DDR 03ea844c5d typ 24/09/03-10:42:57,fwver: v1.23
ln
wdqs_if: 0x1010100
LP4/4x derate en, other dram:1x trefi
SRX
ddrconfig:0
MID:0xff
LPDDR4, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss_lf: cs0 dqs0: -24ps, dqs1: -72ps, dqs2: -96ps, dqs3: -120ps,
tdqss_hf: cs0 dqs0: -24ps, dqs1: -72ps, dqs2: -96ps, dqs3: -120ps,
change to: 324MHz
PHY drv:clk:38,ca:38,DQ:30,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x62
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
err: cs 0 wrtrn err
change to: 780MHz
PHY drv:clk:38,ca:38,DQ:30,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
rx vref: 17.4%
err: cs 0 wrtrn err
tx vref: 42.0%
change to: 1056MHz(final freq)
vrefinner:16%, vrefout:29%
dram drv:40,odt:80
vref_ca:00000068
clk skew:0x36
rx vref: 16.4%
tx vref: 27.0%
cs 0:
rdtrn RS:
DQS0:0x39, DQS1:0x3b, DQS2:0x39, DQS3:0x36,
min : 0x3 0x5 0x3 0x2 0x5 0x2 0x3 0x3 , 0x1 0x4 0x2 0x2 0x1 0x4 0x7 0x7 ,
0x4 0x1 0x5 0x2 0x4 0x6 0x3 0x6 , 0x7 0x5 0x1 0x1 0x7 0x9 0x1 0x7 ,
mid :0x1f 0x20 0x1f 0x1c 0x20 0x1e 0x1d 0x1f ,0x1c 0x1d 0x1d 0x1d 0x1d 0x21 0x23 0x23 ,
0x1e 0x1c 0x21 0x1f 0x20 0x1f 0x1d 0x20 ,0x23 0x21 0x1c 0x1b 0x22 0x25 0x1f 0x23 ,
max :0x3b 0x3c 0x3b 0x37 0x3b 0x3b 0x37 0x3c ,0x38 0x36 0x38 0x38 0x39 0x3e 0x3f 0x3f ,
0x39 0x37 0x3d 0x3c 0x3c 0x38 0x37 0x3b ,0x3f 0x3d 0x38 0x35 0x3e 0x42 0x3d 0x3f ,
range:0x38 0x37 0x38 0x35 0x36 0x39 0x34 0x39 ,0x37 0x32 0x36 0x36 0x38 0x3a 0x38 0x38 ,
0x35 0x36 0x38 0x3a 0x38 0x32 0x34 0x35 ,0x38 0x38 0x37 0x34 0x37 0x39 0x3c 0x38 ,
wrtrn RS:
DQS0:0x33, DQS1:0x2d, DQS2:0x2a, DQS3:0x26,
min :0x57 0x59 0x59 0x57 0x59 0x57 0x58 0x59 0x59 ,0x4d 0x4e 0x4f 0x4f 0x4e 0x51 0x54 0x53 0x50 ,
0x4d 0x4d 0x4e 0x4e 0x4e 0x50 0x4d 0x52 0x51 ,0x4e 0x4d 0x48 0x48 0x4f 0x4f 0x4b 0x50 0x4a ,
mid :0x6f 0x72 0x71 0x70 0x70 0x6f 0x6f 0x72 0x73 ,0x64 0x67 0x66 0x66 0x64 0x69 0x6e 0x6d 0x68 ,
0x67 0x66 0x68 0x68 0x68 0x66 0x64 0x68 0x67 ,0x67 0x65 0x60 0x60 0x66 0x67 0x66 0x68 0x62 ,
max :0x88 0x8b 0x8a 0x89 0x87 0x87 0x87 0x8b 0x8d ,0x7c 0x81 0x7d 0x7d 0x7b 0x82 0x88 0x88 0x81 ,
0x81 0x7f 0x82 0x83 0x82 0x7c 0x7b 0x7e 0x7e ,0x81 0x7d 0x79 0x78 0x7d 0x80 0x82 0x80 0x7a ,
range:0x31 0x32 0x31 0x32 0x2e 0x30 0x2f 0x32 0x34 ,0x2f 0x33 0x2e 0x2e 0x2d 0x31 0x34 0x35 0x31 ,
0x34 0x32 0x34 0x35 0x34 0x2c 0x2e 0x2c 0x2d ,0x33 0x30 0x31 0x30 0x2e 0x31 0x37 0x30 0x30 ,
CBT RS:
cs:0 min :0x40 0x3d 0x38 0x2f 0x35 0x2f 0x38 ,0x44 0x39 0x36 0x2c 0x35 0x2c 0x39 ,
cs:0 mid :0x7d 0x7f 0x74 0x71 0x71 0x72 0x65 ,0x7e 0x7d 0x70 0x70 0x6f 0x70 0x65 ,
cs:0 max :0xba 0xc2 0xb1 0xb4 0xae 0xb5 0x93 ,0xb9 0xc1 0xab 0xb5 0xaa 0xb4 0x91 ,
cs:0 range:0x7a 0x85 0x79 0x85 0x79 0x86 0x5b ,0x75 0x88 0x75 0x89 0x75 0x88 0x58 ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-g606f72bd97a-240527 #lxh (May 30 2024 - 16:08:15), fwver: v1.14
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
No misc partition
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 (gzip @0x00240000) ... sha256(d5325ff715...) + sha256(b5946ac63d...) + OK
## Checking uboot 0x00a00000 (gzip @0x00c00000) ... sha256(982f04b1a1...) + sha256(dbe80f1ae0...) + OK
## Checking fdt 0x00b57f60 ... sha256(a474c6bb61...) + OK
## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK
## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK
## Checking atf-4 0xfdcce000 ... sha256(86ef885748...) + OK
## Checking atf-5 0xfdcd0000 ... sha256(0b2b146c60...) + OK
## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(34defb3dac...) + sha256(9ffc99f1a2...) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 168.157/235.617 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44
NOTICE: BL31: Built : 16:36:43, Sep 19 2023
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: pmu v1 is valid 220114
INFO: l3 cache partition cfg-0
INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 0
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-891-g9f2aca7d1 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Thu Oct 31 10:26:19 CST 2024 aarch64, fwver: v2.15
I/TC: OP-TEE memory: TEEOS 0x200000 TA 0xc00000 SHM 0x200000
I/TC: Primary CPU initializing
I/TC: CRYPTO_CRYPTO_VERSION_NEW no support. Skip all algo mode check.
I/TC: Primary CPU switching to normal world boot
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0xa00000
INFO: SPSR = 0x3c9
usb dr_mode not found
U-Boot 2017.09-g8f53f800da-241224 #jiawen (Apr 22 2026 - 16:25:53 +0800)
Model: Rockchip RK3568 Evaluation Board
MPIDR: 0x0
PreSerial: 2, raw, 0xfe660000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7d207000
Relocation fdt: 7b7f8c48 - 7b7fece8
CR: M/C/I
Using default environment
optee api revision: 2.0
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Bootdev(scan): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
TEEC: Waring: Could not find security partition
E/TC:? 0 storage_check_security_level_flag:561 Not support security level!
DM: v1
164315 bytes read in 5 ms (31.3 MiB/s)
DTB(Distro): rk-kernel.dtb
No misc partition
boot mode: normal
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu 900000 uV
can't find shutdown-sequence prop
can't find vb-shutdown-sequence prop
PMIC: RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
INFO: ddr dmc_fsp already initialized in loader.
Could not find baseparameter partition
Model: Embedfire LubanCat-RK356x
No resource file: logo.bmp
63478 bytes read in 4 ms (15.1 MiB/s)
logo(Distro): logo.bmp
Rockchip UBOOT DRM driver version: v1.0.1
Assign plane mask automatically
VOP have 1 active VP
vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4
vp1 have layer nr:0[], primary plane: 0
vp2 have layer nr:0[], primary plane: 0
hdmi@fe0a0000 disconnected
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 1104000 KHz
dpll 528000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 1104000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000
Hit key to stop autoboot('CTRL+C'): 0
Scanning mmc 0:2...
Found U-Boot script /boot.scr
4108 bytes read in 2 ms (2 MiB/s)
## Executing script at 00c00000
[boot.cmd] run boot.cmd scripts ...
