楼主 #1 2020-04-08 00:17:39
X3
已发帖子: 86
试一试 Ubuntu 18.04 编译 X3 SDK
哎呀, 搜了一圈居然发现已经全有了: https://whycan.cn/t_3270.html
source build/envsetup.sh
lunch
选1 [astar_parrot-tina]
make
pack
楼主 #2 2020-04-08 08:32:35
X3
已发帖子: 86
Re: 试一试 Ubuntu 18.04 编译 X3 SDK
~/A33/x3sdk/x3_tina_send$ make
~/A33/x3sdk/x3_tina_send/build/board.mk:9: ~/A33/x3sdk/x3_tina_send/target/allwinner/-common/BoardConfigCommon.mk: No such file or directory
~/A33/x3sdk/x3_tina_send/build/board.mk:10: ~/A33/x3sdk/x3_tina_send/target/allwinner//BoardConfig.mk: No such file or directory
make[3]: *** No rule to make target '~/A33/x3sdk/x3_tina_send/target/allwinner//BoardConfig.mk'.  Stop.
make[2]: *** No rule to make target '~/A33/x3sdk/x3_tina_send/target/allwinner//BoardConfig.mk'.  Stop.
~/A33/x3sdk/x3_tina_send/build/toplevel.mk:287: recipe for target 'prereq' failed
make[1]: *** [prereq] Error 2
~/A33/x3sdk/x3_tina_send/build/toplevel.mk:301: recipe for target 'world' failed
make: *** [world] Error 2
解决方案:
date +%s > version.date
原因:
原因是yaffs需要用这个日期信息来生成一个冗长的version信息,系统会从git信息中查找,但git没有安装,或者git环境变量错误。
参考: https://blog.csdn.net/yulijun2201/article/details/81667198
楼主 #3 2020-04-08 09:08:09
X3
已发帖子: 86
打包成功:
toc0.fex Len: 0x8
fes1.fex Len: 0x31c0
full_img.fex Len: 0x16
usbtool.fex Len: 0x24200
aultools.fex Len: 0x27c29
aultls32.fex Len: 0x24d3f
cardtool.fex Len: 0x11e00
cardscript.fex Len: 0x6ea
sunxi_mbr.fex Len: 0x10000
dlinfo.fex Len: 0x4000
boot-resource.fex Len: 0x4c800
Vboot-resource.fex Len: 0x4
env.fex Len: 0x20000
Venv.fex Len: 0x4
boot.fex Len: 0x400000
Vboot.fex Len: 0x4
rootfs.fex Len: 0xc00000
Vrootfs.fex Len: 0x4
recovery.fex Len: 0x18
Vrecovery.fex Len: 0x4
BuildImg 0
Dragon execute image.cfg SUCCESS !
----------image is for nand/emmc----------
----------image is at----------
~/A33/x3sdk/x3_tina_send/out/astar-parrot/tina_astar-parrot_uart0.img
pack finish
楼主 #4 2020-04-08 09:57:04
X3
已发帖子: 86
这下麻烦,不知道烧哪里, 烧TF卡发现一闪而过.
参考这个帖子: https://whycan.cn/t_917.html#p30343
解包img文件, 发现boot0 只有 boot0_sdcard.fex / boot0_nand.fex
看来可能是 tf卡 或者 spi nand 固件:
$ ../imgRePacker.exe "tina_astar-parrot_uart0.img"
        imgRePacker (version 2.05 windows)
        LiveSuit's & PhoenixSuit's firmware image unpacker/packer
        (c) RedScorpio, Moscow, 2012-2014
            RedScorpio@land.ru
        ==========================[ START ]==========================
        --- Firmware unpacking ---
        PhoenixSuit image format detected
        - image.cfg creating -
        image.cfg created
        - Files extracting -
        "\sys_config.fex"               extracted (format: unknown)
        "\config.fex"           extracted (format: unknown)
        "\split_xxxx.fex"               extracted (format: unknown)
        "\sys_partition.fex"            extracted (format: unknown)
        "\boot0_nand.fex"               extracted (format: Allwinner BOOT0 file)
        "\boot0_sdcard.fex"             extracted (format: Allwinner BOOT0 file)
        "\u-boot.fex"           extracted (format: unknown)
        "\toc1.fex"             extracted (format: unknown/empty?)
        "\toc0.fex"             extracted (format: unknown/empty?)
        "\fes1.fex"             extracted (format: Allwinner BOOT0 file)
        "\full_img.fex"         extracted (format: unknown/empty?)
        "\usbtool.fex"          extracted (format: Windows PE file)
        "\aultools.fex"         extracted (format: Compiled lua file)
        "\aultls32.fex"         extracted (format: Compiled lua file)
        "\cardtool.fex"         extracted (format: Windows PE file)
        "\cardscript.fex"               extracted (format: unknown)
        "\sunxi_mbr.fex"                extracted (format: unknown)
        "\dlinfo.fex"           extracted (format: unknown)
        "\boot-resource.fex"            extracted (format: FAT16 image)
                "boot-resource.fex.iso" created
        "\Vboot-resource.fex"           extracted (format: unknown/empty?)
        "\env.fex"              extracted (format: unknown)
        "\Venv.fex"             extracted (format: unknown/empty?)
        "\boot.fex"             extracted (format: unknown)
        "\Vboot.fex"            extracted (format: unknown/empty?)
        "\rootfs.fex"           extracted (format: unknown)
        "\Vrootfs.fex"          extracted (format: unknown/empty?)
        "\recovery.fex"         extracted (format: unknown/empty?)
        "\Vrecovery.fex"                extracted (format: unknown/empty?)
        ==========================[ STOP  ]==========================
楼主 #5 2020-04-08 10:28:01
X3
已发帖子: 86
烧录应该成功了,因为插卡之后就没有USB FEL设备了, 但是串口0没有反应, 芯片没有发热, 这TMD就怪了。
楼主 #6 2020-04-13 19:44:18
X3
已发帖子: 86
X3 Tina Linux 运行成功了.
#7 2020-04-13 22:42:16
88秒?
#8 2020-04-14 16:09:54
sochip索智科技-全志代理商方案商
已发帖子: 61
是Tina哪个版本呢?
X3 wrote:
/files/members/3672/QQ图片20200413194300.jpg
#9 2020-04-18 02:00:11
grantho
和A33,R16的sdk啥区别?ddr配置?
