楼主 #1 2018-10-10 14:30:18
Quotation
已发帖子: 298
贡献个F1C100s ADC驱动(for XBOOT)
F1C100s没有通用的ADC,所以用音频ADC撸了个通用ADC的驱动。
支持3路channel,分别对应FMINL,FMINR,LINL引脚。只支持单次采样,不是用来录制音频的。产品里需要电量检测什么的可以用。
下载代码:adc-f1c100s.c,添加到mach-f1c100s/driver;
再在设备树添加:
"clk-gate@0x01c20068": {"parent": "apb1", "name": "gate-bus-audiocodec", "shift": 0, "invert": false },
"clk-setting@0": {"clocks": [{"name": "gate-bus-audiocodec", "enable": true}]},
"clk-gate@0x01c20140": {"parent": "pll-audio", "name": "gate-sclk-audiocodec", "shift": 31, "invert": false },
"clk-link": { "parent": "gate-sclk-audiocodec", "name": "link-audiocodec" },
"adc-f1c100s@0x01c23c00": {
    "clock-name": "link-audiocodec",
    "reset": 64
#2 2018-10-10 14:33:05
已发帖子: 9,387
Re: 贡献个F1C100s ADC驱动(for XBOOT)
 * driver/adc-f1c100s.c
 * F1C100s ADC driver for XBOOT.
 * Use Audio ADCs as generic ADC.
#include <xboot.h>
#include <clk/clk.h>
#include <reset/reset.h>
#include <adc/adc.h>
enum
	// DAC_DPC				= 0x00,
	// DAC_FIFOC			= 0x04,
	// DAC_FIFOS			= 0x08,
	// DAC_TXDATA			= 0x0c,
	ADC_FIFOC			= 0x10,
	ADC_FIFOS			= 0x14,
	ADC_RXDATA			= 0x18,
	// DAC_MIXER_CTRL		= 0x20,
	ADC_MIXER_CTRL		= 0x24,
	ADDA_TUNE			= 0x28,
	// BIAS_DA16_CAL_CTRL0	= 0x2C,
	// BIAS_DA16_CAL_CTRL1	= 0x34,
	// DAC_CNT				= 0x40,
	ADC_CNT				= 0x44,
	// DAC_DG				= 0x48,
	ADC_DG				= 0x4c,
	// ADC_DAP_CTR			= 0x70,
	// ADC_DAP_LCTR		= 0x74,
	// ADC_DAP_RCTR		= 0x78,
	// ADC_DAP_PARA		= 0x7C,
	// ADC_DAP_LAC			= 0x80,
	// ADC_DAP_LDAT		= 0x84,
	// ADC_DAP_RAC			= 0x88,
	// ADC_DAP_RDAT		= 0x8C,
	// ADC_DAP_HPFC		= 0x90,
	// ADC_DAP_LINAC		= 0x94,
	// ADC_DAP_RINAC		= 0x98,
	// ADC_DAP_ORT			= 0x9c,
enum
    ADC_CHANNEL_FMINL = 0,
    ADC_CHANNEL_FMINR,
    ADC_CHANNEL_LINL,
    // ADC_CHANNEL_MICIN,
    ADC_CHANNEL_COUNT
struct adc_f1c100s_pdata_t
    virtual_addr_t virt;
	char * clk;
	int reset;
static u32_t adc_f1c100s_read(struct adc_t *adc, int channel)
    struct adc_f1c100s_pdata_t *pdat = (struct adc_f1c100s_pdata_t *)adc->priv;
    // unmute channel.
    // bits of channel in User Manual is wrong.
    virtual_addr_t ADDR_MIXEL_CTRL = pdat->virt + ADC_MIXER_CTRL;
    u32_t mixerReg = read32(ADDR_MIXEL_CTRL) & ~(0x1f << 8);
    switch (channel) {
        case ADC_CHANNEL_FMINL:
            write32(ADDR_MIXEL_CTRL, mixerReg | (1 << 11));
            break;
        case ADC_CHANNEL_FMINR:
            write32(ADDR_MIXEL_CTRL, mixerReg | (1 << 10));
            break;
        case ADC_CHANNEL_LINL:
            write32(ADDR_MIXEL_CTRL, mixerReg | (1 << 12));
            break;
        default:
            // mute all
            break;
    // FIFO flush
    write32(pdat->virt + ADC_FIFOC, read32(pdat->virt + ADC_FIFOC) | (1 << 0));
    const uint32_t WAIT_STABLE = 500;
    udelay(WAIT_STABLE);  // wait for internal filter to be stable
    // by default, 0V = -24000 and VRA = 0.
