楼主 # 2026-09-25 12:17:30
xichuangxue
已发帖子: 39
【求助】f1c600上烧录f1c100suboot和kernel报错unrecognized/unsupported processor
各位大佬,咸鱼买了一片f1c600的板子,原本是nor Flash到手后换成128M spi Nand了。
编译了榴莲派的boot和kernel, 在手头的f1c100s上正常运行。但烧录到f1c600上后,启动kernel报错如下。万能的坛友,有知道原因和解决方案的吗?
Reading 16384 byte(s) (8 page(s)) at offset 0x00100000
Reading 5636096 byte(s) (2752 page(s)) at offset 0x00120000
Kernel image @ 0x80008000 [ 0x000000 - 0x4e3688 ]
Working FDT set to 80c00000
   Loading Device Tree to 81567000, end 8156dab6 ... OK
Working FDT set to 81567000
Error: unrecognized/unsupported processor variant (0x41069265).
原本以为是uboot和kernel macheine ID不一致导致。但相同IMG 烧录到f1c100s上是可以正常启动的,且打印的mache ID也是41069265。故排除了这个原因。
uboot中bdinfo如下:
=> bdinfo
boot_params = 0x80000100
DRAM bank   = 0x00000000
-> start    = 0x80000000
-> size     = 0x02000000
flashstart  = 0x00000000
flashsize   = 0x00000000
flashoffset = 0x00000000
baudrate    = 115200 bps
relocaddr   = 0x81b91000
reloc off   = 0x00f91000
Build       = 32-bit
current eth = unknown
eth-1addr   = (not set)
IP addr     = <NULL>
fdt_blob    = 0x81a6e960
Video       = sunxi_de active
FB base     = 0x81c00000
FB size     = 480x272x32
lmb_dump_all:
 memory.count = 0x1
 memory[0]      [0x80000000-0x81ffffff], 0x2000000 bytes, flags: none
 reserved.count = 0x1
 reserved[0]    [0x8156e940-0x81ffffff], 0xa916c0 bytes, flags: no-overwrite
devicetree  = separate
serial addr = 0x01c25800
 width      = 0x00000004
 shift      = 0x00000002
 offset     = 0x00000000
 clock      = 0x05f5e100
arch_number = 0x00000000
TLB addr    = 0x81ff0000
irq_sp      = 0x81a6e950
sp start    = 0x81a6e940
Early malloc usage: 3d0 / 2000
#1 2026-09-25 13:45:09
Re: 【求助】f1c600上烧录f1c100suboot和kernel报错unrecognized/unsupported processor
Linux 内核识别 CPU 时失败:
f1c600 有几个 otp 寄存器不同,你跟踪一下这个log
楼主 #2 2026-09-25 19:47:01
xichuangxue
已发帖子: 39
感谢晕哥指导。
debug 下来发现不是 otp 寄存器不同导致。说明下debug过程。
让AI找关键打印,AI review code发现这里不存在问题。建议排除zImage完整性。于是按下面验证。
---------------------in pc
crc32 zImage
57b3bf67
---------------------in f1c600
=> mtd read spi-nand0 0x80008000 0x120000 0x560000
=> crc32 0x80008000 0x4e3688
crc32 for 80008000 ... 804eb687 ==> 0f74d416
---------------------in f1c100s
crc32 for 80008000 ... 804eb687 ==> 57b3bf67
然后通过串口加载zImage,发现可以正常启动。
=> loadb 0x80008000
## Ready for binary (kermit) download to 0x80008000 at 115200 bps...
Starting kermit transfer.  Press Ctrl+C to cancel.
Transferring zImage...
  100%    5005 KB       8 KB/sec    00:09:35       0 Errors
CACHE: Misaligned operation at range [80008000, 804eb688]
## Total Size      = 0x004e3688 = 5125768 Bytes
## Start Addr      = 0x80008000
bootz 0x80008000 - 0x80C00000
[    0.000000] Linux version 5.4.77-g38e13221c72f-dirty (demo@DESKTOP-RE5L8IU) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #3 Sun Sep 20 11:49:16 CST 2026
楼主 #3 2026-09-25 19:50:12
xichuangxue
已发帖子: 39
现在确认了是板子上的 zImage有问题。
烧录前有整片擦除,试过烧录到其他地址,发现还是一样。
目前怀疑是板子上的spi nand有啥问题(但没有证据)。
楼主 #4 2026-09-28 21:39:48
xichuangxue
已发帖子: 39
破案了,原因是 f1c600 使用的uboot和kernel 原本不支持 MX35LF1G24AD这颗flash, 虽然改代码中ID,可以起来,但读写还有问题。
替换成W25N01GV后,可以正常烧写和启动。
另外请教下,看论坛中的帖子中有的说 f1c600 是64MB in chip DDR,有的是说是32M,到底是多大?
#5 2026-09-29 00:09:20
@xichuangxue
原来如此,又学到新知识了,感谢分享。
F1C600 DDR 64M
