楼主 #1 2019-05-16 17:58:23
MrJacky
全志A83T无法进系统问题
在A83T平台接8G大小的emmc烧录完后,系统不能启动。日志如附件,求大神帮忙看下啥问题。谢谢!
#2 2019-05-16 17:59:42
所在地: 微信 whycan_cn
已发帖子: 9,240
Re: 全志A83T无法进系统问题
附件右下角有个插入的图标,按一下。
楼主 #3 2019-05-16 18:07:29
MrJacky
Re: 全志A83T无法进系统问题
#4 2019-05-16 18:33:06
所在地: 微信 whycan_cn
已发帖子: 9,240
Re: 全志A83T无法进系统问题
[BEGIN] 2019/5/16 9:53:28
HELLO! BOOT0 is starting!
boot0 version : 4.2.0
boot0 commit : c7427fafe51714aab06c0c1b92b2eb684e52992d
rtc[1] value = 0x00010000
rtc[2] value = 0x00020000
rtc[3] value = 0x00030000
DRAM DRIVE INFO: V1.50
DRAM normal_mode value: 00000001
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1200 mv
ID CHECK VERSION: V0.3
using ic A83T
using axp AXP813
DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK =648 MHZ
DRAM zq value: 00003bfb
dram size =2048
card boot number = 2
card no is 2
sdcard 2 line count 8
[mmc]: mmc driver ver 2015-04-13 16:05:39
[mmc]: ***Try SD card 2***
[mmc]: mmc 2 cmd 8 err 00000100
[mmc]: mmc 2 send if cond failed
[mmc]: mmc 2 cmd 55 err 00000100
[mmc]: mmc 2 send app cmd failed
[mmc]: ***Try MMC card 2***
[mmc]: mmc re-update_phase
[mmc]: 8bit ddr!!!
[mmc]: MMC ver 4.0
[mmc]: SD/MMC Card: 8bit, capacity: 7456MB
[mmc]: vendor: Man 0090014a Snr a110d280
[mmc]: product: H8G4a
[mmc]: revision: 9.2
[mmc]: ***SD/MMC 2 init OK!!!***
sdcard 2 init ok
The size of uboot is 000e8000.
sum=322b0f36
src_sum=322b0f36
set_mmc_para,sdly 50M 0
set_mmc_para,sdly 25M 0
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
[      0.290]MODE
U-Boot 2011.09-rc1-00000-gc7427fa (May 15 2019 - 20:06:30) Allwinner Technology
[      0.299]version: 2.1.0
[      0.301]uboot commit : c7427fafe51714aab06c0c1b92b2eb684e52992d
normal mode
[      0.327]pmbus:   normal or secure os
ready
[      0.331]PMU: AXP81X
[      0.334]PMU: AXP81X found
bat_vol=0, ratio=100
[      0.339]PMU: dcdc2 900
[      0.342]PMU: pll1 1008 Mhz
AXI0=336 Mhz,PLL_PERIPH =1200 Mhz AHB1=200 Mhz, APB1=100 Mhz
dcdc1_vol = 3000, onoff=1
dcdc2_vol = 900, onoff=1
dcdc3_vol = 900, onoff=1
dcdc4_vol = 900, onoff=1
dcdc6_vol = 900, onoff=1
aldo1_vol = 1800, onoff=1
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
eldo2_vol = 1800, onoff=0
eldo1_vol = 1200, onoff=0
dldo2_vol = 3300, onoff=0
dldo3_vol = 2800, onoff=0
dldo4_vol = 2800, onoff=0
fldo2_vol = 900, onoff=1
dldo1_vol = 3300, onoff=0
gpio0ldo_vol = 3300, onoff=0
find power_sply to end
supply=dcdc1
axp=axp81x, supply=dcdc1, vol=3000
reg addr=0x1c20b04, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b08, value=0xa, pmu_vol=3000
supply=aldo1
axp=axp81x, supply=aldo1, vol=1800
reg addr=0x1c20b0c, value=0x0, pmu_vol=1800
supply=dcdc1
reg addr=0x1c20b10, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b14, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b18, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b1c, value=0xa, pmu_vol=3000
supply=aldo3
axp=axp81x, supply=aldo3, vol=3000
reg addr=0x1f02f00, value=0xa, pmu_vol=3000
config gpio bias voltage finish
vbus exist
normal dc exist, limit to dc
ac100 reg 0x00 = 0x101
ac100 reg 0xd0 = 0x0
ac100 reg 0xd1 = 0x0
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[      1.068]DRAM:  2 GiB
relocation Offset is: 75ae4000
board.c 621
gic: secure os not exist
script config pll_de to 504 Mhz
Not Found clk pll_video1 in script
Not Found clk pll_video in script
Not Found clk pll_periph0 in script
============tv_init==========
DRV_DISP_Init end
[      1.386]fetch script data boot_disp.output_disp fail
[      1.391]fetch script data boot_disp.output_type fail
[      1.396]fetch script data boot_disp.output_mode fail
[      1.401]fetch script data boot_disp.auto_hpd fail
[      1.406]lcd0_para.lcd_used=1
disp0 device type(1) enable
lcd_panel_fun[0].cfg_open_flow is NULL
lcd_panel_fun[0].cfg_panel_info is NULL
disp 0, clk: pll(312000000),clk(312000000),dclk(78000000) dsi_rate(78000000)
     clk real:pll(312000000),clk(0),dclk(0) dsi_rate(78000000)
workmode = 0
MMC:	 2
[      1.540][mmc]: mmc driver ver 2015-12-03 21:17:15
[      1.545][mmc]: get sdc_phy_wipe fail.
[      1.549][mmc]: get sdc0 sdc_erase fail.
[      1.553][mmc]: get sdc_2xmode ok, val = 1
[      1.557][mmc]: get sdc_ddrmode ok, val = 1
[      1.561][mmc]: get sdc_f_max fail,use default  50000000Hz
[      1.567][mmc]: get card_line ok, card_line = 8
[      1.571][mmc]: get sdc_ex_dly_used fail,use default
[      1.577][mmc]: SUNXI SD/MMC: 2
[      1.581][mmc]: mmc_config_clock: clk 400000
[      1.596][mmc]: *Try SD card 2*
[      1.601][mmc]: mmc 2 cmd 8 err 100
[      1.607][mmc]: mmc send if cond failed
[      1.612][mmc]: mmc 2 cmd 55 err 100
[      1.618][mmc]: send app cmd failed
[      1.621][mmc]: *Try MMC card 2*
[      1.660][mmc]: Invalid ext_csd revision 8
[      1.676][mmc]: unrecognised EXT_CSD revision 8
[      1.681][mmc]: decode ext_csd failed
[      1.684][mmc]: mmc_config_clock: clk 25000000
[      1.699][mmc]: mmc re-update_phase
[      1.706][mmc]: mmc re-update_phase
[      1.713][mmc]: mmc re-update_phase
[      1.719][mmc]: ddr8
[      1.723][mmc]: mmc re-update_phase
[      1.730][mmc]: mmc_config_clock: clk 25000000
[      1.740][mmc]: mmc_config_clock: clk 50000000
[      1.746][mmc]: CID 0x90014a48 0x38473461 0x92a110d2 0x802726b9
[      1.751][mmc]: MMC ver 4.0
[      1.754][mmc]: mmc clk 50000000
[      1.757][mmc]: SD/MMC Card: 8bit, capacity: 7456MB
[      1.762][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB
[      1.768][mmc]: ***SD/MMC 2 init OK!!!***
[      1.773][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte
[      1.779][mmc]: secure_feature 0x55
[      1.783][mmc]: secure_removal_type  0x3b
[      1.787]sunxi flash init ok
In:    serial
Out:   serial
Err:   serial
-total partitions:15-
bootloader  : 1000000       2000000
env         : 3000000       1000000
boot        : 4000000       1000000
system      : 5000000       80000000
verity_block: 85000000      2000000
misc        : 87000000      1000000
recovery    : 88000000      2000000
cache       : 8a000000      30000000
metadata    : ba000000      1000000
private     : bb000000      1000000
frp         : bc000000      80000
empty       : bc080000      f80000
alog        : bd000000      5000000
media_data  : c2000000      1000000
UDISK       : c3000000      0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 0
recovery key high 10, low 8
cant find fstbt value
misc partition found
to be run cmd=run setargs_mmc boot_normal
** Unable to use sunxi_flash 9:0 for fatload **
load file(ULI/factory/snum.txt) error
serial is: 100001318804b21f5425
Net:   usb_etherWarning: failed to set MAC address
mount part name bootloader
cant open script.bin, maybe it is not exist
WORK_MODE_BOOT
board_status_probe
sunxi_bmp_logo_display
[      2.049][mmc]: blkcnt should not be 0
[      2.065]fetch script data boot_disp.output_disp fail
[      2.070]screen_id =0, screen_width =800, screen_height =1280
[      2.076]frame buffer address 46400036
read item0 copy0
Item0 (Map) magic is bad
the secure storage item0 copy0 is bad
read item0 copy1
the secure storage item0 copy0 == copy1, the data is good
the secure storage map is empty
no item name key_burned_flag in the map
sunxi secure storage has no flag
[      2.106]usb burn from boot
delay time 0
[      2.177]usb prepare ok
[      2.979]timer occur
[      2.981]overtime
[      3.016]do_burn_from_boot usb : no usb exist
limit to dc
[      3.022]Hit any key to stop autoboot:  0
read boot or recovery all
[      3.201]sunxi flash read :offset 4000000, 14963648 bytes OK
[      3.211]ready to boot
[      3.213][mmc]: mmc exit start
[      3.218][mmc]: mmc_config_clock: clk 50000000
[      3.222][mmc]: mmc_config_clock: clk 400000
[      3.237][mmc]: mmc 2 cmd 8 err 100
[      3.243][mmc]: mmc send if cond failed
[      3.248][mmc]: mmc 2 cmd 55 err 100
[      3.254][mmc]: send app cmd failed
[      3.271][mmc]: get sdc_phy_wipe fail.
[      3.275][mmc]: get sdc0 sdc_erase fail.
[      3.279][mmc]: get sdc_2xmode ok, val = 1
[      3.283][mmc]: get sdc_ddrmode ok, val = 1
[      3.287][mmc]: get sdc_f_max fail,use default  50000000Hz
[      3.293][mmc]: get card_line ok, card_line = 8
[      3.297][mmc]: get sdc_ex_dly_used fail,use default
[      3.302][mmc]: mmc 2 exit ok
[      3.305]
[sun8i_fixup]: From boot, get meminfo:
	Start:	0x40000000
ion_carveout reserve: 96m@0 128m@0
ion_reserve_common: ion reserve: [0xb8000000, 0xc0000000]!
ion_cma reserve: 120m@0 176m@0 512m@0
ion_reserve_common: ion reserve: [0xa0000000, 0xc0000000]!
------sun8i_smp_init_ops----37-----
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.4.39 (pengchj@WorldChip) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #2 SMP PREEMPT Wed May 15 20:10:54 CST 2019
[    0.000000] Machine: sun8i
[    0.000000] Initialized persistent memory from 43084800-430947ff
[    0.000000] cma: CMA: reserved 512 MiB at a0000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 524288
[    0.000000] free_area_init_node: node 0, pgdat c0948e40, node_mem_map c1402000
[    0.000000]   Normal zone: 1404 pages used for memmap
[    0.000000]   Normal zone: 158340 pages, LIFO batch:31
[    0.000000]   HighMem zone: 3204 pages used for memmap
[    0.000000]   HighMem zone: 361340 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] [mcpm_smp_init_cpus] ncores=8
[    0.000000] PERCPU: Embedded 8 pages/cpu @c2627000 s10752 r8192 d13824 u32768
[    0.000000] pcpu-alloc: s10752 r8192 d13824 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 519680
[    0.000000] Kernel command line: boot_type=2 disp_para=100 fb_base=0x46400000 config_size=55900 androidboot.serialno=100001318804b21f5425 androidboot.hardware=sun8i console=ttyS0,115200 root=/dev/mmcblk0p7 init=/init vmalloc=384M ion_cma_list=120m,176m,512m loglevel=8 partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:system@mmcblk0p7:verity_block@mmcblk0p8:misc@mmcblk0p9:recovery@mmcblk0p10:cache@mmcblk0p11:metadata@mmcblk0p12:private@mmcblk0p13:frp@mmcblk0p14:empty@mmcblk0p15:alog@mmcblk0p16:media_data@mmcblk0p17:UDISK@mmcblk0p1 androidboot.selinux=enforcing
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2048MB = 2048MB total
[    0.000000] Memory: 1537904k/1537904k available, 559248k reserved, 933888K highmem
[    0.000000]     vmalloc : 0xe7800000 - 0xff000000   ( 376 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe7000000   ( 624 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08759dc   (8631 kB)
[    0.000000]       .init : 0xc0876000 - 0xc08c7a00   ( 327 kB)
[    0.000000]       .data : 0xc08c8000 - 0xc094b730   ( 526 kB)
[    0.000000]        .bss : 0xc094bd54 - 0xc0ad43d0   (1570 kB)
[    0.000000] NR_IRQS:544
[    0.000255] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000281] pid_max: default: 32768 minimum: 301
[    0.000456] Security Framework initialized
[    0.000480] SELinux:  Initializing.
