楼主 #1 2018-11-21 17:32:35
无情一刀
已发帖子: 695
触摸屏上传数据给input的格式是什么了 各位大神
下面截图的是将数据上传给input但是不知道上传每个字节里面放的是什么  导致我接收到了数据不知道第几个字节是是坐标还是其他的
#2 2018-11-21 17:53:02
所在地: 微信 whycan_cn
已发帖子: 9,245
Re: 触摸屏上传数据给input的格式是什么了 各位大神
有个工具叫 evtest,  你试一试
源码: https://github.com/nicochidt/openwrt-packages/blob/master/evtest-1.33.tar.gz
 *  Copyright (c) 1999-2000 Vojtech Pavlik
 *  Copyright (c) 2009-2011 Red Hat, Inc
 * @file
 * Event device test program
 * evtest prints the capabilities on the kernel devices in /dev/input/eventX
 * and their events. Its primary purpose is for kernel or X driver
 * debugging.
 * See INSTALL for installation details or manually compile with
 * gcc -o evtest evtest.c
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
 * Should you need to contact me, the author, you can do so either by
 * e-mail - mail your message to <vojtech@ucw.cz>, or by paper mail:
 * Vojtech Pavlik, Simunkova 1594, Prague 8, 182 00 Czech Republic
#define _GNU_SOURCE /* for asprintf */
#include <stdio.h>
#include <stdint.h>
#if HAVE_CONFIG_H
#include <config.h>
#include <linux/version.h>
#include <linux/input.h>
#include <string.h>
#include <fcntl.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <dirent.h>
#include <errno.h>
#include <getopt.h>
#include <ctype.h>
#include <signal.h>
#include <sys/time.h>
#include <sys/types.h>
#include <unistd.h>
#define BITS_PER_LONG (sizeof(long) * 8)
#define NBITS(x) ((((x)-1)/BITS_PER_LONG)+1)
#define OFF(x)  ((x)%BITS_PER_LONG)
#define BIT(x)  (1UL<<OFF(x))
#define LONG(x) ((x)/BITS_PER_LONG)
#define test_bit(bit, array)    ((array[LONG(bit)] >> OFF(bit)) & 1)
#define DEV_INPUT_EVENT "/dev/input"
#define EVENT_DEV_NAME "event"
#ifndef EV_SYN
#define EV_SYN 0
#ifndef SYN_MAX
#define SYN_MAX 3
#define SYN_CNT (SYN_MAX + 1)
#ifndef SYN_MT_REPORT
#define SYN_MT_REPORT 2
#ifndef SYN_DROPPED
#define SYN_DROPPED 3
#define NAME_ELEMENT(element) [element] = #element
enum evtest_mode {
    MODE_CAPTURE,
    MODE_QUERY,
    MODE_VERSION,
static const struct query_mode {
    const char *name;
    int event_type;
    int max;
    int rq;
} query_modes[] = {
    { "EV_KEY", EV_KEY, KEY_MAX, EVIOCGKEY(KEY_MAX) },
    { "EV_LED", EV_LED, LED_MAX, EVIOCGLED(LED_MAX) },
    { "EV_SND", EV_SND, SND_MAX, EVIOCGSND(SND_MAX) },
    { "EV_SW",  EV_SW, SW_MAX, EVIOCGSW(SW_MAX) },
static int grab_flag = 0;
static volatile sig_atomic_t stop = 0;
static void interrupt_handler(int sig)
    stop = 1;
 * Look up an entry in the query_modes table by its textual name.
 * @param mode The name of the entry to be found.
 * @return The requested query_mode, or NULL if it could not be found.
static const struct query_mode *find_query_mode_by_name(const char *name)
    int i;
    for (i = 0; i < sizeof(query_modes) / sizeof(*query_modes); i++) {
        const struct query_mode *mode = &query_modes[i];
        if (strcmp(mode->name, name) == 0)
            return mode;
    return NULL;
 * Look up an entry in the query_modes table by value.
 * @param event_type The value of the entry to be found.
static const struct query_mode *find_query_mode_by_value(int event_type)
    int i;
        if (mode->event_type == event_type)
            return mode;
    return NULL;
 * Find a query_mode based on a string identifier. The string can either
 * be a numerical value (e.g. "5") or the name of the event type in question
 * (e.g. "EV_SW").
 * @param query_mode The mode to search for
 * @return The requested code's numerical value, or negative on error.
static const struct query_mode *find_query_mode(const char *query_mode)
    if (isdigit(query_mode[0])) {
        unsigned long val;
        errno = 0;
        val = strtoul(query_mode, NULL, 0);
        if (errno)
            return NULL;
        return find_query_mode_by_value(val);
    } else {
        return find_query_mode_by_name(query_mode);
static const char * const events[EV_MAX + 1] = {
    [0 ... EV_MAX] = NULL,
    NAME_ELEMENT(EV_SYN),            NAME_ELEMENT(EV_KEY),
    NAME_ELEMENT(EV_REL),            NAME_ELEMENT(EV_ABS),
    NAME_ELEMENT(EV_MSC),            NAME_ELEMENT(EV_LED),
    NAME_ELEMENT(EV_SND),            NAME_ELEMENT(EV_REP),
    NAME_ELEMENT(EV_FF),            NAME_ELEMENT(EV_PWR),
    NAME_ELEMENT(EV_FF_STATUS),        NAME_ELEMENT(EV_SW),
static const int maxval[EV_MAX + 1] = {
    [0 ... EV_MAX] = -1,
    [EV_SYN] = SYN_MAX,
    [EV_KEY] = KEY_MAX,
    [EV_REL] = REL_MAX,
    [EV_ABS] = ABS_MAX,
    [EV_MSC] = MSC_MAX,
    [EV_SW] = SW_MAX,
    [EV_LED] = LED_MAX,
    [EV_SND] = SND_MAX,
    [EV_REP] = REP_MAX,
    [EV_FF] = FF_MAX,
    [EV_FF_STATUS] = FF_STATUS_MAX,
#ifdef INPUT_PROP_SEMI_MT
static const char * const props[INPUT_PROP_MAX + 1] = {
    [0 ... INPUT_PROP_MAX] = NULL,
    NAME_ELEMENT(INPUT_PROP_POINTER),
    NAME_ELEMENT(INPUT_PROP_DIRECT),
    NAME_ELEMENT(INPUT_PROP_BUTTONPAD),
    NAME_ELEMENT(INPUT_PROP_SEMI_MT),
#ifdef INPUT_PROP_TOPBUTTONPAD
    NAME_ELEMENT(INPUT_PROP_TOPBUTTONPAD),
#ifdef INPUT_PROP_POINTING_STICK
    NAME_ELEMENT(INPUT_PROP_POINTING_STICK),
static const char * const keys[KEY_MAX + 1] = {
    [0 ... KEY_MAX] = NULL,
    NAME_ELEMENT(KEY_RESERVED),        NAME_ELEMENT(KEY_ESC),
    NAME_ELEMENT(KEY_1),            NAME_ELEMENT(KEY_2),
    NAME_ELEMENT(KEY_3),            NAME_ELEMENT(KEY_4),
    NAME_ELEMENT(KEY_5),            NAME_ELEMENT(KEY_6),
    NAME_ELEMENT(KEY_7),            NAME_ELEMENT(KEY_8),
    NAME_ELEMENT(KEY_9),            NAME_ELEMENT(KEY_0),
    NAME_ELEMENT(KEY_MINUS),        NAME_ELEMENT(KEY_EQUAL),
    NAME_ELEMENT(KEY_BACKSPACE),        NAME_ELEMENT(KEY_TAB),
    NAME_ELEMENT(KEY_Q),            NAME_ELEMENT(KEY_W),
    NAME_ELEMENT(KEY_E),            NAME_ELEMENT(KEY_R),
    NAME_ELEMENT(KEY_T),            NAME_ELEMENT(KEY_Y),
    NAME_ELEMENT(KEY_U),            NAME_ELEMENT(KEY_I),
    NAME_ELEMENT(KEY_O),            NAME_ELEMENT(KEY_P),
