楼主 # 2025-09-13 22:16:20
qsy_qsy
Trying to boot from MMcl 系统启动到这里一直重启循环 各位佬怎么解决
U-Boot 2020.07 (Sep 01 2025 - 07:26:28 -0700) Allwinner Technology
CPU:   Allwinner F Series (SUNIV)
DRAM:  64 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from FAT... Card did not respond to voltage select!
Loading Environment from SPI Flash... unrecognized JEDEC id bytes: ff, ef, aa
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial
Out:   vga
Err:   vga
No working controllers found
Hit any key to stop autoboo▒
U-Boot SPL 2020.07 (Sep 01 2025 - 07:26:28 -0700)
DRAM: 64 MiB
Trying to boot from MMC1
DRAM:  64 MiB
In:    serial
Out:   vga
Err:   vga
DRAM: 64 MiB
DRAM:  64 MiB
In:    serial
Out:   vga
Err:   vga
DRAM: 64 MiB
DRAM:  64 MiB
In:    serial
Out:   vga
Err:   vga
DRAM: 64 MiB
DRAM:  64 MiB
In:    serial
Out:   vga
Err:   vga
Hit any key to stop autoboot▒
DRAM: 64 MiB
#1 2025-09-13 22:45:51
已发帖子: 9,415
Re: Trying to boot from MMcl 系统启动到这里一直重启循环 各位佬怎么解决
uboot没有支持你当前的flash型号。
楼主 #2 2025-09-13 22:48:00
qsy_qsy
可是我用的SD卡启动啊  这跟也会去检测spi flash吗
#3 2025-09-14 10:10:54
已发帖子: 9,415
qsy_qsy 说:
参考这个:
buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 * 已支持DVP摄像头 *,支持SPI NAND
https://whycan.com/t_5221.html
