核心驱动代码:
#include "lcd.h"
#include "stdlib.h"
#include "delay.h"
#include "spi.h"
//管理LCD重要参数
//默认为竖屏
_lcd_dev lcddev;
//画笔颜色,背景颜色
u16 POINT_COLOR = 0x0000,BACK_COLOR = 0xFFFF;
u16 DeviceCode;
* @name :void LCD_WR_REG(u8 data)
* @date :2018-08-09
* @function :Write an 8-bit command to the LCD screen
* @parameters :data:Command value to be written
* @retvalue :None
LCD_CS_CLR;
SPI_WriteByte(SPI2,0x70);
SPI_WriteByte(SPI2,data);
LCD_CS_SET;
* @name :void LCD_WR_DATA(u8 data)
* @date :2018-08-09
* @function :Write an 8-bit data to the LCD screen
* @parameters :data:data value to be written
* @retvalue :None
LCD_CS_CLR;
SPI_WriteByte(SPI2,0x72);
LCD_CS_SET;
* @name :void LCD_WriteReg(u8 LCD_Reg, u16 LCD_RegValue)
* @date :2018-08-09
* @function :Write data into registers
* @parameters :LCD_Reg:Register address
LCD_RegValue:Data to be written
* @retvalue :None
void LCD_WriteReg(u8 LCD_Reg, u8 LCD_RegValue)
LCD_WR_REG(LCD_Reg);
LCD_WR_DATA(LCD_RegValue);
* @name :void LCD_WriteRAM_Prepare(void)
* @date :2018-08-09
* @function :Write GRAM
* @parameters :None
* @retvalue :None
LCD_WR_REG(lcddev.wramcmd);
* @name :void Lcd_WriteData_16Bit(u16 Data)
* @date :2018-08-09
* @function :Write an 16-bit command to the LCD screen
* @parameters :Data:Data to be written
* @retvalue :None
LCD_CS_CLR;
SPI_WriteByte(SPI2,Data>>8);
SPI_WriteByte(SPI2,Data);
LCD_CS_SET;
* @name :void LCD_DrawPoint(u16 x,u16 y)
* @date :2018-08-09
* @function :Write a pixel data at a specified location
* @parameters :x:the x coordinate of the pixel
y:the y coordinate of the pixel
* @retvalue :None
LCD_SetCursor(x,y);//设置光标位置
Lcd_WriteData_16Bit(POINT_COLOR);
* @name :void LCD_Clear(u16 Color)
* @date :2018-08-09
* @function :Full screen filled LCD screen
* @parameters :color:Filled color
* @retvalue :None
unsigned int i,m;
LCD_SetWindows(0,0,lcddev.width-1,lcddev.height-1);
LCD_CS_CLR;
for(i=0;i<lcddev.height;i++)
for(m=0;m<lcddev.width;m++)
Lcd_WriteData_16Bit(Color);
LCD_CS_SET;
* @name :void LCD_GPIOInit(void)
* @date :2018-08-09
* @function :Initialization LCD screen GPIO
* @parameters :None
* @retvalue :None
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB ,ENABLE); //使能GPIOB时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11| GPIO_Pin_12; //GPIOB9,10,11,12
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
* @name :void LCD_RESET(void)
* @date :2018-08-09
* @function :Reset LCD screen
* @parameters :None
* @retvalue :None
LCD_RST_CLR;
delay_ms(100);
LCD_RST_SET;
delay_ms(50);
* @date :2018-08-09
* @parameters :None
* @retvalue :None
void LCD_Init(void)
SPI2_Init(); //硬件SPI2初始化
LCD_GPIOInit();//LCD GPIO初始化
LCD_RESET(); //LCD 复位
//************3.2 inch LG4573B 初始化**********//
//lg4573 display mode settings
LCD_WR_REG(0x3A);
LCD_WR_DATA(0x66);
LCD_WR_REG(0xB1);
LCD_WR_DATA(0x08);
LCD_WR_DATA(0x3B);
LCD_WR_DATA(0x0F);
LCD_WR_REG(0xB2);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0xC8);
LCD_WR_REG(0xB3);
LCD_WR_DATA(0x00);
LCD_WR_REG(0xB4);
LCD_WR_DATA(0x00);
LCD_WR_REG(0xB5);
LCD_WR_DATA(0x42);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x20);
LCD_WR_REG(0xB6);
LCD_WR_DATA(0x0B);
LCD_WR_DATA(0x0F);
LCD_WR_DATA(0x3C);
LCD_WR_DATA(0x13);
LCD_WR_DATA(0x13);
LCD_WR_DATA(0xE8);
LCD_WR_REG(0xB7);
LCD_WR_DATA(0x46);
LCD_WR_DATA(0x06);
LCD_WR_DATA(0x0C);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
//lg4573 power settings
LCD_WR_REG(0xC0);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x11);
LCD_WR_REG(0xC3);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x04);
LCD_WR_DATA(0x04);
LCD_WR_DATA(0x04);
LCD_WR_REG(0xC4);
LCD_WR_DATA(0x12);
LCD_WR_DATA(0x24);
LCD_WR_DATA(0x18);