    NAME_ELEMENT(KEY_LEFTBRACE),        NAME_ELEMENT(KEY_RIGHTBRACE),
    NAME_ELEMENT(KEY_ENTER),        NAME_ELEMENT(KEY_LEFTCTRL),
    NAME_ELEMENT(KEY_A),            NAME_ELEMENT(KEY_S),
    NAME_ELEMENT(KEY_D),            NAME_ELEMENT(KEY_F),
    NAME_ELEMENT(KEY_G),            NAME_ELEMENT(KEY_H),
    NAME_ELEMENT(KEY_J),            NAME_ELEMENT(KEY_K),
    NAME_ELEMENT(KEY_L),            NAME_ELEMENT(KEY_SEMICOLON),
    NAME_ELEMENT(KEY_APOSTROPHE),        NAME_ELEMENT(KEY_GRAVE),
    NAME_ELEMENT(KEY_LEFTSHIFT),        NAME_ELEMENT(KEY_BACKSLASH),
    NAME_ELEMENT(KEY_Z),            NAME_ELEMENT(KEY_X),
    NAME_ELEMENT(KEY_C),            NAME_ELEMENT(KEY_V),
    NAME_ELEMENT(KEY_B),            NAME_ELEMENT(KEY_N),
    NAME_ELEMENT(KEY_M),            NAME_ELEMENT(KEY_COMMA),
    NAME_ELEMENT(KEY_DOT),            NAME_ELEMENT(KEY_SLASH),
    NAME_ELEMENT(KEY_RIGHTSHIFT),        NAME_ELEMENT(KEY_KPASTERISK),
    NAME_ELEMENT(KEY_LEFTALT),        NAME_ELEMENT(KEY_SPACE),
    NAME_ELEMENT(KEY_CAPSLOCK),        NAME_ELEMENT(KEY_F1),
    NAME_ELEMENT(KEY_F2),            NAME_ELEMENT(KEY_F3),
    NAME_ELEMENT(KEY_F4),            NAME_ELEMENT(KEY_F5),
    NAME_ELEMENT(KEY_F6),            NAME_ELEMENT(KEY_F7),
    NAME_ELEMENT(KEY_F8),            NAME_ELEMENT(KEY_F9),
    NAME_ELEMENT(KEY_F10),            NAME_ELEMENT(KEY_NUMLOCK),
    NAME_ELEMENT(KEY_SCROLLLOCK),        NAME_ELEMENT(KEY_KP7),
    NAME_ELEMENT(KEY_KP8),            NAME_ELEMENT(KEY_KP9),
    NAME_ELEMENT(KEY_KPMINUS),        NAME_ELEMENT(KEY_KP4),
    NAME_ELEMENT(KEY_KP5),            NAME_ELEMENT(KEY_KP6),
    NAME_ELEMENT(KEY_KPPLUS),        NAME_ELEMENT(KEY_KP1),
    NAME_ELEMENT(KEY_KP2),            NAME_ELEMENT(KEY_KP3),
    NAME_ELEMENT(KEY_KP0),            NAME_ELEMENT(KEY_KPDOT),
    NAME_ELEMENT(KEY_ZENKAKUHANKAKU),     NAME_ELEMENT(KEY_102ND),
    NAME_ELEMENT(KEY_F11),            NAME_ELEMENT(KEY_F12),
    NAME_ELEMENT(KEY_RO),            NAME_ELEMENT(KEY_KATAKANA),
    NAME_ELEMENT(KEY_HIRAGANA),        NAME_ELEMENT(KEY_HENKAN),
    NAME_ELEMENT(KEY_KATAKANAHIRAGANA),    NAME_ELEMENT(KEY_MUHENKAN),
    NAME_ELEMENT(KEY_KPJPCOMMA),        NAME_ELEMENT(KEY_KPENTER),
    NAME_ELEMENT(KEY_RIGHTCTRL),        NAME_ELEMENT(KEY_KPSLASH),
    NAME_ELEMENT(KEY_SYSRQ),        NAME_ELEMENT(KEY_RIGHTALT),
    NAME_ELEMENT(KEY_LINEFEED),        NAME_ELEMENT(KEY_HOME),
    NAME_ELEMENT(KEY_UP),            NAME_ELEMENT(KEY_PAGEUP),
    NAME_ELEMENT(KEY_LEFT),            NAME_ELEMENT(KEY_RIGHT),
    NAME_ELEMENT(KEY_END),            NAME_ELEMENT(KEY_DOWN),
    NAME_ELEMENT(KEY_PAGEDOWN),        NAME_ELEMENT(KEY_INSERT),
    NAME_ELEMENT(KEY_DELETE),        NAME_ELEMENT(KEY_MACRO),
    NAME_ELEMENT(KEY_MUTE),            NAME_ELEMENT(KEY_VOLUMEDOWN),
    NAME_ELEMENT(KEY_VOLUMEUP),        NAME_ELEMENT(KEY_POWER),
    NAME_ELEMENT(KEY_KPEQUAL),        NAME_ELEMENT(KEY_KPPLUSMINUS),
    NAME_ELEMENT(KEY_PAUSE),        NAME_ELEMENT(KEY_KPCOMMA),
    NAME_ELEMENT(KEY_HANGUEL),        NAME_ELEMENT(KEY_HANJA),
    NAME_ELEMENT(KEY_YEN),            NAME_ELEMENT(KEY_LEFTMETA),
    NAME_ELEMENT(KEY_RIGHTMETA),        NAME_ELEMENT(KEY_COMPOSE),
    NAME_ELEMENT(KEY_STOP),            NAME_ELEMENT(KEY_AGAIN),
    NAME_ELEMENT(KEY_PROPS),        NAME_ELEMENT(KEY_UNDO),
    NAME_ELEMENT(KEY_FRONT),        NAME_ELEMENT(KEY_COPY),
    NAME_ELEMENT(KEY_OPEN),            NAME_ELEMENT(KEY_PASTE),
    NAME_ELEMENT(KEY_FIND),            NAME_ELEMENT(KEY_CUT),
    NAME_ELEMENT(KEY_HELP),            NAME_ELEMENT(KEY_MENU),
    NAME_ELEMENT(KEY_CALC),            NAME_ELEMENT(KEY_SETUP),
    NAME_ELEMENT(KEY_SLEEP),        NAME_ELEMENT(KEY_WAKEUP),
    NAME_ELEMENT(KEY_FILE),            NAME_ELEMENT(KEY_SENDFILE),
    NAME_ELEMENT(KEY_DELETEFILE),        NAME_ELEMENT(KEY_XFER),
    NAME_ELEMENT(KEY_PROG1),        NAME_ELEMENT(KEY_PROG2),
    NAME_ELEMENT(KEY_WWW),            NAME_ELEMENT(KEY_MSDOS),
    NAME_ELEMENT(KEY_COFFEE),        NAME_ELEMENT(KEY_DIRECTION),
    NAME_ELEMENT(KEY_CYCLEWINDOWS),        NAME_ELEMENT(KEY_MAIL),
    NAME_ELEMENT(KEY_BOOKMARKS),        NAME_ELEMENT(KEY_COMPUTER),
    NAME_ELEMENT(KEY_BACK),            NAME_ELEMENT(KEY_FORWARD),
    NAME_ELEMENT(KEY_CLOSECD),        NAME_ELEMENT(KEY_EJECTCD),
    NAME_ELEMENT(KEY_EJECTCLOSECD),        NAME_ELEMENT(KEY_NEXTSONG),
    NAME_ELEMENT(KEY_PLAYPAUSE),        NAME_ELEMENT(KEY_PREVIOUSSONG),
    NAME_ELEMENT(KEY_STOPCD),        NAME_ELEMENT(KEY_RECORD),
    NAME_ELEMENT(KEY_REWIND),        NAME_ELEMENT(KEY_PHONE),
    NAME_ELEMENT(KEY_ISO),            NAME_ELEMENT(KEY_CONFIG),
    NAME_ELEMENT(KEY_HOMEPAGE),        NAME_ELEMENT(KEY_REFRESH),
    NAME_ELEMENT(KEY_EXIT),            NAME_ELEMENT(KEY_MOVE),
    NAME_ELEMENT(KEY_EDIT),            NAME_ELEMENT(KEY_SCROLLUP),
    NAME_ELEMENT(KEY_SCROLLDOWN),        NAME_ELEMENT(KEY_KPLEFTPAREN),
    NAME_ELEMENT(KEY_KPRIGHTPAREN),     NAME_ELEMENT(KEY_F13),
    NAME_ELEMENT(KEY_F14),            NAME_ELEMENT(KEY_F15),
    NAME_ELEMENT(KEY_F16),            NAME_ELEMENT(KEY_F17),
    NAME_ELEMENT(KEY_F18),            NAME_ELEMENT(KEY_F19),
    NAME_ELEMENT(KEY_F20),            NAME_ELEMENT(KEY_F21),
    NAME_ELEMENT(KEY_F22),            NAME_ELEMENT(KEY_F23),
    NAME_ELEMENT(KEY_F24),            NAME_ELEMENT(KEY_PLAYCD),
    NAME_ELEMENT(KEY_PAUSECD),        NAME_ELEMENT(KEY_PROG3),
    NAME_ELEMENT(KEY_PROG4),        NAME_ELEMENT(KEY_SUSPEND),
    NAME_ELEMENT(KEY_CLOSE),        NAME_ELEMENT(KEY_PLAY),
    NAME_ELEMENT(KEY_FASTFORWARD),        NAME_ELEMENT(KEY_BASSBOOST),
    NAME_ELEMENT(KEY_PRINT),        NAME_ELEMENT(KEY_HP),
    NAME_ELEMENT(KEY_CAMERA),        NAME_ELEMENT(KEY_SOUND),
    NAME_ELEMENT(KEY_QUESTION),        NAME_ELEMENT(KEY_EMAIL),
    NAME_ELEMENT(KEY_CHAT),            NAME_ELEMENT(KEY_SEARCH),
    NAME_ELEMENT(KEY_CONNECT),        NAME_ELEMENT(KEY_FINANCE),
