楼主 #1 2019-05-27 09:08:03
已发帖子: 1,392
下载ilicheePi-nano的镜像后,启动不成功。
自己画了个f1c100的板子,然后烧录的ilicheePi-nano的一键烧录镜像。
结果没启动成功,卡在这里了:
[    1.374530] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.390370] cfg80211: failed to load regulatory.db
[    1.400904] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilitie
点鼠标右键的话,貌似又重启了,结果启动的更短一些。
不知道如何插入已上传的文件...
直接贴吧。
U-Boot SPL 2018.01-05676-g00188782ee (Apr 08 2018 - 16:10:25)
DRAM: 32 MiB
Trying to boot from MMC1
U-Boot 2018.01-05676-g00188782ee (Apr 08 2018 - 16:10:25 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM:  32 MiB
MMC:   SUNXI SD/MMC: 0
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
280 bytes read in 15 ms (17.6 KiB/s)
## Executing script at 80c50000
8553 bytes read in 28 ms (297.9 KiB/s)
reading zImage
3802240 bytes read in 188 ms (19.3 MiB/s)
   Loading Device Tree to 80e60000, end 80e65168 ... OK
[    0.000000] Linux version 4.15.0-rc8-licheepi-nano+ (root@biglion-MRC-WX0) (gcc version 7.2.0 (Ubuntu/Linaro 7.2.0-6ubuntu1)) #69 Wed Apr 4 17:47:49 CST 2018
[    0.000000] Kernel command line: console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw
[    0.000000] Memory: 22680K/32768K available (6144K kernel code, 235K rwdata, 1376K rodata, 1024K init, 243K bss, 10088K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 236 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 244 kB)
[    0.000041] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000093] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000551] Console: colour dummy device 80x30
[    0.001102] console [tty0] enabled
[    0.001188] Calibrating delay loop... 358.80 BogoMIPS (lpj=1794048)
[    0.050255] pid_max: default: 32768 minimum: 301
[    0.050522] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.050594] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.051791] CPU: Testing write buffer coherency: ok
[    0.053425] Setting up static identity map for 0x80100000 - 0x80100058
[    0.055441] devtmpfs: initialized
[    0.060291] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.060436] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.060712] pinctrl core: initialized pinctrl subsystem
[    0.062514] NET: Registered protocol family 16
[    0.063756] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.065190] cpuidle: using governor menu
[    0.083308] SCSI subsystem initialized
[    0.083653] usbcore: registered new interface driver usbfs
[    0.083827] usbcore: registered new interface driver hub
[    0.084029] usbcore: registered new device driver usb
[    0.084483] pps_core: LinuxPPS API ver. 1 registered
[    0.084551] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.084643] PTP clock support registered
[    0.084981] Advanced Linux Sound Architecture Driver Initialized.
[    0.086198] clocksource: Switched to clocksource timer
[    0.108617] NET: Registered protocol family 2
[    0.109801] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.109924] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.109980] TCP: Hash tables configured (established 1024 bind 1024)
[    0.110275] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.110360] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.110792] NET: Registered protocol family 1
[    0.111933] RPC: Registered named UNIX socket transport module.
[    0.112026] RPC: Registered udp transport module.
[    0.112057] RPC: Registered tcp transport module.
[    0.112084] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.113873] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.115458] Initialise system trusted keyrings
[    0.116037] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.128525] NFS: Registering the id_resolver key type
[    0.128664] Key type id_resolver registered
[    0.128705] Key type id_legacy registered
[    0.139786] Key type asymmetric registered
[    0.139884] Asymmetric key parser 'x509' registered
[    0.140096] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.140175] io scheduler noop registered
[    0.140209] io scheduler deadline registered
[    0.140804] io scheduler cfq registered (default)
[    0.140887] io scheduler mq-deadline registered
[    0.140925] io scheduler kyber registered
[    0.141813] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    0.149328] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.293221] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.298993] console [ttyS0] disabled
[    0.319292] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 24, base_baud = 6250000) is a 16550A
[    0.789725] console [ttyS0] enabled
[    0.798563] panel-simple panel: panel supply power not found, using dummy regulator
[    0.808726] usbcore: registered new interface driver rtl8150
[    0.814933] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.821628] ehci-platform: EHCI generic platform driver
[    0.827210] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.833473] ohci-platform: OHCI generic platform driver
[    0.839177] usbcore: registered new interface driver usb-storage
[    0.845999] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    0.855096] i2c /dev entries driver
[    0.916326] sunxi-mmc 1c0f000.mmc: base:0x5f3aa981 irq:19
[    0.923740] hidraw: raw HID events driver (C) Jiri Kosina
[    0.930242] usbcore: registered new interface driver usbhid
[    0.935872] usbhid: USB HID core driver
[    0.942457] NET: Registered protocol family 17
[    0.947306] Key type dns_resolver registered
[    0.954589] Loading compiled-in X.509 certificates
[    0.970229] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0739498)
[    0.979056] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073877c)
[    0.986905] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.993544] [drm] No driver support for vblank timestamp query.
