楼主 # 2025-11-04 16:37:38
vertiny
D211使用Linux SDK出现热插拔TF卡引起内核报错的问题
D211DCX, 自己做的板子,参照官方原理图, 启动后进去系统后,热插拔tf卡,内核都会报错一次,而且是只报错一次,之后再插拔不会再报,报错信息如下
[aic@] # [   20.856019] ------------[ cut here ]------------
[   20.860687] WARNING: CPU: 0 PID: 0 at kernel/softirq.c:174 __local_bh_enable_ip+0x34/0x60
[   20.868861] Modules linked in:
[   20.871941] CPU: 0 PID: 0 Comm: swapper Not tainted 5.10.44 #1
[   20.877778] epc: ffffffff800260d2 ra : ffffffff8035a716 sp : ffffffff805d7ab0
[   20.884916]  gp : ffffffff8069c978 tp : ffffffff805dc640 t0 : 0000000000000040
[   20.892140]  t1 : 0000000000000000 t2 : 0000000010000000 s0 : ffffffff805d7ae0
[   20.899363]  s1 : 0000000000000000 a0 : ffffffff8035a6f8 a1 : 0000000000000200
[   20.906586]  a2 : 0000000000040000 a3 : 00000000000f0000 a4 : 0000000000010000
[   20.913810]  a5 : ffffffff805dc640 a6 : ffffffff80c00248 a7 : ffffffff80c00270
[   20.921033]  s2 : ffffffff81029800 s3 : ffffffff80930818 s4 : ffffffff81029c00
[   20.928257]  s5 : ffffffff80666810 s6 : ffffffff8091d400 s7 : 000000000000000a
[   20.935481]  s8 : ffffffff80692000 s9 : 0000000000000001 s10: 0000000000000000
[   20.942704]  s11: ffffffff80930818 t3 : 0000000000000002 t4 : 0000000000000402
[   20.949926]  t5 : ffffffff806573b0 t6 : ffffffff806573b8
[   20.955244] status: 0000000200000100 badaddr: 0000000000000000 cause: 0000000000000003
[   20.963158] ---[ end trace cbdb6a4bdacedf88 ]---
[   21.061622] mmc0: card b369 removed
/mnt/sdcard is unmounted
请问大家有没有碰到一样的问题呢
最近编辑记录 vertiny (2025-11-04 16:38:26)
#1 2025-11-05 09:42:31
狼狼
已发帖子: 107
Re: D211使用Linux SDK出现热插拔TF卡引起内核报错的问题
虽然没用过D211,也不知道原因,但从代码可以知道报错一次的原因是WARN_ON_ONCE宏定义,即in_irq返回非零值,表示在这个有关下半部的处理过程中,检查发现硬中断计数非0(处于中断上下文)?
kernel/softirq.c
void __local_bh_enable_ip(unsigned long ip, unsigned int cnt)
	WARN_ON_ONCE(in_irq());
// ........略过后续代码
EXPORT_SYMBOL(__local_bh_enable_ip);
include/linux/preempt.h
#define hardirq_count()	(preempt_count() & HARDIRQ_MASK)
 * Are we doing bottom half or hardware interrupt processing?
 * in_irq()       - We're in (hard) IRQ context
 * in_softirq()   - We have BH disabled, or are processing softirqs
 * in_interrupt() - We're in NMI,IRQ,SoftIRQ context or have BH disabled
 * in_serving_softirq() - We're in softirq context
 * in_nmi()       - We're in NMI context
 * in_task()	  - We're in task context
 * Note: due to the BH disabled confusion: in_softirq(),in_interrupt() really
 *       should not be used in new code.
#define in_irq()		(hardirq_count())
