楼主 #1 2019-01-04 12:18:42
zhuacai
已发帖子: 234
大家好,想把webRTC的aec回声清除移植到RDA5981(m4架构)上,但到遇到架构不会设置,请各位大神帮忙!!
typedefs.h文件
*  Copyright (c) 2012 The WebRTC project authors. All Rights Reserved.
*  Use of this source code is governed by a BSD-style license
*  that can be found in the LICENSE file in the root of the source
*  tree. An additional intellectual property rights grant can be found
*  in the file PATENTS.  All contributing project authors may
*  be found in the AUTHORS file in the root of the source tree.
// This file contains platform-specific typedefs and defines.
// Much of it is derived from Chromium's build/build_config.h.
#ifndef WEBRTC_TYPEDEFS_H_
#define WEBRTC_TYPEDEFS_H_
// For access to standard POSIXish features, use WEBRTC_POSIX instead of a
// more specific macro.
#if defined(WEBRTC_MAC) || defined(WEBRTC_LINUX) || \
    defined(WEBRTC_ANDROID)
#define WEBRTC_POSIX
// Processor architecture detection.  For more info on what's defined, see:
//   http://msdn.microsoft.com/en-us/library/b0084kay.aspx
//   http://www.agner.org/optimize/calling_conventions.pdf
//   or with gcc, run: "echo | gcc -E -dM -"
#if defined(_M_X64) || defined(__x86_64__)
#define WEBRTC_ARCH_X86_FAMILY
#define WEBRTC_ARCH_X86_64
#define WEBRTC_ARCH_64_BITS
#define WEBRTC_ARCH_LITTLE_ENDIAN
#elif defined(_M_IX86) || defined(__i386__)
#define WEBRTC_ARCH_32_BITS
#elif defined(__ARMEL__)
// TODO(ajm): We'd prefer to control platform defines here, but this is
// currently provided by the Android makefiles. Commented to avoid duplicate
// definition warnings.
//#define WEBRTC_ARCH_ARM
// TODO(ajm): Chromium uses the following two defines. Should we switch?
//#define WEBRTC_ARCH_ARM_FAMILY
//#define WEBRTC_ARCH_ARMEL
#elif defined(__MIPSEL__)
#else
#error Please add support for your architecture in typedefs.h
#if !(defined(WEBRTC_ARCH_LITTLE_ENDIAN) ^ defined(WEBRTC_ARCH_BIG_ENDIAN))
#error Define either WEBRTC_ARCH_LITTLE_ENDIAN or WEBRTC_ARCH_BIG_ENDIAN
#if defined(__SSE2__) || defined(_MSC_VER)
#define WEBRTC_USE_SSE2
#if !defined(_MSC_VER)
#include <stdint.h>
#else
// Define C99 equivalent types, since MSVC doesn't provide stdint.h.
typedef signed char         int8_t;
typedef signed short        int16_t;
typedef signed int          int32_t;
typedef __int64             int64_t;
typedef unsigned char       uint8_t;
typedef unsigned short      uint16_t;
typedef unsigned int        uint32_t;
typedef unsigned __int64    uint64_t;
// Borrowed from Chromium's base/compiler_specific.h.
// Annotate a virtual method indicating it must be overriding a virtual
// method in the parent class.
// Use like:
//   virtual void foo() OVERRIDE;
#if defined(_MSC_VER)
#define OVERRIDE override
#elif defined(__clang__)
// Clang defaults to C++03 and warns about using override. Squelch that.
// Intentionally no push/pop here so all users of OVERRIDE ignore the warning
// too. This is like passing -Wno-c++11-extensions, except that GCC won't die
// (because it won't see this pragma).
#pragma clang diagnostic ignored "-Wc++11-extensions"
#elif defined(__GNUC__) && __cplusplus >= 201103 && \
    (__GNUC__ * 10000 + __GNUC_MINOR__ * 100) >= 40700
// GCC 4.7 supports explicit virtual overrides when C++11 support is enabled.
#else
#define OVERRIDE
// Annotate a function indicating the caller must examine the return value.
// Use like:
//   int foo() WARN_UNUSED_RESULT;
// TODO(ajm): Hack to avoid multiple definitions until the base/ of webrtc and
// libjingle are merged.
#if !defined(WARN_UNUSED_RESULT)
#if defined(__GNUC__)
#define WARN_UNUSED_RESULT __attribute__((warn_unused_result))
#else
#endif  // WARN_UNUSED_RESULT
#endif  // WEBRTC_TYPEDEFS_H_
报错信息:error Please add support for your architecture in typedefs.h
#2 2019-01-04 14:23:20
已发帖子: 9,399
Re: 大家好,想把webRTC的aec回声清除移植到RDA5981(m4架构)上,但到遇到架构不会设置,请各位大神帮忙!!
webrtc 目录里面有 typedefs.h 吗?