[boot.cmd] load mmc 0:2 0x0a080000 /uEnv/uEnv.txt ...
329 bytes read in 4 ms (80.1 KiB/s)
[boot.cmd] Importing environment from mmc ...
bootargs=storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal root=/dev/mmcblk0p3 boot_part=2 earlyprintk console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=7 rootwait rw rootfstype=ext4
[boot.cmd] try load mmc 0:2 0x0a200000 /initrd ...
** File not found /initrd **
[boot.cmd] try load mmc 0:2 0x0a200000 /initrd-6.1 ...
** File not found /initrd-6.1 **
[boot.cmd] try load mmc 0:2 0x00280000 /Image ...
42213888 bytes read in 229 ms (175.8 MiB/s)
[boot.cmd] loading default rk-kernel.dtb
[boot.cmd] check the I2C bus
Bus 0: i2c@fdd40000 (active 0)
1c: tcs4525@1c, offset len 1, flags 0
20: pmic@20, offset len 1, flags 0
[boot.cmd] [mmc 0:2] ...
[boot.cmd] booti 0x00280000 - 0x0a100000 ...
Fdt Ramdisk skip relocation
No misc partition
## Flattened Device Tree blob at 0x0a100000
Booting using the fdt blob at 0x0a100000
Using Device Tree in place at 000000000a100000, end 000000000a12b1da
No resource file: logo_kernel.bmp
21434 bytes read in 3 ms (6.8 MiB/s)
logo(Distro): logo_kernel.bmp
vp0, plane_mask:0x3f, primary-id:4, curser-id:-1
vp1, plane_mask:0x0, primary-id:0, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
## reserved-memory:
drm-logo@0: addr=7df00000 size=318000
drm-cubic-lut@0: addr=7ff00000 size=8000
ramoops@110000: addr=110000 size=f0000
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0x80000000 (size: 0x76c00000)
Total: 778.141/826.478 ms
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[ 0.832683] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.832719] Linux version 6.1.99-rk356x (jiawen@dev120.embedfire.local) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #8 SMP Wed Apr 22 16:26:16 CST 2026
[ 0.834541] random: crng init done
[ 0.837618] Machine model: Embedfire LubanCat-RK356x
[ 0.849021] efi: UEFI not found.
[ 0.890229] Zone ranges:
[ 0.890242] DMA [mem 0x0000000000200000-0x000000007fffffff]
[ 0.890257] DMA32 empty
[ 0.890262] Normal empty
[ 0.890266] Movable zone start for each node
[ 0.890268] Early memory node ranges
[ 0.890270] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 0.890278] node 0: [mem 0x0000000009400000-0x000000007fffffff]
[ 0.890283] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff]
[ 0.891173] On node 0, zone DMA: 512 pages in unavailable ranges
[ 0.906330] On node 0, zone DMA: 4096 pages in unavailable ranges
[ 0.906354] cma: Reserved 16 MiB at 0x000000007ea00000
[ 0.906461] psci: probing for conduit method from DT.
[ 0.906474] psci: PSCIv1.1 detected in firmware.
[ 0.906480] psci: Using standard PSCI v0.2 function IDs
[ 0.906487] psci: Trusted OS migration not required
[ 0.906500] psci: SMC Calling Convention v1.2
[ 0.906906] percpu: Embedded 29 pages/cpu s78456 r8192 d32136 u118784
[ 0.907048] Detected VIPT I-cache on CPU0
[ 0.907103] CPU features: detected: GIC system register CPU interface
[ 0.907107] CPU features: detected: Virtualization Host Extensions
[ 0.907122] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[ 0.907126] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.907132] alternatives: applying boot alternatives
[ 0.909862] Built 1 zonelists, mobility grouping on. Total pages: 511496
[ 0.909882] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal root=/dev/mmcblk0p3 boot_part=2 earlyprintk console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=7 rootwait rw rootfstype=ext4 androidboot.fwver=ddr-v1.23-03ea844c5d,spl-v1.14,bl31-v1.44,bl32-v2.15,uboot-8f53f800da-04/22/2026
[ 0.910261] Unknown kernel command line parameters "earlyprintk storagemedia=emmc boot_part=2", will be passed to user space.
[ 0.910791] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.911047] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.911059] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.937428] Memory: 1975808K/2078720K available (21952K kernel code, 3976K rwdata, 7652K rodata, 7488K init, 709K bss, 86528K reserved, 16384K cma-reserved)
[ 0.937589] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.937645] ftrace: allocating 67943 entries in 266 pages
[ 1.054175] ftrace: allocated 266 pages with 3 groups
[ 1.054386] trace event string verifier disabled
[ 1.054624] rcu: Hierarchical RCU implementation.
[ 1.054631] rcu: RCU event tracing is enabled.
[ 1.054633] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 1.054641] Rude variant of Tasks RCU enabled.
[ 1.054643] Tracing variant of Tasks RCU enabled.
[ 1.054646] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 1.054652] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 1.065287] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 1.067205] GICv3: GIC: Using split EOI/Deactivate mode
[ 1.067215] GICv3: 320 SPIs implemented
[ 1.067222] GICv3: 0 Extended SPIs implemented
[ 1.067267] Root IRQ handler: gic_handle_irq
[ 1.067286] GICv3: GICv3 features: 16 PPIs
[ 1.067735] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[ 1.068323] ITS [mem 0xfd440000-0xfd45ffff]
[ 1.068398] ITS@0x00000000fd440000: allocated 8192 Devices @3230000 (indirect, esz 8, psz 64K, shr 0)
[ 1.068441] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @3240000 (flat, esz 2, psz 64K, shr 0)
[ 1.068455] ITS: using cache flushing for cmd queue
[ 1.068896] GICv3: using LPI property table @0x0000000003250000
[ 1.069016] GIC: using cache flushing for LPI property table
[ 1.069023] GICv3: CPU0: using allocated LPI pending table @0x0000000003260000
[ 1.069107] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 1.100905] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 1.100931] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 1.100945] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 1.102249] Console: colour dummy device 80x25
[ 1.102659] printk: console [tty1] enabled
[ 1.102706] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 1.102730] pid_max: default: 32768 minimum: 301
[ 1.102899] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.102926] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.103939] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.104674] cblist_init_generic: Setting adjustable number of callback queues.
[ 1.104694] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 1.104798] cblist_init_generic: Setting adjustable number of callback queues.
[ 1.104815] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 1.105037] rcu: Hierarchical SRCU implementation.
[ 1.105054] rcu: Max phase no-delay instances is 1000.
[ 1.105896] Platform MSI: interrupt-controller@fd440000 domain created
[ 1.106483] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 1.106941] EFI services will not be available.
[ 1.107381] smp: Bringing up secondary CPUs ...
[ 1.108705] Detected VIPT I-cache on CPU1
[ 1.108802] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 1.108818] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 1.108842] GICv3: CPU1: using allocated LPI pending table @0x0000000003270000
[ 1.108897] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 1.110265] Detected VIPT I-cache on CPU2
[ 1.110345] cacheinfo: Unable to detect cache hierarchy for CPU 2
[ 1.110359] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 1.110380] GICv3: CPU2: using allocated LPI pending table @0x0000000003280000
[ 1.110419] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 1.111744] Detected VIPT I-cache on CPU3
[ 1.111820] cacheinfo: Unable to detect cache hierarchy for CPU 3
[ 1.111834] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 1.111853] GICv3: CPU3: using allocated LPI pending table @0x0000000003290000
[ 1.111891] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 1.111992] smp: Brought up 1 node, 4 CPUs
[ 1.112111] SMP: Total of 4 processors activated.
[ 1.112123] CPU features: detected: 32-bit EL0 Support
[ 1.112134] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 1.112147] CPU features: detected: Common not Private translations
[ 1.112156] CPU features: detected: CRC32 instructions
[ 1.112169] CPU features: detected: RCpc load-acquire (LDAPR)
[ 1.112178] CPU features: detected: LSE atomic instructions
[ 1.112188] CPU features: detected: Privileged Access Never
[ 1.112197] CPU features: detected: RAS Extension Support
[ 1.112208] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 1.112287] CPU: All CPU(s) started at EL2
[ 1.112300] alternatives: applying system-wide alternatives
[ 1.117615] devtmpfs: initialized
[ 1.139919] Registered cp15_barrier emulation handler
[ 1.139963] Registered setend emulation handler
[ 1.140169] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 1.140203] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 1.140693] pinctrl core: initialized pinctrl subsystem
[ 1.141376] DMI not present or invalid.
