全志T507,去掉了千兆网,把PI12、PI13复用为PWM2、PWM3,想要让PWM2、3互补输出。
在源码pwm_sunxi_new里面看到可以将pwm配置成互补输出模式,手册上也说可以配置成互补输出。
咨询飞凌他们没玩过互补输出。
看源码需要在设备树里面配置"bind_pwm"和"dead_time",获取死区时间和“互补输出绑定的pwm??”,这里的bind_pwm不是很理解。
static int sunxi_pwm_get_config(struct platform_device *pdev, struct sunxi_pwm_config *config)
struct device_node *np = pdev->dev.of_node;
int ret = 0;
/* read register config */
pr_info("sunxi_pwm_get_config %s\n", np->name);
ret = of_property_read_u32(np, "bind_pwm", &config->bind_pwm);
if (ret < 0) {
/*if there is no bind pwm,set 255, dual pwm invalid!*/
config->bind_pwm = 255;
ret = 0;
ret = of_property_read_u32(np, "dead_time", &config->dead_time);
if (ret < 0) {
/*if there is bind pwm, but not set dead time,set bind pwm 255,dual pwm invalid!*/
ret = 0;
pr_info("bind_pwm=%d,dead_time=%d\n", config->bind_pwm, config->dead_time);
ret = of_property_read_u32(np, "clk_bypass_output", &config->clk_bypass_output);
if (ret < 0) {
/*if use pwm as the internal clock source!*/
config->clk_bypass_output = 0;
ret = 0;
of_node_put(np);
return ret;
}修改设备树,增加"bind_pwm"和"dead_time"
pwm2: pwm2@0300a000 {
pinctrl-names = "active", "sleep";
pinctrl-0 = <&pwm2_pin_a>;
pinctrl-1 = <&pwm2_pin_b>;
bind_pwm = 2;
dead_time = 1000;
};但是设备树配置了这两个之后编译失败
Error: arch/arm64/boot/dts/sunxi/CII-Common.dtsi:543.15-16 syntax error
FATAL ERROR: Unable to parse input tree
make[2]: *** [scripts/Makefile.lib:313: arch/arm64/boot/dts/sunxi/board.dtb] Error 1
make[1]: *** [scripts/Makefile.build:648: arch/arm64/boot/dts/sunxi] Error 2
make: *** [arch/arm64/Makefile:153: dtbs] Error 2
make: *** Waiting for unfinished jobs....
CHK kernel/config_data.h
ERROR: build kernel Failed
INFO: mkkernel failed有大佬玩过PWM的互补输出吗?怎么才能互补输出?