[    0.000560] SELinux:  Starting in permissive mode
[    0.000647] Mount-cache hash table entries: 512
[    0.001853] Initializing cgroup subsys debug
[    0.001870] Initializing cgroup subsys freezer
[    0.001913] CPU: Testing write buffer coherency: ok
[    0.001981] ftrace: allocating 22803 entries in 67 pages
[    0.030300] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030352] Setting up static identity map for 0x405ebe68 - 0x405ebec0
[    0.031405] CPU1: Booted secondary processor
[    0.031405] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031513] CPU2: Booted secondary processor
[    0.031513] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.031513] CPU3: Booted secondary processor
[    0.031513] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040534] CPU4: failed to boot: -22
[    0.040643] CPU5: failed to boot: -22
[    0.040643] CPU6: failed to boot: -22
[    0.040643] CPU7: failed to boot: -22
[    0.040643] Brought up 4 CPUs
[    0.040643] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.040729] devtmpfs: initialized
[    0.053329] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.053845] pinctrl core: initialized pinctrl subsystem
[    0.074382] NET: Registered protocol family 16
[    0.075551] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.075551] script_sysfs_init success
[    0.075551] sunxi_dump_init success
[    0.075551] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.076591] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.077003] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[    0.078274] persistent_ram: uncorrectable error in header
[    0.078288] persistent_ram: no valid data in buffer (sig = 0xffffffff)
[    0.089411] console [ram-1] enabled
[    0.089813] [sunxi-module]: [sunxi-module.0] probe success
[    0.090390] Not Found clk pll_video1 in script
[    0.090502] script config pll_ve to 432 Mhz
[    0.090684] Not Found clk pll_periph in script
[    0.090788] script config pll_gpu to 432 Mhz
[    0.090893] script config pll_hsic to 480 Mhz
[    0.091079] script config pll_de to 504 Mhz
[    0.091177] sunxi_default_clk_init
[    0.091277] try to set pll6ahb1 to 200000000
[    0.091492] try to set ahb clk source to pll6ahb1
[    0.091593] set ahb clk source to pll6ahb1
[    0.091774] try to set ahb1 to 200000000
[    0.091875] try to set apb1 to 100000000
[    0.092976] ===fe3o4==== sunxi_root_procfs_attach ret:0
[    0.100473] bio: create slab <bio-0> at 0
[    0.100618] [ARISC] :sunxi-arisc driver v1.03
[    0.109946] [ARISC] :arisc version: [v0.1.79]
[    0.110438] sunxi_get_soc_bin: slow chip
[    0.111010] [ARISC] :sunxi-arisc driver v1.03 startup succeeded
[    0.120187] CPU4: Booted secondary processor
[    0.120187] CPU4: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.123496] CPU5: Booted secondary processor
[    0.123496] CPU5: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.130307] CPU6: Booted secondary processor
[    0.130307] CPU6: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.130307] CPU7: Booted secondary processor
[    0.130307] CPU7: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.140349] pwm module init!
[    0.141550] SCSI subsystem initialized
[    0.141550] usbcore: registered new interface driver usbfs
[    0.141550] usbcore: registered new interface driver hub
[    0.141550] usbcore: registered new device driver usb
[    0.141550] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.141550] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.141550] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.141550] twi_chan_cfg()332 - [twi3] has no twi_used!
[    0.141550] twi_chan_cfg()352 - [twi3] has no twi_used!
[    0.141731] Linux video capture interface: v2.00
[    0.190401] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.191256] Bluetooth: Core ver 2.16
[    0.191398] NET: Registered protocol family 31
[    0.191501] Bluetooth: HCI device and connection manager initialized
[    0.191686] Bluetooth: HCI socket layer initialized
[    0.191787] Bluetooth: L2CAP socket layer initialized
[    0.191989] Bluetooth: SCO socket layer initialized
[    0.200283] cfg80211: Calling CRDA to update world regulatory domain
[    0.200701] Switching to clocksource arch_sys_counter
[    0.219369] FS-Cache: Loaded
[    0.219829] CacheFiles: Loaded
[    0.232059] axp81x_dcdc1: Failed to create debugfs directory
[    0.233871] NET: Registered protocol family 2
[    0.234277] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.235385] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.238021] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.239670] TCP: Hash tables configured (established 131072 bind 65536)
[    0.239853] TCP: reno registered
[    0.239957] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.240231] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.240765] NET: Registered protocol family 1
[    0.241238] Unpacking initramfs...
[    0.540627] Freeing initrd memory: 4100K
[    0.543006] [pm]aw_pm_init!
[    0.543194] standby_mode = 0.
[    0.543293] aw_pm_init: not support super standby.
[    0.543394] wakeup src cnt is : 3.
[    0.543580] pmu name: pmu1_para .
[    0.543684] pmu1_enable = 0x1.
[    0.543783] pmux_id = 0x7.
[    0.543885] pmu name: pmu2_para .
[    0.544065] config_pmux_para: script_parser_fetch err.
[    0.544166] pmu2_enable = 0x0.
[    0.544678] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[    0.545015] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[    0.545127] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[    0.545309] after inited: sys_mask config = 0x6bd5.
[    0.545411] dynamic_standby enalbe = 0x0.
[    0.545650] sunxi_reg_init enter
[    0.546188] lock super standby for a83!
[    0.546296] lookup_scene_lock_name: new scene lock super_standby
[    0.546475] scene_lock_init name=super_standby
[    0.546577] scene_lock: super_standby, type 5, count 1
[    0.547360] audit: initializing netlink socket (disabled)
[    0.547512] type=2000 audit(0.540:1): initialized
[    0.548577] highmem bounce pool size: 64 pages
[    0.550354] NTFS driver 2.1.30 [Flags: R/W].
[    0.550663] fuse init (API version 7.18)
[    0.551415] msgmni has been set to 1187
[    0.551553] SELinux:  Registering netfilter hooks
[    0.554220] io scheduler noop registered
[    0.554405] io scheduler deadline registered
[    0.554622] io scheduler cfq registered (default)
[    0.556320] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.556429] sw_uart_pm()890 - uart0 clk is already enable
[    0.556621] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.653350] console [ttyS0] enabled
[    0.752639] axp81x_dcdc1: Failed to create debugfs directory
[    0.851503] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    0.950394] axp81x_dcdc1: Failed to create debugfs directory
[    1.146771] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    1.245475] axp81x_dcdc1: Failed to create debugfs directory
[    1.343928] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[    1.448264] loop: module loaded
[    1.680248] [rf_pm]: select module num is 9
[    1.685101] [rf_pm]: module power1 name vcc-wifi-io
[    1.690674] [rf_pm]: module power1 vol 3300000
[    1.695736] [rf_pm]: module power2 name
[    1.700312] [rf_pm]: failed to fetch module_power2_vol
[    1.706152] [rf_pm]: module power3 name
[    1.710726] [rf_pm]: failed to fetch module_power3_vol
[    1.716565] [rf_pm]: mod has no power_switch gpio
[    1.721935] [rf_pm]: mod has no chip_en gpio
[    1.726882] [rf_pm]: lpo_use_apclk: ac10032k2
[    1.731937] [rf_pm]: get power regulator  failed.
[    1.737371] [rf_pm]: set vcc-wifi-io to 3300000 v
[    1.742817] [rf_pm]: enable vcc-wifi-io.
[    1.747857] [rf_pm]: mod info power switch -1
[    1.753010] [rf_pm]: set ac10032k2 32k out
[    1.757790] scene_lock_init name=rf_pm
[    1.762383] [wifi_pm]: wifi gpio init is OK !!
[    1.767587] [rfkill]: mod has no ls_int gpio
[    1.772483] [rfkill]: mod has no pcm_ch gpio
[    1.778364] axp81x_dcdc1: Failed to create debugfs directory
[    1.785073] spi spi0: master is unqueued, this is deprecated
[    1.791722] tun: Universal TUN/TAP device driver, 1.6
[    1.797462] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.804806] PPP generic driver version 2.4.2
[    1.809854] PPP BSD Compression module registered
[    1.815228] PPP Deflate Compression module registered
[    1.822319] PPP MPPE Compression module registered
[    1.827775] NET: Registered protocol family 24
[    1.832946] PPTP driver version 0.8.5
[    1.837734] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.865248] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.874414] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.884954] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.910040] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.916845] ehci_irq: highspeed device connect
[    1.922032] hub 1-0:1.0: USB hub found
[    1.926408] hub 1-0:1.0: 1 port detected
[    1.931367] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.958557] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.967249] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[    1.975960] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    2.044680] hub 2-0:1.0: USB hub found
[    2.049055] hub 2-0:1.0: 1 port detected
[    2.054129] usbcore: registered new interface driver cdc_acm
[    2.060655] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.069697] Initializing USB Mass Storage driver...
[    2.075436] usbcore: registered new interface driver usb-storage
[    2.082243] USB Mass Storage support registered.
[    2.087621] usbcore: registered new interface driver ums-alauda
[    2.094394] usbcore: registered new interface driver ums-cypress
[    2.101350] usbcore: registered new interface driver ums-datafab
[    2.108210] usbcore: registered new interface driver ums_eneub6250
[    2.115358] usbcore: registered new interface driver ums-freecom
[    2.122209] usbcore: registered new interface driver ums-isd200
[    2.129043] usbcore: registered new interface driver ums-jumpshot
[    2.136041] usbcore: registered new interface driver ums-karma
[    2.142807] usbcore: registered new interface driver ums-onetouch
[    2.149772] usbcore: registered new interface driver ums-realtek
[    2.156765] usbcore: registered new interface driver ums-sddr09
[    2.163523] usbcore: registered new interface driver ums-sddr55
[    2.170360] usbcore: registered new interface driver ums-usbat
[    2.177188] usbcore: registered new interface driver usbserial
[    2.183830] usbserial: USB Serial Driver core
[    2.188853] usbcore: registered new interface driver option
[    2.195284] USB Serial support registered for GSM modem (1-port)
[    2.250065] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[    2.402636] hub 1-1:1.0: USB hub found
[    2.407239] hub 1-1:1.0: 4 ports detected
[    2.414801] file system registered
[    2.420643] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.428512] android_usb gadget: Number of LUNs=3
[    2.433787]  lun0: LUN: removable file: (no medium)
[    2.439335]  lun1: LUN: removable file: (no medium)
[    2.444983]  lun2: LUN: removable file: (no medium)
[    2.450939] get usb_serial_number success from boot command line
[    2.457648] android_usb gadget: android_usb ready
[    2.463787] axp81x_dcdc1: Failed to create debugfs directory
[    2.470350] sunxi_hcd_host0 sunxi_hcd_host0: sunxi_hcd host driver
[    2.477364] sunxi_hcd_host0 sunxi_hcd_host0: new USB bus registered, assigned bus number 3
[    2.487515] hub 3-0:1.0: USB hub found
[    2.491837] hub 3-0:1.0: 1 port detected
[    2.497411] mousedev: PS/2 mouse device common for all mice
[    2.504046] sunxikbd_script_init: key para not found, used default para.
[    2.512507] sunxi_rtc_init(836): sunxi rtc device register!
[    2.519710] rtc_gettime(340): read time 1970-1-1 1:0:7
[    2.525988] alarm_gettime(477): get alarm time 1970-1-1 1:0:0 success!
[    2.533852] rtc_gettime(340): read time 1970-1-1 1:0:7
[    2.540045] rtc0 rtc0: rtc core: registered rtc0 as rtc0
[    2.546285] sunxi_rtc_probe(775)!
[    2.550233] i2c /dev entries driver
[    2.554904] IR RC5(x) protocol handler initialized
[    2.560500] sunxi cedar version 0.1
[    2.564732] [cedar]: install start!!!
[    2.569156] [cedar]: install end!!!
[    2.579279] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    2.589225] Bluetooth: HCI UART driver ver 2.2
[    2.594374] Bluetooth: HCI H4 protocol initialized
[    2.599901] Bluetooth: HCI Realtek H5 protocol initialized
[    2.606627] sunxi_get_soc_bin: slow chip
[    2.613877] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.116 2015-7-11 11:55) Compiled in May 15 2019 at 20:10:11
[    2.625361] [mmc]: get mmc2's 2xmode ok, val = 1
[    2.630550] [mmc]: get mmc2's ddrmode ok, val = 1
[    2.635828] [mmc]: MMC host used card: 0x4, boot card: 0x4, io_card 0
[    2.643969] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.654927] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.656647] usbcore: registered new interface driver usbhid
[    2.656652] usbhid: USB HID core driver
[    2.656658] zram: num_devices not specified. Using default: 1
[    2.656663] zram: Creating 1 devices ...
[    2.686721] ashmem: initialized
[    2.690418] logger: created 256K log 'log_main'
[    2.695676] logger: created 256K log 'log_events'
[    2.700031] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.711304] logger: created 256K log 'log_radio'
[    2.716579] logger: created 256K log 'log_system'
[    2.720835] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    2.721664] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    2.721683] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.724144] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.726033] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 8,  RTO !!
[    2.726050] *******************Try sdio*******************
[    2.726863] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.727686] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.728508] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.729331] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.729347] *******************Try sd *******************
[    2.730161] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.730988] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.731816] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.732641] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.732662] *******************Try mmc*******************
[    2.732670] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.733074] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.733157] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.733239] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.735697] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.771212] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.783205] mmc0: unrecognised EXT_CSD revision 8
[    2.783217] mmc0: error -22 whilst initialising MMC card
[    2.783224] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.785937] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.800030] [mmc]: sdc2 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.821102] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    2.822195] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    2.822214] [mmc]: sdc2 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.824802] [mmc]: sdc2 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.826973] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 8,  RTO !!