[ 1.141708] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 1.143146] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 1.143470] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 1.143674] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 1.144389] Registered FIQ tty driver
[ 1.144839] thermal_sys: Registered thermal governor 'fair_share'
[ 1.144847] thermal_sys: Registered thermal governor 'step_wise'
[ 1.144861] thermal_sys: Registered thermal governor 'user_space'
[ 1.144872] thermal_sys: Registered thermal governor 'power_allocator'
[ 1.144942] cpuidle: using governor menu
[ 1.145382] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.145528] ASID allocator initialised with 65536 entries
[ 1.148572] ramoops: dmesg-0 0x20000@0x0000000000110000
[ 1.148627] ramoops: console 0x80000@0x0000000000130000
[ 1.148654] ramoops: pmsg 0x50000@0x00000000001b0000
[ 1.149124] printk: console [ramoops-1] enabled
[ 1.149140] pstore: Registered ramoops as persistent store backend
[ 1.149154] ramoops: using 0xf0000@0x110000, ecc: 0
[ 1.166249] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[ 1.166358] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000
[ 1.186365] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[ 1.186937] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[ 1.187474] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[ 1.187995] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[ 1.188564] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[ 1.188760] rockchip-pinctrl pinctrl: probed pinctrl
[ 1.206818] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.206864] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 1.206881] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.206895] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 1.206910] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.206923] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 1.206938] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.206951] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 1.264323] raid6: neonx8 gen() 2055 MB/s
[ 1.321096] raid6: neonx4 gen() 2091 MB/s
[ 1.377856] raid6: neonx2 gen() 1941 MB/s
[ 1.434642] raid6: neonx1 gen() 1593 MB/s
[ 1.491417] raid6: int64x8 gen() 1381 MB/s
[ 1.548185] raid6: int64x4 gen() 1524 MB/s
[ 1.604950] raid6: int64x2 gen() 1351 MB/s
[ 1.661716] raid6: int64x1 gen() 980 MB/s
[ 1.661734] raid6: using algorithm neonx4 gen() 2091 MB/s
[ 1.718484] raid6: .... xor() 1601 MB/s, rmw enabled
[ 1.718505] raid6: using neon recovery algorithm
[ 1.720263] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found
[ 1.720307] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found
[ 1.720334] fiq_debugger_probe: could not install nmi irq handler
[ 1.720868] printk: console [ttyFIQ0] enabled
[ 1.721146] Registered fiq debugger ttyFIQ0
[ 1.726179] iommu: Default domain type: Translated
[ 1.726218] iommu: DMA domain TLB invalidation policy: strict mode
[ 1.726593] SCSI subsystem initialized
[ 1.726857] usbcore: registered new interface driver usbfs
[ 1.726929] usbcore: registered new interface driver hub
[ 1.726984] usbcore: registered new device driver usb
[ 1.727422] mc: Linux media interface: v0.10
[ 1.727515] videodev: Linux video capture interface: v2.00
[ 1.727620] pps_core: LinuxPPS API ver. 1 registered
[ 1.727641] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.727675] PTP clock support registered
[ 1.727730] EDAC MC: Ver: 3.0.0
[ 1.728570] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[ 1.728725] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 1.728803] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[ 1.730534] Advanced Linux Sound Architecture Driver Initialized.
[ 1.731671] rockchip-cpuinfo cpuinfo: SoC : 35662000
[ 1.731704] rockchip-cpuinfo cpuinfo: Serial : 21e3895e05aa36a6
[ 1.732947] clocksource: Switched to clocksource arch_sys_counter
[ 1.743249] NET: Registered PF_INET protocol family
[ 1.743471] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 1.745353] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 1.745426] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.745510] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.745637] TCP bind hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 1.746597] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.746772] UDP hash table entries: 1024 (order: 4, 98304 bytes, linear)
[ 1.746891] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes, linear)
[ 1.747188] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.747671] RPC: Registered named UNIX socket transport module.
[ 1.747697] RPC: Registered udp transport module.
[ 1.747713] RPC: Registered tcp transport module.
[ 1.747729] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.748747] PCI: CLS 0 bytes, default 64
[ 1.751294] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 1.751707] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.765773] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[ 2.132589] Initialise system trusted keyrings
[ 2.132897] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 2.139198] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.140165] NFS: Registering the id_resolver key type
[ 2.140243] Key type id_resolver registered
[ 2.140264] Key type id_legacy registered
[ 2.140363] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.140406] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.142357] Key type cifs.idmap registered
[ 2.142431] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 2.142706] fuse: init (API version 7.37)
[ 2.143190] SGI XFS with security attributes, no debug enabled
[ 2.181170] NET: Registered PF_ALG protocol family
[ 2.181266] xor: measuring software checksum speed
[ 2.185271] 8regs : 2498 MB/sec
[ 2.189683] 32regs : 2288 MB/sec
[ 2.193706] arm64_neon : 2499 MB/sec
[ 2.193756] xor: using function: arm64_neon (2499 MB/sec)
[ 2.193790] Key type asymmetric registered
[ 2.193822] Asymmetric key parser 'x509' registered
[ 2.193961] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 2.194395] io scheduler mq-deadline registered
[ 2.194435] io scheduler kyber registered
[ 2.207865] pwm-backlight backlight: supply power not found, using dummy regulator
[ 2.208350] iep: Module initialized.
[ 2.208436] mpp_service mpp-srv: 53c0acb01bce6 author: Tao Huang 2024-12-09 video: rockchip: mpp: Fix typos in Rockchip copyright notices
[ 2.208466] mpp_service mpp-srv: probe start
[ 2.211740] mpp_service mpp-srv: probe success
[ 2.216646] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.216707] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.218827] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.218869] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.219584] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[ 2.219766] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[ 2.219910] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[ 2.220273] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.220936] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[ 2.221221] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 2.222186] rockchip-pinctrl pinctrl: pin gpio2-14 already requested by vcc5v0-usb20-lbc1-regulator; cannot claim for fe650000.serial
[ 2.222224] rockchip-pinctrl pinctrl: pin-78 (fe650000.serial) status -22
[ 2.222246] rockchip-pinctrl pinctrl: could not request pin 78 (gpio2-14) from group uart1m0-ctsn on device rockchip-pinctrl
[ 2.222270] dw-apb-uart fe650000.serial: Error applying setting, reverse things back
[ 2.229758] rockchip-vop2 fe040000.vop: Adding to iommu group 7
[ 2.237398] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4]
[ 2.237485] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[ 2.237516] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[ 2.237761] [drm] failed to init overlay plane Cluster0-win1
[ 2.237896] rockchip-vop2 fe040000.vop: bin=0
[ 2.238021] rockchip-vop2 fe040000.vop: leakage=49
[ 2.238050] rockchip-vop2 fe040000.vop: leakage-volt-sel=0
[ 2.238122] rockchip-vop2 fe040000.vop: pvtm = 84080, from nvmem
[ 2.238151] rockchip-vop2 fe040000.vop: pvtm-volt-sel=1
[ 2.238278] rockchip-vop2 fe040000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found
[ 2.238342] rockchip-vop2 fe040000.vop: failed to set opp config
[ 2.238365] rockchip-vop2 fe040000.vop: failed to init opp info
[ 2.238383] rockchip-vop2 fe040000.vop: Unsupported VOP aclk dvfs
[ 2.238405] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffffc0096bbfe8)
[ 2.238764] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.239439] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.239822] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[ 2.240268] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffffc0096d0218)
[ 2.241343] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0
[ 2.241479] rockchip-drm display-subsystem: route-hdmi: failed to get logo,offset
[ 2.241509] rockchip-drm display-subsystem: can't not find any logo display
[ 2.241533] rockchip-drm display-subsystem: failed to show kernel logo
[ 2.241663] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 2.241793] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 2.242014] rockchip-drm display-subsystem: [drm] run display error_event monitor
[ 2.245408] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input0
[ 2.246398] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 2.247291] brd: module loaded
[ 2.252602] loop: module loaded
[ 2.253125] zram: Added device: zram0
[ 2.253404] lkdtm: No crash points registered, enable through debugfs
[ 2.259815] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[ 2.260136] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[ 2.260303] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 2.260330] rk_gmac-dwmac fe010000.ethernet: TX delay(0x16).