    NAME_ELEMENT(KEY_SPORT),        NAME_ELEMENT(KEY_SHOP),
    NAME_ELEMENT(KEY_ALTERASE),        NAME_ELEMENT(KEY_CANCEL),
    NAME_ELEMENT(KEY_BRIGHTNESSDOWN),    NAME_ELEMENT(KEY_BRIGHTNESSUP),
    NAME_ELEMENT(KEY_MEDIA),        NAME_ELEMENT(KEY_UNKNOWN),
    NAME_ELEMENT(KEY_OK),
    NAME_ELEMENT(KEY_SELECT),        NAME_ELEMENT(KEY_GOTO),
    NAME_ELEMENT(KEY_CLEAR),        NAME_ELEMENT(KEY_POWER2),
    NAME_ELEMENT(KEY_OPTION),        NAME_ELEMENT(KEY_INFO),
    NAME_ELEMENT(KEY_TIME),            NAME_ELEMENT(KEY_VENDOR),
    NAME_ELEMENT(KEY_ARCHIVE),        NAME_ELEMENT(KEY_PROGRAM),
    NAME_ELEMENT(KEY_CHANNEL),        NAME_ELEMENT(KEY_FAVORITES),
    NAME_ELEMENT(KEY_EPG),            NAME_ELEMENT(KEY_PVR),
    NAME_ELEMENT(KEY_MHP),            NAME_ELEMENT(KEY_LANGUAGE),
    NAME_ELEMENT(KEY_TITLE),        NAME_ELEMENT(KEY_SUBTITLE),
    NAME_ELEMENT(KEY_ANGLE),        NAME_ELEMENT(KEY_ZOOM),
    NAME_ELEMENT(KEY_MODE),            NAME_ELEMENT(KEY_KEYBOARD),
    NAME_ELEMENT(KEY_SCREEN),        NAME_ELEMENT(KEY_PC),
    NAME_ELEMENT(KEY_TV),            NAME_ELEMENT(KEY_TV2),
    NAME_ELEMENT(KEY_VCR),            NAME_ELEMENT(KEY_VCR2),
    NAME_ELEMENT(KEY_SAT),            NAME_ELEMENT(KEY_SAT2),
    NAME_ELEMENT(KEY_CD),            NAME_ELEMENT(KEY_TAPE),
    NAME_ELEMENT(KEY_RADIO),        NAME_ELEMENT(KEY_TUNER),
    NAME_ELEMENT(KEY_PLAYER),        NAME_ELEMENT(KEY_TEXT),
    NAME_ELEMENT(KEY_DVD),            NAME_ELEMENT(KEY_AUX),
    NAME_ELEMENT(KEY_MP3),            NAME_ELEMENT(KEY_AUDIO),
    NAME_ELEMENT(KEY_VIDEO),        NAME_ELEMENT(KEY_DIRECTORY),
    NAME_ELEMENT(KEY_LIST),            NAME_ELEMENT(KEY_MEMO),
    NAME_ELEMENT(KEY_CALENDAR),        NAME_ELEMENT(KEY_RED),
    NAME_ELEMENT(KEY_GREEN),        NAME_ELEMENT(KEY_YELLOW),
    NAME_ELEMENT(KEY_BLUE),            NAME_ELEMENT(KEY_CHANNELUP),
    NAME_ELEMENT(KEY_CHANNELDOWN),        NAME_ELEMENT(KEY_FIRST),
    NAME_ELEMENT(KEY_LAST),            NAME_ELEMENT(KEY_AB),
    NAME_ELEMENT(KEY_NEXT),            NAME_ELEMENT(KEY_RESTART),
    NAME_ELEMENT(KEY_SLOW),            NAME_ELEMENT(KEY_SHUFFLE),
    NAME_ELEMENT(KEY_BREAK),        NAME_ELEMENT(KEY_PREVIOUS),
    NAME_ELEMENT(KEY_DIGITS),        NAME_ELEMENT(KEY_TEEN),
    NAME_ELEMENT(KEY_TWEN),            NAME_ELEMENT(KEY_DEL_EOL),
    NAME_ELEMENT(KEY_DEL_EOS),        NAME_ELEMENT(KEY_INS_LINE),
    NAME_ELEMENT(KEY_DEL_LINE),
    NAME_ELEMENT(KEY_VIDEOPHONE),        NAME_ELEMENT(KEY_GAMES),
    NAME_ELEMENT(KEY_ZOOMIN),        NAME_ELEMENT(KEY_ZOOMOUT),
    NAME_ELEMENT(KEY_ZOOMRESET),        NAME_ELEMENT(KEY_WORDPROCESSOR),
    NAME_ELEMENT(KEY_EDITOR),        NAME_ELEMENT(KEY_SPREADSHEET),
    NAME_ELEMENT(KEY_GRAPHICSEDITOR),     NAME_ELEMENT(KEY_PRESENTATION),
    NAME_ELEMENT(KEY_DATABASE),        NAME_ELEMENT(KEY_NEWS),
    NAME_ELEMENT(KEY_VOICEMAIL),        NAME_ELEMENT(KEY_ADDRESSBOOK),
    NAME_ELEMENT(KEY_MESSENGER),        NAME_ELEMENT(KEY_DISPLAYTOGGLE),
#ifdef KEY_SPELLCHECK
    NAME_ELEMENT(KEY_SPELLCHECK),
#ifdef KEY_LOGOFF
    NAME_ELEMENT(KEY_LOGOFF),
#ifdef KEY_DOLLAR
    NAME_ELEMENT(KEY_DOLLAR),
#ifdef KEY_EURO
    NAME_ELEMENT(KEY_EURO),
#ifdef KEY_FRAMEBACK
    NAME_ELEMENT(KEY_FRAMEBACK),
#ifdef KEY_FRAMEFORWARD
    NAME_ELEMENT(KEY_FRAMEFORWARD),
#ifdef KEY_CONTEXT_MENU
    NAME_ELEMENT(KEY_CONTEXT_MENU),
#ifdef KEY_MEDIA_REPEAT
    NAME_ELEMENT(KEY_MEDIA_REPEAT),
#ifdef KEY_10CHANNELSUP
    NAME_ELEMENT(KEY_10CHANNELSUP),
#ifdef KEY_10CHANNELSDOWN
    NAME_ELEMENT(KEY_10CHANNELSDOWN),
#ifdef KEY_IMAGES
    NAME_ELEMENT(KEY_IMAGES),
    NAME_ELEMENT(KEY_DEL_EOL),        NAME_ELEMENT(KEY_DEL_EOS),
    NAME_ELEMENT(KEY_INS_LINE),         NAME_ELEMENT(KEY_DEL_LINE),
    NAME_ELEMENT(KEY_FN),            NAME_ELEMENT(KEY_FN_ESC),
    NAME_ELEMENT(KEY_FN_F1),        NAME_ELEMENT(KEY_FN_F2),
    NAME_ELEMENT(KEY_FN_F3),        NAME_ELEMENT(KEY_FN_F4),
    NAME_ELEMENT(KEY_FN_F5),        NAME_ELEMENT(KEY_FN_F6),
    NAME_ELEMENT(KEY_FN_F7),        NAME_ELEMENT(KEY_FN_F8),
    NAME_ELEMENT(KEY_FN_F9),        NAME_ELEMENT(KEY_FN_F10),
    NAME_ELEMENT(KEY_FN_F11),        NAME_ELEMENT(KEY_FN_F12),
    NAME_ELEMENT(KEY_FN_1),            NAME_ELEMENT(KEY_FN_2),
    NAME_ELEMENT(KEY_FN_D),            NAME_ELEMENT(KEY_FN_E),
    NAME_ELEMENT(KEY_FN_F),            NAME_ELEMENT(KEY_FN_S),
    NAME_ELEMENT(KEY_FN_B),
    NAME_ELEMENT(KEY_BRL_DOT1),        NAME_ELEMENT(KEY_BRL_DOT2),
    NAME_ELEMENT(KEY_BRL_DOT3),        NAME_ELEMENT(KEY_BRL_DOT4),
    NAME_ELEMENT(KEY_BRL_DOT5),        NAME_ELEMENT(KEY_BRL_DOT6),
    NAME_ELEMENT(KEY_BRL_DOT7),        NAME_ELEMENT(KEY_BRL_DOT8),
    NAME_ELEMENT(KEY_BRL_DOT9),        NAME_ELEMENT(KEY_BRL_DOT10),
#ifdef KEY_NUMERIC_0
    NAME_ELEMENT(KEY_NUMERIC_0),        NAME_ELEMENT(KEY_NUMERIC_1),
    NAME_ELEMENT(KEY_NUMERIC_2),        NAME_ELEMENT(KEY_NUMERIC_3),
    NAME_ELEMENT(KEY_NUMERIC_4),        NAME_ELEMENT(KEY_NUMERIC_5),
    NAME_ELEMENT(KEY_NUMERIC_6),        NAME_ELEMENT(KEY_NUMERIC_7),
    NAME_ELEMENT(KEY_NUMERIC_8),        NAME_ELEMENT(KEY_NUMERIC_9),
    NAME_ELEMENT(KEY_NUMERIC_STAR),        NAME_ELEMENT(KEY_NUMERIC_POUND),
    NAME_ELEMENT(KEY_BATTERY),
    NAME_ELEMENT(KEY_BLUETOOTH),        NAME_ELEMENT(KEY_BRIGHTNESS_CYCLE),
    NAME_ELEMENT(KEY_BRIGHTNESS_ZERO),
#ifdef KEY_DASHBOARD
    NAME_ELEMENT(KEY_DASHBOARD),
    NAME_ELEMENT(KEY_DISPLAY_OFF),        NAME_ELEMENT(KEY_DOCUMENTS),
    NAME_ELEMENT(KEY_FORWARDMAIL),        NAME_ELEMENT(KEY_NEW),
    NAME_ELEMENT(KEY_KBDILLUMDOWN),        NAME_ELEMENT(KEY_KBDILLUMUP),
    NAME_ELEMENT(KEY_KBDILLUMTOGGLE),     NAME_ELEMENT(KEY_REDO),
    NAME_ELEMENT(KEY_REPLY),        NAME_ELEMENT(KEY_SAVE),
#ifdef KEY_SCALE
    NAME_ELEMENT(KEY_SCALE),
    NAME_ELEMENT(KEY_SEND),
    NAME_ELEMENT(KEY_SCREENLOCK),        NAME_ELEMENT(KEY_SWITCHVIDEOMODE),
#ifdef KEY_UWB
