楼主 #1 2019-05-06 20:25:20
lgliang
v3s ubuntu 配置qt-everywhere-opensource-src-5.4.1报错
我跟着“zero.lichee.pro”来进行配置的,但是提示
Creating qmake...
make: Nothing to be done for `first'.
Running configuration tests...
Warning: Disabling pkg-config since PKG_CONFIG_LIBDIR is not set.
Warning: Disabling pkg-config since PKG_CONFIG_SYSROOT_DIR is not set.
Could not determine the target architecture!
Turn on verbose messaging (-v) to see the final report.
The tslib functionality test failed!
#2 2019-05-06 21:32:57
已发帖子: 9,492
Re: v3s ubuntu 配置qt-everywhere-opensource-src-5.4.1报错
用buildroot吧, 省事,
在本站搜索 buildroot qt
