完整log,求大佬指正
U-Boot SPL 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 26 2024 - 01:19:55)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 26 2024 - 01:19:55 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
eth0: ethernet@1c30000
USB0: musb_init_controller failed with status -22
probe failed, error -5
USB error: all controllers failed lowlevel init
Loading Device Tree to 42dfa000, end 42dfffd9 ... OK
[ 0.000000] Linux version 5.2.0-licheepi-zero+ (linux@linux) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #18 SMP Thu Dec 26 16:06:08 CST 2024
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi0.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 55060K/65536K available (6144K kernel code, 284K rwdata, 1672K rodata, 1024K init, 252K bss, 10476K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x484 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000198] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000439] Console: colour dummy device 80x30
[ 0.000497] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000514] pid_max: default: 32768 minimum: 301
[ 0.000676] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000694] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001483] CPU: Testing write buffer coherency: ok
[ 0.001989] /cpus/cpu@0 missing clock-frequency property
[ 0.002016] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002835] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003050] rcu: Hierarchical SRCU implementation.
[ 0.003583] smp: Bringing up secondary CPUs ...
[ 0.003603] smp: Brought up 1 node, 1 CPU
[ 0.003612] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003619] CPU: All CPU(s) started in SVC mode.
[ 0.004698] devtmpfs: initialized
[ 0.008189] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008508] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008538] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.008781] pinctrl core: initialized pinctrl subsystem
[ 0.009809] NET: Registered protocol family 16
[ 0.010413] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.011668] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.011687] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.035754] SCSI subsystem initialized
[ 0.036036] usbcore: registered new interface driver usbfs
[ 0.036091] usbcore: registered new interface driver hub
[ 0.036198] usbcore: registered new device driver usb
[ 0.036434] mc: Linux media interface: v0.10
[ 0.036474] videodev: Linux video capture interface: v2.00
[ 0.037925] clocksource: Switched to clocksource arch_sys_counter
[ 0.049958] NET: Registered protocol family 2
[ 0.050763] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.050802] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050826] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.050849] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.050993] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.051043] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.051365] NET: Registered protocol family 1
[ 0.053229] Initialise system trusted keyrings
[ 0.053602] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.059841] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.097203] Key type asymmetric registered
[ 0.097225] Asymmetric key parser 'x509' registered
[ 0.097340] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.097354] io scheduler mq-deadline registered
[ 0.097363] io scheduler kyber registered
[ 0.098577] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.102273] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.171857] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.174202] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.175262] printk: console [ttyS0] disabled
[ 0.195570] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.708183] printk: console [ttyS0] enabled
[ 0.738352] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.750004] m25p80 spi0.0: mx25l25635e (32768 Kbytes)
[ 0.755092] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.761079] Creating 4 MTD partitions on "spi0.0":
[ 0.765876] 0x000000000000-0x000000100000 : "uboot"
[ 0.771567] 0x000000100000-0x000000110000 : "dtb"
[ 0.776792] 0x000000110000-0x000000510000 : "kernel"
[ 0.782396] 0x000000510000-0x000002000000 : "rootfs"
[ 0.788531] libphy: Fixed MDIO Bus: probed
[ 0.793200] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.799093] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.805293] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[ 0.814781] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.822018] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.829247] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.834208] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.841000] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.846652] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.852557] libphy: stmmac: probed
[ 0.856680] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[ 0.863034] libphy: mdio_mux: probed
[ 0.866637] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[ 0.873038] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[ 0.880196] libphy: mdio_mux: probed
[ 0.884108] PPP generic driver version 2.4.2
[ 0.888916] usbcore: registered new interface driver cdc_ether
[ 0.894790] usbcore: registered new interface driver rndis_host
[ 0.900876] usbcore: registered new interface driver zaurus
[ 0.906460] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.913016] ehci-platform: EHCI generic platform driver
[ 0.918557] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.924171] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.932173] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.967915] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.975108] hub 1-0:1.0: USB hub found
[ 0.979078] hub 1-0:1.0: 1 port detected
[ 0.983740] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.990069] ohci-platform: OHCI generic platform driver
[ 0.995615] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.002337] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.010328] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 1.083022] hub 2-0:1.0: USB hub found
[ 1.086868] hub 2-0:1.0: 1 port detected
[ 1.094201] usbcore: registered new interface driver cdc_acm
[ 1.099969] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.108070] usbcore: registered new interface driver cdc_wdm
[ 1.113838] usbcore: registered new interface driver usbserial_generic
[ 1.120475] usbserial: USB Serial support registered for generic
[ 1.126519] usbcore: registered new interface driver option
[ 1.132181] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.139338] usbcore: registered new interface driver usb_serial_simple
[ 1.145918] usbserial: USB Serial support registered for carelink
[ 1.152084] usbserial: USB Serial support registered for zio
[ 1.157764] usbserial: USB Serial support registered for funsoft
[ 1.163814] usbserial: USB Serial support registered for flashloader
[ 1.170205] usbserial: USB Serial support registered for google
[ 1.176153] usbserial: USB Serial support registered for libtransistor
[ 1.182720] usbserial: USB Serial support registered for vivopay
[ 1.188759] usbserial: USB Serial support registered for moto_modem
[ 1.195038] usbserial: USB Serial support registered for motorola_tetra
[ 1.201694] usbserial: USB Serial support registered for novatel_gps
[ 1.208078] usbserial: USB Serial support registered for hp4x
[ 1.213839] usbserial: USB Serial support registered for suunto
[ 1.219791] usbserial: USB Serial support registered for siemens_mpi
[ 1.226757] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers
[ 1.236454] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.246288] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 1.251476] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.256096] i2c /dev entries driver
[ 1.261075] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.270890] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.279609] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.316092] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.323406] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.359793] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[ 1.367855] usbcore: registered new interface driver usbhid
[ 1.373521] usbhid: USB HID core driver
[ 1.377994] Initializing XFRM netlink socket
[ 1.382306] NET: Registered protocol family 17
[ 1.387377] Registering SWP/SWPB emulation handler
[ 1.393437] Loading compiled-in X.509 certificates
[ 1.404635] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.416192] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.422045] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.431475] hub 3-0:1.0: USB hub found
[ 1.435440] hub 3-0:1.0: 1 port detected
[ 1.440747] using random self ethernet address
[ 1.445201] using random host ethernet address
[ 1.450360] usb0: HOST MAC 12:9c:f0:3e:ad:4f
[ 1.454687] usb0: MAC b6:7a:5c:ef:71:96
[ 1.458649] using random self ethernet address
[ 1.463095] using random host ethernet address
[ 1.467623] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 1.474273] g_ether gadget: g_ether ready
[ 1.478812] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T06:53:24 UTC (24804)
[ 1.487378] vcc5v0: disabling
[ 1.492701] random: fast init done
[ 1.515033] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.540214] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.549245] random: crng init done
[ 1.560854] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.572614] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.582774] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.592160] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.600082] mmc1: new high speed SDIO card at address 0001
[ 7.527354] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 7.534716] devtmpfs: mounted
[ 7.538929] Freeing unused kernel memory: 1024K
[ 7.543622] Run /sbin/init as init process
Starting logging: OK
Starting mdev...
/etc/init.d/S10mdev: line 21: can't create /proc/sys/kernel/hotplug: nonexistent directory
Starting network: OK