    // make 0V = 0 and vreference = 65535.
    int val = (int16_t)(read32(pdat->virt + ADC_RXDATA) >> 16);
    val += 24000;
    if (val < 0) {
        val = 0;
    return (u32_t)val;
static void adc_f1c100s_config(struct adc_t *adc)
	struct adc_f1c100s_pdata_t * pdat = (struct adc_f1c100s_pdata_t*)adc->priv;
	u32_t regVal =
		(0 << 29)       // 48kHz,make higher for better speed
		| (1 << 28)     // digital enable
        | (0 << 24)     // mode 0
        | (0 << 17)     // delay after enable
        | (0 << 16)     // delay function
        | (0xf << 8)    // default
        | (0 << 7)      // stereo
        | (0 << 6)      // 16-bit
    write32(pdat->virt + ADC_FIFOC, regVal);
    regVal =
        (1 << 31)       // analog enable
        | (3 << 24)     // mic gain
        | (0 << 21)     // linein gain
        | (3 << 16)     // adc gain = 0
        | (1 << 14)     // COS slop time
        | (0 << 8)      // all mute
        | (4 << 0)      // default
    write32(pdat->virt + ADC_MIXER_CTRL, regVal);
static struct device_t * adc_f1c100s_probe(struct driver_t * drv, struct dtnode_t * n)
	struct adc_f1c100s_pdata_t * pdat;
	struct adc_t * adc;
	struct device_t * dev;
	virtual_addr_t virt = phys_to_virt(dt_read_address(n));
	char * clk = dt_read_string(n, "clock-name", NULL);
	pdat = malloc(sizeof(struct adc_f1c100s_pdata_t));
	if(!pdat)
		return FALSE;
	adc = malloc(sizeof(struct adc_t));
	if (!adc)
		free(pdat);
		return FALSE;
	clk_enable(clk);
	pdat->virt = virt;
	pdat->clk = strdup(clk);
	pdat->reset = dt_read_int(n, "reset", -1);
	adc->name = alloc_device_name(dt_read_name(n), -1);
	adc->vreference = 2800000; // (AVCC * 1000000)
	adc->resolution = 16;
    adc->nchannel = ADC_CHANNEL_COUNT;
    adc->read = adc_f1c100s_read;
	adc->priv = pdat;
	if(pdat->reset >= 0)
		reset_deassert(pdat->reset);
    adc_f1c100s_config(adc);
	if (!register_adc(&dev, adc))
		clk_disable(pdat->clk);
		free(pdat->clk);
		free_device_name(adc->name);
		free(adc->priv);
		free(adc);
		return NULL;
	dev->driver = drv;
	return dev;
static void adc_f1c100s_remove(struct device_t * dev)
	struct adc_t * adc = (struct adc_t *)dev->priv;
	struct adc_f1c100s_pdata_t * pdat = (struct adc_f1c100s_pdata_t *)adc->priv;
	if(adc && unregister_adc(adc))
		free(pdat->clk);
		free(adc->priv);
		free(adc);
static void adc_f1c100s_suspend(struct device_t * dev)
static void adc_f1c100s_resume(struct device_t * dev)
static struct driver_t adc_f1c100s = {
	.name		= "adc-f1c100s",
	.probe		= adc_f1c100s_probe,
	.remove		= adc_f1c100s_remove,
	.suspend	= adc_f1c100s_suspend,
	.resume		= adc_f1c100s_resume,
static __init void adc_f1c100s_driver_init(void)
	register_driver(&adc_f1c100s);
static __exit void adc_f1c100s_driver_exit(void)
	unregister_driver(&adc_f1c100s);
driver_initcall(adc_f1c100s_driver_init);
driver_exitcall(adc_f1c100s_driver_exit);
感谢分享!
#3 2018-10-10 14:34:26
已发帖子: 9,387
唱戏机里面 FMINL,FMINR 接了 RTC6222 调频收音机芯片.
楼主 #4 2018-11-09 09:18:00
Quotation
已发帖子: 298
之前对ADC理解有误,现在修正了bug,更新一下代码。上面的代码作废。(话说本站不能编辑帖子吗?)
主要是对FIFO的理解:ADC向FIFO写入数据,写满后如果一直不读,新数据是被丢弃的,不会把旧数据挤走。所以要先清FIFO,等待下一帧数据到来再读取。
driver里加入adc-f1c100s.c:
#include <xboot.h>
enum
	ADC_FIFOC			= 0x10,
	ADC_FIFOS			= 0x14,
	ADC_RXDATA			= 0x18,
	ADDA_TUNE			= 0x28,
	ADC_CNT				= 0x44,
	ADC_DG				= 0x4c,
enum
    ADC_CHANNEL_FMINR,
    ADC_CHANNEL_LINL,
    ADC_CHANNEL_COUNT
	char * clk;
	char * sclk;
	int reset;
    // unmute channel.
