楼主 # 2025-12-13 19:24:58
yuanhuijun
/dev/disp调用后无法正常退出
如标题,打开“/dev/disp”后什么都不干,关闭程序后屏幕之前显示的内容就没有了,tina-v853-open环境下的csi_test_mplane例子,程序只能正常运行一次(能在LCD上显示摄像头图像),退出程序后就无法正常操作LCD了。出现以下信息:time cost 5.174114[   44.894805] [DISP] disp_mgr_set_layer_config,line:1504:(s)
[   44.904146] NULL hdl!
[11:28:48.456]收←◆[   44.934101] [DISP] disp_lcd_disable,line:2160:
[   44.938899] lcd_panel_fun[0].cfg_close_flow is NULL
[   44.944826] [DISP] de_fcm_set_para,line:491:
[   44.949414] fcm lut 0 not find, auto retry after init
[   44.955503] [DISP] de_fcm_set_para,line:491:
[   44.960097] fcm lut 0 not find, auto retry after init
屏蔽掉后续的操作屏幕,只打开打开“/dev/disp”也不正常,有人遇到过这种情况吗?
楼主 #1 2025-12-13 19:54:06
yuanhuijun
Re: /dev/disp调用后无法正常退出
搞定了,sdk问题:) smile
