楼主 #1 2019-11-04 21:36:38
已发帖子: 841
常用cpu性能大比拼
手头有f1c100s,f1c200s,v3s,zerow。本次测试了v3s和zerow(sysbench),v3s比zerow稍微慢了点,频率都是1G,可能和v3s的ram太小有关,v3s的ram是64m,zerow是512m,差太多了。
v3s:
root@LicheePi:~# sysbench --test=cpu --cpu-max-prime=20000 run
sysbench 0.4.12:  multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 1
Doing CPU performance benchmark
Threads started!
Done.
Maximum prime number checked in CPU test: 20000
Test execution summary:
    total time:                          730.7818s
    total number of events:              10000
    total time taken by event execution: 730.7642
    per-request statistics:
         min:                                 72.70ms
         avg:                                 73.08ms
         max:                                 79.48ms
         approx.  95 percentile:              74.25ms
Threads fairness:
    events (avg/stddev):           10000.0000/0.00
    execution time (avg/stddev):   730.7642/0.00
zerow
pi@raspberrypi:~/go/src/test $ sysbench --test=cpu --cpu-max-prime=20000 run
Threads started!
Done.
    total time:                          596.4347s
    total time taken by event execution: 596.4006
         min:                                 59.52ms
         avg:                                 59.64ms
         max:                                157.06ms
         approx.  95 percentile:              59.71ms
Threads fairness:
    execution time (avg/stddev):   596.4006/0.00
最近编辑记录 kekemuyu (2019-11-04 21:38:43)
#2 2019-11-05 09:04:02
已发帖子: 1,204
Re: 常用cpu性能大比拼
zerow是什么?荔枝派zero?树莓派zero?
能否和imx6ull对比下?
楼主 #3 2019-11-05 09:12:01
已发帖子: 841
Re: 常用cpu性能大比拼
Gentlepig 说:
能否和imx6ull对比下?
树莓派zerow,没有i.mx6ull。欢迎有i.mx6ull的朋友比拼
#4 2019-11-05 19:05:41
magusneo
Re: 常用cpu性能大比拼
应该有问题吧。zero是arm11,同频能比arm a7还快?
楼主 #5 2019-11-05 20:28:30
已发帖子: 841
Re: 常用cpu性能大比拼
magusneo 说:
实测就是这样,可能和linux版本不同有关。pizerow是4.19,licheepizero是4.13
最近编辑记录 kekemuyu (2019-11-05 20:31:46)
楼主 #6 2019-11-10 15:29:24
已发帖子: 841
Re: 常用cpu性能大比拼
f1c200s的700m测试:
root@antbian:~/tool# sysbench --test=cpu --cpu-max-prime=20000 run
Threads started!
Done.
    total time:                          2553.1847s
    total time taken by event execution: 2553.0733
         min:                                254.73ms
         avg:                                255.31ms
         max:                                574.51ms
         approx.  95 percentile:             255.38ms
Threads fairness:
    execution time (avg/stddev):   2553.0733/0.00
最近编辑记录 kekemuyu (2019-11-10 15:32:25)
楼主 #7 2019-11-10 15:31:38
已发帖子: 841
Re: 常用cpu性能大比拼
f1c200s比v3s满了三倍
#8 2019-11-11 08:56:55
ifree64
已发帖子: 74
Re: 常用cpu性能大比拼
我来发一个PC机上的测试数据,配置为R7 2700的KVM虚拟机,分配了8核和8G内存。不考虑sysbench的版本的话,速度是V3s的70倍。
WARNING: the --test option is deprecated. You can pass a script name or path on the command line without any options.
sysbench 1.0.15 (using system LuaJIT 2.0.5)
Initializing random number generator from current time
Prime numbers limit: 20000
Initializing worker threads...
Threads started!
CPU speed:
    events per second:   686.40
General statistics:
    total time:                          10.0002s
    total number of events:              6865
Latency (ms):
         min:                                    1.31
         avg:                                    1.45
         max:                                    1.85
         95th percentile:                        1.52
         sum:                                 9947.28
Threads fairness:
    events (avg/stddev):           6865.0000/0.00
    execution time (avg/stddev):   9.9473/0.00
#9 2022-06-30 13:48:51
aldfaaa
Re: 常用cpu性能大比拼
楼主是用这个库的吗?
sysbench
期待发个D1/R328/R528/V853s的评测