[    2.826990] *******************Try sdio*******************
[    2.828073] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.829167] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.830260] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.831353] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.831370] *******************Try sd *******************
[    2.832450] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.833543] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.834637] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.835730] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.835746] *******************Try mmc*******************
[    2.835754] [mmc]: sdc2 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.836264] [mmc]: sdc2 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.836359] [mmc]: sdc2 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.836453] [mmc]: sdc2 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.839042] [mmc]: sdc2 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.846036] gpio_switch_init(749): sunxi switch driver register!
[    2.901581] [mmc]: sdc2 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.917348] mmc0: unrecognised EXT_CSD revision 8
[    2.917355] mmc0: error -22 whilst initialising MMC card
[    2.917362] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.920068] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.940022] [mmc]: sdc2 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.944072] i2c-core: driver [ts3a225] using legacy suspend method
[    2.961639] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    2.963268] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    2.963287] [mmc]: sdc2 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.966141] [mmc]: sdc2 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.968875] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 8,  RTO !!
[    2.968891] *******************Try sdio*******************
[    2.970510] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.972140] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.973770] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.975400] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    2.975416] *******************Try sd *******************
[    2.977035] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.978665] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.980295] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.981925] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    2.981941] *******************Try mmc*******************
[    2.981948] [mmc]: sdc2 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.982682] [mmc]: sdc2 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.982803] [mmc]: sdc2 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.982919] [mmc]: sdc2 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.985774] [mmc]: sdc2 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.022333] [mmc]: sdc2 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.041896] i2c-core: driver [ts3a225] using legacy resume method
[    3.045669] mmc0: unrecognised EXT_CSD revision 8
[    3.045676] mmc0: error -22 whilst initialising MMC card
[    3.045682] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.048374] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.070024] [mmc]: sdc2 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.092179] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    3.094339] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 52,  RTO !!
[    3.094357] [mmc]: sdc2 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.097476] [mmc]: sdc2 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.100773] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 8,  RTO !!
[    3.100791] *******************Try sdio*******************
[    3.102947] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    3.105107] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    3.107267] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    3.109427] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 5,  RTO !!
[    3.109443] *******************Try sd *******************
[    3.111600] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    3.113760] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    3.115920] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    3.118080] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 2 err, cmd 55,  RTO !!
[    3.118097] *******************Try mmc*******************
[    3.118104] [mmc]: sdc2 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.119065] [mmc]: sdc2 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.119209] [mmc]: sdc2 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.119350] [mmc]: sdc2 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.122466] [mmc]: sdc2 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.163072] [mmc]: sdc2 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.193967] mmc0: unrecognised EXT_CSD revision 8
[    3.193973] mmc0: error -22 whilst initialising MMC card
[    3.193980] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.238945] sunxi_i2c_do_xfer()985 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x3b)
[    3.659082] i2c_read_interface error1
[    3.663254] sunxi_i2c_do_xfer()985 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x3b)
[    3.672565] i2c_read_interface error1
[    3.672582] gpio_switch_probe,line:539,val:0
[    3.672932] sunxi_oops: heming add OOPS_INFO_ADDR = -20
[    3.673253] usbcore: registered new interface driver snd-usb-audio
[    3.694588] sunxi_i2c_do_xfer()985 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x3b)
[    3.703903] i2c_write_interface error
[    3.720366] asoc: ac100-aif1 <-> pri_dai mapping ok
[    3.726128] asoc: ac100-aif2 <-> bb-voice-dai mapping ok
[    3.736025] asoc: ac100-aif1 <-> sec_dai mapping ok
[    3.741805] asoc: ac100-aif3 <-> bb-voice-dai mapping ok
[    3.747970] asoc: ac100-aif2 <-> bb-voice-dai mapping ok
[    3.761465] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    3.768517] u32 classifier
[    3.771659]     Actions configured
[    3.775495] Netfilter messages via NETLINK v0.30.
[    3.780865] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.788211] ctnetlink v0.93: registering with nfnetlink.
[    3.794245] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.802106] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.809022] xt_time: kernel timezone is -0000
[    3.814056] sunxi_i2c_do_xfer()985 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x3b)
[    3.814128] IPv4 over IPv4 tunneling driver
[    3.814530] gre: GRE over IPv4 demultiplexor driver
[    3.814536] ip_gre: GRE over IPv4 tunneling driver
[    3.815132] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.815328] arp_tables: (C) 2002 David S. Miller
[    3.815389] TCP: cubic registered
[    3.815393] Initializing XFRM netlink socket
[    3.858655] i2c_read_interface error1
[    3.862851] [switch] ti3s225 initial the wrong state,238.
[    3.869048] NET: Registered protocol family 10
[    3.874082] sunxi_i2c_do_xfer()985 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x3b)
[    3.883418] i2c_write_interface error
[    3.888078] Mobile IPv6
[    3.890895] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.897122] IPv6 over IPv4 tunneling driver
[    3.902755] NET: Registered protocol family 17
[    3.907764] NET: Registered protocol family 15
[    3.912971] Bluetooth: RFCOMM TTY layer initialized
[    3.918506] Bluetooth: RFCOMM socket layer initialized
[    3.924313] Bluetooth: RFCOMM ver 1.11
[    3.928597] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.934578] Bluetooth: BNEP filters: protocol multicast
[    3.940443] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.947554] ThumbEE CPU extension supported.
[    3.952396] Registering SWP/SWPB emulation handler
[    3.959537] rtc_gettime(340): read time 1970-1-1 1:0:8
[    3.965359] rtc0 rtc0: setting system clock to 1970-01-01 01:00:08 UTC (3608)
[    3.974309] sunxi_get_soc_bin: slow chip
[    3.979194] CPU Budget:Register notifier
[    3.983733] CPU Budget:register Success
[    3.988051] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    4.002349] =========GPS========= :gsp not used in configuration
[    4.009075] ALSA device list:
[    4.012458]   #0: sndac100
[    4.015580]   #1: sndhdmi
[    4.019192] Freeing init memory: 324K
[    4.025712] init: init started!
[    4.033712] SELinux: 2048 avtab hash slots, 5054 rules.
[    4.039692] SELinux:  Android master kernel running Android M policy in compatibility mode.
[    4.051236] SELinux: 2048 avtab hash slots, 5054 rules.
[    4.057144] SELinux:  1 users, 2 roles, 540 types, 0 bools, 1 sens, 1024 cats
[    4.065366] SELinux:  87 classes, 5054 rules
[    4.072126] SELinux:  Completing initialization.
[    4.077391] SELinux:  Setting up existing superblocks.
[    4.083228] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    4.091339] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[    4.099627] SELinux: initialized (dev bdev, type bdev), not configured for labeling
[    4.108325] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[    4.116220] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    4.124359] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[    4.133631] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[    4.155613] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[    4.163418] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[    4.171235] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
[    4.181466] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[    4.189807] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[    4.198740] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    4.206932] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    4.210051] switch_status_update,line:179,switch_data->state:0
[    4.390034] switch_status_update,line:179,switch_data->state:0
[    4.417050] type=1403 audit(3608.940:2): policy loaded auid=4294967295 ses=4294967295
[    4.426434] type=1404 audit(3608.960:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[    4.650232] init: (Initializing SELinux enforcing took 0.62s.)
[    4.663640] init: init second stage started!
[    4.709919] init: waitpid failed: No child processes
[    4.715925] init: (Loading properties from /default.prop took 0.00s.)
[    4.725312] init: (Parsing /init.environ.rc took 0.00s.)
[    4.731582] init: (Parsing /init.usb.rc took 0.00s.)
[    4.737966] init: (Parsing init.sensors.rc took 0.00s.)
[    4.743924] init: (Parsing init.common.rc took 0.01s.)
[    4.749849] init: (Parsing init.sun8i.common.rc took 0.00s.)
[    4.756435] init: (Parsing init.sun8i.usb.rc took 0.00s.)
[    4.762574] init: (Parsing /init.sun8i.rc took 0.03s.)
[    4.768727] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[    4.775288] init: (Parsing /init.zygote32.rc took 0.00s.)
[    4.781544] init: (Parsing /init.trace.rc took 0.00s.)
[    4.787329] init: (Parsing /init.rc took 0.06s.)
[    4.792772] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    4.803510] init: Starting service 'ueventd'...
[    4.809294] init: Waiting for /dev/.coldboot_done...
[    4.811911] ueventd: ueventd started!
[    5.384952] ueventd: Coldboot took 0.57s.
[    5.393428] init: Waiting for /dev/.coldboot_done took 0.58s.
[    5.399984] init: /dev/hw_random not found
[    5.405846] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    5.415432] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    5.426478] init: write_file: Unable to open '/proc/sys/kernel/hung_task_timeout_secs': No such file or directory
[    5.438165] init: write_file: Unable to open '/proc/sys/kernel/sched_tunable_scaling': No such file or directory
[    5.449653] init: write_file: Unable to open '/proc/sys/kernel/sched_latency_ns': No such file or directory
[    5.460674] init: write_file: Unable to open '/proc/sys/kernel/sched_wakeup_granularity_ns': No such file or directory
[    5.472735] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[    5.590183] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    5.598602] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[    5.610666] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[    5.620906] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    5.629340] init: /dev/hw_random not found
[    5.659757] [NAND]nand init start, nand0_used_flag is 0
[    5.665720] [NAND]nand driver is disabled
[   25.001496] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   25.010824] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: barrier=1 error: No such file or directory
[   45.001140] fs_mgr: check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=-1: No such file or directory
[   45.011972] fs_mgr: Not running /system/bin/e2fsck on /dev/block/by-name/cache (executable not in system image)
[   45.023444] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=-1
[   45.032470] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/cache at /cache options: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic error: No such file or directory
[   65.008100] fs_mgr: check_fs(): mount(/dev/block/by-name/alog,/logger,ext4)=-1: No such file or directory
[   65.018939] fs_mgr: Not running /system/bin/e2fsck on /dev/block/by-name/alog (executable not in system image)
[   65.030295] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=-1
[   65.039311] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/alog at /logger options: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic error: No such file or directory
[   85.004897] fs_mgr: check_fs(): mount(/dev/block/by-name/UDISK,/data,ext4)=-1: No such file or directory
[   85.015631] fs_mgr: Not running /system/bin/e2fsck on /dev/block/by-name/UDISK (executable not in system image)
[   85.027088] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=-1
[   85.036077] fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/UDISK for mount /data type ext4 )
[   85.048770] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   85.056962] init: fs_mgr_mount_all returned an error
[   85.062980] init: fs_mgr_mount_all returned unexpected error 255
[   85.072680] Unable to find swap-space signature
[   85.077924] fs_mgr: swapon failed for /dev/block/zram0
[   90.090902] init: can't not open file!
[   91.095245] init: can't not open file!
[   92.099626] init: can't not open file!
[   93.104035] init: can't not open file!
[   94.108358] init: can't not open file!
[END] 2019/5/16 9:55:50
上面的不正常的?再贴一份正常的上来吧, 用 code 标签.
楼主 #5 2019-05-16 19:20:24
MrJacky
Re: 全志A83T无法进系统问题
þHELLO! BOOT0 is starting!
boot0 commit : ba81bb80fe217e401fc0bee185e0a53ba1a17e7d
PMU: AXP81X
using ic A83T
using axp AXP813
DRAM CLK =648 MHZ
dram size =2048
card no is 2
[mmc]: 8bit ddr!!!
[mmc]: MMC ver 4.0
sdcard 2 init ok
The size of uboot is 000ec000.
sum=77d64102
src_sum=77d64102
[      0.291]MODE
U-Boot 2011.09-rc1-00000-gba81bb8-dirty (Mar 21 2019 - 17:36:40) Allwinner Technology
[      0.300]version: 2.1.0
[      0.303]uboot commit : ba81bb80fe217e401fc0bee185e0a53ba1a17e7d
normal mode
[      0.329]pmbus:   normal or secure os
ready
[      0.333]PMU: AXP81X
[      0.336]PMU: AXP81X found
[      0.341]PMU: dcdc2 900
[      0.343]PMU: pll1 1008 Mhz
supply=dcdc1
supply=dcdc1
supply=aldo1
supply=dcdc1
supply=dcdc1
supply=dcdc1
supply=dcdc1
supply=aldo3
vbus exist
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[      1.070]DRAM:  2 GiB
relocation Offset is: 75adf000
board.c 621
DRV_DISP_Init end
[      1.389]fetch script data boot_disp.output_disp fail
[      1.394]fetch script data boot_disp.output_type fail
[      1.399]fetch script data boot_disp.output_mode fail
[      1.404]fetch script data boot_disp.auto_hpd fail
[      1.409]lcd0_para.lcd_used=1
enable power vcc-mipi, ret=0
enable power vcc-dsi, ret=0
enable power vcc-pd, ret=0
workmode = 0
MMC:	 2
[      1.575][mmc]: mmc driver ver 2016-03-24 19:30:15
[      1.580][mmc]: get sdc_phy_wipe fail.
[      1.584][mmc]: get sdc0 sdc_erase fail.
[      1.588][mmc]: get sdc_2xmode ok, val = 1
[      1.592][mlcd model name D9366
use old lcd!!!