LCD_WR_DATA(0x18);
LCD_WR_DATA(0x02);
LCD_WR_DATA(0x49);
LCD_WR_REG(0xC5);
LCD_WR_DATA(0x6F);
LCD_WR_REG(0xC6);
LCD_WR_DATA(0x41);
LCD_WR_DATA(0x63);
//lg4573 gamma settings
LCD_WR_REG(0xD0);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x73);
LCD_WR_DATA(0x35);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x20);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x03);
LCD_WR_REG(0xD1);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x73);
LCD_WR_DATA(0x35);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x20);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x03);
LCD_WR_REG(0xD2);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x73);
LCD_WR_DATA(0x35);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x20);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x03);
LCD_WR_REG(0xD3);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x73);
LCD_WR_DATA(0x35);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x20);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x03);
LCD_WR_REG(0xD4);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x73);
LCD_WR_DATA(0x35);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x20);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x03);
LCD_WR_REG(0xD5);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x73);
LCD_WR_DATA(0x35);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x20);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x03);
//lg4573 power_on
LCD_WR_REG(0x21); //Display Inversion ON
LCD_WR_REG(0x11); //Exit Sleep
delay_ms(20);
LCD_WR_REG(0x11);
delay_ms(120);
LCD_WR_REG(0x29);
LCD_direction(USE_HORIZONTAL);//设置LCD显示方向
LCD_LED=1;//点亮背光
// LCD_Clear(WHITE);//清全屏白色
* @name :void LCD_SetWindows(u16 xStar, u16 yStar,u16 xEnd,u16 yEnd)
* @date :2018-08-09
* @function :Setting LCD display window
* @parameters :xStar:the bebinning x coordinate of the LCD display window
yStar:the bebinning y coordinate of the LCD display window
xEnd:the endning x coordinate of the LCD display window
yEnd:the endning y coordinate of the LCD display window
* @retvalue :None
LCD_WR_REG(lcddev.setxcmd);
LCD_WR_DATA(xStar>>8);
LCD_WR_DATA(0x00FF&xStar);
LCD_WR_DATA(xEnd>>8);
LCD_WR_DATA(0x00FF&xEnd);
LCD_WR_REG(lcddev.setycmd);
LCD_WR_DATA(yStar>>8);
LCD_WR_DATA(0x00FF&yStar);
LCD_WR_DATA(yEnd>>8);
LCD_WR_DATA(0x00FF&yEnd);
LCD_WriteRAM_Prepare(); //开始写入GRAM
* @name :void LCD_SetCursor(u16 Xpos, u16 Ypos)
* @date :2018-08-09
* @function :Set coordinate value
* @parameters :Xpos:the x coordinate of the pixel
Ypos:the y coordinate of the pixel
* @retvalue :None
LCD_SetWindows(Xpos,Ypos,Xpos,Ypos);
* @name :void LCD_direction(u8 direction)
* @date :2018-08-09
* @function :Setting the display direction of LCD screen
* @parameters :direction:0-0 degree
1-90 degree
2-180 degree
3-270 degree
* @retvalue :None
lcddev.setxcmd=0x2A;
lcddev.setycmd=0x2B;
lcddev.wramcmd=0x2C;
switch(direction){
case 0:
lcddev.width=LCD_W;
lcddev.height=LCD_H;
// LCD_WriteReg(0x36,(1<<3)|(0<<6)|(0<<7));//BGR==1,MY==0,MX==0,MV==0
break;
case 1:
lcddev.width=LCD_H;
lcddev.height=LCD_W;
// LCD_WriteReg(0x36,(1<<3)|(0<<7)|(1<<6)|(1<<5));//BGR==1,MY==1,MX==0,MV==1
break;
case 2:
lcddev.width=LCD_W;
// LCD_WriteReg(0x36,(1<<3)|(1<<6)|(1<<7));//BGR==1,MY==0,MX==0,MV==0
break;
case 3:
lcddev.width=LCD_H;
// LCD_WriteReg(0x36,(1<<3)|(1<<7)|(1<<5));//BGR==1,MY==1,MX==0,MV==1
break;
default:break;
后来经过比较, 驱动代码全部来自: https://github.com/torvalds/linux/blob/master/drivers/gpu/drm/panel/panel-lg-lg4573.c
通过SPI 把 LG4573 设置为 RGB 模式。
注意: 一楼的代码只完成了 LG4573 的初始化, 并没有驱动屏幕, 需要用soc提供PCLK, HSYNC/VSYNC, RGB等信号
看这个程序 难道这个可以直接通过spi总线去刷屏幕吗?
我正在弄这个,代理给的初始化代码不亮,参考下
