楼主 #1 2019-06-11 23:58:53
Jin劲
已发帖子: 217
100s自己写的boot程序fel加载到sram正常运行,烧到flash不正常
这是我的链接脚本
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm")
OUTPUT_ARCH(arm)
STACK_FIQ_SIZE = 1K;
STACK_IRQ_SIZE = 1K;
STACK_SVC_SIZE = 1K;
STACK_ABT_SIZE = 1K;
STACK_UDF_SIZE = 1K;
STACK_SYS_SIZE = 1K;
MEMORY
    sram_stack_fiq : org = 40K-1K,     len = 1K
    sram_stack_irq : org = 40K-2K,     len = 1K
    sram_stack_svc : org = 40K-3K,     len = 1K
    sram_stack_abt : org = 40K-4K,     len = 1K
    sram_stack_udf : org = 40K-5K,     len = 1K
    sram_stack_sys : org = 40K-6K,     len = 1K
    sram           : org = 0x00000000, len = 40K-6K
SECTIONS
    .text : {
        * (.vector)
        jin_boot0_start.o (.text)
        * (.text)
    } > sram
    . = ALIGN(4);
    .data : {
        * (.data)
    } > sram
    . = ALIGN(4);
    .bss : {
        * (.bss)
    } > sram
    . = ALIGN(4);
    .sram_stack_fiq : {
        . += STACK_FIQ_SIZE;
        PROVIDE(stack_fiq_start = .);
    } > sram_stack_fiq
    . = ALIGN(4);
    .sram_stack_irq : {
        . += STACK_IRQ_SIZE;
        PROVIDE(stack_irq_start = .);
    } > sram_stack_irq
    . = ALIGN(4);
    .sram_stack_svc : {
        . += STACK_SVC_SIZE;
        PROVIDE(stack_svc_start = .);
    } > sram_stack_svc
    . = ALIGN(4);
    .sram_stack_abt : {
        . += STACK_ABT_SIZE;
        PROVIDE(stack_abt_start = .);
    } > sram_stack_abt
    . = ALIGN(4);
    .sram_stack_udf : {
        . += STACK_UDF_SIZE;
        PROVIDE(stack_udf_start = .);
    } > sram_stack_udf
    . = ALIGN(4);
    .sram_stack_sys : {
        . += STACK_SYS_SIZE;
        PROVIDE(stack_sys_start = .);
    } > sram_stack_sys
利用下面fel命令或者jlink加载到sram正常运行:
        sudo sunxi-fel -p write 0 jin_boot0.bin
        sudo sunxi-fel exec 0x00000000
loadbin jin_boot0.bin,0
setpc 0
然后利用mksunxi加入全志头部
mksunxi/mksunxi jin_boot0.bin
bootloader size= e59ff200
The bootloader head has been fixed
烧写到flash
sunxi-fel -p spiflash-write 0 jin_boot0.bin
100% [================================================]     6 kB,   77.5 kB/s
重启brom跑到fel模式了
楼主 #2 2019-06-12 00:01:05
Jin劲
已发帖子: 217
Re: 100s自己写的boot程序fel加载到sram正常运行,烧到flash不正常
应该是brom代码检测flash里面内容的校验没通过吧
最近编辑记录 Jin劲 (2019-06-12 00:01:26)
#3 2019-06-12 08:13:17
看起来是有点像校验没通过
#4 2019-06-12 09:09:34
已发帖子: 1,139
Bootloader size这么大,肯定有点问题
楼主 #5 2019-06-12 10:01:00
Jin劲
已发帖子: 217
达克罗德 说:
uboot的spl好像有24K这么大[捂脸]
#6 2019-06-12 10:06:24
已发帖子: 9,399
http://linux-sunxi.org/BROM
spl(boot0) 上限应该可以 24k
#7 2019-06-19 11:07:45
duckduckgo
已发帖子: 58
问题在这里,导致了spl size的异常。
* (.vector)
vector好像没必要放在这里吧
jin_boot0_start.o放在最前面
最近编辑记录 duckduckgo (2019-06-19 11:14:22)
#8 2019-08-27 14:53:43
wangzhg1
已发帖子: 27
我的也是这样操作的,不过我的boot0只有2k,烧录重启后直接没反应了。而且fel也连不上了。
这个程序在IAR调试仿真是通过的。
#9 2019-08-27 15:15:21
已发帖子: 9,399
写一个最简单的程序, 只控制 IO (LED), 看他有没有跑起来.
#10 2019-08-28 12:25:33
wangzhg1
已发帖子: 27
写了,iar的,jtag调试正常,写flash就死机。
#11 2019-08-28 13:52:00
已发帖子: 9,399
这是我TF卡版本的spl: f1c100s_uboot_spl.7z
这是 u-boot 里面的 spl, 我手动用这个命令行生成的 带魔术头文件和u-boot自己生成的一模一样:
tools/mksunxiboot --default-dt suniv-f1c100s-licheepi-nano spl/u-boot-spl.bin spl/x.bin
源码: https://github.com/u-boot/u-boot/blob/master/tools/mksunxiboot.c
#12 2019-08-28 20:30:00
已发帖子: 1,139
哇!谢谢晕哥,正需要。