[      1.737][mmc]: get sdc_f_max fail,use default  50000000Hz
[      1.743][mmc]: get card_line ok, card_line = 8
[      1.747][mmc]: get sdc_ex_dly_used fail,use default
[      1.752][mmc]: SUNXI SD/MMC: 2
[      1.757][mmc]: mmc_config_clock: clk 400000
[      1.772][mmc]: *Try SD card 2*
[      1.777][mmc]: mmc 2 cmd 8 err 100
[      1.783][mmc]: mmc send if cond failed
[      1.788][mmc]: mmc 2 cmd 55 err 100
[      1.794][mmc]: send app cmd failed
[      1.797][mmc]: *Try MMC card 2*
[      1.849][mmc]: mmc_config_clock: clk 25000000
[      1.864][mmc]: mmc re-update_phase
[      1.871][mmc]: mmc re-update_phase
[      1.878][mmc]: mmc re-update_phase
[      1.884][mmc]: ddr8
[      1.888][mmc]: mmc re-update_phase
[      1.895][mmc]: mmc_config_clock: clk 25000000
[      1.905][mmc]: mmc_config_clock: clk 50000000
[      1.911][mmc]: CID 0x90014a48 0x38473461 0x92a110d2 0x802726b9
[      1.916][mmc]: MMC v5.1
[      1.919][mmc]: mmc clk 50000000
[      1.922][mmc]: SD/MMC Card: 8bit, capacity: 7456MB
[      1.927][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB
[      1.933][mmc]: ***SD/MMC 2 init OK!!!***
[      1.938][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte
[      1.944][mmc]: secure_feature 0x55
[      1.947][mmc]: secure_removal_type  0x3b
[      1.951]sunxi flash init ok
In:    serial
Out:   serial
Err:   serial
UDISK       : c3000000      0
key 0
WORK_MODE_BOOT
board_status_probe
[      2.144][mmc]: blkcnt should not be 0
[      2.152]fetch script data boot_disp.output_disp fail
[      2.157]screen_id =0, screen_width =800, screen_height =1280
[      2.163]frame buffer address 46400036
read item0 copy0
read item0 copy1
[      2.193]usb burn from boot
delay time 0
[      2.264]usb prepare ok
[      3.066]timer occur
[      3.068]overtime
[      3.103]do_burn_from_boot usb : no usb exist
limit to dc
[      3.109]Hit any key to stop autoboot:  0
[      3.289]sunxi flash read :offset 4000000, 15023696 bytes OK
[      3.299]ready to boot
[      3.301][mmc]: mmc exit start
[      3.305][mmc]: mmc_config_clock: clk 50000000
[      3.310][mmc]: mmc_config_clock: clk 400000
[      3.325][mmc]: mmc 2 cmd 8 err 100
[      3.331][mmc]: mmc send if cond failed
[      3.336][mmc]: mmc 2 cmd 55 err 100
[      3.342][mmc]: send app cmd failed
[      3.359][mmc]: get sdc_phy_wipe fail.
[      3.363][mmc]: get sdc0 sdc_erase fail.
[      3.367][mmc]: get sdc_2xmode ok, val = 1
[      3.371][mmc]: get sdc_ddrmode ok, val = 1
[      3.375][mmc]: get sdc_f_max fail,use default  50000000Hz
[      3.381][mmc]: get card_line ok, card_line = 8
[      3.385][mmc]: get sdc_ex_dly_used fail,use default
[      3.390][mmc]: mmc 2 exit ok
[      3.393]
	Start:	0x40000000
[    0.000000] Linux version 3.4.39 (guozh@WorldChip) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #31 SMP PREEMPT Thu Apr 11 10:30:31 CST 2019
[    0.000000] free_area_init_node: node 0, pgdat c094fa00, node_mem_map c140a000
[    0.000000] PERCPU: Embedded 8 pages/cpu @c262f000 s10752 r8192 d13824 u32768
[    0.000000] Memory: 1537844k/1537844k available, 559308k reserved, 933888K highmem
[    0.000000]       .text : 0xc0008000 - 0xc087ad74   (8652 kB)
[    0.000000]       .init : 0xc087b000 - 0xc08cda00   ( 331 kB)
[    0.000000]       .data : 0xc08ce000 - 0xc09522f0   ( 529 kB)
[    0.000000]        .bss : 0xc0952914 - 0xc0adb010   (1570 kB)
[    0.000250] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000275] pid_max: default: 32768 minimum: 301
[    0.000450] Security Framework initialized
[    0.000474] SELinux:  Initializing.
[    0.000555] SELinux:  Starting in permissive mode
[    0.000641] Mount-cache hash table entries: 512
[    0.001843] Initializing cgroup subsys debug
[    0.001861] Initializing cgroup subsys freezer
[    0.001904] CPU: Testing write buffer coherency: ok
[    0.001975] ftrace: allocating 22841 entries in 67 pages
[    0.030306] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030358] Setting up static identity map for 0x405ee980 - 0x405ee9d8
[    0.031416] CPU1: Booted secondary processor
[    0.031416] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031529] CPU2: Booted secondary processor
[    0.031529] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.031529] CPU3: Booted secondary processor
[    0.031529] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040540] CPU4: failed to boot: -22
[    0.040650] CPU5: failed to boot: -22
[    0.040650] CPU6: failed to boot: -22
[    0.040650] CPU7: failed to boot: -22
[    0.040650] Brought up 4 CPUs
[    0.040650] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.040733] devtmpfs: initialized
[    0.053523] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.054036] pinctrl core: initialized pinctrl subsystem
[    0.074777] NET: Registered protocol family 16
[    0.075956] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.075956] script_sysfs_init success
[    0.075956] sunxi_dump_init success
[    0.075956] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.076215] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.076622] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[    0.077902] persistent_ram: uncorrectable error in header
[    0.077916] persistent_ram: no valid data in buffer (sig = 0xffffffff)
[    0.089486] console [ram-1] enabled
[    0.089896] [sunxi-module]: [sunxi-module.0] probe success
[    0.090411] Not Found clk pll_video1 in script
[    0.090525] script config pll_ve to 432 Mhz
[    0.090707] Not Found clk pll_periph in script
[    0.090811] script config pll_gpu to 432 Mhz
[    0.090916] script config pll_hsic to 480 Mhz
[    0.091101] script config pll_de to 504 Mhz
[    0.091200] sunxi_default_clk_init
[    0.091299] try to set pll6ahb1 to 200000000
[    0.091514] try to set ahb clk source to pll6ahb1
[    0.091614] set ahb clk source to pll6ahb1
[    0.091716] try to set ahb1 to 200000000
[    0.091820] try to set apb1 to 100000000
[    0.092933] ===fe3o4==== sunxi_root_procfs_attach ret:0
[    0.100600] bio: create slab <bio-0> at 0
[    0.110115] [ARISC] :arisc version: [v0.1.79]
[    0.110721] sunxi_get_soc_bin: slow chip
[    0.111294] [ARISC] :sunxi-arisc driver v1.03 startup succeeded
[    0.120189] CPU4: Booted secondary processor
[    0.120189] CPU4: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.130050] CPU5: Booted secondary processor
[    0.130050] CPU5: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.130306] CPU6: Booted secondary processor
[    0.130306] CPU6: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.140046] CPU7: Booted secondary processor
[    0.140046] CPU7: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.140346] pwm module init!
[    0.141593] SCSI subsystem initialized
[    0.141593] usbcore: registered new interface driver usbfs
[    0.141593] usbcore: registered new interface driver hub
[    0.141593] usbcore: registered new device driver usb
[    0.141593] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.141593] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.141593] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.141593] twi_chan_cfg()332 - [twi3] has no twi_used!
[    0.141593] twi_chan_cfg()352 - [twi3] has no twi_used!
[    0.142344] Linux video capture interface: v2.00
[    0.190405] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.191171] Bluetooth: Core ver 2.16
[    0.191312] NET: Registered protocol family 31
[    0.191413] Bluetooth: HCI device and connection manager initialized
[    0.191600] Bluetooth: HCI socket layer initialized
[    0.191703] Bluetooth: L2CAP socket layer initialized
[    0.191904] Bluetooth: SCO socket layer initialized
[    0.200245] cfg80211: Calling CRDA to update world regulatory domain
[    0.200669] Switching to clocksource arch_sys_counter
[    0.219499] FS-Cache: Loaded
[    0.219964] CacheFiles: Loaded
[    0.232255] axp81x_dcdc1: Failed to create debugfs directory
[    0.234059] NET: Registered protocol family 2
[    0.234477] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.235593] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.238227] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.239878] TCP: Hash tables configured (established 131072 bind 65536)
[    0.240116] TCP: reno registered
[    0.240224] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.240446] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.240976] NET: Registered protocol family 1
[    0.241446] Unpacking initramfs...
[    0.544879] Freeing initrd memory: 4132K
[    0.547309] [pm]aw_pm_init!
[    0.547498] standby_mode = 0.
[    0.547599] aw_pm_init: not support super standby.
[    0.547700] wakeup src cnt is : 3.
[    0.547886] pmu name: pmu1_para .
[    0.547991] pmu1_enable = 0x1.
[    0.548091] pmux_id = 0x7.
[    0.548192] pmu name: pmu2_para .
[    0.548372] config_pmux_para: script_parser_fetch err.
[    0.548473] pmu2_enable = 0x0.
[    0.548988] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[    0.549323] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[    0.549435] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson.
[    0.549618] after inited: sys_mask config = 0x6bd5.
[    0.549720] dynamic_standby enalbe = 0x0.
[    0.549952] sunxi_reg_init enter
[    0.550520] lock super standby for a83!
[    0.550628] lookup_scene_lock_name: new scene lock super_standby
[    0.550809] scene_lock_init name=super_standby
[    0.550912] scene_lock: super_standby, type 5, count 1
[    0.551705] audit: initializing netlink socket (disabled)
[    0.551872] type=2000 audit(0.550:1): initialized
[    0.552920] highmem bounce pool size: 64 pages
[    0.554629] NTFS driver 2.1.30 [Flags: R/W].
[    0.554939] fuse init (API version 7.18)
[    0.555687] msgmni has been set to 1187
[    0.555826] SELinux:  Registering netfilter hooks
[    0.558502] io scheduler noop registered
[    0.558689] io scheduler deadline registered
[    0.558906] io scheduler cfq registered (default)
[    0.560692] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.560800] sw_uart_pm()890 - uart0 clk is already enable
[    0.560993] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.755570] console [ttyS0] enabled
[    0.854203] axp81x_dcdc1: Failed to create debugfs directory
[    0.952851] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    1.051579] axp81x_dcdc1: Failed to create debugfs directory
[    1.248158] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    1.346881] axp81x_dcdc1: Failed to create debugfs directory
[    1.666302] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[    1.679091] loop: module loaded
[    1.683030] [rf_pm]: select module num is 9
[    1.687884] [rf_pm]: module power1 name vcc-wifi-io
[    1.693459] [rf_pm]: module power1 vol 3300000
[    1.698602] [rf_pm]: module power2 name
[    1.703099] [rf_pm]: failed to fetch module_power2_vol
[    1.708941] [rf_pm]: module power3 name
[    1.713517] [rf_pm]: failed to fetch module_power3_vol
[    1.719357] [rf_pm]: mod has no power_switch gpio
[    1.724809] [rf_pm]: mod has no chip_en gpio
[    1.729677] [rf_pm]: lpo_use_apclk: ac10032k2
[    1.734739] [rf_pm]: get power regulator  failed.
[    1.740195] [rf_pm]: set vcc-wifi-io to 3300000 v
[    1.745618] [rf_pm]: enable vcc-wifi-io.
[    1.750764] [rf_pm]: mod info power switch -1
[    1.755805] [rf_pm]: set ac10032k2 32k out
[    1.760612] scene_lock_init name=rf_pm
[    1.765272] [wifi_pm]: wifi gpio init is OK !!
[    1.770431] [rfkill]: mod has no ls_int gpio
[    1.775299] [rfkill]: mod has no pcm_ch gpio
[    1.781210] axp81x_dcdc1: Failed to create debugfs directory
[    1.787890] spi spi0: master is unqueued, this is deprecated
[    1.794529] tun: Universal TUN/TAP device driver, 1.6
[    1.800291] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.807633] PPP generic driver version 2.4.2
[    1.812720] PPP BSD Compression module registered
[    1.818150] PPP Deflate Compression module registered
[    1.825023] PPP MPPE Compression module registered
[    1.830506] NET: Registered protocol family 24
[    1.835652] PPTP driver version 0.8.5
[    1.840480] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.868074] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.877162] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.887715] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.910061] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.916786] ehci_irq: highspeed device connect
[    1.921974] hub 1-0:1.0: USB hub found
[    1.926346] hub 1-0:1.0: 1 port detected
[    1.931321] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.958503] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.967198] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[    1.975889] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    2.044692] hub 2-0:1.0: USB hub found
[    2.048995] hub 2-0:1.0: 1 port detected
[    2.054078] usbcore: registered new interface driver cdc_acm
[    2.060606] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.069650] Initializing USB Mass Storage driver...
[    2.075399] usbcore: registered new interface driver usb-storage
[    2.082232] USB Mass Storage support registered.