    NAME_ELEMENT(KEY_UWB),
#ifdef KEY_VIDEO_NEXT
    NAME_ELEMENT(KEY_VIDEO_NEXT),
#ifdef KEY_VIDEO_PREV
    NAME_ELEMENT(KEY_VIDEO_PREV),
#ifdef KEY_WIMAX
    NAME_ELEMENT(KEY_WIMAX),
#ifdef KEY_WLAN
    NAME_ELEMENT(KEY_WLAN),
#ifdef KEY_RFKILL
    NAME_ELEMENT(KEY_RFKILL),
#ifdef KEY_MICMUTE
    NAME_ELEMENT(KEY_MICMUTE),
#ifdef KEY_CAMERA_FOCUS
    NAME_ELEMENT(KEY_CAMERA_FOCUS),
#ifdef KEY_WPS_BUTTON
    NAME_ELEMENT(KEY_WPS_BUTTON),
#ifdef KEY_TOUCHPAD_TOGGLE
    NAME_ELEMENT(KEY_TOUCHPAD_TOGGLE),
    NAME_ELEMENT(KEY_TOUCHPAD_ON),
    NAME_ELEMENT(KEY_TOUCHPAD_OFF),
#ifdef KEY_CAMERA_ZOOMIN
    NAME_ELEMENT(KEY_CAMERA_ZOOMIN),    NAME_ELEMENT(KEY_CAMERA_ZOOMOUT),
    NAME_ELEMENT(KEY_CAMERA_UP),        NAME_ELEMENT(KEY_CAMERA_DOWN),
    NAME_ELEMENT(KEY_CAMERA_LEFT),        NAME_ELEMENT(KEY_CAMERA_RIGHT),
#ifdef KEY_ATTENDANT_ON
    NAME_ELEMENT(KEY_ATTENDANT_ON),        NAME_ELEMENT(KEY_ATTENDANT_OFF),
    NAME_ELEMENT(KEY_ATTENDANT_TOGGLE),    NAME_ELEMENT(KEY_LIGHTS_TOGGLE),
    NAME_ELEMENT(BTN_0),            NAME_ELEMENT(BTN_1),
    NAME_ELEMENT(BTN_2),            NAME_ELEMENT(BTN_3),
    NAME_ELEMENT(BTN_4),            NAME_ELEMENT(BTN_5),
    NAME_ELEMENT(BTN_6),            NAME_ELEMENT(BTN_7),
    NAME_ELEMENT(BTN_8),            NAME_ELEMENT(BTN_9),
    NAME_ELEMENT(BTN_LEFT),            NAME_ELEMENT(BTN_RIGHT),
    NAME_ELEMENT(BTN_MIDDLE),        NAME_ELEMENT(BTN_SIDE),
    NAME_ELEMENT(BTN_EXTRA),        NAME_ELEMENT(BTN_FORWARD),
    NAME_ELEMENT(BTN_BACK),            NAME_ELEMENT(BTN_TASK),
    NAME_ELEMENT(BTN_TRIGGER),        NAME_ELEMENT(BTN_THUMB),
    NAME_ELEMENT(BTN_THUMB2),        NAME_ELEMENT(BTN_TOP),
    NAME_ELEMENT(BTN_TOP2),            NAME_ELEMENT(BTN_PINKIE),
    NAME_ELEMENT(BTN_BASE),            NAME_ELEMENT(BTN_BASE2),
    NAME_ELEMENT(BTN_BASE3),        NAME_ELEMENT(BTN_BASE4),
    NAME_ELEMENT(BTN_BASE5),        NAME_ELEMENT(BTN_BASE6),
    NAME_ELEMENT(BTN_DEAD),            NAME_ELEMENT(BTN_C),
#ifdef BTN_SOUTH
    NAME_ELEMENT(BTN_SOUTH),        NAME_ELEMENT(BTN_EAST),
    NAME_ELEMENT(BTN_NORTH),        NAME_ELEMENT(BTN_WEST),
#else
    NAME_ELEMENT(BTN_A),            NAME_ELEMENT(BTN_B),
    NAME_ELEMENT(BTN_X),            NAME_ELEMENT(BTN_Y),
    NAME_ELEMENT(BTN_Z),            NAME_ELEMENT(BTN_TL),
    NAME_ELEMENT(BTN_TR),            NAME_ELEMENT(BTN_TL2),
    NAME_ELEMENT(BTN_TR2),            NAME_ELEMENT(BTN_SELECT),
    NAME_ELEMENT(BTN_START),        NAME_ELEMENT(BTN_MODE),
    NAME_ELEMENT(BTN_THUMBL),        NAME_ELEMENT(BTN_THUMBR),
    NAME_ELEMENT(BTN_TOOL_PEN),        NAME_ELEMENT(BTN_TOOL_RUBBER),
    NAME_ELEMENT(BTN_TOOL_BRUSH),        NAME_ELEMENT(BTN_TOOL_PENCIL),
    NAME_ELEMENT(BTN_TOOL_AIRBRUSH),    NAME_ELEMENT(BTN_TOOL_FINGER),
    NAME_ELEMENT(BTN_TOOL_MOUSE),        NAME_ELEMENT(BTN_TOOL_LENS),
    NAME_ELEMENT(BTN_TOUCH),        NAME_ELEMENT(BTN_STYLUS),
    NAME_ELEMENT(BTN_STYLUS2),        NAME_ELEMENT(BTN_TOOL_DOUBLETAP),
    NAME_ELEMENT(BTN_TOOL_TRIPLETAP),
#ifdef BTN_TOOL_QUADTAP
    NAME_ELEMENT(BTN_TOOL_QUADTAP),
    NAME_ELEMENT(BTN_GEAR_DOWN),
    NAME_ELEMENT(BTN_GEAR_UP),
#ifdef BTN_DPAD_UP
    NAME_ELEMENT(BTN_DPAD_UP),        NAME_ELEMENT(BTN_DPAD_DOWN),
    NAME_ELEMENT(BTN_DPAD_LEFT),        NAME_ELEMENT(BTN_DPAD_RIGHT),
#ifdef KEY_ALS_TOGGLE
    NAME_ELEMENT(KEY_ALS_TOGGLE),
#ifdef KEY_BUTTONCONFIG
    NAME_ELEMENT(KEY_BUTTONCONFIG),
#ifdef KEY_TASKMANAGER
    NAME_ELEMENT(KEY_TASKMANAGER),
#ifdef KEY_JOURNAL
    NAME_ELEMENT(KEY_JOURNAL),
#ifdef KEY_CONTROLPANEL
    NAME_ELEMENT(KEY_CONTROLPANEL),
#ifdef KEY_APPSELECT
    NAME_ELEMENT(KEY_APPSELECT),
#ifdef KEY_SCREENSAVER
    NAME_ELEMENT(KEY_SCREENSAVER),
#ifdef KEY_VOICECOMMAND
    NAME_ELEMENT(KEY_VOICECOMMAND),
#ifdef KEY_BRIGHTNESS_MIN
    NAME_ELEMENT(KEY_BRIGHTNESS_MIN),
#ifdef KEY_BRIGHTNESS_MAX
    NAME_ELEMENT(KEY_BRIGHTNESS_MAX),
#ifdef KEY_KBDINPUTASSIST_PREV
    NAME_ELEMENT(KEY_KBDINPUTASSIST_PREV),
#ifdef KEY_KBDINPUTASSIST_NEXT
    NAME_ELEMENT(KEY_KBDINPUTASSIST_NEXT),
#ifdef KEY_KBDINPUTASSIST_PREVGROUP
    NAME_ELEMENT(KEY_KBDINPUTASSIST_PREVGROUP),
#ifdef KEY_KBDINPUTASSIST_NEXTGROUP
    NAME_ELEMENT(KEY_KBDINPUTASSIST_NEXTGROUP),
#ifdef KEY_KBDINPUTASSIST_ACCEPT
    NAME_ELEMENT(KEY_KBDINPUTASSIST_ACCEPT),
#ifdef KEY_KBDINPUTASSIST_CANCEL
    NAME_ELEMENT(KEY_KBDINPUTASSIST_CANCEL),
#ifdef BTN_TRIGGER_HAPPY
    NAME_ELEMENT(BTN_TRIGGER_HAPPY1),    NAME_ELEMENT(BTN_TRIGGER_HAPPY11),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY2),    NAME_ELEMENT(BTN_TRIGGER_HAPPY12),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY3),    NAME_ELEMENT(BTN_TRIGGER_HAPPY13),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY4),    NAME_ELEMENT(BTN_TRIGGER_HAPPY14),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY5),    NAME_ELEMENT(BTN_TRIGGER_HAPPY15),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY6),    NAME_ELEMENT(BTN_TRIGGER_HAPPY16),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY7),    NAME_ELEMENT(BTN_TRIGGER_HAPPY17),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY8),    NAME_ELEMENT(BTN_TRIGGER_HAPPY18),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY9),    NAME_ELEMENT(BTN_TRIGGER_HAPPY19),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY10),    NAME_ELEMENT(BTN_TRIGGER_HAPPY20),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY21),    NAME_ELEMENT(BTN_TRIGGER_HAPPY31),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY22),    NAME_ELEMENT(BTN_TRIGGER_HAPPY32),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY23),    NAME_ELEMENT(BTN_TRIGGER_HAPPY33),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY24),    NAME_ELEMENT(BTN_TRIGGER_HAPPY34),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY25),    NAME_ELEMENT(BTN_TRIGGER_HAPPY35),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY26),    NAME_ELEMENT(BTN_TRIGGER_HAPPY36),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY27),    NAME_ELEMENT(BTN_TRIGGER_HAPPY37),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY28),    NAME_ELEMENT(BTN_TRIGGER_HAPPY38),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY29),    NAME_ELEMENT(BTN_TRIGGER_HAPPY39),
