我的sun8i.h的设置文件是下面设置的 求大神看看啊
#define CONFIG_BOOTCOMMAND "setenv bootm_boot_mode sec; " \
"load mmc 0:1 0x41000000 zImage; " \
"load mmc 0:1 0x41800000 sun8i-v3s-licheepi-zero-dock.dtb; " \
"bootz 0x41000000 - 0x41800000;"
#define CONFIG_BOOTARGS "console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0"
这块板子,这张卡烧我做的固件正常?
这个卡是烧的我自己的固件
另外一张卡烧的你固件打印信息如下
DRAM: 64 MiB
Trying to boot from MMC1
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
dotclock: 33000kHz = 33000kHz: (1 3MHz 66) / 6
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
eth0: ethernet@1c30000
No controllers found
reading zImage
4016104 bytes read in 641 ms (6 MiB/s)
Unable to read file sun8i-v3s-licheepi-zero-dock.dtb
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
换了一张卡后打印的信息又不一样了
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 02:37:00)
DRAM: 64 MiB
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 02:37:00 -0700) Allwinner Technology
DRAM: 64 MiB
贴片式T卡 来顶一顶。支持一下
用三楼那张卡烧你自己的固件试一试
都是一样的效果 没有什么区别
我现在重新clone一个uboot 直接编译玩后下载后 就是同一样的结果
修改 drivers/mmc/sunxi_mmc.c
return mmc_set_mod_clk(mmchost, 24000000); //24Mhz改为:
return mmc_set_mod_clk(mmchost, 2000000); //2Mhz试一试
再不行就加上这个: https://whycan.cn/t_2050.html#p14059
int spl_mmc_load_image(struct spl_image_info *spl_image,
struct spl_boot_device *bootdev)
struct mmc *mmc = NULL;
u32 boot_mode;
int err = 0;
__maybe_unused int part;
err = spl_mmc_find_device(&mmc, bootdev->boot_device);
if (err)
return err;
int try_count = 0;
do
err = mmc_init(mmc);
if (err)
#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT
printf("spl: mmc init failed with error: %d\n", err);
try_count++;
if(try_count > 10)
return err;
break;
}while(1);在线
还是很难起来 我现在在uboot是 不是昨天下载的
设置时钟为2的时候打印是下面的信息
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 18:25:24)
DRAM: 64 MiB
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 18:25:24 -0700) Allwinner Technology
DRAM: 64 MiB
然后代码也改了后是打印下面
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 18:37:28)
DRAM: 64 MiB
看上面的 log 降低 MMC 的频率, spl & u-boot 都跑起来了.
再把 u-boot 里面的 DRAM 和 CPU 频率都降下来。
可以直接修改 .config 文件
DRAM 166M
CPU 800M
就是配置这样两个是吧??
CONFIG_DRAM_CLK=166
CONFIG_SYS_CLK_FREQ=838860800
CONFIG_DRAM_CLK=166
CONFIG_SYS_CLK_FREQ=800000000试一试这样.
无语了 还是这样
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:13:26)
DRAM: 64 MiB
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:13:26 -0700) Allwinner Technology
DRAM: 64 MiB
这有点尴尬,烧我的固件不会酱紫?
我都按照上面的修改了
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:25:02)
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
DRAM: 64 MiB
就那个代码里面一直在读取了
这有点尴尬,烧我的固件不会酱紫?
下载你的没有问题
无情一刀 wrote:
这有点尴尬,烧我的固件不会酱紫?
下载你的没有问题
那单独烧我固件的 uboot 试一试?
好的 下午试试
我刚才烧写刚下载的uboot 打印的信息是下面 这个新的uboot 我就修改了DRAM和CU时钟
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 15 2019 - 20:56:13 -0700) Allwinner Technology
DRAM: 64 MiB
SF: unrecognized JEDEC id bytes: c2, 20, 18
In: serial@01c28000
Net: No ethernet found.
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
reading /sun8i-v3s-licheepi-zero.dtb
11872 bytes read in 25 ms (462.9 KiB/s)
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
无情一刀 wrote:
这有点尴尬,烧我的固件不会酱紫?
下载你的没有问题
那单独烧我固件的 uboot 试一试?
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
reading zImage
Unable to read file zImage
12545 bytes read in 27 ms (453.1 KiB/s)
那可以你在这个基础上改吧.
下载新uboot 烧写进去了uboot是起来 就是一直这样了
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Apr 16 2019 - 00:23:47 -0700) Allwinner Technology
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
Scanning mmc 0:1...
11868 bytes read in 25 ms (462.9 KiB/s)
BOOTP broadcast 1
DHCP client bound to address 192.168.0.168 (4 ms)
*** Warning: no boot file name; using 'C0A800A8.img'
Using ethernet@1c30000 device
TFTP from server 192.168.1.1; our IP address is 192.168.0.168
Filename 'C0A800A8.img'.
Load address: 0x41000000
Loading: T T
步骤没有错的 git clone https://github.com/Lichee-Pi/u-boot.git -b v3s-spi-experimental
第一个分区缺 sun8i-v3s-licheepi-zero.dtb, zImage 文件?
至今没有找到答案 虽然可以跑起来了
我昨天是从新下载了一个uboot带spi 然后在sun8i.h里面设置了TF启动 后面就直接烧写TF卡中 就起来了 ,
我不知道是不是uboot直接cp过来原因的