[    2.087610] usbcore: registered new interface driver ums-alauda
[    2.094386] usbcore: registered new interface driver ums-cypress
[    2.101339] usbcore: registered new interface driver ums-datafab
[    2.108197] usbcore: registered new interface driver ums_eneub6250
[    2.115325] usbcore: registered new interface driver ums-freecom
[    2.122179] usbcore: registered new interface driver ums-isd200
[    2.129013] usbcore: registered new interface driver ums-jumpshot
[    2.136120] usbcore: registered new interface driver ums-karma
[    2.142809] usbcore: registered new interface driver ums-onetouch
[    2.149862] usbcore: registered new interface driver ums-realtek
[    2.156752] usbcore: registered new interface driver ums-sddr09
[    2.163614] usbcore: registered new interface driver ums-sddr55
[    2.170400] usbcore: registered new interface driver ums-usbat
[    2.177229] usbcore: registered new interface driver usbserial
[    2.183852] usbserial: USB Serial Driver core
[    2.188942] usbcore: registered new interface driver option
[    2.195287] USB Serial support registered for GSM modem (1-port)
[    2.402604] hub 1-1:1.0: USB hub found
[    2.407327] hub 1-1:1.0: 4 ports detected
[    2.414769] file system registered
[    2.420654] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.428524] android_usb gadget: Number of LUNs=3
[    2.433802]  lun0: LUN: removable file: (no medium)
[    2.439432]  lun1: LUN: removable file: (no medium)
[    2.445002]  lun2: LUN: removable file: (no medium)
[    2.450951] get usb_serial_number success from boot command line
[    2.457583] android_usb gadget: android_usb ready
[    2.463725] axp81x_dcdc1: Failed to create debugfs directory
[    2.470298] sunxi_hcd_host0 sunxi_hcd_host0: sunxi_hcd host driver
[    2.477313] sunxi_hcd_host0 sunxi_hcd_host0: new USB bus registered, assigned bus number 3
[    2.487463] hub 3-0:1.0: USB hub found
[    2.491864] hub 3-0:1.0: 1 port detected
[    2.497381] mousedev: PS/2 mouse device common for all mice
[    2.504025] sunxikbd_script_init: key para not found, used default para.
[    2.512475] sunxi_rtc_init(836): sunxi rtc device register!
[    2.519680] rtc_gettime(340): read time 1970-1-1 1:0:7
[    2.525961] alarm_gettime(477): get alarm time 1970-1-1 1:0:0 success!
[    2.533905] rtc_gettime(340): read time 1970-1-1 1:0:7
[    2.539998] rtc0 rtc0: rtc core: registered rtc0 as rtc0
[    2.546254] sunxi_rtc_probe(775)!
[    2.550199] pcf8563_init:
[    2.553279] rtc_detect,line:260
[    2.556877] rtc_detect,line:260
[    2.560490] rtc_detect: Detected chip pcf8563 at adapter 2, address 0x51
[    2.568175] get rtc_irq gpio failed
[    2.572186] pcf8563 2-0051: chip found, driver version 0.4.3
[    2.580530] pcf8563_get_datetime : [110]-[-1]-[0]-[1]-[53]-[35]
[    2.587249] pcf8563 2-0051: retrieved date/time is not valid.
[    2.596681] pcf8563_read_alarm: alm_tm is secs=0, mins=8, hours=0,mday=0, mon=-1, year=110, wday=0
[    2.608599] pcf8563_get_datetime : [110]-[-1]-[0]-[1]-[53]-[35]
[    2.615337] pcf8563 2-0051: retrieved date/time is not valid.
[    2.623657] pcf8563_get_datetime : [110]-[-1]-[0]-[1]-[53]-[35]
[    2.630394] pcf8563 2-0051: retrieved date/time is not valid.
[    2.637240] pcf8563 2-0051: rtc core: registered pcf8563 as rtc1
[    2.649140] ===fe3o4===pcf8563_probe:1132
[    2.653829] i2c /dev entries driver
[    2.658516] IR RC5(x) protocol handler initialized
[    2.664130] sunxi cedar version 0.1
[    2.668373] [cedar]: install start!!!
[    2.672833] [cedar]: install end!!!
[    2.683020] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    2.692945] Bluetooth: HCI UART driver ver 2.2
[    2.698009] Bluetooth: HCI H4 protocol initialized
[    2.703544] Bluetooth: HCI Realtek H5 protocol initialized
[    2.710315] sunxi_get_soc_bin: slow chip
[    2.717544] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.122 2016-09-21 09:48) Compiled in Apr 11 2019 at 10:29:43
[    2.729196] [mmc]: get mmc1's sdc_power is null!
[    2.734401] [mmc]: get mmc2's 2xmode ok, val = 1
[    2.739578] [mmc]: get mmc2's ddrmode ok, val = 1
[    2.744921] [mmc]: MMC host used card: 0x7, boot card: 0x4, io_card 2
[    2.753160] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.764125] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.774261] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.787378] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.790036] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.810850] [mmc]: *** sunxi_mci_dump_errinfo(L914):
[    2.811846] usbcore: registered new interface driver usbhid
[    2.811853] usbhid: USB HID core driver
[    2.811861] zram: num_devices not specified. Using default: 1
[    2.811867] zram: Creating 1 devices ...
[    2.838143] smc 2 err, cmd 52,  RTO !!
[    2.842914] ashmem: initialized
[    2.843211] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 52,  RTO !!
[    2.843241] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.845726] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.847628] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 8,  RTO !!
[    2.847645] *******************Try sdio*******************
[    2.848470] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 5,  RTO !!
[    2.848488] mmc0: req failed (CMD5): -110, retrying...
[    2.849312] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 5,  RTO !!
[    2.849329] mmc0: req failed (CMD5): -110, retrying...
[    2.850155] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 5,  RTO !!
[    2.850173] mmc0: req failed (CMD5): -110, retrying...
[    2.850997] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 5,  RTO !!
[    2.851014] *******************Try sd *******************
[    2.851842] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 55,  RTO !!
[    2.852680] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 55,  RTO !!
[    2.853517] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 55,  RTO !!
[    2.854355] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 2 err, cmd 55,  RTO !!
[    2.854372] *******************Try mmc*******************
[    2.854380] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.854794] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.854878] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.854961] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.857429] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.891257] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.903638] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.904079] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.904166] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.904240] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.904312] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.904385] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.904461] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.904537] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.904585] guozh### : mmc_init_card max_dtr = 200000000
[    2.904591] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.904663] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.904730] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.904796] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.904861] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.904928] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.904994] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    2.905061] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.905680] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.905747] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.905814] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.905880] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.905947] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.906013] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.906080] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.906146] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    2.906213] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.906263] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.906328] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.906393] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.906458] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.906528] mmc0: new high speed DDR MMC card at address 0001
[    2.906892] mmcblk0: mmc0:0001 H8G4a 7.28 GiB
[    2.907084] mmcblk0boot0: mmc0:0001 H8G4a partition 1 4.00 MiB
[    2.907249] mmcblk0boot1: mmc0:0001 H8G4a partition 2 4.00 MiB
[    2.908960]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 >
[    2.909006] mmcblk0: p1 size 8937472 extends beyond EOD, truncated
[    2.912138] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.914181]  mmcblk0boot1: unknown partition table
[    2.914741] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.916745]  mmcblk0boot0: unknown partition table
[    2.916946] *******************mmc init ok *******************
[    2.973123] logger: created 256K log 'log_main'
[    3.071191] logger: created 256K log 'log_events'
[    3.267250] logger: created 256K log 'log_radio'
[    3.446154] logger: created 256K log 'log_system'
[    3.451863] sunxi_oops: heming add OOPS_INFO_ADDR = -20
[    3.458077] usbcore: registered new interface driver snd-usb-audio
[    3.481669] asoc: ac100-aif1 <-> pri_dai mapping ok
[    3.487468] asoc: ac100-aif2 <-> bb-voice-dai mapping ok
[    3.497494] asoc: ac100-aif1 <-> sec_dai mapping ok
[    3.503309] asoc: ac100-aif3 <-> bb-voice-dai mapping ok
[    3.509549] asoc: ac100-aif2 <-> bb-voice-dai mapping ok
[    3.522631] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    3.529972] guozh### : set i2s1 clk end!!!
[    3.569735] asoc: sndi2s1 <-> i2s1 mapping ok
[    3.575583] u32 classifier
[    3.578712]     Actions configured
[    3.582567] Netfilter messages via NETLINK v0.30.
[    3.587943] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.595300] ctnetlink v0.93: registering with nfnetlink.
[    3.601337] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.609208] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.616142] xt_time: kernel timezone is -0000
[    3.621251] IPv4 over IPv4 tunneling driver
[    3.626347] gre: GRE over IPv4 demultiplexor driver
[    3.631917] ip_gre: GRE over IPv4 tunneling driver
[    3.637857] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.644095] arp_tables: (C) 2002 David S. Miller
[    3.649364] TCP: cubic registered
[    3.653114] Initializing XFRM netlink socket
[    3.658259] NET: Registered protocol family 10
[    3.664205] Mobile IPv6
[    3.667004] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.673326] IPv6 over IPv4 tunneling driver
[    3.678935] NET: Registered protocol family 17
[    3.683971] NET: Registered protocol family 15
[    3.689210] Bluetooth: RFCOMM TTY layer initialized
[    3.694721] Bluetooth: RFCOMM socket layer initialized
[    3.700570] Bluetooth: RFCOMM ver 1.11
[    3.704797] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.710844] Bluetooth: BNEP filters: protocol multicast
[    3.716699] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.723834] ThumbEE CPU extension supported.
[    3.728665] Registering SWP/SWPB emulation handler
[    3.735678] rtc_gettime(340): read time 1970-1-1 1:0:8
[    3.741552] rtc0 rtc0: setting system clock to 1970-01-01 01:00:08 UTC (3608)
[    3.750480] sunxi_get_soc_bin: slow chip
[    3.755429] CPU Budget:Register notifier
[    3.759866] CPU Budget:register Success
[    3.764212] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    3.783413] =========GPS========= :gsp not used in configuration
[    3.790209] ALSA device list:
[    3.793570]   #0: sndac100
[    3.796638]   #1: sndhdmi
[    3.799614]   #2: sndi2s1
[    3.803309] Freeing init memory: 328K
[    3.809826] init: init started!
[    3.816013] init: init second stage started!
[    3.821476] init: waitpid failed: No child processes
[    3.827355] init: (Loading properties from /default.prop took 0.00s.)
[    3.836638] init: (Parsing /init.environ.rc took 0.00s.)
[    3.842925] init: (Parsing /init.usb.rc took 0.00s.)
[    3.849600] init: (Parsing init.sensors.rc took 0.00s.)
[    3.855531] init: (Parsing init.common.rc took 0.01s.)
[    3.861430] init: (Parsing init.sun8i.common.rc took 0.00s.)
[    3.868003] init: (Parsing init.sun8i.usb.rc took 0.00s.)
[    3.874101] init: (Parsing /init.sun8i.rc took 0.03s.)
[    3.880471] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[    3.887044] init: (Parsing /init.zygote32.rc took 0.00s.)
[    3.893335] init: (Parsing /init.trace.rc took 0.00s.)
[    3.899146] init: (Parsing /init.rc took 0.06s.)
[    3.904607] init: Starting service 'ueventd'...
[    3.910387] init: Waiting for /dev/.coldboot_done...
[    3.912709] ueventd: ueventd started!
[    4.421054] ueventd: Coldboot took 0.51s.
[    4.423974] init: Waiting for /dev/.coldboot_done took 0.51s.
[    4.424036] init: /dev/hw_random not found
[    4.439041] init: write_file: Unable to open '/proc/sys/kernel/hung_task_timeout_secs': No such file or directory
[    4.450732] init: write_file: Unable to open '/proc/sys/kernel/sched_tunable_scaling': No such file or directory
[    4.462279] init: write_file: Unable to open '/proc/sys/kernel/sched_latency_ns': No such file or directory
[    4.473296] init: write_file: Unable to open '/proc/sys/kernel/sched_wakeup_granularity_ns': No such file or directory
[    4.485376] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
[    4.590270] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
[    4.601232] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[    4.611296] init: /dev/hw_random not found
[    4.641843] [NAND]nand init start, nand0_used_flag is 0
[    4.647740] [NAND]nand driver is disabled
[    4.654603] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    4.675466] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: barrier=1
[    4.685064] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=0
[    4.695221] EXT4-fs (mmcblk0p11): VFS: Can't find ext4 filesystem
[    4.850094] fs_mgr: check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=-1: Invalid argument
[    4.861526] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/cache
[    4.942585] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    4.942591]
[    4.949466] e2fsck: ext2fs_open2: Bad magic number in super-block
[    4.949470]
[    4.958108] e2fsck: /system/bin/e2fsck: Superblock invalid, trying backup blocks...
[    4.958112]
[    4.968482] e2fsck: /system/bin/e2fsck: Bad magic number in super-block while trying to open /dev/block/by-name/cache
[    4.968487]
[    4.982156] e2fsck:
[    4.982159]
[    4.986365] e2fsck:
[    4.986367]
[    4.990584] e2fsck: The superblock could not be read or does not describe a correct ext2
[    4.990589]
[    5.001441] e2fsck: filesystem.  If the device is valid and it really contains an ext2
[    5.001445]
[    5.012314] e2fsck: filesystem (and not swap or ufs or something else), then the superblock
[    5.012321]
[    5.023545] e2fsck: is corrupt, and you might try running e2fsck with an alternate superblock:
[    5.023551]
[    5.035019] e2fsck:     e2fsck -b 8193 <device>
[    5.035022]
[    5.041860] e2fsck:
[    5.041863]
[    5.046071] e2fsck: e2fsck terminated by exit(8)
[    5.046075]
[    5.054216] EXT4-fs (mmcblk0p11): VFS: Can't find ext4 filesystem
[    5.170082] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=-1
[    5.180122] fs_mgr: fs_mgr_mount_all(): /dev/block/by-name/cache is wiped and /cache ext4 is formattable. Format it.
