U-Boot SPL 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 27 2024 - 02:57:40)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 27 2024 - 02:57:40 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
eth0: ethernet@1c30000
No controllers found
Loading Device Tree to 42dfa000, end 42dfffd9 ... OK
[ 0.000000] Linux version 5.2.0-200563-g338e6aaa6f28-dirty (linux@linux) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #30 SMP Fri Dec 27 13:01:47 CST 2024
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] cma: Reserved 16 MiB at 0x43000000
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi0.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 38512K/65536K available (6144K kernel code, 424K rwdata, 1628K rodata, 1024K init, 244K bss, 10640K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x484 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.000231] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000496] Console: colour dummy device 80x30
[ 0.000553] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000569] pid_max: default: 32768 minimum: 301
[ 0.000729] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000746] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001565] CPU: Testing write buffer coherency: ok
[ 0.002100] /cpus/cpu@0 missing clock-frequency property
[ 0.002126] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002940] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003168] rcu: Hierarchical SRCU implementation.
[ 0.003706] smp: Bringing up secondary CPUs ...
[ 0.003726] smp: Brought up 1 node, 1 CPU
[ 0.003735] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003742] CPU: All CPU(s) started in SVC mode.
[ 0.004824] devtmpfs: initialized
[ 0.008281] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008594] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008625] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.009431] pinctrl core: initialized pinctrl subsystem
[ 0.010777] NET: Registered protocol family 16
[ 0.011928] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.013193] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.013211] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.030504] SCSI subsystem initialized
[ 0.031258] usbcore: registered new interface driver usbfs
[ 0.031320] usbcore: registered new interface driver hub
[ 0.031401] usbcore: registered new device driver usb
[ 0.031663] pps_core: LinuxPPS API ver. 1 registered
[ 0.031672] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.031694] PTP clock support registered
[ 0.033184] clocksource: Switched to clocksource arch_sys_counter
[ 0.045265] NET: Registered protocol family 2
[ 0.045940] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.045979] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.046004] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.046027] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.046183] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.046232] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.046468] NET: Registered protocol family 1
[ 0.047427] RPC: Registered named UNIX socket transport module.
[ 0.047449] RPC: Registered udp transport module.
[ 0.047456] RPC: Registered tcp transport module.
[ 0.047461] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.049628] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.056699] NFS: Registering the id_resolver key type
[ 0.056769] Key type id_resolver registered
[ 0.056777] Key type id_legacy registered
[ 0.056828] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.057395] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.057414] io scheduler mq-deadline registered
[ 0.057422] io scheduler kyber registered
[ 0.058316] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.062308] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.132988] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.135568] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.136692] printk: console [ttyS0] disabled
[ 0.157001] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.705276] printk: console [ttyS0] enabled
[ 0.735009] libphy: Fixed MDIO Bus: probed
[ 0.739123] CAN device driver interface
[ 0.743727] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.749534] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.755803] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[ 0.765288] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.772504] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.779741] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.784716] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.791497] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.797160] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.803055] libphy: stmmac: probed
[ 0.807229] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[ 0.813612] libphy: mdio_mux: probed
[ 0.817217] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[ 0.823621] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[ 0.830740] libphy: mdio_mux: probed
[ 0.834781] PPP generic driver version 2.4.2
[ 0.839457] PPP BSD Compression module registered
[ 0.844275] PPP Deflate Compression module registered
[ 0.849335] PPP MPPE Compression module registered
[ 0.854153] NET: Registered protocol family 24
[ 0.858743] usbcore: registered new interface driver asix
[ 0.864237] usbcore: registered new interface driver ax88179_178a
[ 0.870355] usbcore: registered new interface driver cdc_ether
[ 0.876250] usbcore: registered new interface driver net1080
[ 0.881950] usbcore: registered new interface driver rndis_host
[ 0.887924] usbcore: registered new interface driver cdc_subset
[ 0.893886] usbcore: registered new interface driver zaurus
[ 0.899505] usbcore: registered new interface driver cdc_ncm
[ 0.905184] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.911703] ehci-platform: EHCI generic platform driver
[ 0.917236] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.922845] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.931073] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.963163] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.970396] hub 1-0:1.0: USB hub found
[ 0.974334] hub 1-0:1.0: 1 port detected
[ 0.978924] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.985249] ohci-platform: OHCI generic platform driver
[ 0.990819] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.997544] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.005638] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 1.078297] hub 2-0:1.0: USB hub found
[ 1.082143] hub 2-0:1.0: 1 port detected
[ 1.089488] usbcore: registered new interface driver option
[ 1.095233] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.103608] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.112821] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 1.117998] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.122739] i2c /dev entries driver
[ 1.128904] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.137593] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.174198] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.181437] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.218158] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[ 1.226272] usbcore: registered new interface driver usbhid
[ 1.231848] usbhid: USB HID core driver
[ 1.236415] NET: Registered protocol family 17
[ 1.240894] can: controller area network core (rev 20170425 abi 9)
[ 1.247253] NET: Registered protocol family 29
[ 1.251702] can: raw protocol (rev 20170425)
[ 1.256010] can: broadcast manager protocol (rev 20170425 t)
[ 1.261674] can: netlink gateway (rev 20170425) max_hops=1
[ 1.267509] Key type dns_resolver registered
[ 1.271935] Registering SWP/SWPB emulation handler
[ 1.284555] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.296042] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.301807] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.311265] hub 3-0:1.0: USB hub found
[ 1.315322] hub 3-0:1.0: 1 port detected
[ 1.320764] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T02:10:14 UTC (7814)
[ 1.329348] vcc5v0: disabling
[ 1.333628] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[ 1.341200] Please append a correct "root=" boot option; here are the available partitions:
[ 1.349632] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[ 1.357980] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-200563-g338e6aaa6f28-dirty #30
[ 1.366229] Hardware name: Allwinner sun8i Family
[ 1.370962] [<c010ee84>] (unwind_backtrace) from [<c010b814>] (show_stack+0x10/0x14)
[ 1.378703] [<c010b814>] (show_stack) from [<c0649518>] (dump_stack+0x88/0x9c)
[ 1.385923] [<c0649518>] (dump_stack) from [<c011e148>] (panic+0x110/0x2fc)
[ 1.392885] [<c011e148>] (panic) from [<c0901360>] (mount_block_root+0x1a4/0x28c)
[ 1.400362] [<c0901360>] (mount_block_root) from [<c090158c>] (mount_root+0x144/0x160)
[ 1.408271] [<c090158c>] (mount_root) from [<c09016f8>] (prepare_namespace+0x150/0x194)
[ 1.416271] [<c09016f8>] (prepare_namespace) from [<c065fc60>] (kernel_init+0x8/0x10c)
[ 1.424181] [<c065fc60>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 1.431738] Exception stack(0xc2835fb0 to 0xc2835ff8)
[ 1.436776] 5fa0: 00000000 00000000 00000000 00000000
[ 1.444943] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.453109] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 1.459728] Rebooting in 5 seconds..离线