    NAME_ELEMENT(BTN_TRIGGER_HAPPY30),    NAME_ELEMENT(BTN_TRIGGER_HAPPY40),
#ifdef BTN_TOOL_QUINTTAP
    NAME_ELEMENT(BTN_TOOL_QUINTTAP),
static const char * const absval[6] = { "Value", "Min  ", "Max  ", "Fuzz ", "Flat ", "Resolution "};
static const char * const relatives[REL_MAX + 1] = {
    [0 ... REL_MAX] = NULL,
    NAME_ELEMENT(REL_X),            NAME_ELEMENT(REL_Y),
    NAME_ELEMENT(REL_Z),            NAME_ELEMENT(REL_RX),
    NAME_ELEMENT(REL_RY),            NAME_ELEMENT(REL_RZ),
    NAME_ELEMENT(REL_HWHEEL),
    NAME_ELEMENT(REL_DIAL),            NAME_ELEMENT(REL_WHEEL),
    NAME_ELEMENT(REL_MISC),
static const char * const absolutes[ABS_MAX + 1] = {
    [0 ... ABS_MAX] = NULL,
    NAME_ELEMENT(ABS_X),            NAME_ELEMENT(ABS_Y),
    NAME_ELEMENT(ABS_Z),            NAME_ELEMENT(ABS_RX),
    NAME_ELEMENT(ABS_RY),            NAME_ELEMENT(ABS_RZ),
    NAME_ELEMENT(ABS_THROTTLE),        NAME_ELEMENT(ABS_RUDDER),
    NAME_ELEMENT(ABS_WHEEL),        NAME_ELEMENT(ABS_GAS),
    NAME_ELEMENT(ABS_BRAKE),        NAME_ELEMENT(ABS_HAT0X),
    NAME_ELEMENT(ABS_HAT0Y),        NAME_ELEMENT(ABS_HAT1X),
    NAME_ELEMENT(ABS_HAT1Y),        NAME_ELEMENT(ABS_HAT2X),
    NAME_ELEMENT(ABS_HAT2Y),        NAME_ELEMENT(ABS_HAT3X),
    NAME_ELEMENT(ABS_HAT3Y),        NAME_ELEMENT(ABS_PRESSURE),
    NAME_ELEMENT(ABS_DISTANCE),        NAME_ELEMENT(ABS_TILT_X),
    NAME_ELEMENT(ABS_TILT_Y),        NAME_ELEMENT(ABS_TOOL_WIDTH),
    NAME_ELEMENT(ABS_VOLUME),        NAME_ELEMENT(ABS_MISC),
#ifdef ABS_MT_BLOB_ID
    NAME_ELEMENT(ABS_MT_TOUCH_MAJOR),
    NAME_ELEMENT(ABS_MT_TOUCH_MINOR),
    NAME_ELEMENT(ABS_MT_WIDTH_MAJOR),
    NAME_ELEMENT(ABS_MT_WIDTH_MINOR),
    NAME_ELEMENT(ABS_MT_ORIENTATION),
    NAME_ELEMENT(ABS_MT_POSITION_X),
    NAME_ELEMENT(ABS_MT_POSITION_Y),
    NAME_ELEMENT(ABS_MT_TOOL_TYPE),
    NAME_ELEMENT(ABS_MT_BLOB_ID),
#ifdef ABS_MT_TRACKING_ID
    NAME_ELEMENT(ABS_MT_TRACKING_ID),
#ifdef ABS_MT_PRESSURE
    NAME_ELEMENT(ABS_MT_PRESSURE),
#ifdef ABS_MT_SLOT
    NAME_ELEMENT(ABS_MT_SLOT),
#ifdef ABS_MT_TOOL_X
    NAME_ELEMENT(ABS_MT_TOOL_X),
    NAME_ELEMENT(ABS_MT_TOOL_Y),
    NAME_ELEMENT(ABS_MT_DISTANCE),
static const char * const misc[MSC_MAX + 1] = {
    [ 0 ... MSC_MAX] = NULL,
    NAME_ELEMENT(MSC_SERIAL),        NAME_ELEMENT(MSC_PULSELED),
    NAME_ELEMENT(MSC_GESTURE),        NAME_ELEMENT(MSC_RAW),
    NAME_ELEMENT(MSC_SCAN),
#ifdef MSC_TIMESTAMP
    NAME_ELEMENT(MSC_TIMESTAMP),
static const char * const leds[LED_MAX + 1] = {
    [0 ... LED_MAX] = NULL,
    NAME_ELEMENT(LED_NUML),            NAME_ELEMENT(LED_CAPSL),
    NAME_ELEMENT(LED_SCROLLL),        NAME_ELEMENT(LED_COMPOSE),
    NAME_ELEMENT(LED_KANA),            NAME_ELEMENT(LED_SLEEP),
    NAME_ELEMENT(LED_SUSPEND),        NAME_ELEMENT(LED_MUTE),
    NAME_ELEMENT(LED_MISC),
#ifdef LED_MAIL
    NAME_ELEMENT(LED_MAIL),
#ifdef LED_CHARGING
    NAME_ELEMENT(LED_CHARGING),
static const char * const repeats[REP_MAX + 1] = {
    [0 ... REP_MAX] = NULL,
    NAME_ELEMENT(REP_DELAY),        NAME_ELEMENT(REP_PERIOD)
static const char * const sounds[SND_MAX + 1] = {
    [0 ... SND_MAX] = NULL,
    NAME_ELEMENT(SND_CLICK),        NAME_ELEMENT(SND_BELL),
    NAME_ELEMENT(SND_TONE)
static const char * const syns[SYN_MAX + 1] = {
    [0 ... SYN_MAX] = NULL,
    NAME_ELEMENT(SYN_REPORT),
    NAME_ELEMENT(SYN_CONFIG),
    NAME_ELEMENT(SYN_MT_REPORT),
    NAME_ELEMENT(SYN_DROPPED)
static const char * const switches[SW_MAX + 1] = {
    [0 ... SW_MAX] = NULL,
    NAME_ELEMENT(SW_LID),
    NAME_ELEMENT(SW_TABLET_MODE),
    NAME_ELEMENT(SW_HEADPHONE_INSERT),
#ifdef SW_RFKILL_ALL
    NAME_ELEMENT(SW_RFKILL_ALL),
#ifdef SW_MICROPHONE_INSERT
    NAME_ELEMENT(SW_MICROPHONE_INSERT),
#ifdef SW_DOCK
    NAME_ELEMENT(SW_DOCK),
#ifdef SW_LINEOUT_INSERT
    NAME_ELEMENT(SW_LINEOUT_INSERT),
#ifdef SW_JACK_PHYSICAL_INSERT
    NAME_ELEMENT(SW_JACK_PHYSICAL_INSERT),
#ifdef SW_VIDEOOUT_INSERT
    NAME_ELEMENT(SW_VIDEOOUT_INSERT),
#ifdef SW_CAMERA_LENS_COVER
    NAME_ELEMENT(SW_CAMERA_LENS_COVER),
    NAME_ELEMENT(SW_KEYPAD_SLIDE),
    NAME_ELEMENT(SW_FRONT_PROXIMITY),
#ifdef SW_ROTATE_LOCK
    NAME_ELEMENT(SW_ROTATE_LOCK),
#ifdef SW_LINEIN_INSERT
    NAME_ELEMENT(SW_LINEIN_INSERT),
#ifdef SW_MUTE_DEVICE
    NAME_ELEMENT(SW_MUTE_DEVICE),
static const char * const force[FF_MAX + 1] = {
    [0 ... FF_MAX] = NULL,
    NAME_ELEMENT(FF_RUMBLE),        NAME_ELEMENT(FF_PERIODIC),
    NAME_ELEMENT(FF_CONSTANT),        NAME_ELEMENT(FF_SPRING),
    NAME_ELEMENT(FF_FRICTION),        NAME_ELEMENT(FF_DAMPER),
    NAME_ELEMENT(FF_INERTIA),        NAME_ELEMENT(FF_RAMP),
    NAME_ELEMENT(FF_SQUARE),        NAME_ELEMENT(FF_TRIANGLE),
    NAME_ELEMENT(FF_SINE),            NAME_ELEMENT(FF_SAW_UP),
    NAME_ELEMENT(FF_SAW_DOWN),        NAME_ELEMENT(FF_CUSTOM),
    NAME_ELEMENT(FF_GAIN),            NAME_ELEMENT(FF_AUTOCENTER),
static const char * const forcestatus[FF_STATUS_MAX + 1] = {
    [0 ... FF_STATUS_MAX] = NULL,
    NAME_ELEMENT(FF_STATUS_STOPPED),    NAME_ELEMENT(FF_STATUS_PLAYING),
static const char * const * const names[EV_MAX + 1] = {
    [EV_SYN] = syns,            [EV_KEY] = keys,
    [EV_REL] = relatives,            [EV_ABS] = absolutes,
    [EV_MSC] = misc,            [EV_LED] = leds,
    [EV_SND] = sounds,            [EV_REP] = repeats,
    [EV_SW] = switches,
    [EV_FF] = force,            [EV_FF_STATUS] = forcestatus,
 * Convert a string to a specific key/snd/led/sw code. The string can either
 * be the name of the key in question (e.g. "SW_DOCK") or the numerical
 * value, either as decimal (e.g. "5") or as hex (e.g. "0x5").