[    5.192020] fs_mgr: fs_mgr_do_format: Format /dev/block/by-name/cache as 'ext4'.
[    5.712943] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    5.725011] fs_mgr: check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=0: Success
[    5.880061] fs_mgr: check_fs(): unmount(/cache) succeeded
[    5.886167] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/cache
[    5.919036] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    5.919040]
[    5.925926] e2fsck: /dev/block/by-name/cache: clean, 11/49152 files, 6355/196608 blocks
[    5.925931]
[    5.943077] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[    5.958462] fs_mgr: __mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=0
[    5.968323] EXT4-fs (mmcblk0p16): VFS: Can't find ext4 filesystem
[    6.110104] fs_mgr: check_fs(): mount(/dev/block/by-name/alog,/logger,ext4)=-1: Invalid argument
[    6.120070] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/alog
[    6.151092] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.151096]
[    6.157917] e2fsck: ext2fs_open2: Bad magic number in super-block
[    6.157921]
[    6.166531] e2fsck: /system/bin/e2fsck: Superblock invalid, trying backup blocks...
[    6.166535]
[    6.176893] e2fsck: /system/bin/e2fsck: Bad magic number in super-block while trying to open /dev/block/by-name/alog
[    6.176898]
[    6.190431] e2fsck:
[    6.190433]
[    6.194629] e2fsck:
[    6.194631]
[    6.198825] e2fsck: The superblock could not be read or does not describe a correct ext2
[    6.198829]
[    6.209660] e2fsck: filesystem.  If the device is valid and it really contains an ext2
[    6.209665]
[    6.220313] e2fsck: filesystem (and not swap or ufs or something else), then the superblock
[    6.220318]
[    6.231436] e2fsck: is corrupt, and you might try running e2fsck with an alternate superblock:
[    6.231441]
[    6.242856] e2fsck:     e2fsck -b 8193 <device>
[    6.242859]
[    6.249663] e2fsck:
[    6.249665]
[    6.253928] e2fsck: e2fsck terminated by exit(8)
[    6.253932]
[    6.261899] EXT4-fs (mmcblk0p16): VFS: Can't find ext4 filesystem
[    6.380067] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=-1
[    6.390082] fs_mgr: fs_mgr_mount_all(): /dev/block/by-name/alog is wiped and /logger ext4 is formattable. Format it.
[    6.401870] fs_mgr: fs_mgr_do_format: Format /dev/block/by-name/alog as 'ext4'.
[    6.617902] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    6.629980] fs_mgr: check_fs(): mount(/dev/block/by-name/alog,/logger,ext4)=0: Success
[    6.790074] fs_mgr: check_fs(): unmount(/logger) succeeded
[    6.796270] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/alog
[    6.827870] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.827874]
[    6.834739] e2fsck: /dev/block/by-name/alog: clean, 11/5120 files, 1358/20480 blocks
[    6.834744]
[    6.851562] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[    6.866917] fs_mgr: __mount(source=/dev/block/by-name/alog,target=/logger,type=ext4)=0
[    6.876783] EXT4-fs (mmcblk0p1): VFS: Can't find ext4 filesystem
[    7.000081] fs_mgr: check_fs(): mount(/dev/block/by-name/UDISK,/data,ext4)=-1: Invalid argument
[    7.009862] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/UDISK
[    7.041918] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    7.041922]
[    7.048833] e2fsck: ext2fs_open2: Bad magic number in super-block
[    7.048837]
[    7.057432] e2fsck: /system/bin/e2fsck: Superblock invalid, trying backup blocks...
[    7.057436]
[    7.068847] e2fsck: /system/bin/e2fsck: Bad magic number in super-block while trying to open /dev/block/by-name/UDISK
[    7.068853]
[    7.082523] e2fsck:
[    7.082526]
[    7.086728] e2fsck:
[    7.086730]
[    7.091014] e2fsck: The superblock could not be read or does not describe a correct ext2
[    7.091019]
[    7.101869] e2fsck: filesystem.  If the device is valid and it really contains an ext2
[    7.101873]
[    7.112489] e2fsck: filesystem (and not swap or ufs or something else), then the superblock
[    7.112493]
[    7.123655] e2fsck: is corrupt, and you might try running e2fsck with an alternate superblock:
[    7.123660]
[    7.135113] e2fsck:     e2fsck -b 8193 <device>
[    7.135117]
[    7.141987] e2fsck:
[    7.141990]
[    7.146192] e2fsck: e2fsck terminated by exit(8)
[    7.146195]
[    7.154178] EXT4-fs (mmcblk0p1): VFS: Can't find ext4 filesystem
[    7.290074] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=-1
[    7.300046] fs_mgr: fs_mgr_mount_all(): /dev/block/by-name/UDISK is wiped and /data ext4 is formattable. Format it.
[    7.311883] fs_mgr: fs_mgr_mount_all(): also wipe /dev/block/by-name/metadata
[    7.319952] +mmc_blk_issue_secdiscard_rq,1836
[    7.324940] mmc0:mmc_do_erase: erase from 6135808 to 6168575 arg 0x80000000
[    7.336034] -mmc_blk_issue_secdiscard_rq,1890
[    7.336039] fs_mgr: fs_mgr_do_format: Format /dev/block/by-name/UDISK as 'ext4'.
[    9.796040] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    9.808021] fs_mgr: check_fs(): mount(/dev/block/by-name/UDISK,/data,ext4)=0: Success
[    9.960080] fs_mgr: check_fs(): unmount(/data) succeeded
[    9.966089] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/UDISK
[   10.007580] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[   10.007585]
[   10.014513] e2fsck: /dev/block/by-name/UDISK: clean, 11/276352 files, 36791/1104896 blocks
[   10.014518]
[   10.031798] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[   10.047103] fs_mgr: __mount(source=/dev/block/by-name/UDISK,target=/data,type=ext4)=0
[   10.293402] Adding 131068k swap on /dev/block/zram0.  Priority:-1 extents:1 across:131068k SS
[   10.304213] FAT-fs (mmcblk0p17): bogus number of reserved sectors
[   10.311114] FAT-fs (mmcblk0p17): Can't find a valid FAT filesystem
[   10.439382] enter tr_probe
[   10.442523] exit tr_probe
[   10.598093] [DISP]disp_module_init
[   10.602957] cmdline,disp=100
[   10.673743] [DISP]disp_module_init finish
[   10.699302] cmdline,disp=100
[   11.300113] [DISP] disp_hdmi_set_detect,line:405:hdmi1's mgr is NULL
[   11.371318] PVR_K: Get gpu regulator successfully.
[   11.376856] PVR_K: Enable gpu external power successfully.
[   11.383034] sunxi_get_soc_bin: slow chip
[   11.387561] PVR_K: Get gpu pll_gpu clock id successfully
[   11.393562] PVR_K: Get gpu core clock id successfully
[   11.399252] PVR_K: Get gpu mem clock id successfully
[   11.404917] PVR_K: Get gpu hyd clock id successfully
[   11.410528] PVR_K: Set the parent of gpu core clock to pll_gpu.
[   11.417231] PVR_K: Set the parent of gpu mem clock to pll_gpu.
[   11.423817] PVR_K: Set the parent of gpu hyd clock to pll_gpu.
[   11.430517] PVR_K: The frequency of gpu pll_gpu clock has been set to 552 MHz
[   11.438588] PVR_K: The frequency of gpu core clock has been set to 552 MHz
[   11.446318] PVR_K: The frequency of gpu mem clock has been set to 552 MHz
[   11.454057] PVR_K: The frequency of gpu hyd clock has been set to 552 MHz
[   11.463770] PVR_K: Release gpu hyd clock reset successfully.
[   11.476979] [fm1288] : fm1288_init
[   11.480961] i2c i2c-0: fm1288_ctl detection function provided no name for 0x60
[   11.489096] [fm1288] : I2C detect success
[   11.493739] [fm1288] : fm1288_rst
[   11.518132] twi_stop()471 - [i2c1] i2c state isn't idle(0xf8)
[   11.524618] sunxi_i2c_core_process()833 - [i2c1] STOP failed!
[   11.528072] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x38, dev addr: 0x60)
[   11.540578] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x60)
[   11.549912] [fm1288] : fm1288_i2c_write:I2C retry timeout, reset chip.
[   11.557096] i2c i2c-2: fm1288_ctl detection function provided no name for 0x60
[   11.579190] ***CTP***GTP driver init
[   11.583262] =====ctp_fetch_sysconfig_para=====.
[   11.588527] ctp_fetch_sysconfig_para: ctp_power_io script_get_item err.
[   11.596077] ctp_irq gpio number is 359
[   11.620034] ***CTP***info.ctp_used:1
[   11.624079] ***CTP***info.twi_id:0
[   11.627918] ***CTP***info.screen_max_x:800
[   11.632610] ***CTP***info.screen_max_y:1280
[   11.637333] ***CTP***info.revert_x_flag:1
[   11.641872] ***CTP***info.revert_y_flag:0
[   11.646453] ***CTP***info.exchange_x_y_flag:1
[   11.651376] ***CTP***info.irq_gpio_number:359
[   11.656352] ***CTP***info.wakeup_gpio_number:358
[   11.661563] ***CTP******CTP*** ctp_wakeup:status:0,ms = 0
[   11.730058] ***CTP******CTP*** ctp_wakeup:status:1,ms = 0
[   11.830293] the adapter number is 0
[   11.834248] ctp_detect: addr = 5d
[   11.838688] detect ret 2
[   11.841591] ======detect ok !=====
[   11.845573] ***CTP***GTP Driver Version: V2.2<2014/01/14>***CTP***GTP Driver Built@10:29:47, Apr 11 2019***CTP***GTP I2C Address: 0x5d<<-GTP-INFO->> IC Version: 911_1060
[   11.864500] ***CTP***Config Groups Lengths: 186, 186, 186, 186, 186, 186
[   11.873353] ***CTP***CTP name : gt9271_noah
[   11.878049] ***CTP***gt9xx:sensor_id = 4
[   11.882544] ***CTP***Sensor_ID: 4***CTP***CTP_CONFIG_GROUP5 used, config length: 186
[   11.892564] ***CTP***CFG_GROUP5 Config Version: 0, 0x00; IC Config Version: 65, 0x41
[   11.901291] <<-GTP-INFO->> Driver send config.
[   11.929074] <<-GTP-INFO->> X_MAX: 1280, Y_MAX: 800, TRIGGER: 0x01
[   11.950061] <<-GTP-INFO->> create proc entry gt9xx_config success
[   11.956969] <<-GTP-INFO->> Ready to run update thread.
[   11.962860] <<-GTP-INFO->> Update by default firmware array
[   11.963231] <<-GTP-INFO->> GTP works in polling mode.
[   11.963240] <<-GTP-INFO->> Applied memory size:2562.
[   11.963246] <<-GTP-INFO->> I2C function: without pre and end cmd!
[   11.963269] <<-GTP-INFO->> Create proc entry success!
[   11.963306] the adapter number is 1
[   11.963315] the adapter number is 2
[   11.968184] sunxigk_init
[   11.968197] sunxigk_script_init power key io number = 361.
[   11.968203] sunxigk_script_init volumeup key io number = 363.
[   11.968208] sunxigk_script_init volumedown key io number = 362.
[   11.968214] sunxigk_script_init sos key io number = 360.
[   11.968942] sunxikbd_init end
[   11.985741] [VFE]cci probe start cci_sel = 0!
[   11.985781] [VFE]cci probe end cci_sel = 0!
[   11.985856] [VFE]cci_init end
[   12.042983] [VFE]Welcome to Video Front End driver
[   12.043439] [VFE]pdev->id = 0
[   12.043443] [VFE]dev->mipi_sel = 0
[   12.043447] [VFE]dev->vip_sel = 0
[   12.043450] [VFE]dev->isp_sel = 0
[   12.049629] [VFE_WARN]vfe vpu clock is null
[   12.070671] <<-GTP-INFO->> FILE HARDWARE INFO:00016000
[   12.072771] [ISP] isp platform_id = 4!
[   12.072875] [VFE]vfe_init end
[   12.080040] [VFE]probe_work_handle start!
[   12.080046] [VFE]..........................vfe clk open!.......................
[   12.080330] [VFE]v4l2 subdev register input_num = 0
[   12.080505] [VFE]vfe sensor detect start! input_num = 0
[   12.080514] [VFE]Find sensor name is "ov5648", i2c address is 6c, type is "RAW" !
[   12.080520] [VFE]Sub device register "ov5648" i2c_addr = 0x6c start!
[   12.080529] [VFE]v4l2_device_register_subdev return 0
[   12.080534] [VFE]registered sensor subdev is OK!
[   12.080537] [VFE]Check sensor!
[   12.080542] [OV5648]CSI_SUBDEV_PWR_ON!
[   12.146982] <<-GTP-INFO->> FILE PID:9271
[   12.151448] <<-GTP-INFO->> FILE VID:1040
[   12.155980] <<-GTP-INFO->> IC HARDWARE INFO:00900600
[   12.161658] <<-GTP-INFO->> IC PID:911
[   12.165864] <<-GTP-INFO->> IC VID:1060
[   12.170240] <<-GTP-INFO->> Firmware length:90112(88K)
[   12.175990] <<-GTP-ERROR->> File PID != Ic PID, update aborted!
[   12.182794] <<-GTP-ERROR->> [update_proc]Check *.bin file fail.
