楼主 #1 2019-05-13 13:58:09
阿黄
已发帖子: 299
请教F1C100S的 USB Host的kernel配置
F1C100S的USB作为纯USB HOST使用,外部接了一个GL850G的HUB,HUB下面挂了一个RTL8188(wifi),一个CH340G,还有一个U盘,
  1、直接用nano的config文件,没法发现usb设备,貌似被作为device了。lsusb 只有一个root hub
  2、我把kernel中USB OTG相关的menuconfig部分取消选择了,结果lsusb 什么都没有了,下面是启动log
  kernel_config.zip (直接改成.config)
  U-Boot 2018.01-05676-g00188782ee (Apr 08 2018 - 16:10:25 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM:  32 MiB
MMC:   SUNXI SD/MMC: 0
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
280 bytes read in 15 ms (17.6 KiB/s)
## Executing script at 80c50000
7583 bytes read in 26 ms (284.2 KiB/s)
reading zImage
3940448 bytes read in 281 ms (13.4 MiB/s)
   Loading Device Tree to 80e60000, end 80e64d9e ... OK
[    0.000000] Linux version 4.15.0-rc8-licheepi-nano+ (njatech@ubuntu) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #7 Sun May 12 22:54:34 PDT 2019
[    0.000000] Kernel command line: console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw
[    0.000000] Memory: 22664K/32768K available (6144K kernel code, 255K rwdata, 1420K rodata, 1024K init, 244K bss, 10104K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 256 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 245 kB)
[    0.000044] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000096] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000544] Console: colour dummy device 80x30
[    0.001097] console [tty0] enabled
[    0.001180] Calibrating delay loop... 358.80 BogoMIPS (lpj=1794048)
[    0.050258] pid_max: default: 32768 minimum: 301
[    0.050514] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.050586] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.051784] CPU: Testing write buffer coherency: ok
[    0.053386] Setting up static identity map for 0x80100000 - 0x80100058
[    0.055406] devtmpfs: initialized
[    0.059925] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.060058] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.060416] pinctrl core: initialized pinctrl subsystem
[    0.062159] NET: Registered protocol family 16
[    0.063420] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.064867] cpuidle: using governor menu
[    0.083400] SCSI subsystem initialized
[    0.083780] usbcore: registered new interface driver usbfs
[    0.083961] usbcore: registered new interface driver hub
[    0.084166] usbcore: registered new device driver usb
[    0.084569] pps_core: LinuxPPS API ver. 1 registered
[    0.084636] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.084726] PTP clock support registered
[    0.085106] Advanced Linux Sound Architecture Driver Initialized.
[    0.086362] clocksource: Switched to clocksource timer
[    0.109472] NET: Registered protocol family 2
[    0.110617] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.110737] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.110798] TCP: Hash tables configured (established 1024 bind 1024)
[    0.111095] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.111183] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.111622] NET: Registered protocol family 1
[    0.112787] RPC: Registered named UNIX socket transport module.
[    0.112888] RPC: Registered udp transport module.
[    0.112924] RPC: Registered tcp transport module.