 * @param mode The mode being queried (key, snd, led, sw)
 * @param kstr The string to parse and convert
static int get_keycode(const struct query_mode *query_mode, const char *kstr)
    if (isdigit(kstr[0])) {
        unsigned long val;
        errno = 0;
        val = strtoul(kstr, NULL, 0);
        if (errno) {
            fprintf(stderr, "Could not interpret value %s\n", kstr);
            return -1;
        return (int) val;
    } else {
        const char * const *keynames = names[query_mode->event_type];
        int i;
        for (i = 0; i < query_mode->max; i++) {
            const char *name = keynames[i];
            if (name && strcmp(name, kstr) == 0)
                return i;
        return -1;
 * Filter for the AutoDevProbe scandir on /dev/input.
 * @param dir The current directory entry provided by scandir.
 * @return Non-zero if the given directory entry starts with "event", or zero
 * otherwise.
static int is_event_device(const struct dirent *dir) {
    return strncmp(EVENT_DEV_NAME, dir->d_name, 5) == 0;
 * Scans all /dev/input/event*, display them and ask the user which one to
 * open.
 * @return The event device file name of the device file selected. This
 * string is allocated and must be freed by the caller.
static char* scan_devices(void)
    struct dirent **namelist;
    int i, ndev, devnum;
    char *filename;
    int max_device = 0;
    ndev = scandir(DEV_INPUT_EVENT, &namelist, is_event_device, versionsort);
    if (ndev <= 0)
        return NULL;
    fprintf(stderr, "Available devices:\n");
    for (i = 0; i < ndev; i++)
        char fname[64];
        int fd = -1;
        char name[256] = "???";
        snprintf(fname, sizeof(fname),
             "%s/%s", DEV_INPUT_EVENT, namelist[i]->d_name);
        fd = open(fname, O_RDONLY);
        if (fd < 0)
            continue;
        ioctl(fd, EVIOCGNAME(sizeof(name)), name);
        fprintf(stderr, "%s:    %s\n", fname, name);
        close(fd);
        sscanf(namelist[i]->d_name, "event%d", &devnum);
        if (devnum > max_device)
            max_device = devnum;
        free(namelist[i]);
    fprintf(stderr, "Select the device event number [0-%d]: ", max_device);
    scanf("%d", &devnum);
    if (devnum > max_device || devnum < 0)
        return NULL;
    asprintf(&filename, "%s/%s%d",
         DEV_INPUT_EVENT, EVENT_DEV_NAME,
         devnum);
    return filename;
static int version(void)
#ifndef PACKAGE_VERSION
#define PACKAGE_VERSION "<version undefined>"
    printf("%s %s\n", program_invocation_short_name, PACKAGE_VERSION);
    return EXIT_SUCCESS;
 * Print usage information.
static int usage(void)
    printf("USAGE:\n");
    printf(" Capture mode:\n");
    printf("   %s [--grab] /dev/input/eventX\n", program_invocation_short_name);
    printf("     --grab  grab the device for exclusive access\n");
    printf("\n");
    printf(" Query mode: (check exit code)\n");
    printf("   %s --query /dev/input/eventX <type> <value>\n",
    printf("\n");
    printf("<type> is one of: EV_KEY, EV_SW, EV_LED, EV_SND\n");
    printf("<value> can either be a numerical value, or the textual name of the\n");
    printf("key/switch/LED/sound being queried (e.g. SW_DOCK).\n");
    return EXIT_FAILURE;
 * Print additional information for absolute axes (min/max, current value,
 * etc.).
 * @param fd The file descriptor to the device.
 * @param axis The axis identifier (e.g. ABS_X).
static void print_absdata(int fd, int axis)
    int abs[6] = {0};
    int k;
    ioctl(fd, EVIOCGABS(axis), abs);
    for (k = 0; k < 6; k++)
        if ((k < 3) || abs[k])
            printf("      %s %6d\n", absval[k], abs[k]);
static void print_repdata(int fd)
    int i;
    unsigned int rep[2];
    ioctl(fd, EVIOCGREP, rep);
    for (i = 0; i <= REP_MAX; i++) {
        printf("    Repeat code %d (%s)\n", i, names[EV_REP] ? (names[EV_REP][i] ? names[EV_REP][i] : "?") : "?");
        printf("      Value %6d\n", rep[i]);
static inline const char* typename(unsigned int type)
    return (type <= EV_MAX && events[type]) ? events[type] : "?";
static inline const char* codename(unsigned int type, unsigned int code)
    return (type <= EV_MAX && code <= maxval[type] && names[type] && names[type][ code]) ? names[type][ code] : "?";
static inline const char* propname(unsigned int prop)
    return (prop <= INPUT_PROP_MAX && props[prop]) ? props[prop] : "?";
static int get_state(int fd, unsigned int type, unsigned long *array, size_t size)
    int rc;
    switch(type) {
    case EV_LED:
        rc = ioctl(fd, EVIOCGLED(size), array);
        break;
    case EV_SND:
        rc = ioctl(fd, EVIOCGSND(size), array);
        break;
    case EV_SW:
        rc = ioctl(fd, EVIOCGSW(size), array);
        break;
    case EV_KEY:
        /* intentionally not printing the value for EV_KEY, let the
         * repeat handle this */
    default:
        return 1;
    if (rc == -1)
        return 1;
 * Print static device information (no events). This information includes
 * version numbers, device name and all bits supported by this device.
 * @return 0 on success or 1 otherwise.
static int print_device_info(int fd)
    unsigned int type, code;
    int version;
    unsigned short id[4];
    char name[256] = "Unknown";
    unsigned long bit[EV_MAX][NBITS(KEY_MAX)];
    unsigned long state[KEY_CNT] = {0};
    unsigned int prop;
    unsigned long propbits[INPUT_PROP_MAX];
    int stateval;
    int have_state;
    if (ioctl(fd, EVIOCGVERSION, &version)) {
        perror("evtest: can't get version");
        return 1;
    printf("Input driver version is %d.%d.%d\n",
        version >> 16, (version >> 8) & 0xff, version & 0xff);
    ioctl(fd, EVIOCGID, id);
    printf("Input device ID: bus 0x%x vendor 0x%x product 0x%x version 0x%x\n",
        id[ID_BUS], id[ID_VENDOR], id[ID_PRODUCT], id[ID_VERSION]);
    printf("Input device name: \"%s\"\n", name);
    memset(bit, 0, sizeof(bit));
    ioctl(fd, EVIOCGBIT(0, EV_MAX), bit[0]);
    printf("Supported events:\n");
    for (type = 0; type < EV_MAX; type++) {
        if (test_bit(type, bit[0]) && type != EV_REP) {
            have_state = (get_state(fd, type, state, sizeof(state)) == 0);
            printf("  Event type %d (%s)\n", type, typename(type));
            if (type == EV_SYN) continue;
            ioctl(fd, EVIOCGBIT(type, KEY_MAX), bit[type]);
            for (code = 0; code < KEY_MAX; code++)
                if (test_bit(code, bit[type])) {
                    if (have_state) {
                        stateval = test_bit(code, state);
                        printf("    Event code %d (%s) state %d\n",
                               code, codename(type, code), stateval);
                    } else {
                        printf("    Event code %d (%s)\n", code, codename(type, code));
                    if (type == EV_ABS)
                        print_absdata(fd, code);
    if (test_bit(EV_REP, bit[0])) {
        printf("Key repeat handling:\n");
        printf("  Repeat type %d (%s)\n", EV_REP, events[EV_REP] ?  events[EV_REP] : "?");
        print_repdata(fd);
    memset(propbits, 0, sizeof(propbits));
    ioctl(fd, EVIOCGPROP(sizeof(propbits)), propbits);
    printf("Properties:\n");
    for (prop = 0; prop < INPUT_PROP_MAX; prop++) {
        if (test_bit(prop, propbits))
            printf("  Property type %d (%s)\n", prop, propname(prop));
 * Print device events as they come in.
static int print_events(int fd)
    struct input_event ev[64];
    int i, rd;
    fd_set rdfs;
    FD_ZERO(&rdfs);
    FD_SET(fd, &rdfs);
    while (!stop) {
        select(fd + 1, &rdfs, NULL, NULL, NULL);
        if (stop)
            break;
        rd = read(fd, ev, sizeof(ev));
        if (rd < (int) sizeof(struct input_event)) {
            printf("expected %d bytes, got %d\n", (int) sizeof(struct input_event), rd);
            perror("\nevtest: error reading");
            return 1;
        for (i = 0; i < rd / sizeof(struct input_event); i++) {
            type = ev[i].type;
            code = ev[i].code;
            printf("Event: time %ld.%06ld, ", ev[i].time.tv_sec, ev[i].time.tv_usec);
            if (type == EV_SYN) {
                if (code == SYN_MT_REPORT)
                    printf("++++++++++++++ %s ++++++++++++\n", codename(type, code));
                else if (code == SYN_DROPPED)
                    printf(">>>>>>>>>>>>>> %s <<<<<<<<<<<<\n", codename(type, code));
                    printf("-------------- %s ------------\n", codename(type, code));
            } else {
                printf("type %d (%s), code %d (%s), ",
                    type, typename(type),
                if (type == EV_MSC && (code == MSC_RAW || code == MSC_SCAN))
                    printf("value %02x\n", ev[i].value);
                    printf("value %d\n", ev[i].value);
    ioctl(fd, EVIOCGRAB, (void*)0);
 * Grab and immediately ungrab the device.
