楼主 # 昨天 13:44:02
john78
已发帖子: 223
D211DCX+25N01G 烧录失败,怎么排查?
[debug] WinEvent: Some devnode changed
[debug] There are "1" device available
[debug] Try to connect the ArtInChip device "2:7-3" ...
[debug] Try to get device hd info...
[debug] Get device hd info success
[debug] The status of ArtInChip device:  true
[debug] Start burn online ...
[debug] Progress range: 0 ~  1075200
[debug] Burn Image file "D:/work/work_2025/prj_print/code/luban-lite/output/s7_print_app/images/d21x_demo128_nand_page_2k_block_128k_v1.0.0.img" ...
[debug] Meta 0 image.updater.ddr , size 30480 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 30480
[debug] Offset: 6656 Size: 30480
[debug]  Dev "2:7-3" Send the rest data 30480
[warn ] aicupg_trans_send_pkt_inner()206:       CSW tag 0xc39, size 0
[error] Dev "2:7-3" Failed to send data 30480
[error]  Dev "2:7-3" Failed to send 30480
[warn ] Try to resend firmware component image.updater.ddr , try count: 1
[warn ] Try to recovery the connection
[warn ] aicupg_trans_send_pkt_inner()255:       CSW is not matched, Sig 0x53425355, Tag got 0xc38, expect 0xc3a
[warn ] Resend firmware component: image.updater.ddr
[debug] Don't check the result of image.updater.ddr
[debug] Meta 1 image.updater.spl , size 273424 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 273424
[debug] Offset: 37376 Size: 273424
[debug]  Dev "2:7-3" Send the rest data 273424
[info ] aicupg_trans_recv_pkt()322:             no CSW. (rc = 0)
[info ] aicupg_cmd_send_fwc_data_final()726:    no resp
[debug] Don't check the result of image.updater.spl
[debug] Meta 2 image.info , size 2048 ...
[debug] Wait to reconnect dev "2:7-3"
[debug] QTime("13:42:30.100") Wait for Dev "2:7-3" ready
[error] QTime("13:42:40.166") Dev "2:7-3" lost!
[error] Dev "2:7-3" is completely lost!