[    0.112953] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.114751] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.116477] Initialise system trusted keyrings
[    0.117071] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.129274] NFS: Registering the id_resolver key type
[    0.129415] Key type id_resolver registered
[    0.129456] Key type id_legacy registered
[    0.140187] Key type asymmetric registered
[    0.140285] Asymmetric key parser 'x509' registered
[    0.140507] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.140581] io scheduler noop registered
[    0.140616] io scheduler deadline registered
[    0.141235] io scheduler cfq registered (default)
[    0.141315] io scheduler mq-deadline registered
[    0.141350] io scheduler kyber registered
[    0.142248] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    0.149160] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.296870] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.302576] console [ttyS0] disabled
[    0.322873] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[    0.793241] console [ttyS0] enabled
[    0.801832] panel-simple panel: panel supply power not found, using dummy regulator
[    0.810996] SCSI Media Changer driver v0.25
[    0.816603] usbcore: registered new interface driver rtl8187
[    0.822445] usbcore: registered new interface driver rtl8xxxu
[    0.828432] usbcore: registered new interface driver rtl8150
[    0.834235] usbcore: registered new interface driver r8152
[    0.840209] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.846861] ehci-platform: EHCI generic platform driver
[    0.852339] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.858677] ohci-platform: OHCI generic platform driver
[    0.864237] usbcore: registered new interface driver cdc_wdm
[    0.870175] usbcore: registered new interface driver usb-storage
[    0.876543] usbcore: registered new interface driver usbserial_generic
[    0.883193] usbserial: USB Serial support registered for generic
[    0.889441] usbcore: registered new interface driver ch341
[    0.895036] usbserial: USB Serial support registered for ch341-uart
[    0.901791] musb-sunxi 1c13000.usb: Invalid or missing 'dr_mode' property
[    0.908769] musb-sunxi: probe of 1c13000.usb failed with error -22
[    0.915280] i2c /dev entries driver
[    0.976480] sunxi-mmc 1c0f000.mmc: base:0xa5d79b30 irq:19
[    0.983576] usbcore: registered new interface driver usbhid
[    0.989331] usbhid: USB HID core driver
[    1.007982] NET: Registered protocol family 17
[    1.012693] Key type dns_resolver registered
[    1.019181] Loading compiled-in X.509 certificates
[    1.033705] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc07396b8)
[    1.042559] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073899c)
[    1.050407] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.057105] [drm] No driver support for vblank timestamp query.
[    1.103887] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.108792] Console: switching to colour frame buffer device 60x34
[    1.109445] mmc0: new high speed SDHC card at address 1234
[    1.110416] mmcblk0: mmc0:1234 SA08G 7.21 GiB
[    1.112786]  mmcblk0: p1 p2
[    1.166306] sun4i-drm display-engine: fb0:  frame buffer device
[    1.180033] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.195356] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.216873] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.231103] ALSA device list:
[    1.237869]   #0: Loopback 1
[    1.245275] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.261328] cfg80211: failed to load regulatory.db
[    1.271969] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.313933] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.329768] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.344717] devtmpfs: mounted
[    1.356061] Freeing unused kernel memory: 1024K
[    1.522052] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting logging: OK
Welcome to Lichee Pi
Lichee login: [    6.625019] random: crng init done
最近编辑记录 阿黄 (2019-05-13 14:06:24)
楼主 #2 2019-05-13 14:37:31
阿黄
已发帖子: 299
Re: 请教F1C100S的 USB Host的kernel配置
估计是原来的已经可以了,只是我的PE2没有加上拉,导致OTG认为是低,因此变成设备了。
楼主 #3 2019-05-13 15:21:02
阿黄
已发帖子: 299
我用nano加底板 不接microUSB也是一样,显示g_cdc_gadget:g_cdc ready, 可能这个内核版本USB驱动有问题吧,看OTG那个帖子讨论,要把USB Clock配置改下,估计还要查一下
#4 2019-05-13 15:34:33
也有可能本来就是这样,只是告诉用户 cdc 驱动准备好了,没有别的意思
楼主 #5 2019-05-13 15:43:59
阿黄
已发帖子: 299
jiangming1399 说:
花了一点时间对Icenowy的patch和chong的patch进行了比较,结果发现chong的patch包基本上就是在Icenowy的基础上更改了下面的这个文件:
--- ../linux/drivers/clk/sunxi-ng/ccu-suniv.c    2019-01-15 22:48:18.824587965 +0800
+++ drivers/clk/sunxi-ng/ccu-suniv.c    2019-01-23 09:05:17.959348454 +0800
@@ -238,7 +238,7 @@
/* The BSP header file has a CIR_CFG, but no mod clock uses this definition */
static SUNXI_CCU_GATE(usb_phy0_clk,    "usb-phy0",    "osc24M",
-              0x0cc, BIT(8), 0);
+              0x0cc, BIT(1), 0);
static SUNXI_CCU_GATE(dram_ve_clk,    "dram-ve",    "pll-ddr",
              0x100, BIT(0), 0);
理论上将上面这个patch应用到Icenowy的4.14内核中,USB应该也就能跑了。
按照这个修改,测试看看
楼主 #6 2019-05-13 16:01:48
阿黄
已发帖子: 299
阿黄 说:
jiangming1399 说:
@@ -238,7 +238,7 @@
              0x100, BIT(0), 0);
按照这个修改,测试看看
就是修改这个,就OK了。 另外我PE是悬空的,目前设备树里面的PE2 ACTIVE HIGH 不改就可以
最近编辑记录 阿黄 (2019-05-13 16:31:09)
#7 2019-05-13 16:07:18
还能这么玩
已发帖子: 119
好贴火钳留名
请问楼主, 荔枝派 nano 应该如何改?