 * @return 0 if the grab was successful, or 1 otherwise.
static int test_grab(int fd, int grab_flag)
    int rc;
    rc = ioctl(fd, EVIOCGRAB, (void*)1);
    if (rc == 0 && !grab_flag)
    return rc;
 * Enter capture mode. The requested event device will be monitored, and any
 * captured events will be decoded and printed on the console.
 * @param device The device to monitor, or NULL if the user should be prompted.
 * @return 0 on success, non-zero on error.
static int do_capture(const char *device, int grab_flag)
    int fd;
    char *filename = NULL;
    if (!device) {
        fprintf(stderr, "No device specified, trying to scan all of %s/%s*\n",
            DEV_INPUT_EVENT, EVENT_DEV_NAME);
        if (getuid() != 0)
            fprintf(stderr, "Not running as root, no devices may be available.\n");
        filename = scan_devices();
        if (!filename)
            return usage();
    } else
        filename = strdup(device);
    if (!filename)
    if ((fd = open(filename, O_RDONLY)) < 0) {
        perror("evtest");
        if (errno == EACCES && getuid() != 0)
            fprintf(stderr, "You do not have access to %s. Try "
                    "running as root instead.\n",
                    filename);
        goto error;
    if (!isatty(fileno(stdout)))
        setbuf(stdout, NULL);
    if (print_device_info(fd))
        goto error;
    printf("Testing ... (interrupt to exit)\n");
    if (test_grab(fd, grab_flag))
        printf("***********************************************\n");
        printf("  This device is grabbed by another process.\n");
        printf("  No events are available to evtest while the\n"
               "  other grab is active.\n");
        printf("  In most cases, this is caused by an X driver,\n"
               "  try VT-switching and re-run evtest again.\n");
        printf("  Run the following command to see processes with\n"
               "  an open fd on this device\n"
               " \"fuser -v %s\"\n", filename);
    signal(SIGINT, interrupt_handler);
    signal(SIGTERM, interrupt_handler);
    free(filename);
    return print_events(fd);
error:
    free(filename);
 * Perform a one-shot state query on a specific device. The query can be of
 * any known mode, on any valid keycode.
 * @param device Path to the evdev device node that should be queried.
 * @param query_mode The event type that is being queried (e.g. key, switch)
 * @param keycode The code of the key/switch/sound/LED to be queried
 * @return 0 if the state bit is unset, 10 if the state bit is set, 1 on error.
static int query_device(const char *device, const struct query_mode *query_mode, int keycode)
    int fd;
    int r;
    unsigned long state[NBITS(query_mode->max)];
    fd = open(device, O_RDONLY);
    if (fd < 0) {
        perror("open");
    memset(state, 0, sizeof(state));
    r = ioctl(fd, query_mode->rq, state);
    close(fd);
    if (r == -1) {
        perror("ioctl");
    if (test_bit(keycode, state))
        return 10; /* different from EXIT_FAILURE */
 * Enter query mode. The requested event device will be queried for the state
 * of a particular switch/key/sound/LED.
 * @param device The device to query.
 * @param mode The mode (event type) that is to be queried (snd, sw, key, led)
 * @param keycode The key code to query the state of.
 * @return 0 if the state bit is unset, 10 if the state bit is set.
static int do_query(const char *device, const char *event_type, const char *keyname)
    const struct query_mode *query_mode;
    int keycode;
    if (!device) {
        fprintf(stderr, "Device argument is required for query.\n");
        return usage();
    query_mode = find_query_mode(event_type);
    if (!query_mode) {
        fprintf(stderr, "Unrecognised event type: %s\n", event_type);
        return usage();
    keycode = get_keycode(query_mode, keyname);
    if (keycode < 0) {
        fprintf(stderr, "Unrecognised key name: %s\n", keyname);
        return usage();
    } else if (keycode > query_mode->max) {
        fprintf(stderr, "Key %d is out of bounds.\n", keycode);
    return query_device(device, query_mode, keycode);
static const struct option long_options[] = {
    { "grab", no_argument, &grab_flag, 1 },
    { "query", no_argument, NULL, MODE_QUERY },
    { "version", no_argument, NULL, MODE_VERSION },
    { 0, },
int main (int argc, char **argv)
    const char *device = NULL;
    const char *keyname;
    const char *event_type;
    enum evtest_mode mode = MODE_CAPTURE;
    while (1) {
        int option_index = 0;
        int c = getopt_long(argc, argv, "", long_options, &option_index);
        if (c == -1)
            break;
        switch (c) {
        case 0:
            break;
        case MODE_QUERY:
            mode = c;
            break;
        case MODE_VERSION:
            return version();
        default:
            return usage();
    if (optind < argc)
        device = argv[optind++];
    if (mode == MODE_CAPTURE)
        return do_capture(device, grab_flag);
    if ((argc - optind) < 2) {
        fprintf(stderr, "Query mode requires device, type and key parameters\n");
        return usage();
    event_type = argv[optind++];
    keyname = argv[optind++];
    return do_query(device, event_type, keyname);
/* vim: set noexpandtab tabstop=8 shiftwidth=8: */
运行演示
debugdump@ubuntu:/tmp$ sudo evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:    Power Button
/dev/input/event1:    AT Translated Set 2 keyboard
/dev/input/event2:    VirtualPS/2 VMware VMMouse
/dev/input/event3:    VirtualPS/2 VMware VMMouse
/dev/input/event4:    VMware VMware Virtual USB Mouse
Select the device event number [0-4]: 2
Input driver version is 1.0.1
Input device ID: bus 0x11 vendor 0x2 product 0x13 version 0x6
Input device name: "VirtualPS/2 VMware VMMouse"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 272 (BTN_LEFT)
    Event code 273 (BTN_RIGHT)
    Event code 274 (BTN_MIDDLE)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value  55135
      Min        0
      Max    65535
    Event code 1 (ABS_Y)
      Value  27998
      Min        0
      Max    65535
Properties:
Event: time 1542794042.312802, type 3 (EV_ABS), code 0 (ABS_X), value 55090
Event: time 1542794042.312802, -------------- SYN_REPORT ------------
Event: time 1542794042.322575, type 3 (EV_ABS), code 0 (ABS_X), value 54589
Event: time 1542794042.322575, -------------- SYN_REPORT ------------
Event: time 1542794042.332325, type 3 (EV_ABS), code 0 (ABS_X), value 53861
Event: time 1542794042.332325, -------------- SYN_REPORT ------------
Event: time 1542794042.342428, type 3 (EV_ABS), code 0 (ABS_X), value 52587
Event: time 1542794042.342428, -------------- SYN_REPORT ------------
Event: time 1542794042.352737, type 3 (EV_ABS), code 0 (ABS_X), value 49174
楼主 #3 2018-11-21 19:14:05
无情一刀
已发帖子: 695
我这边发现用不了 是不是还有哪里操作失误了
#4 2018-11-21 19:16:34
所在地: 微信 whycan_cn
已发帖子: 9,245
提示你需要安装
楼主 #5 2018-11-21 19:26:39
无情一刀
已发帖子: 695
提示你需要安装
现在在服务器上是可以的  然后我讲目录挂载到我的V3S上去运行
#6 2018-11-21 20:31:30
所在地: 微信 whycan_cn
已发帖子: 9,245
编译姿势不对,或者对应的 evtest 不是可执行文件?
楼主 #7 2018-11-22 09:18:38
无情一刀
已发帖子: 695
我编译的步骤为tar -zxvf evtest-1.33.tar.gz
进入该目录下执行./autogen.sh
然后在make 我在服务器上是可以执行  然后我讲目录挂着到V3S上 执行./evtest 就发现不行
#8 2018-11-22 09:23:40
所在地: 微信 whycan_cn
已发帖子: 9,245
无情一刀 说:
指令集都不同,依赖库也不同, 怎么执行.