    virtual_addr_t ADDR_MIXER_CTRL = pdat->virt + ADC_MIXER_CTRL;
    u32_t mixerReg = read32(ADDR_MIXER_CTRL) & ~(0x1f << 8);
	switch (channel) {
            write32(ADDR_MIXER_CTRL, mixerReg | (1 << 12));
            break;
            write32(ADDR_MIXER_CTRL, mixerReg | (1 << 11));
            break;
            write32(ADDR_MIXER_CTRL, mixerReg | (1 << 10));
            break;
        default:
            // mute all
            break;
    const uint32_t WAIT_STABLE = 400;
	// FIFO flush
	while (((read32(pdat->virt + ADC_FIFOS) >> 23) & 1) == 0) {}
    val += 24000;
    if (val < 0) {
        val = 0;
    return (u32_t)val;
	u32_t regVal =
		(0u << 29)      // 48kHz,higher for better sampling speed
        | (0 << 24)     // mode 0
        | (1 << 7)      // mono
        | (0 << 6)      // 16-bit
    regVal =
        (1u << 31)      // analog enable
        | (1 << 7)      // PA speed fast
        | (4 << 0)      // default
	struct adc_t * adc;
	char * sclk = dt_read_string(n, "sclk-name", NULL);
	if(!pdat)
		return FALSE;
	if (!adc)
		free(pdat);
		return FALSE;
	clk_enable(clk);
	clk_enable(sclk);
	pdat->virt = virt;
	pdat->sclk = strdup(sclk);
	adc->vreference = dt_read_int(n, "vref", 2800000); // (AVCC * 1000000)
	adc->priv = pdat;
		free(pdat->clk);
		clk_disable(pdat->sclk);
		free(pdat->sclk);
		free(adc->priv);
		free(adc);
		return NULL;
	dev->driver = drv;
	return dev;
		free(pdat->clk);
		free(pdat->sclk);
		free(adc->priv);
		free(adc);
设备树里加入:
	"clk-link": { "parent": "gate-bus-audiocodec", "name": "link-adc" },
	"clk-link": { "parent": "gate-sclk-audiocodec", "name": "link-sclk-adc" },
		"clock-name": "link-adc",
		"sclk-name": "link-sclk-adc",
		"reset": 64,
		"vref": 2800000
#5 2018-11-09 09:43:05
已发帖子: 9,387
感谢楼主 @Quotation 分享, 五分钟之内可以编辑帖子, 因为以前有些网友把旧帖改了,然后前后帖联系不起上下文了。
#6 2019-01-18 15:49:44
ZSB
@Quotation @晕哥你们好!请问下F1C100S的KEYADC 可以当普通ADC用吗?比如做电量检测或者温度传感器检测?我直接对寄存器做了些配置,定时1S读数据寄存器但是每次读到的都是63。
void keyadc_irq_handle(void);
void keyadc_init(void)
     KEYADC->KEYADC_CTRL = 0x00402101;
     KEYADC->KEYADC_INTC = 0x00000000;
void time1_irq_handle(void)
       if(nnnnn == 0)
             nnnnn = 1;
             gpio_direction_output(GPIO_PORT_E,GPIO_PIN_5,0);
             nnnnn = 0;
             gpio_direction_output(GPIO_PORT_E,GPIO_PIN_5,1);
       rt_kprintf("adc =  %4d", KEYADC->KEYADC_DATA);
       TIM->TMR_IRQ_STA |= 0x00000002;
#7 2019-01-18 15:55:14
已发帖子: 9,387
可以做普通adc,但是精度有点低,我记得是6位的,是不是配置不对,你参考 linux lradc 驱动
#8 2019-01-18 16:23:21
ZSB
好的 晕哥,我是看寄存器操作的,之前看xboot的里面都是用了中断的,我可以直接配置完后定时去读数据寄存器吧。
#9 2019-01-18 16:38:00
已发帖子: 9,387
ZSB 说:
可以先用死循环读排除问题.
linux 驱动代码在这里: https://github.com/torvalds/linux/blob/master/drivers/input/keyboard/sun4i-lradc-keys.c
#10 2019-01-18 16:45:00
ZSB
好的,谢谢你啦@晕哥!!!
楼主 #11 2019-01-18 20:09:11
Quotation
已发帖子: 298
ZSB 说:
可以,如晕哥所说,就是6bit精度有点低。我是用KEYADC做电量检测用,不用IRQ,IRQ是给做按键功能用的。每次需要值的时候读一下寄存器就好。
#12 2021-07-19 08:58:46
sunxiang
已发帖子: 222
这个好像就一路ADC吧,还是6BIT. STM32都好多路,为什么全志不多加几路呀