[ 2.260351] rk_gmac-dwmac fe010000.ethernet: RX delay(0xa).
[ 2.260378] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 2.260439] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 2.260693] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 2.260947] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 2.260978] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 2.261000] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 2.261021] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 2.261041] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 2.261059] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 2.261132] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 2.261153] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 2.261175] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[ 2.261195] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 2.261215] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[ 2.473224] mdio_bus stmmac-1: MDIO device at address 0 is missing.
[ 2.475226] PPP generic driver version 2.4.2
[ 2.475468] PPP BSD Compression module registered
[ 2.475495] PPP Deflate Compression module registered
[ 2.475770] PPP MPPE Compression module registered
[ 2.475797] NET: Registered PF_PPPOX protocol family
[ 2.475911] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
[ 2.475936] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.476290] usbcore: registered new interface driver rndis_wlan
[ 2.476404] usbcore: registered new interface driver cdc_ether
[ 2.476469] usbcore: registered new interface driver rndis_host
[ 2.489458] phy phy-fe8b0000.usb2-phy.3: illegal mode
[ 2.490085] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 2.490358] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[ 2.490511] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002010010
[ 2.490600] xhci-hcd xhci-hcd.4.auto: irq 46, io mem 0xfd000000
[ 2.490771] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 2.490954] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[ 2.490990] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 2.491144] ehci-platform fd800000.usb: EHCI Host Controller
[ 2.491159] phy phy-fe8b0000.usb2-phy.3: illegal mode
[ 2.491176] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 2.491190] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 2.491201] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.491243] usb usb1: Product: xHCI Host Controller
[ 2.491261] usb usb1: Manufacturer: Linux 6.1.99-rk356x xhci-hcd
[ 2.491279] usb usb1: SerialNumber: xhci-hcd.4.auto
[ 2.491474] ehci-platform fd880000.usb: EHCI Host Controller
[ 2.491488] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 2.491759] hub 1-0:1.0: USB hub found
[ 2.491819] hub 1-0:1.0: 1 port detected
[ 2.492247] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.492393] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 2.492423] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.492446] usb usb2: Product: xHCI Host Controller
[ 2.492464] usb usb2: Manufacturer: Linux 6.1.99-rk356x xhci-hcd
[ 2.492482] usb usb2: SerialNumber: xhci-hcd.4.auto
[ 2.492910] hub 2-0:1.0: USB hub found
[ 2.492997] hub 2-0:1.0: 1 port detected
[ 2.493502] usbcore: registered new interface driver cdc_acm
[ 2.493530] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.493600] usbcore: registered new interface driver cdc_wdm
[ 2.493621] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 4
[ 2.493647] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 5
[ 2.493801] ohci-platform fd840000.usb: irq 49, io mem 0xfd840000
[ 2.493819] ehci-platform fd880000.usb: irq 47, io mem 0xfd880000
[ 2.493902] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3
[ 2.493904] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 6
[ 2.493925] usbcore: registered new interface driver uas
[ 2.494006] ohci-platform fd8c0000.usb: irq 50, io mem 0xfd8c0000
[ 2.494032] usbcore: registered new interface driver usb-storage
[ 2.494037] ehci-platform fd800000.usb: irq 48, io mem 0xfd800000
[ 2.495230] usbcore: registered new interface driver usbtouchscreen
[ 2.495716] i2c_dev: i2c /dev entries driver
[ 2.498095] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 2.502694] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_rst
[ 2.502744] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_pwrdn
[ 2.502783] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_slp
[ 2.504299] rk808 0-0020: chip id: 0x8090
[ 2.504363] rk808 0-0020: No cache defaults, reading back from HW
[ 2.506315] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 2.506726] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 2.506758] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.506781] usb usb5: Product: EHCI Host Controller
[ 2.506799] usb usb5: Manufacturer: Linux 6.1.99-rk356x ehci_hcd
[ 2.506817] usb usb5: SerialNumber: fd880000.usb
[ 2.507342] hub 5-0:1.0: USB hub found
[ 2.507415] hub 5-0:1.0: 1 port detected
[ 2.519624] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 2.519984] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 2.520016] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.520039] usb usb3: Product: EHCI Host Controller
[ 2.520057] usb usb3: Manufacturer: Linux 6.1.99-rk356x ehci_hcd
[ 2.520075] usb usb3: SerialNumber: fd800000.usb
[ 2.520538] hub 3-0:1.0: USB hub found
[ 2.520610] hub 3-0:1.0: 1 port detected
[ 2.528097] rk808 0-0020: source: on=0x40, off=0x00
[ 2.528138] rk808 0-0020: support dcdc3 fb mode:-22, 1
[ 2.528162] rk808 0-0020: support pmic reset mode:0,0
[ 2.530947] rk808 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx
[ 2.535318] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.535386] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.553706] rk817-battery: Failed to locate of_node [id: -1]
[ 2.553803] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 2.553837] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.553861] usb usb4: Product: Generic Platform OHCI controller
[ 2.553880] usb usb4: Manufacturer: Linux 6.1.99-rk356x ohci_hcd
[ 2.553898] usb usb4: SerialNumber: fd840000.usb
[ 2.553902] rk817-battery rk817-battery: Failed to find matching dt id
[ 2.554064] rk817-charger: Failed to locate of_node [id: -1]
[ 2.554203] rk817-charger rk817-charger: Failed to find matching dt id
[ 2.554436] hub 4-0:1.0: USB hub found
[ 2.554493] hub 4-0:1.0: 1 port detected
[ 2.555026] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 2.555059] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.555081] usb usb6: Product: Generic Platform OHCI controller
[ 2.555100] usb usb6: Manufacturer: Linux 6.1.99-rk356x ohci_hcd
[ 2.555118] usb usb6: SerialNumber: fd8c0000.usb
[ 2.555602] hub 6-0:1.0: USB hub found
[ 2.555655] hub 6-0:1.0: 1 port detected
[ 2.557452] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 2.560905] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 2.561219] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 2.563321] usbcore: registered new interface driver uvcvideo
[ 2.565531] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 2.566589] cpu cpu0: bin=0
[ 2.566691] cpu cpu0: leakage=24
[ 2.566749] cpu cpu0: pvtm = 84080, from nvmem
[ 2.566778] cpu cpu0: pvtm-volt-sel=1
[ 2.566803] cpu cpu0: soc version=0, speed=1
[ 2.568776] cpu cpu0: avs=0
[ 2.568992] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.572618] cpu cpu0: EM: created perf domain
[ 2.574933] sdhci: Secure Digital Host Controller Interface driver
[ 2.574984] sdhci: Copyright(c) Pierre Ossman
[ 2.575003] Synopsys Designware Multimedia Card Interface Driver
[ 2.575496] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.576528] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[ 2.576575] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[ 2.577012] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 2.577060] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[ 2.577128] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[ 2.577138] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 2.577169] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[ 2.577247] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 80,32 bit host data width,256 deep fifo
[ 2.577952] cryptodev: driver 1.12 loaded.