[   12.200318] dhd_module_init: in
[   12.203924] ======== dhd_wlan_init_plat_data ========
[   12.209614] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   12.215028] [VFE]mclk on
[   12.218129] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = 355
[   12.224178] dhd_wlan_init_gpio: host_oob_irq: 3
[   12.229277] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   12.235311] dhd_wifi_platform_load: Enter
[   12.237091] [OV5648]sensor_init
[   12.237359] [VFE CCI_0 ERR] Status error at addr_8bit = 6c, wr_flag = 1, val = ce60a30
[   12.237622] [VFE CCI_0 ERR] Status error at addr_8bit = 6c, wr_flag = 1, val = c000a30
[   12.237883] [VFE CCI_0 ERR] Status error at addr_8bit = 6c, wr_flag = 1, val = c000a30
[   12.237892] [OV5648]sensor read retry=2
[   12.237897] [OV5648]error at sensor_detect
[   12.237901] [OV5648]chip found is not an target chip.
[   12.237907] [OV5648]CSI_SUBDEV_PWR_OFF!
[   12.244130] [VFE]mclk off
[   12.256496] [VFE]vfe sensor subdev unregister!
[   12.256503] [VFE]Sub device register "ov5648" failed!
[   12.256508] [VFE_ERR]vfe sensor register check error at input_num = 0
[   12.257630] [VFE]read ini start
[   12.257690] [VFE]Fetch ini file form "/system/etc/hawkview/ov5648/isp_test_param.ini"
[   12.261539] [VFE]Fetch ini file form "/system/etc/hawkview/ov5648/isp_3a_param.ini"
[   12.266756] [VFE]Fetch ini file form "/system/etc/hawkview/ov5648/isp_iso_param.ini"
[   12.271503] [VFE]Fetch ini file form "/system/etc/hawkview/ov5648/isp_tuning_param.ini"
[   12.286056] [VFE]Fetch table form "/system/etc/hawkview/ov5648/bin/gamma_tbl.bin", gamma num = 1
[   12.287642] [VFE]registered actuator device succeed! act_name is ad5820_act
[   12.287659] [VFE]V4L2 device registered as vfe-0
[   12.287709] [VFE]register_early_suspend @ probe handle!
[   12.287715] [VFE]..........................vfe clk close!.......................
[   12.287741] [VFE]probe_work_handle end!
[   12.386120] Power-up adapter 'DHD generic adapter'
[   12.395371] wifi_platform_set_power = 1
[   12.399707] ======== PULL WL_REG_ON(-1) HIGH! ========
[   12.405496] [wifi_pm]: wifi power on
[   12.710038] wifi_platform_bus_enumerate device present 1
[   12.716030] ======== Card detection to detect SDIO card! ========
[   12.722976] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   12.734279] [mmc]: sdc1 power_supply is null
[   12.760025] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   12.797370] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 1 err, cmd 52,  RTO !!
[   12.806449] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 1 err, cmd 52,  RTO !!
[   12.814765] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   12.827564] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   12.839781] [mmc]: *** sunxi_mci_dump_errinfo(L914): smc 1 err, cmd 8,  RTO !!
[   12.847940] *******************Try sdio*******************
[   12.854515] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   12.874999] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[   12.882822] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   12.890583] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   12.899664] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[   12.909333] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[   12.967956] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[   12.978216] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[   12.988716] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   13.001971] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[   13.008238] mmc2: new high speed SDIO card at address 0001
[   13.015113] *******************sdio init ok*******************
[   13.031117] bcmsdh_register: register client driver
[   13.036684] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[   13.042247] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[   13.047655] bus num (host idx)=2, slot num (rca)=1
[   13.053064] found adapter info 'DHD generic adapter'
[   13.058734] sdioh_attach: set sd_f2_blocksize 128
[   13.064322] dhdsdio_probe : no mutex held. set lock
[   13.069951] F1 signature read @0x18000000=0x15264345
[   13.078275] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
[   13.086063] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[   13.093859] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
[   13.099928] dhd_conf_set_conf_path_by_nv_path: config_path=/system/vendor/modules/config.txt
[   13.110677] dhd_conf_read_config: dhd_slpauto = 0
[   13.116883] wl_create_event_handler(): thread:wl_event_handler:b1 started
[   13.116891] tsk Enter, tsk = 0xe0641410
[   13.129740] p2p0: P2P Interface Registered
[   13.134472] dhd_attach(): thread:dhd_watchdog_thread:b2 started
[   13.141269] dhd_attach(): thread:dhd_dpc:b3 started
[   13.146835] dhd_attach(): thread:dhd_rxf:b4 started
[   13.152403] dhd_deferred_work_init: work queue initialized
[   13.167328] Dongle Host Driver, version 1.201.59.11 (r506368)
[   13.167332] Compiled in drivers/net/wireless/bcmdhd on Apr 11 2019 at 10:30:01
[   13.182531] Register interface [wlan0]  MAC: 6c:21:a2:4a:b7:be
[   13.182535]
[   13.190852] dhd_prot_ioctl : bus is down. we have nothing to do
[   13.197609] bcmsdh_oob_intr_unregister: Enter
[   13.202540] bcmsdh_oob_intr_unregister: irq is not registered
[   13.209024] dhd_txglom_enable: enable 0
[   13.213414] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[   13.220178] dhd_conf_set_txglom_params: txglom_bucket_size=0
[   13.226600] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[   13.235575] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0, txctl_tmo_fix=1
[   13.244284] sdioh_set_mode: set txglom_mode to multi-desc
[   13.250472] dhd_bus_devreset:  WLAN OFF DONE
[   13.255307] wifi_platform_set_power = 0
[   13.259672] ======== PULL WL_REG_ON(-1) LOW! ========
[   13.265426] [wifi_pm]: wifi power off
[   13.269571] dhdsdio_probe : the lock is released.
[   13.274976] dhd_module_init: Exit err=0
[   13.287487] Bluetooth: MSM Sleep Mode Driver Ver 1.2
[   13.293255] Bluetooth: has no bt_wake_invert
[   13.293259]
[   13.316161] usbcore: registered new interface driver asix
[   13.329149] usbcore: registered new interface driver qf9700
[   13.342354] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[   13.357198] usbcore: registered new interface driver cdc_ether
[   13.371533] usbcore: registered new interface driver smsc75xx
[   13.385508] usbcore: registered new interface driver smsc95xx
[   13.392931] [BT_LPM] bluesleep_get_uart_port: bluesleep_get_uart_port get uart_port from blusleep_uart_dev: uart, port irq: 33
[   13.406247] init: Starting service 'logd'...
[   13.422107] init: (Loading properties from /system/build.prop took 0.01s.)
[   13.430057] init: (Loading properties from /vendor/build.prop took 0.00s.)
[   13.437909] init: (Loading properties from /factory/factory.prop took 0.00s.)
[   13.446328] init: /recovery not specified in fstab
[   13.451870] init: void property_opt_for_mem(): start!
[   13.457665] logd.auditd: start
[   13.458811] get_item_store: input buf lcd0_para lcd_x
[   13.458822] get_item_store: get "lcd0_para"->"lcd_x"
[   13.458842] get_item_show(804): script_get_item return type [int] for lcd0_para->lcd_x
[   13.458852] get_item_store: input buf lcd0_para lcd_y
[   13.458857] get_item_store: get "lcd0_para"->"lcd_y"
[   13.458865] get_item_show(804): script_get_item return type [int] for lcd0_para->lcd_y
[   13.458985] init: void property_opt_for_mem(): width_dp = 800; height_dp = 1280; screenSize = 3; bSupport64Bit = 0, g_total_mem = 2018
[   13.475012] init: void property_opt_for_mem(): end!
[   13.475920] init: Starting service 'vold'...
[   13.476841] init: Not bootcharting.
[   13.477524] init: Failed to reload policy
[   13.477755] init: Starting service 'exec 0 (/system/bin/tzdatacheck)'...
[   13.510902] init: Service 'exec 0 (/system/bin/tzdatacheck)' (pid 193) exited with status 0
[   13.535164] init: Starting service 'bootclone'...
[   13.536148] init: (Loading properties from /data/local.prop took 0.00s.)
[   13.536203] init: Unable to open persistent property directory "/data/property": No such file or directory
[   13.536282] init: Starting service 'logd-reinit'...
[   13.540768] init: Starting service 'healthd'...
[   13.541676] init: Starting service 'lmkd'...
[   13.542676] init: Starting service 'servicemanager'...
[   13.543864] init: Starting service 'surfaceflinger'...
[   13.545639] init: Starting service 'pvrsrvctl'...
[   13.546176] binder: 202:202 transaction failed 29189, size 0-0
[   13.546536] init: Starting service 'sayeye'...
[   13.549029] rtc_gettime(340): read time 1970-1-1 1:0:18
[   13.549200] init: Starting service 'zygote'...
[   13.551337] logd.klogd: 13551281674
[   13.552103] init: Starting service 'console'...
[   13.553841] init: Starting service 'encrypt'...
[   13.555079] android_usb: already disabled
[   13.555652] init: Starting service 'adbd'...
[   13.561499] adb_open
[   13.561513] mtp_bind_config
[   13.561534] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[   13.561542] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[   13.561551] ep_matches, wrn: endpoint already claimed, ep(0xc091e0e0, 0xe61ebe00, ep1out-bulk)
[   13.561558] gadget_is_softwinner_otg is not -int
[   13.561563] gadget_is_softwinner_otg is not -int
[   13.561605] adb_bind_config
[   13.561612] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[   13.561619] ep_matches, wrn: endpoint already claimed, ep(0xc091e0e0, 0xe61ebe00, ep1out-bulk)
[   13.561627] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[   13.561633] ep_matches, wrn: endpoint already claimed, ep(0xc091e0e0, 0xe61ebe00, ep1out-bulk)
[   13.561640] ep_matches, wrn: endpoint already claimed, ep(0xc091e12c, 0xe61c8900, ep2in-bulk)
[   13.561935] logd.daemon: reinit
[   13.563406] init: Service 'logd-reinit' (pid 199) exited with status 0
[   13.737803] init: Service 'zygote' is being killed...
[   13.739613] init: Service 'zygote' (pid 212) killed by signal 9
[   13.739638] init: Service 'zygote' (pid 212) killing any children in process group
[   13.740430] init: Not bootcharting.
[   13.742296] init: Failed to reload policy
[   13.742565] init: Starting service 'exec 1 (/system/bin/tzdatacheck)'...
[   13.759105] init: Service 'exec 1 (/system/bin/tzdatacheck)' (pid 239) exited with status 0
[   13.760213] init: property_set("ro.bt.bdaddr_path", "/data/misc/bluetooth/bdaddr") failed
[   13.762505] PVR_K: UM DDK-(3793329) and KM DDK-(3793329) match. [ OK ]
[   13.779881] init: Service 'pvrsrvctl' (pid 208) exited with status 0
[   13.851991] init: Service 'bootclone' (pid 198) exited with status 0
shell@octopus-f1:/ $ [   13.924799] init: Starting service 'bootanim'...
[   14.328531] sunxi_snddaudio_hw_params,line:62,freq_in:22579200,daudio_pcm_select:1,audio_format:1,signal_inversion:1
[   14.543881] [DISP] ready enter pm_runtime_get_sync, device0
[   20.750444] CPU Budget: Temperature: 52 Limit state:1 item[1608000,4,1608000,4 0]
[   21.770253] CPU Budget: Temperature: 54 Limit state:0 item[1800000,4,1800000,4 0]
[   22.280168] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[   22.780184] CPU Budget: Temperature: 55 Limit state:1 item[1608000,4,1608000,4 0]
[   23.420090] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   23.426973] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   23.433819] [BT_LPM] bluesleep_hostwake_task: hostwake line change
[   25.290158] CPU Budget: Temperature: 51 Limit state:0 item[1800000,4,1800000,4 0]
[   25.800137] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[   26.300124] CPU Budget: Temperature: 51 Limit state:1 item[1608000,4,1608000,4 0]
[   27.310113] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   27.820104] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[   28.820113] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[   29.830138] CPU Budget: Temperature: 51 Limit state:0 item[1800000,4,1800000,4 0]
[   30.340087] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[   30.840071] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[   31.350075] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   31.860115] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[   32.310711] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[   32.322300] fs_mgr: check_fs(): mount(/dev/block/dm-0,/data,ext4)=0: Success
[   32.440180] fs_mgr: check_fs(): unmount(/data) succeeded
[   32.446233] fs_mgr: Running /system/bin/e2fsck on /dev/block/dm-0
[   32.492566] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[   32.492571]
[   32.499470] e2fsck: /dev/block/dm-0: clean, 11/276352 files, 36791/1104896 blocks
[   32.499479]
[   32.520144] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[   32.534945] fs_mgr: __mount(source=/dev/block/dm-0,target=/data,type=ext4)=0
[   32.544999] init: (Loading properties from /data/local.prop took 0.00s.)
[   32.552702] init: Unable to open persistent property directory "/data/property": No such file or directory
[   32.563852] init: Starting service 'logd-reinit'...
[   32.574873] init: Not bootcharting.
[   32.601499] logd.daemon: reinit
[   32.603511] init: Service 'logd-reinit' (pid 308) exited with status 0
[   32.610886] init: Failed to reload policy
[   32.611180] init: Starting service 'exec 2 (/system/bin/tzdatacheck)'...
[   32.628451] init: Service 'exec 2 (/system/bin/tzdatacheck)' (pid 311) exited with status 0
[   32.641041] init: property_set("ro.bt.bdaddr_path", "/data/misc/bluetooth/bdaddr") failed
[   32.650572] init: Starting service 'bootclone'...
