初始化程序建立一个group,并把之设置为默认group
lv_group_t * g = lv_group_create();
lv_group_set_default(g);
创建输入设备后,把输入设备与该group关联:
lv_indev_set_group(indev2, g);
多group 的 demo
lv_obj_t *btn1, *btn2, *btn3, *btn4;
lv_group_t* group1;
lv_group_t* group2;
void change_group_event_cb(lv_event_t* e)
lv_indev_t * cur_drv = NULL;
cur_drv = lv_indev_get_next(cur_drv);
if(!cur_drv) {
lv_indev_set_group(cur_drv, group1);
lv_group_focus_obj(btn1);
void init_multi_groups(void)
// 创建第一个组的对象
lv_obj_t* textarea1 = lv_textarea_create(lv_scr_act());
lv_obj_set_size(textarea1, 200, 100);
lv_obj_align(textarea1, LV_ALIGN_CENTER, -150, -100);
btn1 = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn1, 100, 50);
lv_obj_align(btn1, LV_ALIGN_CENTER, -150, 0);
lv_obj_t *label1 = lv_label_create(btn1);
lv_label_set_text(label1, "Button 1");
btn2 = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn2, 100, 50);
lv_obj_align(btn2, LV_ALIGN_CENTER, -150, 100);
lv_obj_t *label2 = lv_label_create(btn2);
lv_label_set_text(label2, "Button 2");
// 创建第二个组的对象
lv_obj_t* textarea2 = lv_textarea_create(lv_scr_act());
lv_obj_set_size(textarea2, 200, 100);
lv_obj_align(textarea2, LV_ALIGN_CENTER, 150, -100);
btn3 = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn3, 100, 50);
lv_obj_align(btn3, LV_ALIGN_CENTER, 150, 0);
lv_obj_t *label3 = lv_label_create(btn3);
lv_label_set_text(label3, "Button 3");
btn4 = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn4, 100, 50);
lv_obj_align(btn4, LV_ALIGN_CENTER, 150, 100);
lv_obj_t *label4 = lv_label_create(btn4);
lv_label_set_text(label4, "Button 4");
// 创建两个输入设备组
group1 = lv_group_create();
lv_group_add_obj(group1, textarea1);
lv_group_add_obj(group1, btn1);
lv_group_add_obj(group1, btn2);
group2 = lv_group_create();
lv_group_add_obj(group2, textarea2);
lv_group_add_obj(group2, btn3);
lv_group_add_obj(group2, btn4);
lv_obj_add_event_cb(btn4, change_group_event_cb, LV_EVENT_CLICKED, NULL);
// 初始焦点设置到第一个组的第一个对象
if(!cur_drv) {
lv_indev_set_group(cur_drv, group2);
lv_group_focus_obj(textarea2);
这个demo默认焦点在 group2 上,点击btn4之后,默认焦点切换到group1。