[ 2.578048] hid: raw HID events driver (C) Jiri Kosina
[ 2.578447] usbcore: registered new interface driver usbhid
[ 2.578480] usbhid: USB HID core driver
[ 2.579775] rockchip,bus bus-npu: bin=0
[ 2.579835] rockchip,bus bus-npu: Failed to get leakage
[ 2.579907] rockchip,bus bus-npu: pvtm = 84080, from nvmem
[ 2.579940] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 2.581040] rockchip,bus bus-npu: avs=0
[ 2.587139] usbcore: registered new interface driver snd-usb-audio
[ 2.588912] rk817-codec rk817-codec: DMA mask not set
[ 2.589018] clk: failed to reparent i2s1_mclkout_tx to clk_i2s1_8ch_tx: -22
[ 2.590611] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 2.594359] Initializing XFRM netlink socket
[ 2.594827] NET: Registered PF_INET6 protocol family
[ 2.596169] Segment Routing with IPv6
[ 2.596240] In-situ OAM (IOAM) with IPv6
[ 2.596373] NET: Registered PF_PACKET protocol family
[ 2.596423] NET: Registered PF_KEY protocol family
[ 2.596495] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.596566] 8021q: 802.1Q VLAN Support v1.8
[ 2.596611] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.596632] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.597411] Key type dns_resolver registered
[ 2.599511] Loading compiled-in X.509 certificates
[ 2.603137] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 2.603419] pstore: Using crash dump compression: deflate
[ 2.608942] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[ 2.611084] rga2 fdeb0000.rk_rga: probe successfully, irq = 83, hw_version:3.2.63318
[ 2.611441] rga: IOMMU binding successfully, default mapping core[0x4]
[ 2.611691] rga: Module initialized. v1.3.7
[ 2.641016] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 2.641117] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 2.641261] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 2.641448] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 2.641580] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(3300000 uV) supplied by vcc_3v3
[ 2.641651] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 2.641721] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(3300000 uV) supplied by vcc_3v3
[ 2.641796] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 2.642109] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5
[ 2.642301] mpp_rkvenc fdf40000.rkvenc: probing start
[ 2.642705] mpp_rkvenc fdf40000.rkvenc: bin=0
[ 2.642738] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[ 2.642789] mpp_rkvenc fdf40000.rkvenc: pvtm = 84080, from nvmem
[ 2.642810] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[ 2.643090] mpp_rkvenc fdf40000.rkvenc: avs=0
[ 2.643547] mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 2.643922] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 2.644244] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 1
[ 2.644409] mpp_vdpu2 fdea0400.vdpu: probe device
[ 2.644680] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 2.644922] mpp_vepu2 fdee0000.vepu: Adding to iommu group 3
[ 2.645058] mpp_vepu2 fdee0000.vepu: probing start
[ 2.645289] mpp_vepu2 fdee0000.vepu: probing finish
[ 2.645499] mpp-iep2 fdef0000.iep: Adding to iommu group 4
[ 2.645598] mpp-iep2 fdef0000.iep: probe device
[ 2.645822] mpp-iep2 fdef0000.iep: probing finish
[ 2.646024] mpp_jpgdec fded0000.jpegd: Adding to iommu group 2
[ 2.646120] mpp_jpgdec fded0000.jpegd: probe device
[ 2.646422] mpp_jpgdec fded0000.jpegd: probing finish
[ 2.646720] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6
[ 2.646904] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[ 2.647166] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 2.647184] rkvdec2_init:1198: No niu aclk reset resource define
[ 2.647200] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 2.647212] rkvdec2_init:1201: No niu hclk reset resource define
[ 2.647435] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[ 2.647503] mpp_rkvdec2 fdf80200.rkvdec: leakage=49
[ 2.647524] mpp_rkvdec2 fdf80200.rkvdec: leakage-volt-sel=0
[ 2.647563] mpp_rkvdec2 fdf80200.rkvdec: pvtm = 84080, from nvmem
[ 2.647582] mpp_rkvdec2 fdf80200.rkvdec: pvtm-volt-sel=1
[ 2.647838] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[ 2.648273] mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 2.648426] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 2.648445] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 2.648459] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 2.648471] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 2.648486] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 2.648547] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 2.648622] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 2.648637] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 2.649623] rockchip-dmc dmc: bin=0
[ 2.649682] mali fde60000.gpu: Kernel DDK version g25p0-00eac0
[ 2.649710] rockchip-dmc dmc: leakage=49
[ 2.649735] rockchip-dmc dmc: leakage-volt-sel=0
[ 2.649774] rockchip-dmc dmc: pvtm = 84080, from nvmem
[ 2.649794] rockchip-dmc dmc: pvtm-volt-sel=1
[ 2.649811] rockchip-dmc dmc: soc version=0, speed=1
[ 2.649847] mali fde60000.gpu: GPU metrics tracepoint support enabled
[ 2.650208] rockchip-dmc dmc: avs=0
[ 2.650233] rockchip-dmc dmc: current ATF version 0x102
[ 2.650246] mali fde60000.gpu: bin=0
[ 2.650321] mali fde60000.gpu: leakage=7
[ 2.650362] mali fde60000.gpu: pvtm = 84080, from nvmem
[ 2.650384] mali fde60000.gpu: pvtm-volt-sel=1
[ 2.650400] mali fde60000.gpu: soc version=0, speed=1
[ 2.651029] mali fde60000.gpu: avs=0
[ 2.651051] rockchip-dmc dmc: normal_rate = 780000000
[ 2.651071] rockchip-dmc dmc: reboot_rate = 1056000000
[ 2.651080] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 144; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 2.651086] rockchip-dmc dmc: suspend_rate = 324000000
[ 2.651113] rockchip-dmc dmc: video_4k_rate = 780000000
[ 2.651127] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[ 2.651140] rockchip-dmc dmc: boost_rate = 1056000000
[ 2.651154] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[ 2.651169] rockchip-dmc dmc: performance_rate = 1056000000
[ 2.651199] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 2.651420] mali fde60000.gpu: Register LUT 00070200 initialized for GPU arch 0x00070400
[ 2.651466] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 2.651753] mali fde60000.gpu: No priority control manager is configured
[ 2.651772] mali fde60000.gpu: Large page allocation set to false after hardware feature check
[ 2.651784] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.652326] mali fde60000.gpu: No memory group manager is configured
[ 2.654234] mali fde60000.gpu: l=0 h=2147483647 hyst=5000 l_limit=700000000 h_limit=0 h_table=0
[ 2.655606] mali fde60000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model'
[ 2.655664] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[ 2.656061] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[ 2.656550] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[ 2.657020] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ''
[ 2.657465] mali fde60000.gpu: No thermal zone specified, will use the default temperature value of 55000
[ 2.659866] mali fde60000.gpu: Clearing BASE_MEM_UNCACHED_GPU flag to avoid MMA violation
[ 2.660062] mali fde60000.gpu: Using configured power model mali-g52_r1-power-model, and fallback mali-simple-power-model
[ 2.661013] RKNPU fde40000.npu: Adding to iommu group 0
[ 2.661663] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 2.661712] mali fde60000.gpu: * MALI kbase_mmap_min_addr compiled to CONFIG_DEFAULT_MMAP_MIN_ADDR, no runtime update possible! *
[ 2.661737] mali fde60000.gpu: Probed as mali0
[ 2.662054] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[ 2.662132] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[ 2.662519] [drm] Initialized rknpu 0.9.8 20240828 for fde40000.npu on minor 1
[ 2.663180] RKNPU fde40000.npu: bin=0
[ 2.663244] RKNPU fde40000.npu: leakage=4
[ 2.663289] RKNPU fde40000.npu: pvtm = 84080, from nvmem
[ 2.663313] RKNPU fde40000.npu: pvtm-volt-sel=1
[ 2.663331] RKNPU fde40000.npu: soc version=0, speed=1
[ 2.664167] RKNPU fde40000.npu: avs=0
[ 2.664386] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.666779] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.668458] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 2.669064] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.669188] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.669215] cfg80211: failed to load regulatory.db
[ 2.669469] clk: Disabling unused clocks
[ 2.670997] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 2.671665] rockchip-suspend not set sleep-mode-config for mem-lite
[ 2.671682] rockchip-suspend not set wakeup-config for mem-lite
[ 2.671696] rockchip-suspend not set sleep-mode-config for mem-ultra
[ 2.671708] rockchip-suspend not set wakeup-config for mem-ultra
[ 2.672732] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 407; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '07:49:09', on 'Apr 22 2026'.
[ 2.673305] Mali:
[ 2.673312] Mali device driver loaded
[ 2.673528] ALSA device list:
[ 2.673549] No soundcards found.
[ 2.673906] Waiting for root device /dev/mmcblk0p3...
[ 2.679268] mmc0: Host Software Queue enabled
[ 2.679333] mmc0: new HS200 MMC card at address 0001
[ 2.680908] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 2.685135] mmcblk0: p1 p2 p3
[ 2.686240] mmcblk0boot0: mmc0:0001 8GTF4R 4.00 MiB
[ 2.688200] mmcblk0boot1: mmc0:0001 8GTF4R 4.00 MiB
[ 2.689969] mmcblk0rpmb: mmc0:0001 8GTF4R 512 KiB, chardev (235:0)
[ 2.705253] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Quota mode: disabled.
