楼主 #1 2020-03-13 12:01:03
yuanlwjt
已发帖子: 129
V3S 烧录TF卡启动盘
按照论坛里的教程:
    1) 删除TF卡所有分区
    2) 将uboot写入到sd卡8k偏移处(必须8K偏移, brom龟腚的)。
        sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdX bs=1024 seek=8
    3) 建立第一个分区,大小32M(可以随意填写), 格式FAT16, 把zImage, sun8i-v3s-licheepi-zero-dock.dtb拷贝到 这个分区
    4) 建立第二个分区,用尽剩余空间,格式ext4, 把buildroot产生的rootfs.tar解压到该分区根目录
在V3S ZERO开发板上运行后,出现如下情况:
[    1.391582] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.401860] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.552817] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    1.567509] EXT4-fs (mmcblk0p2): recovery complete
[    1.577550] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.585719] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.594166] devtmpfs: mounted
[    1.598397] Freeing unused kernel memory: 1024K
[    1.613776] Starting init: /sbin/init exists but couldn't execute it (error -5)
[    1.623757] Starting init: /bin/sh exists but couldn't execute it (error -5)
[    1.630930] Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[    1.645087] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.16-licheepi-zero #1
[    1.652298] Hardware name: Allwinner sun8i Family
[    1.657036] [<c010e514>] (unwind_backtrace) from [<c010b1b8>] (show_stack+0x10/0x14)
[    1.664779] [<c010b1b8>] (show_stack) from [<c065e5a4>] (dump_stack+0x88/0x9c)
[    1.672001] [<c065e5a4>] (dump_stack) from [<c011b48c>] (panic+0xdc/0x248)
[    1.678875] [<c011b48c>] (panic) from [<c06700ec>] (kernel_init+0x100/0x110)
[    1.685919] [<c06700ec>] (kernel_init) from [<c0107538>] (ret_from_fork+0x14/0x3c)
[    1.693492] Rebooting in 5 seconds..
板子启动不了?是什么情况?
如果把第二步改一下:
  4) 建立第二个分区,大小100M,格式ext4, 把buildroot产生的rootfs.tar解压到该分区根目录
第二个分区改成100M,就可以正常启动。200M就不行了,是什么问题呢?
#2 2020-03-14 21:49:30
已发帖子: 9,441
Re: V3S 烧录TF卡启动盘
根文件系统有问题,文件都存在,但是不能执行:
楼主 #3 2020-03-14 21:54:57
yuanlwjt
已发帖子: 129
Re: V3S 烧录TF卡启动盘
https://whycan.cn/t_561.html
按照这个论坛做的,目前不知道该如何解决问题
楼主 #4 2020-03-14 21:55:31
yuanlwjt
已发帖子: 129
Re: V3S 烧录TF卡启动盘
第二个分区100M可以,大于100M就不行了
楼主 #5 2020-03-14 22:04:06
yuanlwjt
已发帖子: 129
Re: V3S 烧录TF卡启动盘
论坛里说sudo解压缩rootfs,明天我试试
#6 2020-08-05 20:57:21
白菜爱西瓜
Re: V3S 烧录TF卡启动盘
烧到tf卡里后,卡住了
U-Boot SPL 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00055-gc41fbfe7b5 (Jan 20 2017 - 00:39:08 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
287 bytes read in 15 ms (18.6 KiB/s)
reading zImage
3370592 bytes read in 563 ms (5.7 MiB/s)
reading sun8i-v3s-licheepi-zero.dtb
8585 bytes read in 27 ms (309.6 KiB/s)
   Loading Device Tree to 42dfa000, end 42dff188 ... OK
[    0.000000] Linux version 4.13.0-licheepi-zero+ (root@6d32bb12421e) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #2 SMP Wed Aug 5 11:27:20 UTC 2020
[    0.000000] percpu: Embedded 16 pages/cpu @c3de8000 s33868 r8192 d23476 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[    0.000000] Memory: 54636K/64036K available (5120K kernel code, 207K rwdata, 1172K rodata, 1024K init, 257K bss, 9400K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .text : 0xc0008000 - 0xc0600000   (6112 kB)
[    0.000000]       .init : 0xc0800000 - 0xc0900000   (1024 kB)
[    0.000000]       .data : 0xc0900000 - 0xc0933e00   ( 208 kB)
[    0.000000]        .bss : 0xc093a0b8 - 0xc097a684   ( 258 kB)
[    0.000161] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000377] Console: colour dummy device 80x30
[    0.000805] console [tty0] enabled
[    0.000845] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000883] pid_max: default: 32768 minimum: 301
[    0.001022] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001055] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001673] CPU: Testing write buffer coherency: ok
[    0.002065] /cpus/cpu@0 missing clock-frequency property
[    0.002110] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002551] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002744] Hierarchical SRCU implementation.