#9 2018-11-22 09:24:51
所在地: 微信 whycan_cn
已发帖子: 9,245
https://gist.githubusercontent.com/uobikiemukot/457338b890e96babf60b/raw/949308b5822d4ee19c8d1059d7ddd3112f9f8b9c/linux_input.c
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <stdarg.h>
#include <stdint.h>
#include <string.h>
#include <linux/fb.h>
//#include <linux/vt.h>
//#include <linux/kd.h>
//#include <sys/stat.h>
#include <sys/mman.h>
//#include <sys/wait.h>
enum {
	VERBOSE    = true,
	MAX_WIDTH  = 1280,
	MAX_HEIGHT = 1024,
	VALUE_PRESSED  = 1,
	VALUE_RELEASED = 0,
	BITS_PER_BYTE  = 8,
	CURSOR_COLOR   = 0x00FF00,
struct cursor_t {
	int x, y;
struct mouse_t {
	struct cursor_t current;
	struct cursor_t pressed, released;
	//bool button_pressed;
	//bool button_released;
struct fb_t {
    int fd;
    unsigned char *fp;
    int width, height;   /* display resolution */
    long screen_size;    /* screen data size (byte) */
    int line_length;     /* line length (byte) */
    int bytes_per_pixel;
    int bits_per_pixel;
//const char *mouse_dev = "/dev/input/event8";
//const char *mouse_dev = "/dev/input/event9";
const char *mouse_dev = "/dev/input/by-path/pci-0000:00:1a.0-usb-0:1.2:1.1-event-mouse";
const char *fb_dev    = "/dev/fb0";
const char *ev_type[EV_CNT] = {
	[EV_SYN]       = "EV_SYN",
	[EV_KEY]       = "EV_KEY",
	[EV_REL]       = "EV_REL",
	[EV_ABS]       = "EV_ABS",
	[EV_MSC]       = "EV_MSC",
	[EV_SW]        = "EV_SW",
	[EV_LED]       = "EV_LED",
	[EV_SND]       = "EV_SND",
	[EV_REP]       = "EV_REP",
	[EV_FF]        = "EV_FF",
	[EV_PWR]       = "EV_PWR",
	[EV_FF_STATUS] = "EV_FF_STATUS",
	[EV_MAX]       = "EV_MAX",
const char *ev_code_syn[SYN_CNT] = {
	[SYN_REPORT]    = "SYN_REPORT",
	[SYN_CONFIG]    = "SYN_CONFIG",
	[SYN_MT_REPORT] = "SYN_MT_REPORT",
	[SYN_DROPPED]   = "SYN_DROPPED",
	[SYN_MAX]       = "SYN_MAX",
const char *ev_code_rel[REL_CNT] = {
	[REL_X]      = "REL_X",
	[REL_Y]      = "REL_Y",
	[REL_Z]      = "REL_Z",
	[REL_RX]     = "REL_RX",
	[REL_RY]     = "REL_RY",
	[REL_RZ]     = "REL_RZ",
	[REL_HWHEEL] = "REL_WHEEL",
	[REL_DIAL]   = "REL_DIAL",
	[REL_WHEEL]  = "REL_WHEEL",
	[REL_MISC]   = "REL_MISC",
	[REL_MAX]    = "REL_MAX",
const char *ev_code_key[KEY_CNT] = {
	[BTN_LEFT]    = "BTN_LEFT",
	[BTN_RIGHT]   = "BTN_RIGHT",
	[BTN_MIDDLE]  = "BTN_MIDDLE",
	[BTN_SIDE]    = "BTN_SIDE",
	[BTN_EXTRA]   = "BTN_EXTRA",
	[BTN_FORWARD] = "BTN_FORWARD",
	[BTN_BACK]    = "BTN_BACK",
	[BTN_TASK]    = "BTN_TASK",
	[KEY_MAX]     = "KEY_MAX",
/* logging functions */
enum loglevel_t {
    DEBUG = 0,
    WARN,
    ERROR,
    FATAL,
void logging(enum loglevel_t loglevel, char *format, ...)
    va_list arg;
    static const char *loglevel2str[] = {
        [DEBUG] = "DEBUG",
        [WARN]  = "WARN",
        [ERROR] = "ERROR",
        [FATAL] = "FATAL",
    /* debug message is available on verbose mode */
    if ((loglevel == DEBUG) && (VERBOSE == false))
        return;
    fprintf(stderr, ">>%s<<\t", loglevel2str[loglevel]);
    va_start(arg, format);
    vfprintf(stderr, format, arg);
    va_end(arg);
/* misc functions */
int my_ceil(int val, int div)
    if (div == 0)
        return (val + div - 1) / div;
/* framebuffer functions */
bool fb_init(struct fb_t *fb)
	struct fb_fix_screeninfo finfo;
	struct fb_var_screeninfo vinfo;
	if ((fb->fd = open(fb_dev, O_RDWR)) < 0) {
		perror("open");
		return false;
	if (ioctl(fb->fd, FBIOGET_FSCREENINFO, &finfo)) {
		logging(ERROR, "ioctl: FBIOGET_FSCREENINFO failed\n");
		return false;
	if (ioctl(fb->fd, FBIOGET_VSCREENINFO, &vinfo)) {
		logging(ERROR, "ioctl: FBIOGET_VSCREENINFO failed\n");
		return false;
	fb->width  = vinfo.xres;
	fb->height = vinfo.yres;
	fb->screen_size = finfo.smem_len;
	fb->line_length = finfo.line_length;
	fb->bits_per_pixel  = vinfo.bits_per_pixel;
	fb->bytes_per_pixel = my_ceil(fb->bits_per_pixel, BITS_PER_BYTE);
	if ((fb->fp = (unsigned char *) mmap(0, fb->screen_size,
		PROT_WRITE | PROT_READ, MAP_SHARED, fb->fd, 0)) == MAP_FAILED)
		return false;
	return true;
void fb_die(struct fb_t *fb)
	munmap(fb->fp, fb->screen_size);
	close(fb->fd);
void fb_draw(struct fb_t *fb, struct cursor_t *cursor, uint32_t color)
	memcpy(fb->fp + cursor->y * fb->line_length + cursor->x * fb->bytes_per_pixel, &color, fb->bytes_per_pixel);
/* mouse functions */
void init_mouse(struct mouse_t *mouse)
	mouse->current.x  = mouse->current.y  = 0;
	mouse->pressed.x  = mouse->pressed.y  = 0;
	mouse->released.x = mouse->released.y = 0;
	//mouse->button_pressed  = false;
	//mouse->button_released = false;
void print_event(struct input_event *ie)
	switch (ie->type) {
	case EV_SYN:
		fprintf(stderr, "time:%ld.%06ld\ttype:%s\tcode:%s\tvalue:%d\n",
			ie->time.tv_sec, ie->time.tv_usec, ev_type[ie->type],
			ev_code_syn[ie->code], ie->value);
		break;
	case EV_REL:
			ev_code_rel[ie->code], ie->value);
		break;
	case EV_KEY:
			ev_code_key[ie->code], ie->value);
		break;
	default:
		break;
void print_mouse_state(struct mouse_t *mouse)
	fprintf(stderr, "\033[1;1H\033[2Kcurrent(%d, %d) pressed(%d, %d) released(%d, %d)",
		mouse->current.x, mouse->current.y,
		mouse->pressed.x, mouse->pressed.y,
		mouse->released.x, mouse->released.y);
void cursor(struct input_event *ie, struct mouse_t *mouse)
	if (ie->code == REL_X)
		mouse->current.x += ie->value;
	if (mouse->current.x < 0)
		mouse->current.x = 0;
	else if (mouse->current.x >= MAX_WIDTH)
		mouse->current.x = MAX_WIDTH - 1;
	if (ie->code == REL_Y)
		mouse->current.y += ie->value;
	if (mouse->current.y < 0)
	else if (mouse->current.y >= MAX_HEIGHT)
		mouse->current.y = MAX_HEIGHT - 1;
void button(struct input_event *ie, struct mouse_t *mouse)
	if (ie->code != BTN_LEFT)
		return;
	if (ie->value == VALUE_PRESSED)
		mouse->pressed = mouse->current;
	if (ie->value == VALUE_RELEASED)
		mouse->released = mouse->current;
void sync(struct input_event *ie, struct mouse_t *mouse)
	if (ie->code != SYN_REPORT)
		return;
void (*event_handler[EV_CNT])(struct input_event *ie, struct mouse_t *mouse) = {
	//[EV_SYN] = sync,
	[EV_REL] = cursor,
	[EV_KEY] = button,
	[EV_MAX] = NULL,
	int fd;
	const char *dev;
	struct input_event ie;
	struct mouse_t mouse;
	struct fb_t fb;
	dev = (argc > 1) ? argv[1]: mouse_dev;
	if ((fd = open(dev, O_RDONLY)) == -1) {
		perror("opening device");
		exit(EXIT_FAILURE);
	init_mouse(&mouse);
	fb_init(&fb);
	while (read(fd, &ie, sizeof(struct input_event))) {
		//print_event(&ie);
		print_mouse_state(&mouse);
		fb_draw(&fb, &mouse.current, CURSOR_COLOR);
		if (event_handler[ie.type])
			event_handler[ie.type](&ie, &mouse);
	fb_die(&fb);
	close(fd);
这个demo不错,我试过鼠标的了。
#10 2018-11-22 09:31:51
所在地: 微信 whycan_cn
已发帖子: 9,245
试了一下鼠标能用, 电阻触摸屏用不了.