[ 2.706003] vendor storage:20190527 ret = 0
[ 2.707994] VFS: Mounted root (ext4 filesystem) on device 179:3.
[ 2.708872] devtmpfs: mounted
[ 2.721515] Freeing unused kernel memory: 7488K
[ 2.721785] Run /sbin/init as init process
[ 2.785403] BUG: spinlock wrong CPU on CPU#1, init/1
[ 2.785511] lock: 0xffffff8006e1c768, .magic: dead4ead, .owner: init/1, .owner_cpu: 16777217
[ 2.785573] CPU: 1 PID: 1 Comm: init Not tainted 6.1.99-rk356x #8
[ 2.785613] Hardware name: Embedfire LubanCat-RK356x (DT)
[ 2.785646] Call trace:
[ 2.785673] dump_backtrace+0xe4/0x140
[ 2.785724] show_stack+0x20/0x30
[ 2.785764] dump_stack_lvl+0x68/0x84
[ 2.785805] dump_stack+0x18/0x34
[ 2.785839] spin_dump+0x9c/0xb0
[ 2.785877] do_raw_spin_unlock+0xf4/0x100
[ 2.785921] _raw_spin_unlock_irq+0x18/0x40
[ 2.785958] __filemap_add_folio+0x1f4/0x44c
[ 2.785998] filemap_add_folio+0x4c/0xd0
[ 2.786033] page_cache_ra_unbounded+0x104/0x200
[ 2.786070] ondemand_readahead+0x1c4/0x340
[ 2.786104] page_cache_sync_ra+0x7c/0xb0
[ 2.786138] filemap_get_pages+0xbc/0x67c
[ 2.786173] filemap_read+0xc0/0x360
[ 2.786207] generic_file_read_iter+0x108/0x1a0
[ 2.786244] ext4_file_read_iter+0x58/0x180
[ 2.786287] vfs_read+0x1bc/0x280
[ 2.786325] ksys_read+0x70/0xfc
[ 2.786359] __arm64_sys_read+0x24/0x30
[ 2.786394] invoke_syscall+0x50/0x120
[ 2.786433] el0_svc_common.constprop.0+0x58/0x190
[ 2.786472] do_el0_svc+0x24/0x30
[ 2.786508] el0_svc+0x28/0xb0
[ 2.786542] el0t_64_sync_handler+0xb8/0xbc
[ 2.786579] el0t_64_sync+0x19c/0x1a0
[ 2.790146] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.796964] CPU: 1 PID: 1 Comm: init Not tainted 6.1.99-rk356x #8
[ 2.797532] Hardware name: Embedfire LubanCat-RK356x (DT)
[ 2.798030] Call trace:
[ 2.798266] dump_backtrace+0xe4/0x140
[ 2.798646] show_stack+0x20/0x30
[ 2.798977] dump_stack_lvl+0x68/0x84
[ 2.799331] dump_stack+0x18/0x34
[ 2.799656] panic+0x17c/0x354
[ 2.799960] make_task_dead+0x0/0x18c
[ 2.800313] do_group_exit+0x3c/0xa0
[ 2.800661] get_signal+0x848/0x880
[ 2.801003] do_notify_resume+0x344/0xdec
[ 2.801392] el0_da+0xf4/0xfc
[ 2.801683] el0t_64_sync_handler+0x68/0xbc
[ 2.802081] el0t_64_sync+0x19c/0x1a0
[ 2.802431] SMP: stopping secondary CPUs
[ 2.802803] CPU2: stopping
[ 2.802817] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 6.1.99-rk356x #8
[ 2.802831] Hardware name: Embedfire LubanCat-RK356x (DT)
[ 2.802837] Call trace:
[ 2.802842] dump_backtrace+0xe4/0x140
[ 2.802865] show_stack+0x20/0x30
[ 2.802869] CPU0: stopping
[ 2.802881] dump_stack_lvl+0x68/0x84
[ 2.802884] CPU3: stopping
[ 2.802895] dump_stack+0x18/0x34
[ 2.802908] local_cpu_stop+0x78/0x80
[ 2.802922] ipi_handler+0xe4/0x2c0
[ 2.802935] handle_percpu_devid_irq+0x90/0x1c4
[ 2.802950] generic_handle_domain_irq+0x34/0x4c
[ 2.802968] gic_handle_irq+0x12c/0x268
[ 2.802977] call_on_irq_stack+0x24/0x50
[ 2.802991] do_interrupt_handler+0x88/0x9c
[ 2.803004] el1_interrupt+0x48/0xb0
[ 2.803017] el1h_64_irq_handler+0x18/0x2c
[ 2.803030] el1h_64_irq+0x74/0x78
[ 2.803039] cpuidle_enter_state+0xbc/0x44c
[ 2.803057] cpuidle_enter+0x40/0x60
[ 2.803072] do_idle+0x234/0x2c0
[ 2.803088] cpu_startup_entry+0x40/0x44
[ 2.803102] secondary_start_kernel+0x138/0x19c
[ 2.803116] __secondary_switched+0xb0/0xb4
[ 2.803133] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 6.1.99-rk356x #8
[ 2.803147] Hardware name: Embedfire LubanCat-RK356x (DT)
[ 2.803153] Call trace:
[ 2.803157] dump_backtrace+0xe4/0x140
[ 2.803178] show_stack+0x20/0x30
[ 2.803193] dump_stack_lvl+0x68/0x84
[ 2.803206] dump_stack+0x18/0x34
[ 2.803217] local_cpu_stop+0x78/0x80
[ 2.803231] ipi_handler+0xe4/0x2c0
[ 2.803243] handle_percpu_devid_irq+0x90/0x1c4
[ 2.803256] generic_handle_domain_irq+0x34/0x4c
[ 2.803271] gic_handle_irq+0x12c/0x268
[ 2.803281] call_on_irq_stack+0x24/0x50
[ 2.803293] do_interrupt_handler+0x88/0x9c
[ 2.803306] el1_interrupt+0x48/0xb0
[ 2.803318] el1h_64_irq_handler+0x18/0x2c
[ 2.803331] el1h_64_irq+0x74/0x78
[ 2.803340] cpuidle_enter_state+0xbc/0x44c
[ 2.803357] cpuidle_enter+0x40/0x60
[ 2.803371] do_idle+0x234/0x2c0
[ 2.803385] cpu_startup_entry+0x3c/0x44
[ 2.803399] secondary_start_kernel+0x138/0x19c
[ 2.803413] __secondary_switched+0xb0/0xb4
[ 2.803429] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 6.1.99-rk356x #8
[ 2.803443] Hardware name: Embedfire LubanCat-RK356x (DT)
[ 2.803448] Call trace:
[ 2.803452] dump_backtrace+0xe4/0x140
[ 2.803473] show_stack+0x20/0x30
[ 2.803488] dump_stack_lvl+0x68/0x84
[ 2.803501] dump_stack+0x18/0x34
[ 2.803512] local_cpu_stop+0x78/0x80
[ 2.803525] ipi_handler+0xe4/0x2c0
[ 2.803537] handle_percpu_devid_irq+0x90/0x1c4
[ 2.803549] generic_handle_domain_irq+0x34/0x4c
[ 2.803565] gic_handle_irq+0x12c/0x268
[ 2.803574] call_on_irq_stack+0x24/0x50
[ 2.803586] do_interrupt_handler+0x88/0x9c
[ 2.803599] el1_interrupt+0x48/0xb0
[ 2.803611] el1h_64_irq_handler+0x18/0x2c
[ 2.803624] el1h_64_irq+0x74/0x78
[ 2.803633] cpuidle_enter_state+0xbc/0x44c
[ 2.803649] cpuidle_enter+0x40/0x60
[ 2.803663] do_idle+0x234/0x2c0
[ 2.803677] cpu_startup_entry+0x40/0x44
[ 2.803691] rest_init+0xd8/0xe0
[ 2.803705] arch_post_acpi_subsys_init+0x0/0x28
[ 2.803720] start_kernel+0x72c/0x76c
[ 2.803733] __primary_switched+0xb4/0xbc
[ 2.803749] PMU CRU:
[ 2.830420] 00000000: 00006064 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 2.831208] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.831995] 00000040: 00002063 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 2.832781] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.833565] 00000080: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.834350] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.835133] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.835918] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.836702] 00000100: 00000080 0040b71b 00000001 00000001 00000800 00000000 00000001 00000009
[ 2.837487] 00000120: 0000050f 0000888b 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.838270] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.839054] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.839838] 00000180: 00000000 000039ff 0000fff9 00000000 00000000 00000000 00000000 00000000
