在bsp内核上使用双目摄像头,能使用相同的传感器芯片吗?比如一个用2710的dvp模式,一个用2710的mipi模式,然后有些相机的i2c地址分为读地址和写地址,这种在config.fex配置文件中vip_dev0_twi_addr应该写哪个地址?
The following tables provide descriptions of the device control registers contained in the OV2710. For all registers
enable/disable bits, ENABLE = 1 and DISABLE = 0. The device slave addresses are 0x6C for write and 0x6D for read.没有问题。
但是, ov2710 只有一组读写地址, 所以你得接 V3s两组不同的I2C。
ov2710的 MIPI/DVP复用了, 你用i2c写寄存器切换即可。
岁月留痕 wrote:
The following tables provide descriptions of the device control registers contained in the OV2710. For all registers enable/disable bits, ENABLE = 1 and DISABLE = 0. The device slave addresses are 0x6C for write and 0x6D for read.没有问题。
那配置文件里的i2c地址写ov2710的写地址吗?
谢谢!
