any key to stop autoboot:  2 FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1
[00.637]LCD open finish
0
## Error: "distro_bootcmd" not defined