[    1.042834] Console: switching to colour frame buffer device 60x34
[    1.048008] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.050049] mmc0: new high speed SDHC card at address 0001
[    1.051038] mmcblk0: mmc0:0001 ASTC 7.44 GiB
[    1.053331]  mmcblk0: p1 p2
[    1.101695] sun4i-drm display-engine: fb0:  frame buffer device
[    1.115805] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.132053] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.154805] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.168746] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.184776] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.199283] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.214232] usb usb1: Product: MUSB HDRC host driver
[    1.223163] usb usb1: Manufacturer: Linux 4.15.0-rc8-licheepi-nano+ musb-hcd
[    1.237957] usb usb1: SerialNumber: musb-hdrc.1.auto
[    1.248344] hub 1-0:1.0: USB hub found
[    1.256376] hub 1-0:1.0: 1 port detected
[    1.265601] using random self ethernet address
[    1.274073] using random host ethernet address
[    1.283788] usb0: HOST MAC 6a:24:90:09:80:d3
[    1.292060] usb0: MAC 3a:7c:32:5a:c1:cc
[    1.299786] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.314606] g_cdc gadget: g_cdc ready
[    1.324329] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.346036] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.360037] ALSA device list:
[    1.366755]   No soundcards found.
[    1.400904] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
DRAM: 32 MiB
DRAM:  32 MiB
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Scanning mmc 0:1...
reading /boot.scr
reading zImage
楼主 #2 2019-05-27 09:13:27
已发帖子: 1,392
Re: 下载ilicheePi-nano的镜像后,启动不成功。
还有,启动后,发现串口输出的调试信息的波特率是57600,可启动内核时,却有这么一句:
难道启动内核后,波特率又改为115200了?
#3 2019-05-27 09:59:57
已发帖子: 9,350
Gentlepig 说:
是的, 改为了 115200, 你的 u-boot 波特率是 57600 ?
楼主 #4 2019-05-27 10:11:28
已发帖子: 1,392
是的,没有自己编译,直接用的ilicheePi-nano的烧录文件,我也没想到会是57600这个波特率。
楼主 #5 2019-05-27 10:27:44
已发帖子: 1,392
第一个警告,好像是没认出spi flash来,这个对后面有影响吗?
ilicheePi-nano原理图上是MX25....,我焊的是W25...
#6 2019-05-28 21:50:05
zpyws
已发帖子: 33
我也画了块板,请问第一次是怎么下载uboot进去的?
#7 2019-05-28 22:38:36
已发帖子: 9,350
zpyws 说:
可以试一试这个: https://whycan.cn/t_2449.html
不用烧录, 直接 USB 跑 uboot 和 linux
2019-05-17 更新:
f1c100s 的也搞定了: f1c100s_fel_autorun_linux_uart0_pe0_pe1_20190517_TF_sdnand.7z (登录账号: root, 密码: whycan.cn)
2019-05-18 更新:
32M w25q256 和 TF 卡挂载均 OK
w25q256运行:      Run_F1C100s_LicheePi_Nano_SPI_NOR_W25Q256_OK.bat
tf/sd nand 运行:  Run_F1C100s_LicheePi_Nano_TFCard.bat
配合 Win32DiskImager或dd, 可以用来烧录软件.
下载: f1c100s_fel_autorun_linux_uart0_pe0_pe1_20190518_TF_sdnand_w25q256.7z
楼主 #8 2019-05-29 14:07:41
已发帖子: 1,392
zpyws 说:
我是用tf卡启动的,ilicheePi-nano提供了几个烧录镜像,有flash启动的,有tf卡启动的。