[   32.670838] init: Service 'bootclone' (pid 314) exited with status 0
[   32.678859] init: Starting service 'netd'...
[   32.685262] init: Starting service 'debuggerd'...
[   32.692427] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[   32.700970] init: Starting service 'ril-daemon'...
[   32.707348] init: Starting service 'drm'...
[   32.713412] init: Starting service 'media'...
[   32.719407] init: Starting service 'installd'...
[   32.725956] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
[   32.735644] init: Starting service 'keystore'...
[   32.742232] init: Starting service 'logger_private'...
[   32.749441] init: Starting service 'zygote'...
[   32.755905] init: Starting service 'gatekeeperd'...
[   32.932755] init: Starting service 'perfprofd'...
[   32.939524] init: Service 'logger_private' (pid 335) exited with status 1
[   33.360156] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[   33.460074] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   33.466943] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   33.681340] init: Service 'encrypt' (pid 218) exited with status 0
[   37.870119] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   38.380121] CPU Budget: Temperature: 52 Limit state:1 item[1608000,4,1608000,4 0]
[   42.890092] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   43.400069] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[   43.480036] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   43.486817] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   43.900171] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[   49.910234] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[   50.410626] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[   50.910235] CPU Budget: Temperature: 58 Limit state:1 item[1608000,4,1608000,4 0]
[   51.910215] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[   52.410263] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[   52.910192] CPU Budget: Temperature: 58 Limit state:1 item[1608000,4,1608000,4 0]
[   53.520105] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   53.526907] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   53.910205] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[   54.910298] CPU Budget: Temperature: 58 Limit state:1 item[1608000,4,1608000,4 0]
[   55.410306] CPU Budget: Temperature: 58 Limit state:1 item[1608000,4,1608000,4 0]
[   56.410266] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[   57.410209] CPU Budget: Temperature: 61 Limit state:1 item[1608000,4,1608000,4 0]
[   57.910241] CPU Budget: Temperature: 57 Limit state:1 item[1608000,4,1608000,4 0]
[   62.910153] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   63.420839] CPU Budget: Temperature: 54 Limit state:1 item[1608000,4,1608000,4 0]
[   63.560042] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   63.566827] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   65.430099] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   65.940092] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[   66.060102] warning: `main' uses 32-bit capabilities (legacy support in use)
[   66.450094] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   66.960099] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[   73.600082] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   73.606952] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   74.550762] healthd: battery l=0 v=0 t=30.0 h=2 st=2 c=0 chg=a 1970-01-01 01:01:19.290507159 UTC
[   78.716924] request_suspend_state: wakeup (3->0) at 78716907748 (1970-01-01 01:01:23.459630578 UTC)
[   83.640053] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   83.646847] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   87.480087] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   87.990092] CPU Budget: Temperature: 51 Limit state:1 item[1608000,4,1608000,4 0]
[   89.010086] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   89.520108] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[   90.530142] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[   91.040199] CPU Budget: Temperature: 52 Limit state:1 item[1608000,4,1608000,4 0]
[   93.680104] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[   93.686990] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[   96.278013] healthd: battery l=0 v=0 t=30.0 h=2 st=2 c=0 chg=a 1970-01-01 01:01:41.020674794 UTC
[   96.667815] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[   96.676023] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[   96.682198] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[   96.688380] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[   96.694781] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[   96.701142] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[   96.707493] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[   97.219493] acc_open
[   97.222138] acc_release
[  103.720095] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  103.726950] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  109.050163] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  109.550121] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  110.053079] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  112.050247] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  112.550223] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  113.050197] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  113.550240] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  113.760110] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  113.767103] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  114.050248] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  114.550242] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  115.050219] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  115.550415] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  116.050213] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  116.550235] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  117.050239] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  117.550223] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  118.050187] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  118.550201] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  119.050190] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  119.550234] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  120.050226] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  120.553444] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  121.550098] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  122.050127] CPU Budget: Temperature: 57 Limit state:1 item[1608000,4,1608000,4 0]
[  123.800103] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  123.807043] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  125.600593] init: Service 'adbd' is being killed...
[  125.606846] adb_release
[  125.610967] init: Service 'adbd' (pid 219) killed by signal 9
[  125.617555] init: Service 'adbd' (pid 219) killing any children in process group
[  125.626720] init: Starting service 'adbd'...
[  125.640858] adb_open
[  125.643456] mtp_bind_config
[  125.646651] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[  125.656393] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[  125.666001] ep_matches, wrn: endpoint already claimed, ep(0xc091e0e0, 0xe61ebe00, ep1out-bulk)
[  125.675760] gadget_is_softwinner_otg is not -int
[  125.681055] gadget_is_softwinner_otg is not -int
[  125.686345] adb_bind_config
[  125.689853] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[  125.699623] ep_matches, wrn: endpoint already claimed, ep(0xc091e0e0, 0xe61ebe00, ep1out-bulk)
[  125.709398] ep_matches, wrn: endpoint already claimed, ep(0xc091e094, 0xe61ebe00, ep1in-bulk)
[  125.719009] ep_matches, wrn: endpoint already claimed, ep(0xc091e0e0, 0xe61ebe00, ep1out-bulk)
[  125.728761] ep_matches, wrn: endpoint already claimed, ep(0xc091e12c, 0xe61c8900, ep2in-bulk)
[  127.550222] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  128.050429] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  128.550394] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  130.550253] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  131.050294] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  131.550087] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  133.840116] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  133.847003] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  134.548767] healthd: battery l=0 v=0 t=30.0 h=2 st=2 c=0 chg=a 1970-01-01 01:02:19.291420020 UTC
[  135.050414] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  135.550165] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  136.050240] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  137.550294] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  138.550162] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  139.050194] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  140.050106] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  140.550154] CPU Budget: Temperature: 58 Limit state:1 item[1608000,4,1608000,4 0]
[  143.880085] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  143.886962] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  145.050255] CPU Budget: Temperature: 61 Limit state:2 item[1412000,4,1412000,4 0]
[  145.550274] CPU Budget: Temperature: 61 Limit state:1 item[1608000,4,1608000,4 0]
[  146.050168] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  151.050077] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[  151.560063] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[  152.570071] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[  153.080095] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[  153.580132] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[  153.920029] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  153.926855] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  154.090088] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[  154.600077] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[  155.110065] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[  155.620068] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[  156.620131] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[  156.831339] init: Service 'bootanim' (pid 266) exited with status 0
[  157.048559] init: Starting service 'precopy'...
[  157.241596] init: Service 'precopy' (pid 2782) exited with status 0
[  159.972772] [dsm] Scene:0 "sayeye" (pid:235)
[  162.971577] CPU7: shutdown
[  162.992258] CPU5: shutdown
[  163.011646] CPU4: shutdown
[  163.171863] CPU4: Booted secondary processor
[  163.291988] CPU5: Booted secondary processor
[  163.371404] CPU7: Booted secondary processor
[  163.960054] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  163.966837] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  164.891596] CPU7: shutdown
[  164.911557] CPU6: shutdown
[  164.931492] CPU5: shutdown
[  164.951534] CPU4: shutdown
[  164.971421] CPU3: shutdown
[  165.091860] CPU2: shutdown
[  165.110883] CPU2: Booted secondary processor
[  165.271027] CPU3: Booted secondary processor
[  165.311020] CPU4: Booted secondary processor
[  165.350877] CPU5: Booted secondary processor
[  165.390982] CPU6: Booted secondary processor
[  165.430935] CPU7: Booted secondary processor
[  166.772303] CPU6: shutdown
[  166.791271] CPU6: Booted secondary processor
[  167.811863] CPU5: shutdown
[  167.832011] CPU4: shutdown
[  168.072022] CPU7: shutdown
[  168.130217] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[  168.571192] CPU4: Booted secondary processor
[  168.630760] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[  168.651042] CPU5: Booted secondary processor
[  168.831297] CPU7: Booted secondary processor
[  171.140297] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  171.640204] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  172.140249] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  172.640392] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  173.140273] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  173.641318] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  174.000114] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  174.007073] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  174.140234] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  174.640411] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  175.031576] CPU7: shutdown
[  175.051590] CPU6: shutdown
[  175.071819] CPU5: shutdown
[  175.091643] CPU4: shutdown
[  175.140148] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  175.211545] CPU3: shutdown
[  175.230892] CPU3: Booted secondary processor
[  176.230951] CPU4: Booted secondary processor
[  177.350997] CPU5: Booted secondary processor
[  177.411282] CPU6: Booted secondary processor
[  177.451516] CPU7: Booted secondary processor
[  179.791926] CPU7: shutdown
[  179.811837] CPU5: shutdown
[  179.851850] CPU4: shutdown
[  180.820972] [dsm] Scene:0 "sayeye" (pid:235)
[  181.102163] CPU6: shutdown
[  181.301535] CPU2: shutdown
[  181.426285] CPU1: shutdown
[  182.025897] CPU1: Booted secondary processor
[  182.061003] CPU2: Booted secondary processor
[  182.081080] CPU4: Booted secondary processor
[  182.141291] CPU5: Booted secondary processor
[  182.181526] CPU6: Booted secondary processor
[  182.221524] CPU7: Booted secondary processor
[  184.040085] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  184.046979] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  187.992063] CPU6: shutdown
[  188.011859] CPU7: shutdown
[  188.031903] CPU5: shutdown
[  188.051835] CPU4: shutdown
[  188.071479] CPU3: shutdown
[  188.111540] CPU2: shutdown
[  188.570868] CPU2: Booted secondary processor
[  188.650860] CPU3: Booted secondary processor
[  189.371463] CPU4: Booted secondary processor
[  189.411087] CPU5: Booted secondary processor
[  190.640087] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[  190.941295] CPU6: Booted secondary processor
[  190.981482] CPU7: Booted secondary processor
[  191.140284] CPU Budget: Temperature: 50 Limit state:1 item[1608000,4,1608000,4 0]
[  192.650201] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  193.081647] CPU7: shutdown
[  193.101490] CPU5: shutdown
[  193.121405] CPU4: shutdown
[  193.150074] CPU Budget: Temperature: 60 Limit state:1 item[1608000,4,1608000,4 0]
[  193.650086] CPU Budget: Temperature: 59 Limit state:1 item[1608000,4,1608000,4 0]
[  194.080022] [BT_LPM] bluesleep_tx_timer_expire: Tx timer expired
[  194.086776] [BT_LPM] bluesleep_tx_timer_expire: Tx has been idle
[  194.547680] healthd: battery l=0 v=0 t=30.0 h=2 st=2 c=0 chg=a 1970-01-01 01:03:19.290332257 UTC
[  194.771430] CPU6: shutdown
[  194.791483] CPU2: shutdown
[  194.951011] CPU2: Booted secondary processor
[  195.571286] CPU4: Booted secondary processor
[  195.650924] CPU5: Booted secondary processor
[  196.311380] CPU6: Booted secondary processor
[  196.650175] CPU Budget: Temperature: 50 Limit state:0 item[1800000,4,1800000,4 0]
[  196.687535] [dsm] Scene:0 "sayeye" (pid:235)
[  196.696653] [dsm] Scene:0 "sayeye" (pid:235)
[  196.743309] [dsm] Scene:0 "sayeye" (pid:235)
[  197.152749] CPU Budget: Temperature: 49 Limit state:0 item[1800000,4,1800000,4 0]
[  197.292091] CPU7: Booted secondary processor
[  197.660276] CPU Budget: Temperature: 52 Limit state:1 item[1608000,4,1608000,4 0]
[  198.453105] [dsm] Scene:0 "sayeye" (pid:235)
[  198.464743] [dsm] Scene:0 "sayeye" (pid:235)
[  198.487132] [dsm] Scene:0 "sayeye" (pid:235)
[  198.490151] sunxi_snddaudio_hw_params,line:62,freq_in:24576000,daudio_pcm_select:1,audio_format:1,signal_inversion:1
[  198.510596] [dsm] Scene:0 "sayeye" (pid:235)
[  198.539360] [dsm] Scene:0 "sayeye" (pid:235)
[  198.702306] CPU4: shutdown
[  198.862497] CPU6: shutdown
[  198.941364] CPU4: Booted secondary processor
[  198.981475] CPU6: Booted secondary processor
[  200.180394] CPU Budget: Temperature: 60 Limit state:2 item[1412000,4,1412000,4 0]
[  200.542005] CPU7: shutdown
[  200.561865] CPU6: shutdown
#6 2019-05-16 20:00:48
所在地: 微信 whycan_cn
已发帖子: 9,240
Re: 全志A83T无法进系统问题
重点排查 1, 2, 3, 4 看为什么会有这些差异,
顺便报一下 两个 eMMC的型号
是不是8G的不支持 ext_csd 命令?
比较软件这里下载: https://whycan.cn/t_1636.html
楼主 #7 2019-05-16 20:24:01
MrJacky
Re: 全志A83T无法进系统问题
型号都是一样的8G,16G都在兼容性列表里啊,,应该是哪些没有设置好.
#8 2019-05-16 20:31:32
所在地: 微信 whycan_cn
已发帖子: 9,240
Re: 全志A83T无法进系统问题
跟踪驱动  ext_csd 命令,前后加调试语句,或试着跳过这个命令。
楼主 #9 2019-05-16 20:46:45
MrJacky
Re: 全志A83T无法进系统问题
好的,我试试