[    0.003267] smp: Bringing up secondary CPUs ...
[    0.003300] smp: Brought up 1 node, 1 CPU
[    0.003320] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003340] CPU: All CPU(s) started in SVC mode.
[    0.004123] devtmpfs: initialized
[    0.006628] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006947] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007007] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007193] pinctrl core: initialized pinctrl subsystem
[    0.008086] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[    0.008260] NET: Registered protocol family 16
[    0.008731] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009824] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009879] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.020183] SCSI subsystem initialized
[    0.020522] usbcore: registered new interface driver usbfs
[    0.020602] usbcore: registered new interface driver hub
[    0.020705] usbcore: registered new device driver usb
[    0.020942] pps_core: LinuxPPS API ver. 1 registered
[    0.020969] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.021016] PTP clock support registered
[    0.022321] clocksource: Switched to clocksource arch_sys_counter
[    0.023124] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4080000
[    0.023178] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    0.029977] Console: switching to colour frame buffer device 100x30
[    0.039945] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    0.053715] NET: Registered protocol family 2
[    0.058154] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062039] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.065936] TCP: Hash tables configured (established 1024 bind 1024)
[    0.069838] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.073635] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.077544] NET: Registered protocol family 1
[    0.081926] RPC: Registered named UNIX socket transport module.
[    0.085717] RPC: Registered udp transport module.
[    0.089260] RPC: Registered tcp transport module.
[    0.092748] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.098173] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.110703] NFS: Registering the id_resolver key type
[    0.114334] Key type id_resolver registered
[    0.117679] Key type id_legacy registered
[    0.122007] random: fast init done
[    0.128372] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.131886] io scheduler noop registered
[    0.135441] io scheduler deadline registered
[    0.139137] io scheduler cfq registered (default)
[    0.142607] io scheduler mq-deadline registered
[    0.145889] io scheduler kyber registered
[    0.153841] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.226760] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.233881] console [ttyS0] disabled
[    0.257435] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 31, base_baud = 1500000) is a U6_16550A
[    0.871554] console [ttyS0] enabled
[    0.880026] libphy: Fixed MDIO Bus: probed
[    0.887758] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.897528] ehci-platform: EHCI generic platform driver
[    0.906013] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.915377] ohci-platform: OHCI generic platform driver
[    0.924232] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    0.937145] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    0.947315] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.955048] i2c /dev entries driver
[    0.963095] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[    0.975921] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.042377] sunxi-mmc 1c0f000.mmc: base:0xc405d000 irq:23
[    1.052213] usbcore: registered new interface driver usbhid
[    1.061363] usbhid: USB HID core driver
[    1.069008] NET: Registered protocol family 17
[    1.077060] Key type dns_resolver registered
[    1.084925] Registering SWP/SWPB emulation handler
[    1.099841] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.118390] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.127930] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.142955] hub 1-0:1.0: USB hub found
[    1.150632] hub 1-0:1.0: 1 port detected
[    1.159622] using random self ethernet address
[    1.167928] using random host ethernet address
[    1.177065] usb0: HOST MAC 16:61:b5:5c:4c:0a
[    1.185025] usb0: MAC a6:3b:5d:7d:87:2e
[    1.192333] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.203253] g_cdc gadget: g_cdc ready
[    1.210604] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:11 UTC (11)
[    1.222507] vcc3v0: disabling
[    1.228981] vcc5v0: disabling
[    1.236864] Waiting for root device /dev/mmcblk0p2...
[    1.279840] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.293451] mmc0: new high speed SD card at address 0260
[    1.302952] mmcblk0: mmc0:0260 NCard 949 MiB
[    1.312755]  mmcblk0: p1 p2
[    1.333604] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.346583] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.957788] random: crng init done
[    2.245240] EXT4-fs (mmcblk0p2): recovery complete
[    2.260269] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.271807] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.282610] devtmpfs: mounted
[    2.290205] Freeing unused kernel memory: 1024K
[    2.407201] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
