楼主 #1 2019-11-16 18:18:24
psst
已发帖子: 92
v3s 怎么使用gpio模拟iic
请教各位高手。我想用drivers/i2c/busses/i2c-gpio.c 模拟iic,硬件iic口没有使用,io被占用了。要怎么玩?
menuconfig配置如下
  -*- I2C support
     Enable compatibility bits for old user-space
  <*>   I2C device interface
   <*>   I2C bus multiplexing support
              Multiplexer I2C Chip support  --->
   [**]   Autoselect pertinent helper modules
            I2C Hardware Bus support  --->
      *** I2C system bus drivers (mostly embedded / system-on-chip)
  │ │    < > CBUS I2C driver
  │ │    < > Synopsys DesignWare Platform
  │ │    < > EMMA Mobile series I2C adapter
  │ │    <*> GPIO-based bitbanging I2C
  │ │    < > Marvell mv64xxx I2C Controller
  │ │    < > OpenCores I2C Controller
  │ │    < > PCA9564/PCA9665 as platform device
  │ │    < > Rockchip RK3xxx I2C adapter
  │ │    < > Simtec Generic I2C interface
dts如下
i2c0@0 {
        compatible = "i2c-gpio";
            gpios = <&pio 2 2 // sda
                     &pio 2 1 // scl
            i2c-gpio,sda-open-drain;
            i2c-gpio,scl-open-drain;
            i2c-gpio,delay-us = <2>;
        #address-cells = <1>;
        #size-cells = <0>;
        //rv3029c2@56 {
            //compatible = "rv3029c2";
            //reg = <0x56>;
启动后报错, OF: /soc/i2c0@0: could not get #gpio-cells for /soc/clock@01c20000
是不是gpio配置不对,
&pio 2 2 /* sda */
&pio 2 1这两个口是串口,没有使用,应该不会被占用,
设备树怎么写?请教大家了
最近编辑记录 psst (2019-11-16 18:19:36)
#2 2019-11-16 18:29:38
已发帖子: 853
Re: v3s 怎么使用gpio模拟iic
软件模拟也需要定时器吧,否则时序无法控制
#3 2019-11-18 13:54:40
已发帖子: 9,408
你的设备树配置有误, 来这里抄一个吧:
https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/allwinner/sun50i-a64-amarula-relic.dts
	i2c {
		sda-gpios = <&pio 4 13 GPIO_ACTIVE_HIGH>;
		scl-gpios = <&pio 4 12 GPIO_ACTIVE_HIGH>;
		i2c-gpio,delay-us = <5>;
		#size-cells = <0>;
#4 2020-07-24 12:59:07
liuy
我也在用模拟iic,请问启动了吗?
# dmesg | grep i2c
[    0.120130] i2c-gpio i2c-gpio: error trying to get descriptor: -2
[    0.981720] i2c /dev entries driver
[    6.656316] goodix-ts 1-005d: GTP i2c test failed time 1
[   11.086325] goodix-ts 1-005d: GTP i2c test failed time 2
[   15.516320] goodix-ts 1-005d: GTP i2c test failed time 3
[   15.544682] i2c-gpio i2c-gpio: using lines 3 (SDA) and 0 (SCL),-1
一直是这个错误
#5 2020-08-02 20:03:27
lignin
已发帖子: 120
在pinctrl里面要声明使用的引脚,然后在使用它gpio模拟iic的,应该是类似的
可以参考一下这个gpio模拟spi的例子
在根节点下加入
    spi2:spi2{
        compatible = "spi-gpio";
        #address-cells = <0x1>;
        #size-cells = <0>;
        //ranges;
        gpio-sck = <&pio 3 0 1>;
        gpio-miso = <&pio 3 1 1>;
        gpio-mosi = <&pio 3 2 1>;
        cs-gpios = <&pio 3 3 1>;
        num-chipselects = <1>;
        pinctrl-names = "default";//注意这两排
        pinctrl-0 = <&spi2_pins_a>;//
        spidev2 {
            #size-cells = <0>;
            compatible = "rohm,dh2228fv";
            spi-max-frequency = <20000000>;
            reg = <0>;
在pinctrl里面加入
&pio{
    spi2_pins_a: spi2-pins-pc {
                pins = "PD0", "PD1", "PD2", "PD3";
                function = "gpio_out";
                                bias-pull-up;
最近编辑记录 lignin (2020-08-02 20:05:48)
#6 2022-06-11 00:14:45
资本家大善人
已发帖子: 193
就在两地方,毫无问题
 .config - Linux/arm 5.4.99 Kernel Configuration
 > Device Drivers > I2C support > I2C Hardware Bus support ────────────────────
  ┌─────────────────────── I2C Hardware Bus support ────────────────────────┐
  │  Arrow keys navigate the menu.  <Enter> selects submenus ---> (or empty │
  │  submenus ----).  Highlighted letters are hotkeys.  Pressing <Y>        │
  │  includes, <N> excludes, <M> modularizes features.  Press <Esc><Esc> to │
  │  exit, <?> for Help, </> for Search.  Legend: [*] built-in  [ ]         │
  │ │        *** I2C system bus drivers (mostly embedded / system-on-chip)│ │
  │ │    < > CBUS I2C driver                                              │ │
  │ │    < > Synopsys DesignWare Platform                                 │ │
  │ │    < > EMMA Mobile series I2C adapter                               │ │
	i2c_gpio0: i2c-gpio-0 {
		sda-gpios = <&pio 4 0 GPIO_ACTIVE_HIGH>;
		scl-gpios = <&pio 4 1 GPIO_ACTIVE_HIGH>;
		#size-cells = <0>;
        ft6x06@38 {
                compatible = "focaltech,ft6236";
                reg = <0x38>;
                interrupt-parent = <&pio>;
                interrupts = <4 2 IRQ_TYPE_LEVEL_LOW>;
                reset-gpios = <&pio 4 3 GPIO_ACTIVE_LOW>;
                touchscreen-size-x = <240>;
                touchscreen-size-y = <240>;