[ 2.840622] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.841405] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.842189] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.842973] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.843756] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.844531] 00000240: 00040020 00000000
[ 2.844895] CRU:
[ 2.845089] 00000000: 00004064 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 2.845873] 00000020: 00004082 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 2.846656] 00000040: 00002063 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 2.847439] 00000060: 0000107d 00001443 00000000 00000007 00007f00 00000000 00000000 00000000
[ 2.848223] 00000080: 00002064 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.849006] 000000a0: 0000307d 00001442 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.849790] 000000c0: 00004455 00000000 00000000 00000000 00640064 00000000 00000000 00000103
[ 2.850573] 000000e0: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.851357] 00000100: 000000c0 00000000 00000001 00000101 00000101 00000111 00004155 000000e5
[ 2.852141] 00000120: 00000053 00000100 00000000 00008000 00040004 00008000 00040004 00000400
[ 2.852924] 00000140: 00803057 00008000 00040004 00008000 00040004 00008000 00040004 00004000
[ 2.853708] 00000160: 00040004 0000000b 00000000 00000010 00001031 00001c30 00000520 00000000
[ 2.854492] 00000180: 00000020 00000004 00000310 0000c001 0000c0c0 00003100 00000001 00000000
[ 2.855276] 000001a0: 00000401 00000003 00000103 00002100 00000203 00000003 00000000 00000103
[ 2.856060] 000001c0: 00000003 00000303 00000001 00001725 0000200b 00000000 0000200b 00000000
[ 2.856843] 000001e0: 0000200b 00000000 0000200b 00000000 0000200b 00000000 0000200b 00000000
[ 2.857627] 00000200: 0000200b 00000000 0000200b 00000000 0000200b 00000000 00000303 00000203
[ 2.858411] 00000220: 00001500 00000000 0000001f 00000302 00000705 00000f0b 0000013b 00000303
[ 2.859195] 00000240: 00000f07 00002713 00001f09 00008000 00040004 00003b2f 00000101 00000302
[ 2.859978] 00000260: 00000704 0000130f 00001f27 00000000 00000000 00000000 00000000 00000000
[ 2.860762] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.861544] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.862328] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.863110] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.863893] 00000300: 00000000 00000e00 000001c0 00000f9f 00000000 0000ff00 0000ffff 0000ffff
[ 2.864676] 00000320: 0000f87f 00000c1f 00000010 00000777 00001f1f 0000005f 00000000 000011fc
[ 2.865460] 00000340: 00000000 00000467 00002e07 00000717 00003d40 000003c7 0000d033 0000fff3
[ 2.866243] 00000360: 000001c3 00000000 00000e00 0000f7e0 0000fff6 0000ffff 0000ffff 0000fc03
[ 2.867026] 00000380: 000087e7 0000e100 00007870 00002000 00000000 00000000 00000000 00000000
[ 2.867809] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.868592] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.869374] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.870158] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.870941] 00000420: 00000000 00000000 00000002 00000002 00000002 00000000 00000000 00000000
[ 2.871724] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.872506] 00000460: 00000000 00000000 00000400 00000000 000002a0 00000000 00000000 00000000
[ 2.873290] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.874073] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.874856] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.875640] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.876423] 00000500: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[ 2.877207] 00000520: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[ 2.877990] 00000540: 00040020 00000000 00040020 00000000 00000000 00000000 00000000 00000000
[ 2.878773] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.879549] 00000580: 00000002 00000000
[ 2.879916] CPU0 online:0
[ 2.880177] EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[ 2.880907]
[ 2.881057] CPU1 online:1
[ 2.881316] EL2(NS) PC: <0xffffffc008996f40> readl+0x0/0x20
[ 2.881959]
[ 2.882109] CPU2 online:0
[ 2.882367] EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[ 2.883030] EL2(NS) PC: <0xffffffc00802350c> local_cpu_stop+0x4c/0x80
[ 2.883643] EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[ 2.884317]
[ 2.884466] CPU3 online:0
[ 2.884724] EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[ 2.885446]
[ 2.885604] CPU0 CPU1 CPU2 CPU3
[ 2.886202] 13: 581 539 592 349 GICv3 26 Level arch_timer
[ 2.886997] 14: 10 6 22 21 GICv3 141 Level rk_timer
[ 2.887780] 15: 0 0 0 0 GICv3 65 Level (null)
[ 2.888548] 16: 0 0 0 0 GICv3 66 Level (null)
[ 2.889317] 17: 0 0 0 0 GICv3 67 Level (null)
[ 2.890084] 18: 0 0 0 0 GICv3 68 Level (null)
[ 2.890852] 19: 0 0 0 0 GICv3 69 Level (null)
[ 2.891621] 20: 0 0 0 0 GICv3 284 Edge debug-signal
[ 2.892437] 21: 0 0 0 0 GICv3 150 Level debug
[ 2.893196] 22: 0 0 0 0 GICv3 147 Level rockchip_thermal
[ 2.894036] 23: 0 0 0 0 GICv3 260 Level arm-pmu
[ 2.894806] 24: 0 0 0 0 GICv3 261 Level arm-pmu
[ 2.895575] 25: 0 0 0 0 GICv3 262 Level arm-pmu
[ 2.896343] 26: 0 0 0 0 GICv3 263 Level arm-pmu
[ 2.897125] 27: 1 0 0 0 GICv3 167 Level rockchip_usb2phy
[ 2.897966] 28: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 2.898807] 29: 0 0 0 0 GICv3 46 Level fe530000.dma-controller
[ 2.899707] 30: 0 0 0 0 GICv3 45 Level fe530000.dma-controller
[ 2.900608] 31: 0 0 0 0 GICv3 48 Level fe550000.dma-controller
[ 2.901509] 32: 0 0 0 0 GICv3 47 Level fe550000.dma-controller
[ 2.902412] 33: 0 0 0 0 GICv3 183 Level fde4b000.iommu, fde40000.npu
[ 2.903350] 34: 0 0 0 0 GICv3 170 Level fdea0800.iommu
[ 2.904178] 35: 0 0 0 0 GICv3 93 Level fded0480.iommu
[ 2.905006] 36: 0 0 0 0 GICv3 95 Level fdee0800.iommu
[ 2.905836] 37: 0 0 0 0 GICv3 88 Level fdef0800.iommu, fdef0000.iep
