U-Boot 2018.07-g12e5399-dirty (Sep 19 2025 - 10:38:09 +0800) Allwinner Technology
[00.482]CPU: Allwinner Family
[00.485]Model: sun50iw10
I2C: ready
[00.500]DRAM: 4 GiB
[00.504]Relocation Offset is: 75ed8000
[00.547]secure enable bit: 0
[00.549]axp519 pmic_bus_read fail
[00.553]pmu_axp806_probe pmic_bus_read fail
[00.557]PMU: AXP803
[01.476]PMU: AXP803
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
[01.495]pmu_sy8827g_probe pmic_bus_read fail
[01.499]pmu_tcs4838_probe pmic_bus_read fail
[01.503]CPU=1416 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[01.509]gic: sec monitor mode
[01.513]flash init start
[01.515]workmode = 0,storage type = 2
[01.518][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
[01.524][mmc]: SUNXI SDMMC Controller Version:0x50300
[01.549][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
[01.556]sunxi flash init ok
[01.558]drv_disp_init
request pwm success, pwm0:pwm0:0x300a000.
[01.612]drv_disp_init finish
[01.623]Loading Environment from SUNXI_FLASH... [01.636]Item0 (Map) magic is bad
[01.639]the secure storage item0 copy0 magic is bad
[01.651]Item0 (Map) magic is bad
[01.654]the secure storage item0 copy1 magic is bad
[01.659]Item0 (Map) magic is bad
[01.662]sunxi_secure_storage_exit err: secure storage has not been inited
OK
[01.671]boot_gui_init:start
partno erro : can't find partition Reserve0
bad fb1_cfg[w=0,h=0,bpp=32,format=0]
[01.744]boot_gui_init:finish
[01.755]Item0 (Map) magic is bad
[01.757]the secure storage item0 copy0 magic is bad
[01.770]Item0 (Map) magic is bad
[01.773]the secure storage item0 copy1 magic is bad
[01.777]Item0 (Map) magic is bad
[01.780]usb burn from boot
delay time 0
weak:otg_phy_config
[01.791]usb prepare ok
[02.012]LCD open finish
[02.094]overtime
[02.099]do_burn_from_boot usb : no usb exist
[02.103][ARISC ERROR] :get [allwinner,arisc_space] device node error
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [lbata-te-325rdna1diorg-41v-fd-1.ytri]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
List file under ULI/factory
** Unrecognized filesystem type **
[02.146]update part info
[02.149]bat_ratio:100 safe_ratio:1 bat_vol:0mV safe_vol:3500mV
各位大佬,我想请问一下我全志A133烧录固件上电后,直接卡住在这里是什么问题呢?