楼主 #8 2019-05-13 16:31:33
阿黄
已发帖子: 299
还能这么玩 说:
好贴火钳留名
就是nano啊
#9 2019-05-13 16:33:51
还能这么玩
已发帖子: 119
阿黄 说:
还能这么玩 说:
好贴火钳留名
就是nano啊
好的,谢谢楼主, 一会我也试一试。
#10 2019-05-13 16:46:43
还能这么玩
已发帖子: 119
https://github.com/Lichee-Pi/linux/commits/nano-4.14-exp
https://github.com/Lichee-Pi/linux/commit/44874751dbc7e112de0c78cbfb0479574cdb2332
发现 nano-4.14-exp 这个分支已经改好了 ^_^
clk: sunxi-ng: suniv: fix USB PHY gate clock bit offset
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
#11 2019-05-14 09:56:20
Jmhh247
已发帖子: 262
阿黄 说:
请问,用荔枝派ZERO,TF卡启动,也有很大概率显示:g_cdc_gadget:g_cdc ready,然后卡死,也会是USB驱动问题吗
#12 2019-05-14 10:48:50
感觉不是,可能是硬件问题,或者操作问题吧。
楼主 #13 2019-05-15 11:16:26
阿黄
已发帖子: 299
Jmhh247 说:
阿黄 说:
打印这个是正常的,卡死应该是其他某个任务没法退出,查一下/etc/init.d/里面启动任务
#14 2019-05-16 08:33:15
Jmhh247
已发帖子: 262
阿黄 说:
Jmhh247 说:
阿黄 说:
好的,多谢指导
#15 2020-04-25 22:33:15
hzy831225
1楼,我改了cc-suniv.c 里但是还是HOST没用,插U盘没反映
#16 2020-04-26 08:42:12
sea18c
标记下,后面应该会用得到,谢谢分享!
#17 2020-06-11 16:04:05
SkyLine
标记下
#18 2021-08-20 18:40:23
youzh213
请问楼主,你F1C100S下挂GL850G的HUB,挂的设备能同时工作么?
目前发现HUB挂的设备能枚举,但是无法同时工作,看了太多帖子了,又说什么端点不够的,又说linux-4.x内核不行,需要linux-5内核的
我目前拿到的板子,F1C100S挂的HUB,下面挂了2个设备,一个移远的4G-CAT1模块,一个是8188的WIFI模块
现在枚举都是正常的,但是无法使用,感觉数据不通
#19 2024-03-17 14:10:49
sxlyq_666
已发帖子: 76
大牛好,我的dev目录下没有ttyUSB文件,是什么原因?
#20 2024-06-05 10:11:09
f1c100s_User1
@阿黄
@@ -238,7 +238,7 @@
修改时钟后,插入USB鼠标、键盘有反映,插入U盘或者USB转串口,还是没有反应。