[ 2.906773] 38: 0 0 0 0 GICv3 173 Level fdf40f00.iommu
[ 2.907601] 39: 0 0 0 0 GICv3 174 Level fdf40f00.iommu
[ 2.908430] 40: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 2.909261] 41: 0 0 0 0 GICv3 180 Level fe043e00.iommu, fe040000.vop
[ 2.910199] 42: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 2.911118] 46: 0 0 0 0 GICv3 202 Level xhci-hcd:usb1
[ 2.911936] 47: 0 0 0 0 GICv3 165 Level ehci_hcd:usb5
[ 2.912753] 48: 0 0 0 0 GICv3 162 Level ehci_hcd:usb3
[ 2.913571] 49: 0 0 0 0 GICv3 163 Level ohci_hcd:usb4
[ 2.914388] 50: 0 0 0 0 GICv3 166 Level ohci_hcd:usb6
[ 2.915207] 51: 213 0 0 0 GICv3 78 Level fdd40000.i2c
[ 2.916025] 52: 0 0 0 0 rockchip_gpio_irq 3 Level rk817
[ 2.916854] 53: 0 0 0 0 rk817 0 Edge rk805_pwrkey_fall
[ 2.917707] 54: 0 0 0 0 rk817 1 Edge rk805_pwrkey_rise
[ 2.918577] 77: 0 0 0 0 GICv3 40 Level rockchip-mipi-csi2-hw
[ 2.919454] 78: 0 0 0 0 GICv3 41 Level rockchip-mipi-csi2-hw
[ 2.920332] 79: 0 0 0 0 GICv3 181 Edge fe600000.watchdog
[ 2.921184] 80: 0 0 0 0 GICv3 130 Level dw-mci
[ 2.921954] 81: 387 0 0 0 GICv3 51 Level mmc0
[ 2.922709] 82: 0 0 0 0 GICv3 125 Level fe720000.saradc
[ 2.923550] 83: 0 0 0 0 GICv3 122 Level rga2
[ 2.924306] 84: 0 0 0 0 GICv3 172 Level fdf40000.rkvenc
[ 2.925147] 85: 0 0 0 0 GICv3 171 Level fdea0400.vdpu
[ 2.925965] 86: 0 0 0 0 GICv3 96 Level fdee0000.vepu
[ 2.926783] 87: 0 0 0 0 GICv3 94 Level fded0000.jpegd
[ 2.927611] 88: 0 0 0 0 GICv3 123 Level fdf80200.rkvdec
[ 2.928441] 89: 1 0 0 0 GICv3 72 Level fde60000.gpu
[ 2.929257] 90: 1 0 0 0 GICv3 73 Level fde60000.gpu
[ 2.930073] 91: 1 0 0 0 GICv3 71 Level fde60000.gpu
[ 2.930889] 92: 3 0 0 0 GICv3 42 Level dmc
[ 3.931753] CPU0 CPU1 CPU2 CPU3
[ 3.932343] 13: 581 539 592 349 GICv3 26 Level arch_timer
[ 3.933136] 14: 10 6 22 21 GICv3 141 Level rk_timer
[ 3.933916] 15: 0 0 0 0 GICv3 65 Level (null)
[ 3.934683] 16: 0 0 0 0 GICv3 66 Level (null)
[ 3.935450] 17: 0 0 0 0 GICv3 67 Level (null)
[ 3.936216] 18: 0 0 0 0 GICv3 68 Level (null)
[ 3.936983] 19: 0 0 0 0 GICv3 69 Level (null)
[ 3.937750] 20: 0 0 0 0 GICv3 284 Edge debug-signal
[ 3.938566] 21: 0 0 0 0 GICv3 150 Level debug
[ 3.939323] 22: 0 0 0 0 GICv3 147 Level rockchip_thermal
[ 3.940162] 23: 0 0 0 0 GICv3 260 Level arm-pmu
[ 3.940931] 24: 0 0 0 0 GICv3 261 Level arm-pmu
[ 3.941709] 25: 0 0 0 0 GICv3 262 Level arm-pmu
[ 3.942477] 26: 0 0 0 0 GICv3 263 Level arm-pmu
[ 3.943256] 27: 1 0 0 0 GICv3 167 Level rockchip_usb2phy
[ 3.944096] 28: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 3.944936] 29: 0 0 0 0 GICv3 46 Level fe530000.dma-controller
[ 3.945837] 30: 0 0 0 0 GICv3 45 Level fe530000.dma-controller
[ 3.946736] 31: 0 0 0 0 GICv3 48 Level fe550000.dma-controller
[ 3.947636] 32: 0 0 0 0 GICv3 47 Level fe550000.dma-controller
[ 3.948536] 33: 0 0 0 0 GICv3 183 Level fde4b000.iommu, fde40000.npu
[ 3.949473] 34: 0 0 0 0 GICv3 170 Level fdea0800.iommu
[ 3.950300] 35: 0 0 0 0 GICv3 93 Level fded0480.iommu
[ 3.951128] 36: 0 0 0 0 GICv3 95 Level fdee0800.iommu
[ 3.951956] 37: 0 0 0 0 GICv3 88 Level fdef0800.iommu, fdef0000.iep
[ 3.952892] 38: 0 0 0 0 GICv3 173 Level fdf40f00.iommu
[ 3.953719] 39: 0 0 0 0 GICv3 174 Level fdf40f00.iommu
[ 3.954547] 40: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 3.955375] 41: 0 0 0 0 GICv3 180 Level fe043e00.iommu, fe040000.vop
[ 3.956313] 42: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 3.957228] 46: 0 0 0 0 GICv3 202 Level xhci-hcd:usb1
[ 3.958045] 47: 0 0 0 0 GICv3 165 Level ehci_hcd:usb5
[ 3.958861] 48: 0 0 0 0 GICv3 162 Level ehci_hcd:usb3
[ 3.959678] 49: 0 0 0 0 GICv3 163 Level ohci_hcd:usb4
[ 3.960493] 50: 0 0 0 0 GICv3 166 Level ohci_hcd:usb6
[ 3.961310] 51: 213 0 0 0 GICv3 78 Level fdd40000.i2c
[ 3.962124] 52: 0 0 0 0 rockchip_gpio_irq 3 Level rk817
[ 3.962952] 53: 0 0 0 0 rk817 0 Edge rk805_pwrkey_fall
[ 3.963803] 54: 0 0 0 0 rk817 1 Edge rk805_pwrkey_rise
[ 3.964666] 77: 0 0 0 0 GICv3 40 Level rockchip-mipi-csi2-hw
[ 3.965543] 78: 0 0 0 0 GICv3 41 Level rockchip-mipi-csi2-hw
[ 3.966421] 79: 0 0 0 0 GICv3 181 Edge fe600000.watchdog
[ 3.967272] 80: 0 0 0 0 GICv3 130 Level dw-mci
[ 3.968039] 81: 387 0 0 0 GICv3 51 Level mmc0
[ 3.968794] 82: 0 0 0 0 GICv3 125 Level fe720000.saradc
[ 3.969633] 83: 0 0 0 0 GICv3 122 Level rga2
[ 3.970387] 84: 0 0 0 0 GICv3 172 Level fdf40000.rkvenc
[ 3.971226] 85: 0 0 0 0 GICv3 171 Level fdea0400.vdpu
[ 3.972042] 86: 0 0 0 0 GICv3 96 Level fdee0000.vepu
[ 3.972857] 87: 0 0 0 0 GICv3 94 Level fded0000.jpegd
[ 3.973683] 88: 0 0 0 0 GICv3 123 Level fdf80200.rkvdec
[ 3.974512] 89: 1 0 0 0 GICv3 72 Level fde60000.gpu
[ 3.975327] 90: 1 0 0 0 GICv3 73 Level fde60000.gpu
[ 3.976142] 91: 1 0 0 0 GICv3 71 Level fde60000.gpu
[ 3.976956] 92: 3 0 0 0 GICv3 42 Level dmc
[ 3.977691] PMU:
[ 3.977877] pwr 0x00a0: 00000046 00000000 00000003 00000000
[ 3.978453] status 0x0098: 00000046 00000000 00000046 00000000
[ 3.979023] req 0x0050: 0000004c 00000000 00000000 00000000
[ 3.979593] idle 0x0068: 0000004c 00000000 0000ffff 0000000f
[ 3.980162] ack 0x0060: 0000004c 00000000 0000004c 00000000
[ 3.980738] rockchip-thermal fe710000.tsadc: channal 0: temperature(60 C)
[ 3.981372] rockchip-thermal fe710000.tsadc: channal 1: temperature(53 C)
[ 3.982000] THERMAL REGS:
[ 3.982266] 00000000: 00000fc0 00010033 00000303 00000000 00000000 00000000 00000000 00000000
[ 3.983052] 00000020: 000008cc 000008a4 00000000 00000000 00000940 00000a4c 00000000 00000000
[ 3.983837] 00000040: 00000a70 00000a70 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.984622] 00000060: 00000004 00000004 00000656 00000656 00000000 00000000 00000000 00000000
[ 3.985398] 00000080: 00000000 00000000
[ 3.985764] Kernel Offset: disabled
[ 3.986091] CPU features: 0x60000,000400a4,6600700b
[ 3.986543] Memory Limit: none
[ 3.986857] cpu cpu0: cur_freq: 600000000 Hz, volt: 850000 uV
[ 3.987401] rockchip-dmc dmc: cur_freq: 780000000 Hz, volt: 875000 uV
[ 4.021725] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---板子是自己画的RK3566。LPDDR4 2GB ,EMMC 16GB。大佬有遇到过这种情况吗?烧录了很多镜像但是最后卡死在这个地方,测过电源正常、重新焊接过几次。
根分区已挂载,panic是结果;先查spinlock wrong CPU,降DDR/关DMC变频并核对eMMC容量。
